28th December 2009, 00:50 | #6401 | Link |
HD-Fan
RipBot264 on Wine hangs!
I am able to run it in Wine and do everything but when I try to load in an AVI file, it will not do what I asked. It will just stay like nothing happened. What else do I need to loading the sources? I also don't see any error messages. |
28th December 2009, 01:11 | #6402 | Link | |
28th December 2009, 02:13 | #6403 | Link |
hi Atak_Snajpera,
I looked into your sugestion to use Makemkv to create a mkv with the original full blu-ray video stream. I dont know if this is ment to happen, but it seems to just load the vc1 video in a mkv which is not compatible with windows media center and xboxs & also doesnt remove the black bands at the top and bottom. I would prefer to keep using Ripbot ;-) But could you tell me if there is a way to keep the original bitrate, but just crop the back bands? Thanks in advance |
28th December 2009, 06:35 | #6404 | Link | |
HD-Fan
Too bad something needs to be done to get it work properly. I will also try to search for it and will provide the answer here (if I found it). |
28th December 2009, 20:05 | #6406 | Link |
I've tried every program (AltMKV, Staxrip, MeGui, you name it). I like the simplicity of RipBot but what I really like is that I can rip my DVDs that have DTS audio to MP4. It appears BeSweet (which Staxrip uses) doesn't support DTS so you have to transcode the DTS soundtrack using another program. RipBot does it!
However there is one thing holding me back from making this my #1 program. I rip music video DVD's where the DVDs are ripped into chapter VOBs so you can build playlists of music videos from different artists. A typical music video DVD may have 15-20 chapters. With Staxrip, I can just add the entire folder of VOBs, specify settings and go. With RipBot I have to individually add each vob, change the crop and deinterlace settings (it doesn't save those from the previous job for some reason) which is WAY time consuming. Keep up the good work. If you have add the ability to add several VOBs at once, it will be a killer program! |
28th December 2009, 20:33 | #6407 | Link | |
Haali Media Splitter
Has anyone started using the latest version of Haali Media Splitter?
http://www.videohelp.com/tools/Haali_Media_Splitter Quote:
28th December 2009, 23:13 | #6408 | Link | |
Too many have said to stay away from this version... I have no personal experience but this is common knowledge around the forums..
29th December 2009, 05:43 | #6410 | Link |
Thanks for the info about Haali update. I will install it because I'm not encoding right at the moment.
There's probably no benefit for people who encoding 24/7 to risk an update because the x264 is where the speed comes in. I don't see a new version of Haali have any real performance gains but i could be mistaken though. eac3to updated today 12/28 |
29th December 2009, 15:15 | #6411 | Link | |
29th December 2009, 16:46 | #6413 | Link |
Hello @Atak_Snajpera
it been a while. I just try ripbot with a movie that contains 2 ausio track : Jap, and french. ripbot is not able to detect the audio track. (NO AUDIO). it works fine in Media Player. I try with all ripbot 1.14.0 and 1.14.6 same problem. Here the log from MediaInfo Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 9 frames Muxing mode : Container profile=Unknown@4.1 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 40mn Bit rate : 4 332 Kbps Nominal bit rate : 4 701 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.196 Writing library : x264 core 80 r1373 4322f63 Encoding settings : cabac=1 / ref=9 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=8 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=70 / rc=2pass / mbtree=1 / bitrate=4701 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=1:0.60 Language : Japanese Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Format profile : ES Codec ID : A_DTS Duration : 1h 40mn Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Resolution : 24 bits Language : French Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Format profile : ES Codec ID : A_DTS Duration : 1h 40mn Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 7 channels Channel positions : Front: L C R, Rear: L C R, LFE Sampling rate : 48.0 KHz Resolution : 24 bits Language : Japanese Text #1 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : French Forced Language : French Text #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : French Language : French |
29th December 2009, 17:47 | #6414 | Link |
send me 50 mb sample to www.mediafire.com. use DGsplit
29th December 2009, 22:40 | #6419 | Link | |
But ... for cartoons is a different story, these are dubbed, for kids who cannot read the subtitles. Here are DVDs and Blu-Ray with cartoons with original english and dubbed romanian audio, and I want to keep both audio in mkv or mp4. The kids who don't understand the english language, and cannot read, need dubbed audio, at cartoons. Last edited by Mihai_; 29th December 2009 at 22:42. |
30th December 2009, 06:40 | #6420 | Link | |
(Assuming an .mkv container): 1. Find your RipBot temp folder and the appropriate job folder. 2. Locate the additional audio file you want to include, taking note of the filepath and filename. 3. In that same job folder, find the [YourJobNumber]_MuxFiles.cmd and edit it with notepad. 4. Based on the information you see for the other audio file, you can put in the appropriate commands to include this second audio file as well. Read up on available commands in mkvmerge here. 5. Save your edited .cmd file. *Note: Be sure to triple-check your typed commands, as any mistakes mean that mkvmerge will not be able to properly mux your file. If you have a queue, your encoded video file will be overwritten by the next in the queue. Obviously, with no muxed mkv file and an overwritten video stream, you will need to re-encode the video again. This has happened to me twice on 40 hour encodes. I regularly add additional audio streams, and also edit this to include default languages for the video and track names for the video and audio. Works like a charm everytime. Hope this helps! --radigast |
