Old 9th February 2019, 15:52   #6701  |  Link
Barough
Barough's Avatar
MKVToolNix v31.0.0 is released.
https://mkvtoolnix.download/windows/releases/31.0.0/
Old 11th February 2019, 12:21   #6702  |  Link
taz742
AutoEncode bug with FDK-AAC [M4A]
Partially Bug related to this previous one https://forum.doom9.org/showthread.p...30#post1722030:
Using MeGUI 2908 with AutoEncode button.
Setting:
AudioInput: <filename>.aac
AudioOutput <filename>.m4a
Encoder: FDK-AAC
Extension M4A
Result:
AudioOutput: <filename>.mp4
This time there is no error while encoding audio, neither with final muxing.
It's just a typo error with audio Extension GUI choice not correctly saved when MeGUI generate cmdline job
BTW with the [Queue] audio button, extension choice is correctly passed to cmdline.
taz742 is offline   Reply With Quote
Old 11th February 2019, 13:00   #6703  |  Link
taz742
OneClick DGI Source Nvidia Crop&Resize not used
Using MeGUI 2908 with [OneClick]
[source]: MP4 1920x1080 AVC, AAC
[project]:
[Indexer]: DGDecNV with Audio Demux
[Avisynth]:
DGI Source
Auto Crop&Resize
Use Nvidia Crop&Resize if possible
Max Width: 960
[Video]: x264 [RAWAVC]
[Audio]: FDK-AAC [M4A]
[Muxing]: MP4
[OneClick] don't set the resize to use Nvidia core with DGI Source but set a standard resize using Spline64Resize.
Problem isn't present if I use [Avisynth script creator] then [AutoEncode]
Cheer
Old 12th February 2019, 02:44   #6704  |  Link
Lyle_JP
Unreasonable User
Lyle_JP's Avatar
There's definitely a problem with DGIndexNV 2053.0.165 (32-bit). Every blu-ray source has the bottom 8 pixels cropped off and the picture stretched to compensate.
I confirmed it with discs I had ripped before. By using the same avs script I had used months before, I can confirm that the crop no longer matches and the AR is indeed stretched.
Lyle_JP is offline   Reply With Quote
Old 12th February 2019, 10:55   #6705  |  Link
tebasuna51
tebasuna51's Avatar
There are a new version DGIndexNV 2053.0.167
Old 15th February 2019, 19:55   #6706  |  Link
pommesmatte
This issue is not fixed however with 167 or 168.
EDIT: Tested further. Cropping/Resizing seems to work now again, when using AVS cropping. When using "NVIDIA Crop & Resize" the resulting video has approx 2px black at top and 6px black at bottom.
pommesmatte is offline   Reply With Quote
Old 16th February 2019, 12:00   #6707  |  Link
Zathor
Originally Posted by Barough View Post
Thanks, updated
Old 21st February 2019, 19:25   #6708  |  Link
Zetti
FFmpeg v4.1.1 is released.
Old 24th February 2019, 14:32   #6709  |  Link
Zathor
Thanks, updated.
Also DGIndexNV which may fix the cropping issue.
Old 24th February 2019, 14:36   #6710  |  Link
Zetti
Old 3rd March 2019, 15:25   #6711  |  Link
hello_hello
Zather,
a couple of Bluray encoding issues....
When using Blu-ray as the target playback device, MeGUI won't allow a 720x480 video to be encoded as progressive, even with --fake-interlaced enabled. I tried enabling it via the GUI and adding it to the custom command line. It seems that it should be compliant though.
http://www.chaneru.com/Roku/HLS/X264...ake-interlaced
--[Information] [04/03/19 12:58:28 AM] resolution: 720x480
--[Information] [04/03/19 12:58:28 AM] frame rate: 30000/1001
--[Information] [04/03/19 12:58:28 AM] frames: 1213
--[Information] [04/03/19 12:58:28 AM] length: 00:00:40.474
--[Information] [04/03/19 12:58:28 AM] aspect ratio: 15:11 (1.364)
--[Information] [04/03/19 12:58:28 AM] color space: YV12
--[Information] [04/03/19 12:58:28 AM] target device selected: Blu-ray
--[Information] [04/03/19 12:58:28 AM] custom command line: --fake-interlaced
--[Information] [04/03/19 12:58:28 AM] changing --keyint to 30 as required for the selected device
--[Warning] [04/03/19 12:58:28 AM] the selected device does not support progressive encoding of 30000/1001 fps. changing interlaced mode to tff.
--[Information] [04/03/19 12:58:28 AM] Job command line: "C:\Program Files\MeGUI\tools\x264\x264.exe" --level 4.1 --bluray-compat --keyint 30 --open-gop --slices 4 --vbv-bufsize 30000 --vbv-maxrate 40000 --tff --colorprim smpte170m --transfer smpte170m --colormatrix smpte170m --sar 10:11 --frames 1213 --output "D:\sample 1.264" "D:\sample 1.avs"
--[Information] [04/03/19 12:58:28 AM] Process started
In order to bypass that, I added all the necessary Blu-ray stuff to the custom command line section instead (which worked and stopped MeGUI from forcing interlaced encoding), but I noticed adding --bluray-compat to the custom command line sets --weightp 2 in the GUI, and also adds it to the command line. MeGUI allows it to be changed back to 1, although I doubt it should be setting --weightp 2 in the first place
Cheers.
Old 3rd March 2019, 15:48   #6712  |  Link
sneaker_ger
--bluray-compat --weightp 2 is only a cosmetic issue because --bluray-compat enforces it to not be higher than 1.
Old 4th March 2019, 08:27   #6713  |  Link
hello_hello
sneaker_ger,
I didn't realise --weightp 2 is illegal for Bluray. At least adding it to the command line isn't breaking compliance.
Another possible issue (I'm not sure).
For a 720x480 video at 23.976fps, both these guides say --fake-interlaced is required along with --pulldown 32.
http://www.x264bluray.com/home/480p-ntsc
https://forum.doom9.org/showthread.php?t=154533
MeGUI adds --pulldown 32 when Bluray is selected as the target playback device, but not --fake-interlaced.
And a question....
My recollection was for Bluray encoding to be complaint, the encoder has to write a raw .264 stream and not write directly to MKV. I can't remember why, but is that correct, and if so, should it be something MeGUI enforces when Bluray is selected as the target device?
Cheers.
Old 5th March 2019, 18:41   #6714  |  Link
Shuichiyagami
Did Latest Megui Dev Server can read unicode now?
Well since i am doing project with star symbol in its name. When i use version 2828, i keep renaming or delete the symbol if i want to encode it
Shuichiyagami is offline   Reply With Quote
Old 9th March 2019, 10:59   #6715  |  Link
pommesmatte
Originally Posted by Zathor View Post
Thanks, updated.
Cropping is fixed, however the resize bug not.
https://forum.doom9.org/showthread.p...10#post1864410
NVIDIA Crop&Resize is still not usable.
EDIT: See next post for details, resizing bug seems fixed though.
Old 9th March 2019, 15:17   #6716  |  Link
pommesmatte
New/old cropping bug with MeGUI 2908 and DGIndex 169 with NVIDIA Crop
Details on the remaining bug with Nvidia Crop&Resize (DGindex version 169).
It seems that its a different bug again, no problem with resizing, but again a move in the cropped area.
I used cropping of 134 pix top and bottom (slightly undercropped on purpose, so you can see the black bars.)
Original stream shows approx 2px remaining black on top and bottom
Cropped with Avisynth shows the same 2px on top and bottom.
Cropped with Nvidia Crop the above black border doubles to approx 4px and the bottom one vanishes.
EDIT: The strange thing is: This only happens on some files, other are fine.
Old 9th March 2019, 16:20   #6717  |  Link
taz742
@pommesmatte: Is it possible to have a sample video source that causing your cropping issue?
Old 9th March 2019, 17:44   #6718  |  Link
tebasuna51
tebasuna51's Avatar
From DGDecodeNVManual.html
Important note: The nVidia driver is currently broken such that mod-2 cropping of the top and left sides is broken, and so the values of ct and cl must be mod-4. Right and bottom cropping may be mod-2. DGDecNV allows you to specify mod-2 values for top and left, however, looking forward to a fix from nVidia.
The problem is the top crop 134, it is not mod-4.
Old 9th March 2019, 18:11   #6719  |  Link
taz742
When you say "The nVidia driver is currently broken", you talk about the last relaese of it.
I use an old version of the Nvidia driver without this issue.
So the question is since which version the bug appear to know which old driver version is it safe to use ?
Old 9th March 2019, 18:16   #6720  |  Link
pommesmatte
Thanks for pointing that out! You are correct, with 132 or 136 top cropping, the problem does not occur.
