Old 24th March 2020, 18:43   #14921  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by chompy View Post
...Is then an easy way to know the config used in the original DTS-HD 7.1 track to use it again in the new edited track?
Of course, with your sample (image 2) :
eac3to.exe sample.dtshd -logdts
+ DTS-Core
- frameSize 2012
- DTS-ES +
- channelNo 5
- lfe 1
- channelDescr 5.1
- samplingRate 48000
- bitDepth 24
- bitrate 1509000
- samplesPerFrame 512
- copyHistory 1
+ DTS-HD
- fullSize 116
- headerSize 32
- refClockCode 1/48000
- frameDurationCode 1
- activeMasks [1], [[1]]
+ Asset [0]
- fullSize 84
- headerSize 14
- corePackets Core
- extSubStrPackets XLL
- bitResolution 24
- maxSampleRate 48000
- totalNumChannels 8
- activeSpeakers C L R Ls Rs LFE Lsr Rsr ($4f)
DTS Master Audio, 7.1 (strange setup) channels, 24 bits, 48kHz
(core: DTS-ES, 5.1 channels, 1509kbps, 48kHz)
Other samples (image 1 and 3):
- activeSpeakers C L R Ls Rs LFE Lw Rw ($40f)
- activeSpeakers C L R LFE Lsr Rsr Lss Rss ($84b)
tebasuna51 is offline
Old 24th March 2020, 19:16   #14922  |  Link
chompy
Great, lots of thanks again!!
chompy is offline
Old 25th March 2020, 16:47   #14923  |  Link
DMD
DMD's Avatar
The Static, only one file without need *.dll's
Thank you
DMD is offline
Old 25th March 2020, 17:05   #14924  |  Link
DMD
DMD's Avatar
Good morning
I apologize for my question, as far as the EAC3 Encoder is concerned, bitrate values higher than 640 Kb / s are not expected?
Thank you
DMD is offline
Old 25th March 2020, 17:59   #14925  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by DMD View Post
Good morning
Surely that's a limitation (design flaw) in the GUI
(btw, could you please name it?).
Besides, just like .dca (DTS "coherent acoustics"), the .eac3 compression has no predefined set of "allowed bitrates".
filler56789 is offline
Old 25th March 2020, 20:27   #14926  |  Link
DMD
DMD's Avatar
I tried to force the settings, manually entering the value of 1509 kb/s.
The procedure started regularly with the set bit-rate value.
The only limitation that the maximum number of channels that can be managed is 6, the initial test track is 8ch (7.1).
I don't know how it is possible to manage 8 ch tracks.
DMD is offline
Old 25th March 2020, 20:41   #14927  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
I had a go this morning trying to generate an 8 channel EAC3 encode using an 8 channel PCM source. I also obtained a 6 channel EAC3 elementary stream.
SeeMoreDigital is offline
Old 25th March 2020, 21:22   #14928  |  Link
SeeMoreDigital
As a bit of an addition...
I also created a 6 channel EAC3 encode at 1536 Kbps using one of my DTS audio CD's as a source. And I have to say that the playback results are very good indeed.
Old 25th March 2020, 22:41   #14929  |  Link
tebasuna51
tebasuna51's Avatar
The GUI is UsEac3to, and yes is a GUI limit, I can't understand for what we can need more than 640 Kb/s for lossy 5.1
Old 26th March 2020, 08:35   #14930  |  Link
DMD
DMD's Avatar
If it were possible to manage 8 channels, it would be fantastic.
DMD is offline
Old 26th March 2020, 09:32   #14931  |  Link
The reason why ffmpeg won't encode E-AC3 with >6 channels is not really obvious to me. And I am obviously wrong with my guessed reason...
LigH is offline
Old 26th March 2020, 10:40   #14932  |  Link
Noone has spent time making it, and noone seems interested in doing so unless someone is willing to pay for it?
Thats as logical a reason as for anything. People usually work on one of two things: Stuff they have a personal interest for, or stuff other people pay them for.
nevcairiel is offline
Old 26th March 2020, 11:00   #14933  |  Link
tebasuna51
tebasuna51's Avatar
In my opinion 7.1 don't offer a better 2D surround than 5.1, I think is a commercial placebo, then for me is ok the ffmpeg behaviour.
Other question is Atmos 3D surround.
Old 24th April 2020, 17:07   #14934  |  Link
justnobody
ffmpeg will not support eac3 7.1 encode, just forget it and go
my question: is it possible to cut the end of the file using eac3to? like cut 10s, we can cut the beginning with simple -10000ms but..
anyway for cutting like this ffmpeg is pretty handy, eac3to doesn't come with this function i guess
justnobody is offline
Old 25th April 2020, 10:42   #14935  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Not sure for eac3to, but I use mkvtoolnix to losslessly cut any audio file. Just mux it to MKA, and use the Split After specific timestamps feature (in the Output tab) to split it where you want. Then, you can extract the part you need from the MKA segment with gMKVExtractGUI.
r0lZ
r0lZ is offline
Old 25th April 2020, 11:48   #14936  |  Link
stax76
stax76's Avatar
Except the FLAC format.
stax76 is offline
Old 25th April 2020, 12:05   #14937  |  Link
sneaker_ger
I think only if you specify the length with -edit. E.g. if the file is 1h30m long and you want to cut the last 10 seconds:
eac3to "input.eac3" "output.eac3" "-edit=1:29:50,-10000ms"
(Or maybe make the "-10000" to e.g. "-11000ms" to have some reserve for rounding/alignments.)
sneaker_ger is offline
Old 25th April 2020, 12:28   #14938  |  Link
tebasuna51
tebasuna51's Avatar
If you know the movie length, for instance 1:50:40.000 you can cut the 10 last seconds with:
-edit=1:50:30.000,-10000ms
EDIT: to slow to make the test
Old 25th April 2020, 15:45   #14939  |  Link
richardpl
It will, just pay.
richardpl is offline
Old 25th April 2020, 23:32   #14940  |  Link
filler56789
SuperVirus
Originally Posted by richardpl View Post
It will, just pay.
People will pay IF:
1) the price of the new encoder is lower than the price of the "official"/certified encoders
2) the price of the new encoder is declared publicly;
I mean, no "send me an email and I'll tell you how much it will cost",
alright
eac3to
