Old 16th December 2012, 21:27   #16301  |  Link
gg72
Provide some specifics about your system so we can see what might be causing the issue.
No matter what I want to encode, it does not work. With the previous version it works OK.
For example:
[12.16.12] BD Rebuilder v0.42.06 (beta)
[21:15:23] Source: ***
- Input BD size: 35,30 GB
- Approximate total content: [01:56:44.622]
- Target BD size: 24,51 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Decoding/Frame serving: X264/LAVF [3-way]
[21:15:23] PHASE ONE, Encoding
- [21:15:23] Processing: VID_00125 (1 of 1)
- [21:15:23] Extracting A/V streams [VID_00125]
- [21:19:31] Reencoding video [VID_00125]
- Rate/Length: 23,976fps, 167*943 frames
- Bitrate: 21*691 Kbs
- [21:19:31] Reencoding: VID_00125, Pass 1 of 1
- Encode failed. Aborting.
- BD-Rebuilder v0.42.06 (beta)
- FFDSHOW: 4422, Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[21:19:41] - Failed video encode, aborted
[Status]
LABEL=***
VERSION=v0.42.06 (beta)
SOURCE_SIZE=37897943040
SOURCE_VIDEO_SIZE=37897943040
TARGET_SIZE=26319257600
REDUCTION=.694477206116989
RESIZE_1080=0
AUDIO_TO_KEEP=eng;hun;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=deu;eng;ger;hun;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=-1
INSTANCES=3
DGDECNV=0
QUICK=0
ENCODE_STEP=1.5
[00125]
AUDIO=1010000
PGS=100000000000100000000000000000
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=26319257600
RATE=21691
SPLITS=1
I use bd rebuilder for a long time, this is the first time that I have problems ...
gg72 is offline   Reply With Quote
Old 16th December 2012, 21:43   #16302  |  Link
gonca
@lauguru and gg72
why are you two editing out the source names? Nobody can see what's happening with those movies if nobody knows what they are.
Old 16th December 2012, 21:48   #16303  |  Link
Ch3vr0n
good question. Do not edit the BDRB. We need EVERYTHING INTACT in order to be able to help. Makes your request for help look suspicious
Old 16th December 2012, 22:01   #16304  |  Link
gonca
@Ch3vr0n
I saw lauguru's source name before it was edited. Tried it on google search. Amazing what came up.
Old 16th December 2012, 22:08   #16305  |  Link
gg72
I replaced the x264 files with the old ones (from the v0.42.04 folder) and what a surprise, it works now... Something is wrong with the new x264 files.
I do not think it drives us forward, if I call the movie, I wanted to encode, because the error happens with every movie, that I have tried. But OK, here is the log file:
[21:15:23] Source: PATRIOT_GAMES_00001
- FFDSHOW: 4422, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
And here the encoding with the new Rebuilder but with the old versions of x264:
[21:45:58] Source: PATRIOT_GAMES_00001
- Decoding/Frame serving: X264/LAVF [4-way]
[21:45:58] PHASE ONE, Encoding
- [21:45:58] Processing: VID_00125 (1 of 1)
- [21:45:58] Extracting A/V streams [VID_00125]
- [21:50:05] Reencoding video [VID_00125]
- [21:50:05] Reencoding: VID_00125, Pass 1 of 1
My settings are:
[Options]
VERSION=0.42.0.6
MODE=2
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
MULTIPROCESS=1
AUTO_BIAS=3
ALTERNATE_PAL=1
FORCE_NOENCODE=0
HC_PROFILE=BEST
SD_CONVERT=0
OPEN_GOP=1
RESIZE_1080=0
DEINTERLACE=0
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=1
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=1
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=25100
QUICK_EXTRAS=1
PRIORITY_CLASS=1
SHOW_ENCODER=0
TARGET_SIZE=25800
MOVIEONLY_TYPE=0
ALTCRF=20
ALT_TARGET=1000
ALTMETHOD=0
ALTAUTOCROP=0
[Paths]
SOURCE_PATH=D:\BLURAY_FULLDISC\PATRIOT_GAMES\
WORKING_PATH=I:\BD25\
Old 16th December 2012, 22:16   #16306  |  Link
gonca
@gg72
Can you try with directshow decoding just to get past the problem area?
This is to see if its x264 or LAVF.
Old 16th December 2012, 22:28   #16307  |  Link
lauguru
@gg72
I use lavf internal x264, and the same error
lauguru is offline   Reply With Quote
Old 16th December 2012, 22:37   #16308  |  Link
setarip_old
setarip_old's Avatar
@jdobbs - Another SONY 360 anomaly discovered
I just used BD Rebuilder to create a BD-9 of "Ice Age (4) Continental Drift".
While it played perfectly on my PC (using PowerDVD7 - I will intentionally not update), I then attempted to play it on my SONY 360. After allowing all trailers to play and then selecting "Play" from the menu, the movie starts WITH NO AUDIO, and no access to audio or subtitle controls.
But lo and behold, I found a solution. Simply burning the SAME file package (that fits on a DVD/BD9) onto a BD25 results in a disc that is completely and perfectly playable on my SONY 360!
Go figure ;>}
Anyone have any ideas as to what the nature is of this latest SONY 360 anomaly?
Old 16th December 2012, 22:40   #16309  |  Link
gg72
@gg72
Thanks for your suggestion! So with DirectShow it works fine, with LAVF not.
[22:23:22] Source: PATRIOT_GAMES_00001
- Target BD size: 25,10 GB
- Decoding/Frame serving: DirectShow [4-way]
[22:23:22] PHASE ONE, Encoding
- [22:23:22] Processing: VID_00125 (1 of 1)
- [22:23:22] Extracting A/V streams [VID_00125]
- [22:27:31] Reencoding video [VID_00125]
- Bitrate: 22*359 Kbs
- [22:27:31] Reencoding: VID_00125, Pass 1 of 1
For me, these are the conclusions:
- BD Rebuilder v0.42.06 + LAVF = not working
- BD Rebuilder v0.42.06 + DirectShow = OK
- BD Rebuilder v0.42.06 + previous versions of x264 + LAVF = OK
Old 16th December 2012, 22:56   #16310  |  Link
gonca
@setarip_old
The 360 doesn't seem to like full disk (BD) on DVD media
However, it does like movie only even if it has DTS, Sony only enforces part of the AVCHD spec.
@gg72
It seems the problem might be with the internal LAVF in this version.
Old 16th December 2012, 22:56   #16311  |  Link
lauguru
@gg72
BD Rebuilder v0.42.06 + lavf, you it works?
Old 16th December 2012, 22:58   #16312  |  Link
gg72
Old 16th December 2012, 23:02   #16313  |  Link
lauguru
I see, but I ask gonca, if you work on, since both use lavf by default.
Old 16th December 2012, 23:09   #16314  |  Link
gzr
I have the same crash with x264, when I was using the 0.42.04 version I downloaded the 2230 of x264 from x264.nl and had the same problem.
Now I have replaced the x264 that comes with 0.42.06 with the builds of komisar (2230) and everything works ok, with and without LAVF.
http://komisar.gin.by
gzr is offline   Reply With Quote
Old 16th December 2012, 23:12   #16315  |  Link
gonca
@lauguru
I saw your source name before you changed your log. I agreed to follow the rules of this forum so I will not answer your questions unless a moderator says it is ok.
P.S.
preprocessed source bug reports aren't supposed to be posted here.
Old 16th December 2012, 23:23   #16316  |  Link
lauguru
thanks gzr. I'll try
run perfecftly BD Rebuilder v0.42.06 + LAVF very thanks!!
http://komisar.gin.by/old/2230/x264.2230.x86.exe rename x264
http://komisar.gin.by/old/2230/x264.2230.x86_64.exe rename x264-64
Old 16th December 2012, 23:27   #16317  |  Link
Nothing, I find it impossible to work with this new version
I asked about specifics about your system. So you don't have a processor? You don't have a motherboard? No memory? You have no BD-RB settings in use? I have to assume that would be your issue then.
Old 16th December 2012, 23:32   #16318  |  Link
Can one of you folks who are saying X264 isn't working please download from the X264 download site and try it? I'd like to see if it is ther X264 release, or it is the specific files I've included in the zip.
Old 16th December 2012, 23:42   #16319  |  Link
Go figure ;>}
Wow. I can't imagine -- unless maybe it has updated its BIOS and is subject to Cinavia? Even with that, though, I'd expect some kind of warning message. If I recall, though, you don't allow updates on your 360?
Old 16th December 2012, 23:45   #16320  |  Link
lauguru
jdobbs you asked: gg72 why I have not said anything.
Unfortunately I have also problems (encode failed) with the new version. The same source worked perfectly with the previous version (with the same settings).
"I wouldn't be so paranoid if everyone wasn't out to get me." (Frank Burns)
Website: www.jdobbs.com
processor : i7 980x 4600 mhz
12 gb ddr3 -5-8-6-18 1600 mhz
ati 6850 oc
gigabyte x58-oc
ssd sandisk extreme 240gb
