Old 15th June 2018, 18:43   #21  |  Link
kolak
I had 4 dependencies. Made links to them, but still not working
Old 15th June 2018, 18:45   #22  |  Link
kolak
Originally Posted by l33tmeatwad View Post
Instead of using the brew copies, try using the ones I provided in the download location above to see if that resolves your issues.
But you have only links to plugins, not to dependencies (what goes to libraries)?
I already copied plugins libraries.
Getting lost.
Old 15th June 2018, 18:47   #23  |  Link
l33tmeatwad
l33tmeatwad's Avatar
Getting lost.
In the downloads link there is a folder called "Dependencies" that includes all the dependencies for any of the plugins.
To be completely specific about every dependencies you need, you will need links or copies of the following in /Library/Frameworks/VapourSynth.framework/lib:
libfftw3f_threads.3.dylib
libfftw3f.3.dylib
libgcc_s.1.dylib
libstdc++.6.dylib
l33tmeatwad is offline   Reply With Quote
Old 15th June 2018, 20:25   #24  |  Link
kolak
Sorry, makes sense now.
I have those libs. Lets see if copying yours will fix it.
update: it's working now with your libraries. It's very possible it would work with main also, but I had missing dot in one of the names!
Thank you for your patience.
Old 15th June 2018, 20:32   #25  |  Link
l33tmeatwad
I was looking into brew installs for everything and it appears that it does not place the gcc libs in the lib path for some odd reason...I have updated the first post with instructions on how to get brew installs working properly.
Old 16th June 2018, 09:52   #26  |  Link
jackoneill
unsigned int
jackoneill's Avatar
1. As of today, if you compile MVTools from git, you can pass -static-libstdc++ -static-libgcc so you don't have to worry about shipping those libraries.
If using the latest meson from git:
mkdir build; cd build
meson ../ -Dcpp_link_args="-static-libstdc++ -static-libgcc"
ninja
If using meson 0.46.x it's a bit different due to a bug:
meson ../
meson configure -Dcpp_link_args="-static-libstdc++ -static-libgcc"
ninja
(libtool would strip these from LDFLAGS so you have to use meson.)
2. I don't use anything fancier than C++11, so Apple's clang compiler should be able to compile MVTools. What errors do you get?
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 16th June 2018, 13:18   #27  |  Link
l33tmeatwad
ninja
meson ../
ninja
MVtools is fine for those libs, the fftw dependency was the one they were missing. FFT3DFilter is the one they needed the gcc libs for as it has c++17 code.
Old 16th June 2018, 17:39   #28  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Ah, I mixed them up.
Old 26th June 2018, 22:55   #29  |  Link
l33tmeatwad
Added DeblockPP7, RawSource, RemapFrames, and Retinex. Will be working on more of my backlog of plugins to compile this week. If there are new plugins to add please PM Selur as he is helping me to manage the list.
Old 26th June 2018, 23:28   #30  |  Link
ChaosKing
You can copy paste my list https://forum.doom9.org/showthread.php?t=175529
ChaosKing is online now   Reply With Quote
Old 27th June 2018, 16:57   #31  |  Link
l33tmeatwad
While I try to test every plugin to make sure it doesn't crash before uploading, I will mark any that are not tested that I add. I just added VFR to CFR and because I have nothing to test with I decided to just go ahead and add it. If anyone can test it to verify it works that would be awesome (I know it loads).
Old 28th June 2018, 22:50   #32  |  Link
l33tmeatwad
Added: AutoCrop, BM3D, CNR2, COlorBars, CombMask, DeCross, DeLogo, FillBorders, Histogram, HQDN3D, & SmoothUV
Updated: aWarpSharp2
Old 1st July 2018, 20:41   #33  |  Link
yoon
Hi, VapourSynth Editor crashes when i launch the application. I'm running mac OS Sierra (10.12.6).
It only happens when the plugins folder is not empty.
yoon is offline   Reply With Quote
Old 2nd July 2018, 02:04   #34  |  Link
l33tmeatwad
How did you install VapourSynth, compiling, brew, or the installer? Could you provide the crash log?
Old 12th July 2018, 14:27   #35  |  Link
l33tmeatwad
Originally Posted by Selur View Post
Ps.: @l33tmeatwad: any change of an uninstaller for the base installer? Something that would remove everything the installer added to the system?
I looked into several options on how to best approach this and decided to created a .command file that can be run to remove all of the files added by the installer. I will be packaging it into the installer soonish, but for now I placed it in the installers download folder.
Old 19th July 2018, 11:25   #36  |  Link
l33tmeatwad
R44 is now available. The uninstaller script is included with that and will be for future installers as well. It can be run from the desktop shortcut or by running the terminal command removevs.
Old 29th July 2018, 13:47   #37  |  Link
ChaosKing
Found this https://github.com/Bl4Cc4t/homebrew-...master/Formula
Maybe it can simplify things for you.
Old 30th July 2018, 18:21   #38  |  Link
l33tmeatwad
Good concept, I have to do a lot of custom stuff to make them compile and work for different types of installs, but I should probably start creating scripts like these.
Old 26th October 2018, 16:18   #39  |  Link
l33tmeatwad
Been a bit busy with life, will try to get the installer updated to R45 on Sunday.
Old 29th October 2018, 22:30   #40  |  Link
l33tmeatwad
The installer for R45 is now up, I used the 45.1 source to compile it.
meatwadismagical, meatwadthegreat
