18th September 2016, 21:06 | #39481 | Link | |
I am running Windows 10 Pro 1607 build 14393.187. Nvidia Titan X (pascal) with driver 372.70. Set present 16 frames in advance for windowed mode and uncheck Overlay, Fullscreen Exclusive, and DX11. Go fullscreen, maybe 1440p or higher is required?
madVR options explained Last edited by Asmodian; 18th September 2016 at 23:02. |
18th September 2016, 21:58 | #39483 | Link |
Hi guys, I own an htpc with a gtx 970.
This card can send HDR Metadata to my jvc x5000 projector? I've downloaded the masciola's hdr-10 test patterns and reproduced with latest madvr with hdr Metadata passthrough actived. In invidia panel I use UHD RGB at 12bit out. But to the projector (I verified with HD fury integral) do not arrive any hdr Metadata. Maybe my graphic card is not able to pass hdr Metadata?? Thank you Inviato dal mio SM-N9005 utilizzando Tapatalk |
18th September 2016, 23:05 | #39486 | Link | |
A standard API for passing HDR metadata out of Windows does not exist yet so madshi has not implemented anything in madVR yet.
madVR options explained |
19th September 2016, 01:02 | #39488 | Link |
I don't know if this is lav or madvr. When I watch mvc movie. My intel gpu hits 100 percent and I get glitching and worse my wireless hdmi cuts out. I had 100 percent gpu usage with normal movies and I changed to dxva in madvr and that fixed it. Is there Anything else I can do? Cpu usage is 30 percent or less.
19th September 2016, 08:59 | #39489 | Link | |
If yes then it's likely you are consuming too many resources and there is not enough left for the software/hardware to process/encode the wireless stream. From my experiences using Miracast doesn't come for free and there is some overheads with encoding and transmitting the stream. I have not tested MadVR and Miracast though at the same time. If you mean a specialist HDMI wireless device then you can ignore the above and something else strange is going on. |
19th September 2016, 11:41 | #39490 | Link | |
20th September 2016, 16:25 | #39494 | Link |
The GPU would have to output the metadata on HDMI 2.0a and madVR doesn't have the ability to tell it to do that. There is no standard API to tell it with. It isn't that the metadata is useless, it is that there is no way to transmit it from madVR to the GPU.
20th September 2016, 18:29 | #39496 | Link |
There is an issue with Madvr 0.90.24 using Potplayer x64 + D3D11 Exclusive mode + 60 Hz HDTV HDMI TV + Geforce 1080GTX 372.70 + Windows 10 x64 1607 1493.187 and might even before that, I'm not sure what can be the cause.
If I'm using 60 Hz going to full screen there is big black delay till I see anything ( the sound continues while it's black screen ) and then picture is shown. comparing going out of full screen is just instant. If I'm using 59 Hz going to full screen is quickly as going out and in and is instant . I tried disabling Full Exclusive mode in MadVR and it was fast. What could be the cause ? Drivers ? Windows ? MadVR Exclusive Mode ? |
20th September 2016, 18:39 | #39497 | Link | |
Yes, Nvidia has an API, I understand, but madshi doesn't like it and it wouldn't work on AMD or Intel cards anyway. There isn't a normal Windows API for it right now but Microsoft could probably implement something custom for Xbox One S HDR enabled games if they wanted to. Hopefully they will have a standard API by then instead.
madVR options explained Last edited by Asmodian; 20th September 2016 at 18:43. |
20th September 2016, 20:08 | #39498 | Link | |
20th September 2016, 23:33 | #39499 | Link | |
If its useful for HDR video playback in the future will have to be determined.
21st September 2016, 10:19 | #39500 | Link |
Hello,
I use MPCHC + MADVR for 1080p sources (BR) on a 1080p diffuser. The image decoding is achieved by LAV -> Nvidia Harwdare deocder. Whatever the settings in madvr, I can clearly see some aliasing on straight lines, for instance 20th Century logo at the beginning of movies. Even with all sharpening features disabled. Image doubling reduce partially the aliasing using the maximum NNEDI neurons (which is not affordable). Is this due to the hardware Nvidia Cuda decoding? I activated it for HEVC content, should I disable it for x264 content?
I7 2600K@4.4 / GTX1080 / ACER M550 (DLP 4K) / Catleap (IPS 1440p) / Onkyo SE200 Sound card |
