Old 19th February 2018, 20:11   #27061  |  Link
geheim
Picture uality with NVEnc definitely is worse than with software encoding. I did some UHD encoding with DVDFab using CUDA and the resulting video files have much more blocking and compression artefacts, especially in dark Scenes, than compared to encodes with x265. So CUDA/NVEnc is a good thing for testing, but if you care about picture quality I'd always prefer x265, no matter how long encoding takes with it.
geheim is offline   Reply With Quote
Old 19th February 2018, 20:21   #27062  |  Link
Ch3vr0n
X265 is all ENCODING library. Just like x264. It has ZERO impact on quality software encoding or hardware encoding. Hardware only speeds things up. Quality is determined by the level of compression you choose (and in case of cli the switches you select)
Sent from my Nexus 6P with Tapatalk
Old 19th February 2018, 21:33   #27063  |  Link
Blurayhd
Dear Jdobbs, at this time I just cant donate (I really want to) but my budget dont let me do it, but I just like to say thank you for doing it, I really appreciate your work and pacience to respond questions
And so dar we know you are making a new release that includes support for 4k, please dont get me wrong, it is possible thanks to you, I just wish to know more or less when you think new release will come?
Have a nice week!!
Old 19th February 2018, 22:12   #27064  |  Link
Ch3vr0n
He's already working on uhd support
Sent from my Nexus 7 with Tapatalk
Old 20th February 2018, 00:14   #27065  |  Link
gonca
CUDA encoding results were not that good,
But NVEnc is not CUDA based, it is VPU based
If your encoding app is still using the CUDA cores for encoding, then yeah, quality wouldn't be that good.
Quality, as Ch2vr0n said, also depends on your settings
Old 20th February 2018, 01:27   #27066  |  Link
drmih
Ahhh... I wasn't thinking. I guess I misread and it is a minimum of maxwell (I just haven't been keeping up on this stuff). Has anyone tested a GTX 1050? Is it good enough for HEVC encoding? Any minimum amount of memory? I'm thinking about upgrading -- but I need to keep my cost down.
Does the 10 series encodes support B frames when HEVC encoding? Some reading I saw seems to imply it doesn't.
I have 2 1050s - a second hand 2 Gb one I recently put into an oldish pc (8 years old) and another 4Gb one in a new gaming laptop - both perform the same. With either DVDFab, or CloneBD, the time for a typical UHD ranges from 20 to 40 mins, depending on the length. For discs of around 60 to 70 Gb, where I tend to lose the ATMOS, compressing to bd-25 produces discs which I struggle to tell the difference from the original. As you get up to 90 to 100 Gb then you do occasionally see artefacts, and I tend to go for bd-50 with the ATMOS.
Old 20th February 2018, 02:06   #27067  |  Link
MrVideo
MrVideo's Avatar
Strange issue. I'm authoring some Blu-rays that will also contain some 480i videos extracted from a DVD. The problem is that the audio is leading the video by a second. The original files are fine. If I manually run tsmuxer on the MKV file, the audio is correct. But, the m2ts file that BDRB creates has the issue. So, I went looking for the meta file. Very tricky, in that I have to abort the process during the integration stage and not say OK to the dialog, so that the meta file will hang around.
Here is the content of the meta file:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr  --custom-chapters=00:00:00.000;00:07:18.471
     --vbv-len=500 --start-time=27000000
V_MPEG-2,"E:\BD-REBUILDER\WORK\TEMPIMPORT\Video.track_1.MPV", fps=29.97
A_AC3,"E:\BD-REBUILDER\WORK\TEMPIMPORT\Audio.track_2.AC3", timeshift= -1mn 5s, lang=eng
The plot thickens. For some reason there is that large audio timeshift, yet the actual shift is 1 sec. The audio should not be shifted at all. The H.264 MKV 1080p files are just fine.
As a test, I removed the timeshift and ran the BDRB tsmuxer using the modified meta file and all was well.
What do I have to do to stop the audio shift?
Old 20th February 2018, 02:22   #27068  |  Link
SquallMX
Special SeeD
Yeah, Tried with Ghostbusters (the original one), The results are awful, even using BD-50 as a target size. Software encoding with x265 is way better but more time consuming.
Software encoding------->Hardware encoding.
SquallMX is offline   Reply With Quote
Old 20th February 2018, 11:57   #27069  |  Link
Glarioo
ET movie with CloneBD and hardware acceleration enabled. 7(CUDA and Highest quality).
The bitrate at 29.37mbps, and after 40 minutes ... job done.
I'm happy with my MSI GeForce GTX 1050 Ti 4G OC GPU.
Old 20th February 2018, 15:18   #27070  |  Link
I can't agree with that. There are a number of reasons why X265 will encode better.
Old 20th February 2018, 15:19   #27071  |  Link
Have a nice week!!
I was hoping this week -- but I've run into another problem. I've found that, while now in sync, my full-film backups are running into halt-and-resume problems at about the halfway point (on at least one film). I think it may be related to the muxing.
Old 20th February 2018, 17:56   #27072  |  Link
kufo
kufo's Avatar
I would have been happy if it had worked so fast, but it doesn´t matter for me to wait a bit longer for such a good software. You really set the bar high for it with BDrebuilder
kufo is offline   Reply With Quote
Old 21st February 2018, 02:05   #27073  |  Link
MrVideo
MrVideo's Avatar
Fixed: Audio Issue
Got it working, but not sure why. To get around the issue, I took the TS file and made a new MKV file, with the audio delayed 1 sec. The result: the 1 sec delay stayed. So, I tried the original MKV file and again got the 1 sec advancement.
In frustration, I took the TS file and remade the MKV file, without any delay and all was well (the meta file had a 4ms shift). I made the original MKV file with an older VideoReDo and the new MKV with a newer version.
No idea what BDRB was looking at in the MKV file to cause the original problem, even though the file plays via VLC, and VRD, without any audio issues.
Old 21st February 2018, 02:54   #27074  |  Link
Lathe
Lathe's Avatar
My Total Eclipse 2017 Photos
Very nice pictures mate!
Old 21st February 2018, 05:28   #27075  |  Link
Fixed: Audio Issue
The delay would only be added if MEDIAINFO told BD-RB it existed.
Old 21st February 2018, 19:58   #27076  |  Link
MrVideo
MrVideo's Avatar
Old 21st February 2018, 20:29   #27077  |  Link
MrVideo
MrVideo's Avatar
Interesting. A sample using the BDRB mediainfo.exe:
General
Count                                    : 284
Count of stream of this kind             : 1
Kind of stream                           : General
Stream identifier                        : 0
Unique ID                                : 324646248287871411194358783481100742116
     (0xF43C97D4D0CBC93310519FAEF9F1ADE4)
Count of video streams                   : 1
Count of audio streams                   : 1
Count of menu streams                    : 1
Video_Format_List                        : MPEG Video
Video_Format_WithHint_List               : MPEG Video
Codecs Video                             : MPEG-2 Video
Audio_Format_List                        : AC-3
Audio_Format_WithHint_List               : AC-3
Audio codecs                             : AC3
Audio_Language_List                      : English
Complete name                            : input.mkv
File name                                : input.mkv
File extension                           : mkv
Format                                   : Matroska
Format                                   : Matroska
Format/Url                               : http://packs.matroska.org/
Format/Extensions usually used           : mkv mk3d mka mks
Commercial name                          : Matroska
Format version                           : Version 2
Codec                                    : Matroska
Codec                                    : Matroska
Codec/Url                                : http://packs.matroska.org/
Codec/Extensions usually used            : mkv mk3d mka mks
File size                                : 331694344
File size                                : 316 MiB
File size                                : 316 MiB
File size                                : 316 MiB
File size                                : 316 MiB
File size                                : 316.3 MiB
Duration                                 : 1276908
Duration                                 : 21mn 16s
Duration                                 : 21mn 16s 908ms
Duration                                 : 21mn 16s
Duration                                 : 00:21:16.908
Overall bit rate mode                    : VBR
Overall bit rate mode                    : Variable
Overall bit rate                         : 2078110
Overall bit rate                         : 2 078 Kbps
File creation date                       : UTC 2018-02-21 19:09:40.740
File creation date (local)               : 2018-02-21 13:09:40.740
File last modification date              : UTC 2016-10-24 02:23:45.795
File last modification date (local)      : 2016-10-23 20:23:45.795
Writing application                      : Lavf54.63.104
Writing library                          : Lavf54.63.104
Video
Count                                    : 264
Kind of stream                           : Video
StreamOrder                              : 0
Unique ID                                : 1
Format                                   : MPEG Video
Commercial name                          : MPEG-2 Video
Format profile                           : Main@Main
Format settings                          : CustomMatrix
Format settings, BVOP                    : No
Format settings, Matrix                  : Custom
Format_Settings_Matrix_Data              : [removed due to length]
Internet media type                      : video/MPV
Codec ID                                 : V_MPEG2
Codec ID/Info                            : MPEG 1 or 2 Video
Codec ID/Url                             : http://ffdshow-tryout.sourceforge.net/
Codec                                    : V_MPEG2
Codec                                    : MPEG-2 Video
Codec/Family                             : MPEG-V
Codec/Info                               : MPEG 1 or 2 Video
Codec/Url                                : http://ffdshow-tryout.sourceforge.net/
Codec profile                            : Main@Main
Codec settings                           : CustomMatrix
Codec settings, Matrix                   : Custom
Bit rate mode                            : VBR
Bit rate                                 : 1844756
Bit rate                                 : 1 845 Kbps
Maximum bit rate                         : 9800000
Maximum bit rate                         : 9 800 Kbps
Width                                    : 720
Width                                    : 720 pixels
Height                                   : 480
Height                                   : 480 pixels
Pixel aspect ratio                       : 1.181
Original pixel aspect ratio              : 1.185
Display aspect ratio                     : 1.771
Original display aspect ratio            : 1.778
Original display aspect ratio            : 16:9
Frame rate mode                          : VFR
Frame rate mode                          : Variable
Original frame rate                      : 29.970
Original frame rate                      : 29.970 fps
Standard                                 : NTSC
Resolution                               : 8
Resolution                               : 8 bits
Colorimetry                              : 4:2:0
Bit depth                                : 8
Scan order                               : TFF
Scan order                               : Top Field First
Interlacement                            : PPF
Interlacement                            : Progressive
Delay                                    : 65769
Delay                                    : 1mn 5s
Delay                                    : 1mn 5s 769ms
Delay                                    : 1mn 5s
Delay                                    : 00:01:05.769
Delay, origin                            : Container
Default                                  : No
Default                                  : No
Buffer size                              : 229376
intra_dc_precision                       : 10
Audio
Count                                    : 250
Kind of stream                           : Audio
StreamOrder                              : 1
Unique ID                                : 2
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : AC-3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Codec                                    : AC3
Codec                                    : AC3
Codec/Family                             : AC3
Codec/Info                               : Dolby AC3
Duration                                 : 1276908
Duration                                 : 21mn 16s
Duration                                 : 21mn 16s
Bit rate mode                            : CBR
Bit rate                                 : 192000
Bit rate                                 : 192 Kbps
Channel(s)                               : 2
Channel positions                        : Front: L R
Channel positions                        : 2/0/0
Sampling rate                            : 48000
Sampling rate                            : 48.0 KHz
Samples count                            : 61291584
Resolution                               : 16
Resolution                               : 16 bits
Bit depth                                : 16
Bit depth                                : 16 bits
Delay                                    : 234
Delay                                    : 234ms
Delay                                    : 234ms
Delay                                    : 234ms
Delay                                    : 00:00:00.234
Delay relative to video                  : -65535
Delay relative to video                  : -1mn 5s
Delay relative to video                  : -1mn 5s 535ms
Delay relative to video                  : -00:01:05.535
Video0 delay                             : -65535
Video0 delay                             : -1mn 5s
Video0 delay                             : -1mn 5s 535ms
Video0 delay                             : -00:01:05.535
Stream size                              : 30645792
Stream size                              : 29.2 MiB (9%)
Stream size                              : 29 MiB
Stream size                              : 29.23 MiB
Proportion of this stream                : 0.09239
Language                                 : en
Language                                 : en
Language                                 : eng
Language                                 : en
dsurmod                                  : 1
dsurmod/String                           : Not Dolby Surround encoded
dialnorm                                 : -27
dialnorm/String                          : -27 dB
compr                                    : 5.74
compr/String                             : 5.74 dB
dynrng                                   : 5.60
dynrng/String                            : 5.60 dB
bsid                                     : 6
dialnorm_Average                         : -27
dialnorm_Average/String                  : -27 dB
dialnorm_Minimum                         : -27
dialnorm_Minimum/String                  : -27 dB
dialnorm_Maximum                         : -27
dialnorm_Maximum/String                  : -27 dB
dialnorm_Count                           : 2
compr_Average                            : 5.74
compr_Average/String                     : 5.74 dB
compr_Minimum                            : 5.74
compr_Minimum/String                     : 5.74 dB
compr_Maximum                            : 5.74
compr_Maximum/String                     : 5.74 dB
compr_Count                              : 2
dynrng_Average                           : 5.60
dynrng_Average/String                    : 5.60 dB
dynrng_Minimum                           : 5.60
dynrng_Minimum/String                    : 5.60 dB
dynrng_Maximum                           : 5.60
dynrng_Maximum/String                    : 5.60 dB
dynrng_Count                             : 2
Menu
Count                                    : 81
Kind of stream                           : Menu
Chapters_Pos_Begin                       : 75
Chapters_Pos_End                         : 81
00:00:00.000                             : :Chapter 1
00:05:42.709                             : :Chapter 2
00:10:38.671                             : :Chapter 3
00:15:07.539                             : :Chapter 4
00:20:06.171                             : :Chapter 5
00:21:15.474                             : :Chapter 6
That begs the question, if the audio delay is -1mn 5s, why did it actually become 1 sec?
Something tells me that the library that VRD used had a bug and put in a delay value that was actually wrong. Using VLC, the files played without any kind of sync error.
I'm redoing all of the files with a later version of VRD.
Interesting problem.
Old 22nd February 2018, 01:39   #27078  |  Link
Just out of curiosity -- do you get different results from a newer version of MEDIAINFO?
Old 22nd February 2018, 03:22   #27079  |  Link
MrVideo
MrVideo's Avatar
I downloaded 17.12 and used the CLI version to grab the following info:
General
Count                                    : 328
Unique ID                                : [removed due to length]
Audio codecs                             : AC3
Complete name                            : n:/input.mkv
File name                                : n:/input
Format                                   : Matroska
Format                                   : Matroska
Format/Url                               : https://matroska.org/downloads/windows.html
Codec                                    : Matroska
Codec                                    : Matroska
Codec/Url                                : https://matroska.org/downloads/windows.html
File size                                : 316 MiB
File size                                : 316 MiB
File size                                : 316 MiB
File size                                : 316 MiB
Duration                                 : 1276908
Duration                                 : 21 min 16 s
Duration                                 : 21 min 16 s 908 ms
Overall bit rate                         : 2 078 kb/s
IsStreamable                             : Yes
File creation date                       : UTC 2018-02-22 02:06:20.403
File creation date (local)               : 2018-02-21 20:06:20.403
Video
Count                                    : 343
StreamOrder                              : 0
Unique ID                                : 1
Format                                   : MPEG Video
Format settings                          : CustomMatrix / BVOP
Format settings, BVOP                    : Yes
Format settings, GOP                     : Variable
Codec ID                                 : V_MPEG2
Codec                                    : V_MPEG2
Bit rate mode                            : VBR
Bit rate                                 : 1844756
Bit rate                                 : 1 845 kb/s
Maximum bit rate                         : 9 800 kb/s
Width                                    : 720
Width                                    : 720 pixels
Height                                   : 480
Height                                   : 480 pixels
Sampled_Width                            : 720
Sampled_Height                           : 480
FrameRate_Num                            : 30000
FrameRate_Den                            : 1001
Original frame rate                      : 29.970 FPS
Resolution                               : 8
Resolution                               : 8 bits
Colorimetry                              : 4:2:0
Bit depth                                : 8
Interlacement                            : PPF
Delay                                    : 233
Delay                                    : 233 ms
Delay                                    : 233 ms
Delay                                    : 233 ms
Delay                                    : 00:00:00.233
Default                                  : No
Default                                  : No
Audio
Count                                    : 307
StreamOrder                              : 1
Unique ID                                : 2
Format                                   : AC-3
Codec ID                                 : A_AC3
Codec                                    : AC3
Codec                                    : AC3
Codec/Family                             : AC3
Duration                                 : 1276908
Bit rate mode                            : CBR
Bit rate                                 : 192000
Bit rate                                 : 192 kb/s
Channel(s)                               : 2
ChannelLayout                            : L R
Samples per frame                        : 1536
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250
Frame rate                               : 31.250 FPS (1536 SPF)
Resolution                               : 16
Bit depth                                : 16
Bit depth                                : 16 bits
Delay                                    : 234
Delay                                    : 234 ms
Delay                                    : 234 ms
Delay                                    : 234 ms
Delay relative to video                  : 1
Delay relative to video                  : 1 ms
Delay relative to video                  : 00:00:00.001
Video0 delay                             : 1
Video0 delay                             : 1 ms
Video0 delay                             : 1 ms
Video0 delay                             : 1 ms
Video0 delay                             : 00:00:00.001
Language                                 : en
Language                                 : en
Language                                 : eng
Language                                 : en
Service kind                             : CM
Service kind                             : Complete Main
bsid                                     : 6
dialnorm                                 : -27
dialnorm                                 : -27 dB
compr                                    : 5.74
compr                                    : 5.74 dB
dynrng                                   : 5.60
dynrng                                   : 5.60 dB
dsurmod                                  : 1
dsurmod                                  : Not Dolby Surround encoded
acmod                                    : 2
lfeon                                    : 0
dialnorm_Average                         : -27 dB
dialnorm_Minimum                         : -27 dB
dialnorm_Maximum                         : -27 dB
dialnorm_Count                           : 300
compr_Average                            : 4.91
compr_Average                            : 4.91 dB
compr_Minimum                            : 0.53
compr_Minimum                            : 0.53 dB
compr_Maximum                            : 5.74 dB
compr_Count                              : 56
dynrng_Average                           : 1.98
dynrng_Average                           : 1.98 dB
dynrng_Minimum                           : -0.28
dynrng_Minimum                           : -0.28 dB
dynrng_Maximum                           : 5.74
dynrng_Maximum                           : 5.74 dB
dynrng_Count                             : 202
Menu
Count                                    : 98
Chapters_Pos_Begin                       : 92
Chapters_Pos_End                         : 98
There is definitely a difference.
Hopefully you use Delay relative to video.
Old 24th February 2018, 00:18   #27080  |  Link
DeathStalker77
CopyDirStructure() 00076 1200
I have been getting this specific error on a LOT of BDs lately. Whether it is trying to make a complete copy or shrink to ANY format
DeathStalker77 is offline   Reply With Quote
