21st June 2017, 01:10 | #26061 | Link |
I suppose keeping the full menu structure isn't absolutely necessary. Normally, in most cases I just use BDRB and import the segments and use it's own menu. It's just that in this case, there are quite a few Xtras, so it would be CONVENIENT to be able to keep the menu structure if possible. I know JD is rolling his eyes right about now saying, 'Just compress the whole disc already!'
That's probably what I will do. Just would have been interesting to figure out how to do it. |
21st June 2017, 02:23 | #26063 | Link | |
You already suggested that I think in your first post, but I mentioned in reply that I don't understand how to 'adjust the CRF for the extras' If you can explain to me how to do that, that would be great, thanks! *** EDIT Wait! YES, actually, sorry, I DO remember now how to do that. I set the ini for is it 'alternate crf' or something like that. Right now, I think I have it set for 24. So, what you are saying is that for me just to go ahead and do the re-encode and then if the episode isn't passed through untouched (or close to that) then set the alternate CRF for like 28 or something like that and then do it again...? Last edited by Lathe; 21st June 2017 at 02:25. |
21st June 2017, 02:33 | #26065 | Link |
Ah crumb! There is one hitch though dang it! There is ONE Xtra that actually is larger than the one episode. The episode is about 7.x Gigs and the one Xtra is about 11 Gigs. Dang! Is there a way to flag the episode as the main title or tell BDRB that the 11 Gig segment is an Xtra...?
I bet not... |
21st June 2017, 02:39 | #26066 | Link | |
21st June 2017, 03:15 | #26071 | Link |
Heh, it's SO close too, in a way... In 'Movie Only' there is a choice of 'Other Main Movie' playlist. Now, if in 'Full Backup' mode, there was SOME bloody way also to choose 'Another Main Movie' playlist, that would be perfect!
Hmmm, one thing I could TRY is to extract the 11 Gig Xtra and using x264 go ahead and shrink it by itself to say 2 Gigs or whatever. Then, re-insert that new, smaller m2ts back into and replace the original within the whole BD structure, THEN try opening that altered full structure into BDRB and see if it 'buys' it... Last edited by Lathe; 21st June 2017 at 03:19. |
21st June 2017, 08:23 | #26072 | Link |
Well, it LOOKS like it is working. I took the 11 Gig Xtra and used BDRB at a CRF of 24 to bring it down to about 2.6 Gigs, changed the name of the resulting m2ts file to the original name (number) and swapped the new, smaller file back in the structure in place of the 11 Gig original. BDRB then SEEMED to accept the new structure. So, now the 'movie' file is shown to be the actual 7.x Gig episode, with everything else being Xtras. Then, I reloaded the new (and improved) structure back into BDRB and am now reprocessing it. So far, no errors or anything. So, we'll see if the resulting product (1) has left the episode it's original size, and (2) see if the bloody thing actually plays correctly!
21st June 2017, 09:46 | #26073 | Link |
I suspected that what you were going to do was going to work. Why? Because you weren't going to play the new structure in a BD software, or hardware, player.
BDRB, on the other hand, just sees them as files. |
21st June 2017, 09:49 | #26074 | Link | |
http://forum.doom9.org/showthread.ph...11#post1678011 |
21st June 2017, 20:53 | #26075 | Link | |
So, if it burns okay that hopefully should be it. Like I say, if it comes down to it, honestly, if I simply have to do a full disc backup set at 'High' 2 pass with tweaks like I normally do for larger films, and with a fast encode for Xtras, I'm sure that will be just fine... We'll see... |
21st June 2017, 20:54 | #26076 | Link | |
22nd June 2017, 07:59 | #26080 | Link | |
