23rd May 2020, 19:51 | #201 | Link | |
Pig on the wing
I owe you one good pörkölt
23rd May 2020, 20:28 | #203 | Link | |
Secondly You can agree with FranceBB but you don't know what happened with his environment, nor do we know, but we'll solve it, maybe it was a mis-compiled version as I have written my example. We can solve his problem with a much larger possibility that issues like why does not work properly and old tool which was tested and used when probably not even Avisynth 2.6 was final-released with plugins which I have to chase all around then finally download from Internet-wayback machine. |
23rd May 2020, 21:55 | #204 | Link | ||
Pig on the wing
With max at 10000, the usage is almost 9300 MB with SetCacheMode(1). I haven't done any real-life tests with encoding yet so I don't know what the optimal prefetch value is.
24th May 2020, 08:13 | #205 | Link | |
Acid fr0g
AFAIK the most used bit depths nowadays are 8 and 10 (12 on some specialized streams only). How does it work when you set HBD or a plugin receives a HBD? Doest it switch to 16 bits (or more) regardless of true bit depth or does it work with the same bit depth of the source? Because if it goes straight to 16 bit to work on a 10 bit stream, it seems to me really a waste of power and it would need a dedicated algorithm to process 10 bit only, as they are the second most common after 8, and get faster.
@turment on Telegram |
24th May 2020, 08:20 | #206 | Link |
Acid fr0g
What is a good ratio to determine the number of frames to be prefetched? Now I am using Prefetch(6) because I am GPU memory bound. What effect has the frame parameter? Is it a sort of caching or what? Would set Prefetch (1,6) has the same effects on speed?
24th May 2020, 08:32 | #207 | Link |
For internal calculations the bits used are usually more than that, 16-32 bits (15-16 bit is used even for most 8 bit filters) Only very simple filters, where no precise calculation happens, keep the bit depth internally (e.g. mt_binarize). Imagine, when you multiply two 8 bit data you'll have 16 bit result.
Processing 10 bits can be faster that 16 bits however, in mvtools I had differently optimized - quicker - SAD routines for 10 bits because summing up sixteen 10 bit numbers still fit in a 16bit register, while summing up 16bit numbers require 32 bit processing already. But such optimization specialization is tricky, increases internal complexity and in general it is the very last step when developer have inifinite free time and cannot do other meaningful stuff Plus: as it requires extra programming resources it has to be done when it has real benefits and the task to optimize is the bottleneck in a process. |
24th May 2020, 08:36 | #208 | Link |
Acid fr0g
I asked because I was planning to always use SMDegrain in HBD precision and then go back to 8 or 10 bit but sometimes the overhead is just too much to be of any use. Is there any optimization I could apply?
24th May 2020, 08:38 | #209 | Link | |
But since we do not have knowledge base on the real value of this parameter, always share your findings. |
24th May 2020, 14:54 | #215 | Link |
Pig on the wing
The new cache mode has quite an impact at least in my case where I have that MVTools stuff + downscaling in linear light and debanding with neo_f3kdb. I tested with AVSMeter with an insanely high SetMemoryMax(16384) to make sure cache size will not restrict anything. The default cache mode ran at 9.495 fps and SetCacheMode(1) at 12.36 fps. Memory usage was almost the same, both around 11000 MB.
I'll continue testing to see if lowering the prefetch value from 24 makes any difference.
24th May 2020, 16:41 | #216 | Link |
Pig on the wing
Some tests of x265 encodes with different prefetch values and the abovementioned script structure:
threads=24, frames default 2.53 fps threads=24, frames 12 2.57 fps threads=24, frames 24 2.51 fps threads=24, frames 8 2.56 fps threads=24, frames 10 2.57 fps threads=24, frames 16 2.55 fps threads=22, frames 16 2.55 fps threads=20, frames 12 2.58 fps threads=16, frames 12 2.57 fps threads=12, frames 12 2.55 fps It's quite easy to see that most of the time is spent inside x265 instead of frameserving. At least in my case, lowering the amount of frames was slightly beneficial.
24th May 2020, 16:52 | #217 | Link |
In the staxrip tracker the most active power user posted when avisynth 3.5 is installed staxrip produces errors, it's fine if avisynth is not installed because then staxrip uses the included portable version 3.6 and it's also fine if 3.6 is installed. I had to explain this, maybe some devs can give some advice, my answer:
I changed it to don't allow old versions like currently done for Visual C++ 2019, it shows: The currently used version of is not compatible (too old). And it doesn't allow to edit the version except editing Versions.txt directly instead of using the GUI to do it. Ideally it should not allow defining a custom path in this case but I'm not sure it's worth the trouble writing this code. Here is the situation: Most tools like StaxRip.exe or avs2pipemod.exe just load AviSynth with code like this: LoadLibrary("AviSynth.dll") This is however not a full path and what now is happening is the OS will search this DLL, for that it uses a strict order, first it will search it in the startup folder so next to staxrip.exe or next to avs2pipemod.exe or whatever tool is loading the avs file. Next it searches in the system folder, which is where avisynth is installed. I have tried to create soft links for avisynth.dll next to staxrip.exe but this did not work for unknown reason and then I gave up. One issue was if avisynth is not installed then ffmpeg does not work because it does not use default DLL loading which searches in the path env var which staxrip sets. To fix that a soft link is working, qyot27 and stainless did help me to make this work. In staxrip I could use a full path to load avisynth.dll and avs2pipemod has an option for that too, for the other tools an option could be requested, I can image some authors like rigaya would help, for some tools a mod could be created but for some tools it would be very difficult like ffmpeg. Maybe it's not worth the trouble and just leave it as is, it's many avs tools like 10. For vapoursynth it's working that a user can decide via setting if portable or installed version should be used, it can be defined in the settings dialog of staxrip and it worked for all tools I have tested, staxrip, ffmpeg, vspipe, mpv.net, only problem was mpc-be, not particular important since mpv.net is the primary player in staxrip and it supports portable mode for avisynth and vapoursynth. I have reported it and volt has a new avs vpy source filter in development which is awesome. Maybe somebody can try nvenc and qsvenc for which I don't have hardware or driver.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 24th May 2020 at 17:07. |
24th May 2020, 17:00 | #218 | Link | ||
Broadcast Encoder
Or is it the AviSynth+_3.6.0_i686-xp-nosimd uploaded by qyot27? Well I'm not sure what happened with my environment either, but thank you for being confident that you can solve the issue. I really appreciate that. |
24th May 2020, 19:27 | #219 | Link | |
The problem is that several older AVSI scripts in my plugins folder rely on MaskTools2, and just replacing Maskools with the latest High Bit Depth versions will not work. A while ago I asked Real.Finder explicitly if I could use his latest Srestore version with an older version of MaskTools2, and his answer was NO. I guess the same is true for QTGMC or LFSMod or FineSharp. I do not need and do not want Hi Bit Depth or Hi Color, so I will stay away from such plugins. I installed AVS+ solely in the hope for better speed from multitasking, everything else has no relevance for me. And if AVS+ 3.6 now gives me issues using older AVS 2.5 plugins then I will stop using it. Cheers manolito |
25th May 2020, 05:31 | #220 | Link | |
I checked it, and AvsMeter recognizes mt_masktools-2.6.dll a CPP2.5 DLL, probably because it is using the non-final AVS 2.6 header file, which has AVISYNTH_INTERFACE_VERSION = 5 instead of 6. So this is a pre-2.6 DLL. EDIT: even if it used a pre-avs 2.6 DLL, the plugin doesn't have AvisynthPluginInit3, only AvisynthPluginInit2 EDIT: test-test-test Retro masktools 2.0.48 as an Avisynth 2.6 dll. https://drive.google.com/open?id=1xP...bT0JkffmEUQA67 Do _NOT_ mix it with masktools2! Last edited by pinterf; 25th May 2020 at 11:38. |
