Old 31st August 2013, 01:24   #17841  |  Link
Ch3vr0n
that problem might have multiple reasons. Have you verified that your player even supports BD9? Just because you burn it onto a dvd9 doesn't make it a dvd as you've seen by the bdmv folder. What type of file should they be, well .bdmv files. That's a normal extension, BD's are not supposed to played back in file mode but only in disc mode. Another case might be that your player simply dislikes that crappy "maxell" brand. Does the original disc have a java menu (animated loading image), ifso your player perhaps supports BD9 but does not support bD9's that use java.
Old 31st August 2013, 02:59   #17842  |  Link
DavidJH
Failed video encode The Bourne Ultimatum
BD Rebuilder reported "Failed video encode" for a Movie-only copy of The Bourne Ultimatum.
The log file is shown below.
The odd thing is that I have uninstalled FFDSHOW and reinstalled the version linked from the instruction post. Yet the log output says it is not the recommended version.
It works for most other Blurays, so there seems to be something about the content. However, there's not much error detyail to go on.
Any ideas?
Thanks,
David.
[08-31-13] BD Rebuilder v0.44.14 (beta)
[02:47:21] Source: THE_BOURNE_ULTIMATUM_(2007)_00000
- Input BD size: 31.57 GB
- Approximate total content: [01:55:13.907]
- Target BD size: 19.53 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Quality: Highest (Very Slow), ABR
- Audio [2] set to default.
[02:47:24] PHASE ONE, Encoding
- [02:47:24] Processing: VID_00009 (1 of 1)
- [02:47:24] Extracting A/V streams [VID_00009]
- [02:53:54] Reencoding video [VID_00009]
- Rate/Length: 23.976fps, 165,768 frames
- Bitrate: 17,738 Kbs
- [02:53:54] Reencoding: VID_00009, Pass 1 of 1
- Encode failed. Aborting.
- BD-Rebuilder v0.44.14 (beta)
- HAALI Splitter: 1.11.96.14, Ok
- FFDSHOW: 4504, not recommended version
- FFDSHOW VC-1 set incorrectly: [0]
- FFDSHOW MPEG2 set incorrectly: [0]
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
[02:53:57] - Failed video encode, aborted
DavidJH is offline   Reply With Quote
Old 31st August 2013, 03:29   #17843  |  Link
HWK
HWK's Avatar
Any ideas?
Thanks,
David.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
Begin by uninstall of all helper applications and then reinstall and if it doesn't help remove bd-rebuilder copy and get new one.
Old 31st August 2013, 04:25   #17844  |  Link
VC-1 decoding is set incorrectly. Look at the instructions in the first post of this thread.
Old 31st August 2013, 08:09   #17845  |  Link
Lathe
Lathe's Avatar
'Use x264's internal LAVF for encoding'...
I've been reading through these posts a lot and I noticed a little while back that Mr. JDobbs stated where it seemed that he doesn't like this encoder.
I can't remember where I read this, but I read that this encoder helps with interlaced VC-1 encodes and SUPPOSEDLY utilizes your 64 bit 4 core system better. So I have it selected in the setup menu.
However, now that I just read here that he doesn't like it and I think I saw earlier on this thread that he said it DOESN'T run any faster, I'm confused as to how I should have it set. Also, OTHERS here seem to swear by it and ALWAYS use it. So I am REALLY confused now...
Also, I THINK I read that if you select to use that filter that it nullifies the MULTIPROCESS option where you can set it to '2' is it I think, where it chooses what is best.
Now I DON'T know what to do in how to set up the encoding for the fastest, most efficient way... Should I de-select the LAVF option and put the MULTIPROCESS=2 back in the config file?
I am runnings Windows 8-64, I have 4 processors, and 8 Gigs of RAM.
I really appreciate any clarification that you could give me as to which setting is best.
Thank you!
Old 31st August 2013, 11:01   #17846  |  Link
DavidJH
I checked FFDSHOW settings. Here is a screenshot showing that VC-1 is set to wmv9 as required. But BD Rebuilder is saying it is not set correctly.
Old 31st August 2013, 11:37   #17847  |  Link
DavidJH
Upgrading to BD Rebuilder 0.44.16 seems to have fixed the failed video encode.
However, the resultant 00000.mt2s file has a dark green screen from the start, or various colour shades if you playback from elsewhere. I have seen this issue before with other Bluray copies and had to resort to using the original mt2s file. The playback is either in VLC or with a Dune HD media player. I do not think it's an artifact of VLC.
Here is the log for the copy:
[08-31-13] BD Rebuilder v0.44.16 (beta)
[11:05:50] Source: THE_BOURNE_ULTIMATUM_(2007)_00000
[11:05:53] PHASE ONE, Encoding
- [11:05:53] Processing: VID_00009 (1 of 1)
- [11:05:53] Extracting A/V streams [VID_00009]
- [11:12:48] Reencoding video [VID_00009]
- Bitrate: 17,658 Kbs
- [11:12:48] Reencoding: VID_00009, Pass 1 of 1
- [11:31:23] Video Encode complete
- [11:31:23] Processing audio tracks
- Track 4353 (eng): Keeping original audio
- Track 4358 (eng): Keeping original audio
[11:31:23]PHASE ONE complete
[11:31:23]PHASE TWO - Rebuild Started
- [11:31:23] Rebuilding BD file Structure
[11:32:41] - Encode and Rebuild complete
- WORKFILES folder removed.
[11:32:41] JOB: THE_BOURNE_ULTIMATUM_(2007) finished.
Any ideas how to resolve the incorrect video?
Old 31st August 2013, 16:22   #17848  |  Link
worknstiff
RE: Any ideas how to resolve the incorrect video?
When you load the BD into BD_Rebuilder right click and preview the Vid 000's and see if they play in MPC Classic. If you have the right codecs and FFDshow configured correctly then it will play, if not then you need to uninstall all the helper apps, delete the BD_Rebuilder folder directory and reboot your pc. Maybe not necessary but I always run a temp files and registry cleaner like the excellent (FREE) CCleaner and then follow EXACTLY the instruction's for installing BD_Rebuilder from the first page of this thread. I have had to do this at least three times over the period I first started using this program. It probably seems like over kill for a program that was working before but BD_Rebuilder is a very complex prog and sometimes just needs to be refreshed when it does not work correctly. It is just too complex to trouble shoot each and every part, just nuke it and start over. Hope this helps.
Old 31st August 2013, 16:25   #17849  |  Link
Video Dude
Senior Member
jdobbs,
The author of tsMuxeR has recently posted on the forum about updating the program to add 3D support.
http://forum.doom9.org/showthread.php?t=168539
Perhaps you might be interested to contact the author to fix any bugs you may have found while working with tsMuxeR. It might help you in developing BD-RB.
Video Dude is offline   Reply With Quote
Old 1st September 2013, 08:08   #17850  |  Link
madipav
BD Rebuilder 0.44.16 beta & Nero Blu-Ray Player 12.0.17700
Something is wrong with the BD Rebuilder 0.44.16 because I open a Blu-ray format file with Nero Blu-Ray Player 12.0.17700 without problems and when I compress this file with BD Rebuilder 0.44.16 software it impossible to open it again with Nero Blu-Ray Player 12.0.17700.
I donít know why this happens, perhaps is missing something on the BD Rebuilder 0.44.16?
Somebody can also try it?
madipav is offline   Reply With Quote
Old 1st September 2013, 17:53   #17851  |  Link
Ch3vr0n
try a real player like PowerDVD or Arcsoft Totalmedia Theatre. Nero aint nothin but crappy bloatware
Old 1st September 2013, 21:22   #17852  |  Link
colinhunt
Originally Posted by Video Dude View Post
jdobbs,
Seconded. Quite a few issues I've discovered in BD-RB are caused by tsMuxeR.
Old 1st September 2013, 22:19   #17853  |  Link
AmigaFuture
AmigaFuture's Avatar
JDobbs does pretty well with getting around those challenges also. When we report them, do our best to make them repeatable and or he notices them. For tsMuxeR to evolve would probably ripple over to BD-RB.
@ Ch3vr0n
I noticed the different between transcoding and rerendering, that was a major point to me.
Old 2nd September 2013, 01:13   #17854  |  Link
yankeefan
sound off and scenes repeat
Has anyone had problems with the sound being off when you try to compress a movie? Had it happen to a few lately after many successful uses. The movie starts out fine then about quarter of the way the sound is off by a five seconds. And the last one a scene repeated, strange stuff.
yankeefan is offline   Reply With Quote
Old 2nd September 2013, 01:16   #17855  |  Link
Ch3vr0n
about that sound, bdrb doesn't change the sound volume. Check the original or your playback device. about that scene stuff, not a bdrb issue either. BDRB just recodes what's it being fed. That repeated scene is an indication of an improper decryption.
ooh and looks like the 3D support of tsmuxer is really getting into the dev stages now http://forum.doom9.org/showthread.php?t=168539
Old 2nd September 2013, 01:35   #17856  |  Link
yankeefan
With the sound being off the original is fine just after using bdrb the sound is delayed. Doesn't happen all the time. Happened on three movies around the same time.
I try again and see what happens I updated my decrypter.
Old 3rd September 2013, 17:05   #17857  |  Link
HomeDepot4
This has been happening to me, I posted earlier about Die Hard V.... The rip is fine, I have checked that with a media streamer...
HomeDepot4 is offline   Reply With Quote
Old 3rd September 2013, 19:12   #17858  |  Link
DoctorM
I was reading that adding "AUDIO_DIRECTSHOW=0" prevents ffdshow's mixer from changing the number of channels during recoding.
I don't see it by default in my .INI file. Is that now hardcoded into BD RB or does it still need to be added?
Is there a drawback to using that option?
Edit: And a quick question, what bitrate will be used for a mono source? Is it treated the same as stereo?
Old 3rd September 2013, 21:47   #17859  |  Link
??? Don't know where you got that.
BD-RB always turns off the mixer when it encodes audio -- and then sets it back to its original value afterward.
A mono audio channel defaults to 112Kbs when reencoding to AC-3.
Old 4th September 2013, 00:18   #17860  |  Link
DoctorM
I just did a search on this thread... thanks for the info.
I was hoping to turn the mono track to stereo by adding
audio=GetChannel(audio,1,1)
to the audio script while the video was encoding.
I assume BDRB checks the number of channels and picks the bitrates while preparing. In which case I'll get 112Kbs stereo... which wouldn't be good.
