8th October 2019, 17:31 | #17401 | Link |
Feature request: I have a 4-server distributed rendering setup. I notice that when a job is near the end, two of my machines remain idle (having completed their assigned work) while the last two (or one) complete their render pieces. In order to avoid servers being idle for periods of time like this, could we have the next job start while servers in the farm are still completing the last chunks of the previous job, so that no servers are idle at any time?
Cheers Dhry |
8th October 2019, 17:48 | #17402 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 8th October 2019 at 17:58. |
8th October 2019, 21:45 | #17404 | Link | |
ByteShare
Or, have a 2nd application on each computer encoding a low priority video. The feature was something I thought I wanted a while ago but with faster computers now I'm only seeing one to a few min. of lost time which only would add up if I was doing this for years and profit. |
8th October 2019, 21:51 | #17405 | Link |
Variable priority makes only sense If you run multiple encoding servers on single pc. (For example to get 100% CPU usage)
8th October 2019, 22:39 | #17406 | Link | |
ByteShare
I stopped using it because using only 2 chunks didn't give me a good way to "pause" encodes. I usually stop 1 or more servers to either lower usage or "pause" an encode. Last edited by byteshare; 8th October 2019 at 22:43. |
9th October 2019, 01:34 | #17407 | Link | |
Grumpy Old Man.
I to have a multi pc server farm, and I get very frustrated at the wasted resources between encodes...if you are encoding a 4K movie, when it gets to the muxing stage, ONLY 1 pc is working on that, ALL the other's a twiddling their thumbs, for an extended period, could be 20 - 30 minutes !!! So over several movies in a queue, that's hour's wasted !!! Just because you don't have a set up like this, you think it's a waste of time.
9th October 2019, 01:49 | #17408 | Link | ||
Grumpy Old Man.
And what about us users that have AMD GPU's ??? And here's another feature request.. How about displaying the Core version on the main gui page, so it's there for everyone to see, instead of looking for it. And another suggestion (that has been asked for before), wouldn't it be beneficial to change the build number by a .1 for EVERY auto update, that too would help keep track of build's/version's. And while I'm at it, a changelog would be good, too.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 9th October 2019 at 05:05. |
9th October 2019, 10:27 | #17409 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th October 2019 at 10:31. |
9th October 2019, 11:29 | #17410 | Link | |
Grumpy Old Man.
10Gb for a 4K movie !!, more like 60 - 80Gb !! Admittedly I'm not using SSD's, only 7200rpm spinners.
9th October 2019, 13:40 | #17411 | Link |
OMG, I'm sorry for not reading your mind correctly! Unfortunately my crystal ball is currently under inspection. Maybe it is time to buy some crappy sata3 ssd just for muxing? Assuming that copying speed on sata3 ssd is around 0.25GiB/s ,your big ass 80 GiB file would be muxed in ~5 minutes. Furthermore on decent NVMe SSD this would be reduced to ~1 minute.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th October 2019 at 13:45. |
9th October 2019, 13:56 | #17412 | Link | |
Grumpy Old Man.
I will dig out a "crappy ssd", and try a "big ass 80Gb" encode, with the latest build of RB, and see just how long it does take....
9th October 2019, 13:59 | #17413 | Link | |
9th October 2019, 15:06 | #17414 | Link |
I'm having two issues with my latest set of encodes. The source, according to MediaInfo, has a 1s audio delay relative to the video. This delay is not being copied over, causing the audio to be slightly ahead of the video track. Is there a way for the timing to be picked up automatically by RipBot?
I've tried using the DelayAudio option in the AVS script, but that didn't seem to work, and I would ideally like to not have to do anything custom because I have over a hundred videos to do with the same issue. The second issue is that the aspect ratio on the encoded video is incorrect. The source videos are 1440x1080 with a 4:3 DAR. For some reason, the encoded videos are being given a DAR of 16:9. I'm not using any custom scripts or anything that would change this, and I can't figure out why it's not just using the source DAR. For this, I've tried using --sar 4:3 in the encoding settings, but the DAR is still 16:9 in the resulting video. I've also tried using a custom resize option, setting it to 1440 width with a 1.33:1 ratio. Any help would be greatly appreciated. |
9th October 2019, 15:25 | #17416 | Link | |
9th October 2019, 15:40 | #17417 | Link | |
In any case, that's one issue solved. Any suggestions for the audio sync issue by chance? |
9th October 2019, 15:54 | #17418 | Link |
Do you re-encode audio or just remux? How many audio sources does your file have?
9th October 2019, 16:13 | #17419 | Link |
Just remuxed, and just one audio source. I did figure out how to fix it for my one test video, but it involved a manual edit for the audio delay. That would normally be a good enough solution, but I have more than a hundred videos, and if the delay isn't the same on all of them, I'll have to go through each one individually to fix them unless I can figure out a way to have it read that delay by default.
9th October 2019, 16:19 | #17420 | Link |
Is delay always 1000ms?
