Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 30th November 2019, 15:39   #201  |  Link
videoh
Useful n00b
@redbtn
Don't be sorry, I'm grateful for your testing and reports.
DGDemux already suppresses filler NALUs. It just has to be retrofitted to DGIndexNV. I will do that today.
Old 30th November 2019, 23:18   #202  |  Link
redbtn
redbtn's Avatar
The sound is very loud. I was a little scared.
I'd like to have checkbox to switch it off.
redbtn is offline   Reply With Quote
Old 1st December 2019, 00:54   #203  |  Link
videoh
Useful n00b
Ha ha, you're the guy that asked for something more than '100'. You must really hate DVD Decrypter. And I was thinking of making it louder!
Old 1st December 2019, 02:11   #204  |  Link
redbtn
redbtn's Avatar
Yeah, it's me. But I asked something else, not sound)) Message like done/completed/finished. I never used DVD Decrypter.
Old 1st December 2019, 02:14   #205  |  Link
videoh
Useful n00b
Doesn't eac3to also make horrid noises? DG aims to wake the dead!
Don't run DVD Decrypter without your cocoa and safe space.
BTW, all images and sounds used are in the public domain, courtesy of the US Government and
the BBC. Thanks guys!
Wouldn't you like an app with an intelligent agent talking to you and guiding you? Minimally, it could harangue you periodically. I'm thinking Natasha Fatale for the voice. You like?
Old 1st December 2019, 02:42   #206  |  Link
redbtn
redbtn's Avatar
I'd like to have intelligent agent which can do all work, listening my commands, like "Jarvis", haha)
Eac3to doesn't make any sounds.
Old 1st December 2019, 02:59   #207  |  Link
videoh
Useful n00b
No joke, I've already started coding it.
Sure it does. Did you check your earwax lately?
But most important, do you think Natasha would be a good choice?
Old 1st December 2019, 10:26   #208  |  Link
jpsdr
But in DVDDecrypter, you can disable the sounds...
My github.
Old 1st December 2019, 10:28   #209  |  Link
tebasuna51
tebasuna51's Avatar
...Eac3to doesn't make any sounds.
Only if you replace error.wav and success.wav for silent ones (like me).
Old 1st December 2019, 11:40   #210  |  Link
von Suppé
von Suppé's Avatar
First time I heard the sound in DGDemux now, scared the cr*p out of me
@videoh,
In case of Dolby Atmos or DTS:X, can you add the choice to extract "2D" audio only?
Old 1st December 2019, 12:14   #211  |  Link
redbtn
redbtn's Avatar
@tebasuna51 I just deleted them)
@videoh Yeah, Natasha is good voice. Her English accent like mine, haha))
Old 1st December 2019, 12:55   #212  |  Link
videoh
Useful n00b
OK, good info, guys. I can make the wav external and if you don't like sound just rename it or delete it.
Don't know what Atmos '2D' is but can look into it.
Old 1st December 2019, 13:33   #213  |  Link
redbtn
redbtn's Avatar
Awesome, Thank you!
Old 1st December 2019, 15:56   #214  |  Link
videoh
Useful n00b
Mission accomplished!
Old 1st December 2019, 17:42   #215  |  Link
gonca
Which mission, scaring the cr*p out of von Suppe?
Old 1st December 2019, 18:04   #216  |  Link
videoh
Useful n00b
Fer sure!
Old 2nd December 2019, 16:11   #217  |  Link
videoh
Useful n00b
Version 1.0.0.9 is now available:
http://rationalqm.us/board/viewtopic...p=10383#p10383
Old 2nd December 2019, 22:04   #218  |  Link
redbtn
redbtn's Avatar
@redbtn
I'll have a look at that 10ms thing.
Did you looked at this already?
Old 2nd December 2019, 23:33   #219  |  Link
videoh
Useful n00b
I don't remember you linking me a disk to try to duplicate it. But really, 10ms?
Old 2nd December 2019, 23:53   #220  |  Link
redbtn
redbtn's Avatar
It was 160ms for DTS (Iron man 2), after you did DTS processing it becomes 10ms (1 extra DTS frame). DGDemux should be perfect, isn't it?
It happens at 1.54.35, where the last m2ts starts
