Old 30th June 2016, 15:25   #1881  |  Link
pinterf
Rare occasion... I hope you had
Cola vs Beer
pinterf is offline
Old 30th June 2016, 16:33   #1882  |  Link
real.finder
The one with the new TV_range=true parameter is O.K.
The other two clips are corrupted.
What is the conclusion? The second method receives a limited prefiltered clip, still it shows garbage
something in Dither_Luma_Rebuild not like avs+, did you try something else? like prefilter 1 and 2 and 3?
See My Avisynth Stuff
real.finder is offline
Old 30th June 2016, 17:37   #1883  |  Link
tormento
Acid fr0g
tormento's Avatar
Only prefilter=4 (knl) gives corruption.
@turment on Telegram
tormento is offline
Old 30th June 2016, 18:03   #1884  |  Link
real.finder
try this then
SetFilterMTMode("DEFAULT_MT_MODE", 2)
SetFilterMTMode("lsmashvideosource", 3)
lsmashvideosource("13HoursCUT.mp4", format="YUV420P8")
Crop(0, 140, 0, -140)
# In a more lucid state I could probably have laid out this block much better... or not...
NL_in   = Dither_convert_8_to_16()
NL_W    = width(NL_in)
U8      = UToY8(NL_in)
V8      = VToY8(NL_in)
NL_lsb  = StackVertical(StackVertical(Dither_get_msb(u8),Dither_get_msb(v8)),StackVertical(Dither_get_lsb(u8),Dither_get_lsb(v8)))
Y8      = StackHorizontal(ConvertToY8(NL_in),NL_lsb)
Y8      = Y8.KNLMeansCL(D=1, A=1, h=7.0,lsb_inout=true,device_type="GPU")
u_h = u8.height()/2
v_h = v8.height()/2
u16 = StackVertical(Dither_get_msb(Y8).crop(NL_W,0,0,-v_h),Dither_get_lsb(Y8).crop(NL_W,0,0,-v_h))
v16 = StackVertical(Dither_get_msb(Y8).crop(NL_W,u_h, 0,0),Dither_get_lsb(Y8).crop(NL_W,u_h, 0,0))
prefilter4 = YToUV(u16,v16,Y8.crop(0,0,-u8.width(),0))
SMDegrain (tr=4,PreFilter=prefilter4.SmoothLevels16(preset="tv2pc"),TV_range=false,thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=true,mode=6)
Prefetch(8)
+ this one http://pastebin.com/JtWFN124 (not tested enough)
SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=false,mode=6)
Prefetch(8)
yes, use it with no lsb for testing purpose
Old 1st July 2016, 05:47   #1885  |  Link
tormento
Acid fr0g
tormento's Avatar
try this then
Both works. No corruption.
tormento is offline
Old 1st July 2016, 08:47   #1886  |  Link
pinterf
Weird.
Replaced the one-pass combined YUV KNLMeans path
NL_W    = width(NL_in)
U8      = UToY8(NL_in)
V8      = VToY8(NL_in)
u_h = u8.height()/2
v_h = v8.height()/2
With a 3 pass KNLMeans path (distinct Y, U, V)
U8      = UToY8(NL_in)
V8      = VToY8(NL_in)
Y8      = ConvertToY8(NL_in)
U16 = U8.KNLMeansCL(D=1, A=1, h=7.0,lsb_inout=true,device_type="GPU")
V16 = V8.KNLMeansCL(D=1, A=1, h=7.0,lsb_inout=true,device_type="GPU")
Y16 = ConvertToY8(NL_in).KNLMeansCL(D=1, A=1, h=7.0,lsb_inout=true,device_type="GPU")
prefilter4 = YToUV(u16,v16,Y16)
Result is:
KNLMeansCL: fatal error!
No MT.
Then I tried with different avisynth DLLs I have:
Classic AVS 2.6: no error
Avisynth+ r1576: no error
From Avisynth r1689 on: KNLMeansCL: fatal error!
When omitting KNLMeans calculation for clip V16, it works again.
U8      = UToY8(NL_in)
V8      = VToY8(NL_in)
V16 = U16 #V8.KNLMeansCL(D=1, A=1, h=7.0,lsb_inout=true,device_type="GPU")
Could you try if it works or not for you?
pinterf is offline
Old 1st July 2016, 08:52   #1887  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Ultim, Pinter said that making AviSynth+ cross-platform-compatible wasn't his area of expertise and someone would have to do that. Is that something you'll handle or we'll have to wait until someone else volunteers?
MysteryX is offline
Old 1st July 2016, 09:02   #1888  |  Link
tormento
Acid fr0g
tormento's Avatar
U8      = UToY8(NL_in)
V8      = VToY8(NL_in)
Works.
P.S: When I say it "works", it is corruption related. I am not doing any analysis about quality of output.
tormento is offline
Old 1st July 2016, 09:17   #1889  |  Link
pinterf
Works.
Just to make sure, I suppose you tried with the non-uncommented V16 line (the quote is the commented one)?
pinterf is offline
Old 1st July 2016, 09:25   #1890  |  Link
tormento
Acid fr0g
tormento's Avatar
The "works" is for the commented one.
The uncommented works with Prefetch(6) instead of Prefetch(8) because otherwise GPU memory requirements goes beyond my 2GB card.
tormento is offline
Old 1st July 2016, 10:01   #1891  |  Link
Groucho2004
@tormento, pinterf
You guys realize that using Prefetch(8) will use 8 times the GPU memory, right? I ran a little test and ran out of memory at Prefetch(4). I do however only have 1G graphics memory.
Use AVSMeter with the -gpu switch to check GPU memory usage.
When you run out of GPU memory you'll get this:
KNLMeansCL: fatal error! (AviSynthGetFrame)
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 1st July 2016, 10:14   #1892  |  Link
tormento
Acid fr0g
tormento's Avatar
You are right. I have 2 GB on my GPU and the "uncommented script" with Prefetch(6) works, with following stats:
[Runtime info]
Frames processed:               107 (0 - 106)
FPS (min | max | average):      0.362 | 830086 | 8.244
Memory usage (phys | virt):     1272 | 2775 MiB
Thread count:                   171
CPU usage (average):            54%
GPU usage (average):            29%
Video engine load (average):    15%
GPU memory usage:               1741 MiB
Time (elapsed):                 00:00:12.980
With Prefetch(8), it goes to 1920 MB and then KNL crashes.
tormento is offline
Old 1st July 2016, 10:17   #1893  |  Link
tormento
Acid fr0g
tormento's Avatar
As I wrote, the uncommented works with Prefetch(6) and no corruption too.
tormento is offline
Old 1st July 2016, 10:23   #1894  |  Link
pinterf
@tormento, pinterf
No MT mode here
pinterf is offline
Old 1st July 2016, 10:28   #1895  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
The author of KNLMeansCL explicitely recommended NOT to use MT with KNLMeans, and if you use, set it to MT mode=3. A single instance of it then gets created.
MysteryX is offline
Old 1st July 2016, 11:05   #1896  |  Link
pinterf
Weird.
U8      = UToY8(NL_in)
V8      = VToY8(NL_in)
U16 = U8.KNLMeansCL(D=0, A=1, h=7.0,lsb_inout=true,device_type="GPU")
V16 = V8.KNLMeansCL(D=0, A=1, h=7.0,lsb_inout=true,device_type="GPU")
Y16 = ConvertToY8(NL_in).KNLMeansCL(D=0, A=1, h=7.0,lsb_inout=true,device_type="GPU")
With D=0 it works. (tried before without success: GPU/CPU, lsb_inout=false,h=1.0)
Still no MT. Maybe we should pass the problem to the right forum.
pinterf is offline
Old 1st July 2016, 11:10   #1897  |  Link
Groucho2004
"d=0" uses less gpu memory.
What graphics card do you have? How much memory? Have you tried monitoring the GPU memory usage?
Old 1st July 2016, 11:57   #1898  |  Link
pinterf
AMD 7570, 1G RAM. 385 MB Dedicated, 98 MB Dynamic.
With classic AVS and Avs+ 1576 there is no problem.
pinterf is offline
Old 1st July 2016, 12:11   #1899  |  Link
tormento
Acid fr0g
tormento's Avatar
+1
Let's stay on image corruption topic.
tormento is offline
Old 1st July 2016, 14:26   #1900  |  Link
pinterf
1.) Image corruption solved*
Avisynth.dll compiled for Debug has no corruption.
Release version has.
2.) KNLMeansCL fatal error (3*call in a sequence + SMDegrain) solved**
Avisynth.dll compiled for Debug has no fatal error.
Programmers' dream: debug the release.
*, **not solved
pinterf is offline
