Old 4th August 2017, 01:52   #26341  |  Link
Chuckwagon
Originally Posted by bryrabknowles View Post
I think i may have said it wrong
I know that 10 bit isn't supported for bluray.
What I am trying to do is convert a 10-bit mkv (or .ts) to an 8- bit bluray.
BDRB recognizes the file as AVC encoded. The file is 9.22 GB, Hi10P Level 5.0
When setting BDRB to fit a BD25, the program chooses to keep the original video (even though it isn't BD-Compliant).
Will this option help? (From the Hiddenopts file)
FORCE_ENCODE=n n = 0/1 - if set to 1, BD-RB will never check to see if original video will fit
Chuckwagon is offline   Reply With Quote
Old 5th August 2017, 23:01   #26342  |  Link
zorro101
import 720p 25fps
Hi
I have found a problem with import function (to make blu-ray autoring)
if I import mkv (but i also try many file with .m2ts .ts) with resolution of 1280x720p with 25fps, BDrebuilder trasnform this to 23,976
I have try to use files at 1920x1080p 25fps and it work properly
this is a big problem because lose audio sync
please, can you help me?
thanks
best regards
zorro101 is offline   Reply With Quote
Old 6th August 2017, 02:43   #26343  |  Link
MrVideo
MrVideo's Avatar
720p @ 25fps is not a supported BD format. 720p @ 50fps is.
It shouldn't have, as 1080p @ 25fps is not supported. 1080i @ 25fps is.
Old 6th August 2017, 03:43   #26344  |  Link
BD-RB has an option to automatically convert PAL frame rates to NTSC frame rates (please forego the "they don't exist in the digital world" speech). But... it also adjusts the audio.
I'm away from my office right now for a week, but I'll do some tests to see if I can repeat the issue when I return.
Old 6th August 2017, 06:21   #26345  |  Link
Lathe
Lathe's Avatar
Don't worry boss... I'm ready if Mr. Video tries anything...
Old 6th August 2017, 09:12   #26346  |  Link
zorro101
i have found the hiddenoptions "IMPORT_PAL_TO_FILM" but not make change on audio. the sync is always present!
There is another simple way to make the sync? I have also the subtitles on my mkv!
@MrVideo
What you say is correct:
on the blu-ray associations are not present 1280x720 25p but also not present 1980x1080 25p.
but i have many blu-ray working properly with 1920x1080 25p.
thanks
Old 6th August 2017, 10:25   #26347  |  Link
zorro101
Hi
I have try to make blu-ray using tsremux (using blu-ray filder option) and this create blu-ray 720p 25fps that work properly. (I have burned this to bd-re and play correct on blu-ray player and ps3)
after this I have used bdrebuilder to import BD(s) function and the result is perfect 720 25p blu-ray working
now the "problem" is
i need to make blu-ray whith many episode and many season and this is very complicate to make this process.
there is a possibility of "fix" bd rebuilder, with Calm of course?
thanks again
Old 6th August 2017, 11:00   #26348  |  Link
Hi
thanks again
Are you attempting to play the pseudo-BD, or did you run a job against it after the import? The audio hasn't been adjusted yet in the pseudo-BD folder.
Old 6th August 2017, 12:29   #26349  |  Link
zorro101
I did not understand the question (i dont know pseudo-bd)
I use bdrebuider file-> import function for make "authoring" blu-ray (i need to create blu ray for season series)
i dont know why bdrebuilder import have different behavior
1) file-> import-> mkv,m2ts,etc 1280x720 25p -> audio sync loss (because bdrb change fps to 23.976)
2) if I put mkv into tsremux and make "bluray folder" and after i use bdre -> file-> import-> BD(s) -> work properly (without change fps)
thanks
Old 6th August 2017, 15:12   #26350  |  Link
MrVideo
MrVideo's Avatar
I don't have to, you just did. You can lead a horse to water....
BTW, 23.976 fps was never an analog NTSC frame rate.
Old 6th August 2017, 15:15   #26351  |  Link
MrVideo
MrVideo's Avatar
Oh boy... I'm just shaking in my boots!!!!
Old 6th August 2017, 15:18   #26352  |  Link
MrVideo
MrVideo's Avatar
iWhat you say is correct:
Yes, the spec is one thing and the actual Blu-ray playing device is another. Most of today's players will play non-compliant discs. jdobbs tries to only produce Blu-ray compliant discs.
Old 6th August 2017, 15:25   #26353  |  Link
MrVideo
MrVideo's Avatar
As mentioned a few times, BDRB produces Blu-ray compliant discs. tsReMuxer doesn't try to produce compliant output.
After you import the MKV files and configure the menu, DO NOT click on the Backup button. Just go into the working area and burn the BDMV/CERTIFICATE directories onto a disc. Running the Backup process is where the 25 fps -> 23.976 fps is done.
Only import enough files to fill a 25GB disc (or a 50GB disc).
Old 6th August 2017, 16:37   #26354  |  Link
zorro101
sorry but is not as you say
all my test descript are only with menu creator.
and i can add that the backup (for compression) is not a problem.
i tried to make 5 episode as descript (creating bd from mkv 1280x720 25p with tsremux and after import on bd-rb as multiple BD(s) )
this produce prefect menu with 5 episode and all 5 episode are 1280x720 25p. i have burned and perfect reproduct on blu-ray player, but i also test with bdedit and all 5 file are marked as 1280x720 25p.
after this i have tryed to compress the result with bd-rb and any file are processed, correctly, as 1280x720 25p.
i repeat, the only "problem" on bd-rb is the import function whith file 1280x720 25p from container mkv, ts,m2ts,etc...
thanks
Old 6th August 2017, 17:54   #26355  |  Link
Always a waste of breath... 23.976 is the ACTUAL frame rate for most NTSC film sources on DVD and BD. 29.97 is the rate after pulldown is applied.
Old 6th August 2017, 18:01   #26356  |  Link
Exactly. What good are standards if they aren't followed? What if someone decided that a foot is only 10 inches when building his house because it makes the calculations easier.
Old 6th August 2017, 22:05   #26357  |  Link
MrVideo
MrVideo's Avatar
It is the frame rate that is actually output from the analog DVD player that is NTSC. The 23.976 frame rate is not NTSC (look at the spec). 23.976 fps is now available as a native frame rate on Blu-ray releases, but that that doesn't make it "NTSC." Never has, and never will.
23.976 is available in regions B and C. Does that make it "PAL?"
Old 6th August 2017, 22:18   #26358  |  Link
MrVideo
MrVideo's Avatar
Interesting that you say that. NTSC/PAL are old analog specs that so many are trying to apply to the digital world.
Interesting note for both NTSC and PAL is that both are COLOR specs, added to the existing B&W broadcast standards. NTSC does modify the existing 30 fps B&W spec, to get 29.97 color to work (even though color would have worked @ 30 fps and we wouldn't have this 29.97/23.976 mess) and PAL added color to the existing B&W 25 fps. In other words, the broadcast specs for 30 fps and 25 fps came about long before NTSC or PAL. And none of the broadcast specs include 23.976/24 fps as broadcast frame rates. They include specs on how to handle said frame rates for broadcast (not part of NTSC or PAL).
Old 6th August 2017, 22:31   #26359  |  Link
MrVideo
MrVideo's Avatar
all my test descript[ions] are only with menu creator.
It would have been nice if what you said in this posting would have been originally posted. It adds more detail that can help jdobbs look at the issue.
That said, I suspect that jdobbs will "fix" it so that 720p @ 25fps and 1080p @ 25fps are not available in the final output because both are not part of the Blu-ray spec. But, maybe the conversion to 23.976 could be done in the "Backup" portion of the process, leaving the original files alone during the processes before that point.
And/or, during the "Backup" portion of the process, the 720p could be converted to 50 fps (frame rate doubling) and the 1080p converted to 1080i @ 25fps. I suspect that AVISynth has filters to be able to do both. That will allow the time spectral info not to be lost.
Just a thought.
Old 7th August 2017, 12:24   #26360  |  Link
geheim
Hey jdobbs,
@videofan3d has made a nice little appliciation to keep 3d offsets for subtitles intact after reencoding with FRIM. The tool is called h264offset3d and can be found in this thread: https://forum.doom9.org/showthread.php?t=174563
Any chance you could integrate this in BDRebuilder?? Then we would be able to make perfect backups of 3D discs.
Two additional steps would be required: Before reencoding, the original offsets need to be extracted and after encoding they would need to be reinserted. As h264offset3d is command-line based I think this could be intergrated in BDRebuilder's workflow without too much work??
After reinserting offsets muxing can start and in this step, the subtitle streams need to be flagged to the according 3d plane as on the original disc. It would be nice if we could also choose the used flag manually (as in TSMuxer).
Any chance you could take a look at this and intergrate h264offset3d in BD Rebuilder?? Would be great, thank you very much
geheim is offline   Reply With Quote
