Old 9th October 2020, 08:07   #6921  |  Link
And time for another MP4Box update: GPAC fixed MPEG4-ASP multiplexing. So you can use it again as companion for the raw m4v output from xvid_encraw.
Old 9th October 2020, 15:49   #6922  |  Link
Morku
Originally Posted by kedautinh12 View Post
It's what I am already using (otherwise MeGUI wouldn't work at all). When you open avs with AVS Script Creator, the preview window just will turn black.
Morku is offline   Reply With Quote
Old 9th October 2020, 15:53   #6923  |  Link
MP4Box 1.1.0-DEV-rev80-g960b4cb87-ab-suite (GCC 10.2)
Old 13th October 2020, 17:04   #6924  |  Link
foobar2000
megui crashes under latest windows 10... works fine on wins 7
foobar2000 is offline   Reply With Quote
Old 13th October 2020, 17:38   #6925  |  Link
jlw_4049
I've been using MeGui on latest windows 10 for quite a while. Did you try to reinstall?
Sent from my SM-G986U1 using Tapatalk
Old 14th October 2020, 07:15   #6926  |  Link
Also, if possible, more details about the crash, please: Any dialogs appearing? Any stubs of log files left?
Old 16th October 2020, 05:10   #6927  |  Link
VideoFanatic
My x264 encodes with same settings keep outputting at different filesizes
I'm using MeGUI 2913 on Windows 10. I've got 2 1080p 30fps video clips which are the same format as each other. For some reason the "Raw" clip when encoded with a particular CRF setting multiple times will have a different output filesize each time but the other clip has the same output filesize each time. For the clip that has the problem here are some example results I get:
  • CRF 20 Slow: 91.4 MB, 96.5 MB, 103 MB
  • CRF 21 Slow: 103 MB, 91.4 MB, 49.4 MB
As you can see the above results make no sense. In some cases the CRF 21 output clip has a larger filesize than CRF 20. In another case the CRF 21 clip had 50% lower filesize than CRF 20 which also doesn't make sense.
I've also just done a CRF 20 and CRF 21 encoding of the "Raw" full length episode. Here's the result:
  • CRF 20: 5.68 GB, 6.4 Mbps
  • CRF 21: 8.05 GB, 9.14 Mbps
Again this is wrong as the CRF 21 has a much bigger filesize than the CRF 20 video when in fact it snould have a slightly lower filesize than the CRF 20 video.
I've downloaded the latest updates via the MeGUI program for x264 and everything else and I've switched to the development version.
For my test clip sources I find that it's easiest to replicate the problem by encoding the source clips to CRF 20 then encode the source clips to CRF 21. Then repeat until you have output files of a different size. I do my encodes in OneClick.
Source clips and log are here:
https://drive.google.com/drive/u/0/f..._aRcg9ihXVvaP6
VideoFanatic is offline   Reply With Quote
Old 29th November 2020, 09:30   #6928  |  Link
szabi
Hi
I use MeGUI v2924.
My input is an old avi (xvid) with mp3 audio stream.
When I start File Indexing at the end of index process MeGUI just close.
I did try both the ffms and l-smash but result is same.
However indexing can be finished if no audio is selected.
How could I figure out what cause this issue?
Regards
szabi
szabi is offline   Reply With Quote
Old 29th November 2020, 14:54   #6929  |  Link
StainlessS
StainlessS's Avatar
I never use MeGUI for anything other than pre-prepared AVS files (so have no idea about its file indexer),
but, cant you just use AviSource(), avi dont usually need any indexing, it has its own internal index.
Might be a good idea to follow Avisource() with RequestFramesLinear() as XVID can often have 8 seconds
between key frames. [use args to RequestFramesLinear() to provide cache for at least 8 seconds at input framerate].
EDIT: At least might be worth a try.
EDIT: This would convert to AVI lossless UT_Video codec, audio PCM uncompressed, and remove all of your problems
ConvToAVILossLess.Bat
setlocal
REM Where to Find ffmpeg
set FFMPEG="C:\BIN\ffmpeg.exe"
REM Where to get input file, No terminating Backslash, "." = current directory
set INDIR="."
REM Where to place output file, No terminating Backslash.
set OUTDIR="D:"
FOR %%A IN (*.wmv *.mpg *.avi *.flv *.mov *.mp4 *.m4v *.RAM *.RM *.mkv *.TS *.ogv *264 *.webm *.m2v *.VOB) DO (
  %FFMPEG% -i "%INDIR%\%%A" -vcodec utvideo -acodec pcm_s16le "%OUTDIR%\%%~nxA.AVI"
Pause
I usually convert all 8 bit [except VOB/MPG] video to AVI, saves messing around trying to get LSmash or ffmpegsource to work with awkward stuff
If you do the convert, you will not need RequestFramesLinear().
You need to set path to FFMPEG, and the in and out directories, will BATCH convert all of the container types shown in blue.
You can remove unwanted input container types, or add missing ones (so long as supported by ffmpeg), eg '*.asf' or '*.xvid' or '*.divx' [SPACE separated].
AVI is the output container type, ie Avi.
I sometimes post sober.
Old 29th November 2020, 16:43   #6930  |  Link
It might already help to re-multiplex such an AVI using AviMux-GUI.
Old 29th November 2020, 18:04   #6931  |  Link
StainlessS
StainlessS's Avatar
There was a (real old) version of XVID codec that would only decompress (properley) using exact same codec, cant remember the version number.
EDIT: Wrong version produced weird colors in places, quite often green and maybe magenta, IIRC.
EDIT: I had bad sample back about 2010, and faulty codec was old then.
Old 29th November 2020, 22:37   #6932  |  Link
Probably an Xvid version around v0.9x; there was a similar issue for DivX between up to version 5.02 and from version 5.03 on (different rounding direction).
But my reply was more inspired by the fact that indexing with the audio stream failed, so I guess the indexer may have an issue with the storage of the audio stream. Recreating an AVI container with different attributes, or remultiplexing it to MKV, may help the indexer handling the audio stream better.
Old 5th December 2020, 04:23   #6933  |  Link
kedautinh12
MP4Box-1.1.0-DEV-rev247-gdd4e62f9b
http://www.mediafire.com/file/opt84f...GCC102.7z/file
Old 5th December 2020, 07:42   #6934  |  Link
kedautinh12
FLAC v1.3.3
http://www.mediafire.com/file/p4ln8b...GCC910.7z/file
Old 7th December 2020, 09:30   #6935  |  Link
simple_simon
When using a prerendering job with 2passes in x264 is it possible to set it up to do the first pass with the prerendering job. That would reduce the number of passes from three to two.
simple_simon is offline   Reply With Quote
Old 7th December 2020, 09:38   #6936  |  Link
IIRC, "prerendering" means to create an intermediate lossless AVI because the AviSynth filters use so much computing time that filtering only once saves some remarkable amount of time. That will be a separate job because it does not use x264.
Old 7th December 2020, 19:49   #6937  |  Link
StainlessS
StainlessS's Avatar
The Batch bat in post #7010 will do similar to "prerendering", ie create lossless avi using UT_Video lossless codec and PCM audio,
but you use the result file instead of XVid avi file as source.
It does away with almost all of the nonsense related to source filter problems, and produces fast seeking frame accurate src.
Old 9th December 2020, 04:25   #6938  |  Link
kedautinh12
FDK-AAC v1.0.1
https://github.com/nu774/fdkaac/releases/tag/v1.0.1
https://www.mediafire.com/file/09lrx...GCC102.7z/file
Old 9th December 2020, 08:52   #6939  |  Link
I believe there was a restriction of binary releases regarding the license ... was that only related to distributing ffmpeg with fdk-aac?
Old 30th December 2020, 00:25   #6940  |  Link
kedautinh12
FLAC v1.3.3-Git-2020-12-17-bfd4f13
https://github.com/xiph/flac/releases/tag/1.3.3
https://www.mediafire.com/file/096zx...GCC102.7z/file
MP4Box (Working)
https://www.mediafire.com/file/nja3m...GCC102.7z/file
x264 0.161.3030_8bd6d28
https://www.mediafire.com/file/7dbc4...GCC102.7z/file
