Old 17th November 2019, 21:53   #57781  |  Link
it was never gone and it is pretty much the main thing madshi works on in the past year.
Old 17th November 2019, 23:17   #57782  |  Link
SamuriHL
SamuriHL's Avatar
The test builds are not for the faint of heart, especially right now, but, the quality of HDR to SDR in the latest test builds is astounding. HSTM (tm) is an amazing dynamic tone mapping algorithm. There's a few users that have posted their settings along with the latest curve parameters. See if any are close to what your display is capable of in SDR and start there if you're willing to accept that it's very much a test build. Most of us are using it to watch movies at this point but it requires more setup than a final build will.
Old 18th November 2019, 00:50   #57783  |  Link
mclingo
there is no SDR conversion in the latest stablev0.92.17, sure it was there previously, i'll maybe look at the lastest working versions again.
Old 18th November 2019, 01:12   #57784  |  Link
mclingo
i'm still not seeing and actual HDR to SDR conversion option which was definately there before, all I see if tone map HDR options.
https://1drv.ms/u/s!AgvFafeelEBigqsK...SPe_g?e=gwRVIA
However... even on default settings this has made a huger difference to my HDR quallity. My goto test scene is harry potter goblet of fire, the end scene where he's fighting vold, prior to this I could barely see his mum and dad and I couldnt see diggery at all, they are all now perfectly clear.
I'll maybe have a further play with this as I now no longer need to think about converting to SDR.
Old 18th November 2019, 01:22   #57785  |  Link
Manni
The name of the option was changed because people thought, like you did, that it was an HDR to SDR conversion, so that what they were seeing was SDR, not HDR.
HDR Tonemapping makes it clearer that you're still watching HDR, simply that the tonemapping happens in the source (madVR HTPC) rather than in the VP or display/projector.
That change in name happened before the latest public build. Maybe the build you had installed previously was older than that.
In any case, no option was removed in the last public build.
Win11 Pro x64 b23H2
madVR/LAV/jRiver/MyMovies/CMC
Old 18th November 2019, 02:25   #57786  |  Link
SamuriHL
SamuriHL's Avatar
Right the "option" for SDR tone mapping is called unchecking "output to HDR" on the HDR tone mapping screen.
Old 18th November 2019, 11:14   #57787  |  Link
mclingo
That did occur to me actually, probably needs an HDR/SDR conversion check box really for clarity.
I tried unchecking that and its stopped everything working for me, I just get a blank black screen.
I've scrapped this for now though anyway as my RX 580 just doesnt have the chops for this, I couldnt get it below 43ms regardless of what settings I used, even if I dropped back to lanczos for all processing.
I'll probably pickup a 5700 in the new year and try again then.
Old 18th November 2019, 12:07   #57788  |  Link
nsnhd
Try changing the *highlight recovery strength* to None as that eats so much performances. RX 580 is similarly powerful as my gtx 1060 6gb and it can not afford this setting on.
nsnhd is offline   Reply With Quote
Old 18th November 2019, 14:16   #57789  |  Link
mclingo
i'll have a look at that, I was using that for that particular scene in harry potter, i'll have a proper play with it before I sack it off.
Old 18th November 2019, 15:17   #57790  |  Link
SirMaster
Hmm on my laptop GTX 1060 MaxQ I can have highlight recovery strength on and the performance is just fine.
SirMaster is offline   Reply With Quote
Old 18th November 2019, 23:54   #57791  |  Link
Alucard777
Alucard777's Avatar
hii ..
I'm currently using mpv with svp but i'm missing madvr alot and if I use mpc-hc with madvr & svp >> ( need ffdshow ) then the hdr will not passthrough !! ..
https://www.svp-team.com/wiki/Manual:SVP
can any one confirm if the vapoursynth will be added to madvr ?
if yes will hdr 10 bit passthrough with svp (smooth video project ) ?
thank you
Alucard777 is offline   Reply With Quote
Old 19th November 2019, 03:26   #57792  |  Link
At some stage madshi was looking to add support for this but it will either happen in 5-10 years or not at all. I asked pinterf about 10bit parsing/support in ffdshow but he's too busy for this. Honestly I hold no hope of this ever being done in the 2020s if at all.
Old 19th November 2019, 05:03   #57793  |  Link
Alexkral
If you add "hdr=on" or "transfer=hdr" to the file name you'll get passthrough even using ffdshow.
Old 19th November 2019, 06:08   #57794  |  Link
Magik Mark
Can someone help me create a profile in "DEVICES" for SDR and HDR?
Basically if video is SDR then use SDR Profile
if video is HDR then use HDR Profile
Both in "Devices"
I'm confused reading madshi FAQ
Old 19th November 2019, 12:42   #57795  |  Link
click on your device name create profile 2 times name them HDR and SDR
if (HDR==true) "HDR"
else "SDR"
Old 19th November 2019, 13:03   #57796  |  Link
Magik Mark
Thanks a lot!
Sent from my iPhone using Tapatalk
Old 19th November 2019, 14:01   #57797  |  Link
DMU
else "SDR"
Who runs this profile rule on the AMD Ryzen iGPU correctly?
I can’t achieve this.
R3 3200G / Vega8 / Samsung UE40NU7100
Win11Pro 21H2 / 4K RGB 59Hz / AMD last driver
MPC-HC 1.9.17 / madVR 0.92.17 / FSW / SM / 8bit
DMU is offline   Reply With Quote
Old 19th November 2019, 14:25   #57798  |  Link
he ask me to detect HDR not changing the bit deep.
the properties page is not used properly the rest is.
Old 19th November 2019, 14:58   #57799  |  Link
DMU
Yes it is clear. But how then to change the bitdepth of the output of the madVR depending on the HDR? This is necessary for owners of AMD video cards, as their API does not support HDR with 8 bits.
Old 19th November 2019, 15:33   #57800  |  Link
if (HDR== true) and (bitdepth==10) "HDR"
else "SDR"
maybe he will fix these bugs one day.
maybe he will update the AGS which has been updated according to "user" feat back so it may support 8 bit finally.
maybe just get an nvidia card if you want to use madVR because the developer is clearly favouring and recommending them. it is as it is...
