Old 18th January 2020, 04:01   #29201  |  Link
Originally Posted by LowDead View Post
This is the same file. Used Mediainfo 19.04 (and latest version 19.09) to check it. And I don't have IMPORT_VFR_SCAN at all in my INI.
//LD
Does it report differently if you use the version of MEDIAINFO that is included in BD-RB's tools folder?
Old 18th January 2020, 04:49   #29202  |  Link
LowDead
This is what I get with the included mediainfo (changed filename for ease of use):
General
Unique ID                                : 0 (0x0)
Complete name                            : 1.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 2.06 GiB
Duration                                 : 33 min 16 s
Overall bit rate                         : 8 846 kb/s
Encoded date                             : UTC 2010-02-22 21:41:29
Writing application                      : no_variable_data
Writing library                          : no_variable_data
Video
Format                                   : AVC
Format profile                           : Main@L4
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate                                 : 8 286 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 25.000 FPS
Scan type                                : Interlaced
Scan type, store method                  : Separated fields
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.160
Stream size                              : 1.93 GiB (94%)
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Codec ID                                 : A_AC3
Bit rate                                 : 384 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 16 bits
Stream size                              : 91.4 MiB (4%)
Service kind                             : Complete Main
Old 19th January 2020, 22:59   #29203  |  Link
cartman0208
Jdobbs: I was wondering ... do you plan on implementing GPU encoding in the future?
I was able to do some testing recently with my new graphics card and the results look awesome.
Additionally the encoding time on a UHD 2hr movie decreased from 30 hours to 40 minutes
Old 20th January 2020, 01:47   #29204  |  Link
zamengo
Encoding with cuda cores have a issues, the final result is a 2176p file, not 2160p.
zamengo is offline   Reply With Quote
Old 20th January 2020, 14:42   #29205  |  Link
Really? That's disappointing. I was actually thinking about (eventually) buying an NVIDIA card in the Turing family (for B-Frame support) and doing some testing.
Good to know.
Old 20th January 2020, 15:22   #29206  |  Link
Ch3vr0n
@jdobbs Thats because it's obsolete. CUDA has been replaced by NVEnc https://avidemux.org/smif/index.php?topic=16389.0, https://steamcommunity.com/app/33007...4045360096302/, https://en.wikipedia.org/wiki/Nvidia_NVENC
Old 20th January 2020, 15:49   #29207  |  Link
Originally Posted by Ch3vr0n View Post
NVENC is what I was taking about... so the issue he mentioned isn't related to NVENC? I guess I didn't understand that CUDA and NVENC were mutually exclusive.
If I understand it correctly, in FFMPEG NVENC and NVDEC are still called CUDA, but, honestly, I have spend a whole lot of time researching it. My (still unresearched) plan was to use FFMPEG for NVENC encoding.
Old 20th January 2020, 16:41   #29208  |  Link
videoh
Useful n00b
CUDA refers to the GPU multiprocessors (cores) and the infrastructure to utilize them. NVDec (previously called CUVID) and NVEnc are separate engines on the GPU that implement video decoding and encoding, respectively. CUDA is certainly not obsolete. And CUVID was not replaced, merely renamed.
Old 20th January 2020, 18:04   #29209  |  Link
Thanks for the clarification.
Old 20th January 2020, 20:11   #29210  |  Link
MrVideo
MrVideo's Avatar
References?
Old 20th January 2020, 21:11   #29211  |  Link
prologic
References?
I have done around 70% of all 4k uhd releases , using cuda ..
And everyone , still the same
3840 x 2160 pixels..
It takes around 15mins on my geforce gtx 1070 card , to make then fit on a BD50 ..I also use BD Rebuilder , to Alter the build of the disc as well , resulting in resizing a lot less .
prologic is offline   Reply With Quote
Old 20th January 2020, 23:41   #29212  |  Link
Sharc
…. My (still unresearched) plan was to use FFMPEG for NVENC encoding.
You may also want to take a look at rigaya's NVEncC. It is continually developed and well documented.
https://github.com/rigaya/NVEnc/releases
https://github.com/rigaya/NVEnc/blob..._Options.en.md
Old 21st January 2020, 01:38   #29213  |  Link
Thanks! This looks great.
Old 21st January 2020, 03:19   #29214  |  Link
MrVideo
MrVideo's Avatar
What program?
Old 21st January 2020, 03:51   #29215  |  Link
zamengo
References?
https://devtalk.nvidia.com/default/t...-of-3840x2176/
Old 21st January 2020, 07:32   #29216  |  Link
prologic
What program?
I use DVDFAB
Old 21st January 2020, 12:24   #29217  |  Link
zamengo
I use DVDFAB
Open playlist on tsmuxer, you will figure out 2176p.
This is incompatible with Xbox One S and X player.
Old 21st January 2020, 15:17   #29218  |  Link
MrVideo
MrVideo's Avatar
Based on the reference, it looks like 2176 is it, period. The hardware is only 32x32. Sounds like Xbox needs to get it right. It is the same issue with 1080. It is encoded to 1088 (16x16) and set to display at 1080.
Old 21st January 2020, 19:34   #29219  |  Link
LowDead
Yes, tsmuxer reports 2176p, but mediainfo says 2160p... after reading the discussion at nvidia I would trust tsmuxer. BUT it's an old discussion and in the end they say the Turing (for those who don't know: GTX1660, 2060, 2070, 2080 etc...) cards have HW capabilities of 8x8 and 16x16. So off to buy a new gfx card then
Anyway, even though an dvdfab encode have 2176p, I believe they have gotten around the problem with green screen on the XB and also works flawlessly for most others. So what I'm saying, not to get too much OT, is that jdobbs can also fix these problems when/if they occur with bdrb.
//LD
Old 21st January 2020, 19:37   #29220  |  Link
cartman0208
I did my testing with Staxrip, which makes use of NVEncC.
