Old 15th May 2012, 21:08   #15101  |  Link
drmih
I have done all of the Mummy trilogy and the PiP works fine if you have a player which can handle it.
Old 15th May 2012, 21:13   #15102  |  Link
Audiophile1178
I tested this info using PowerDVD 11 and OPPO BDP-83 player. I went into the OPPO settings to allow secondary audio. I only tested the mummy 2 with my oppo as I quickly became aware of the problem and halted burning the other two discs. PowerDVD 11 plays all the originals back fine but not the backups.
BTW, did you keep all the audio languages or just the english like me?
Audiophile1178 is offline   Reply With Quote
Old 16th May 2012, 12:12   #15103  |  Link
Scorpio1
Ver 4009
Well I have a major problem with 4009, it will start to process the main movie stream and about 20 minutes in will TURN OFF my pc, no warning, no error message, just turns the PC off.
The log doesn't indicate any error and BdRebuilder v 3907 works perfectly.
Also this is on my i7 Quad Core, annoyingly it works perfectly on my old P4 3.2.
Why do the older beta's expire? at least if they didn't I would be able to go back to a previously working version in this sort of circumstance, as it is I now can't shrink 50gb to 25gb. I am NOT expecting something for nothing and I WILL purchase a copy of BdRebuilder once released, in fact I think so highly of the program that I have already donated (twice).
Any chance of having a version of the 3907 version that doesn't expire until this problem is fixed please?
The movie I am trying to shrink at the moment is Transporter 3, although BdRebuilder 4009 exhibits this behaviour with ALL blu rays.
I have reinstalled everything needed for BDrebuilder to work, including avisynth, haali, and FFDshow, I have even tried a clean install with JUST BdRebuilder and the other necessary programs and BdRebuilder stiill just physically turns off my PC, it's just like holding in the power button, it's transcoding away then all of a sudden bang, the computers off. Very frustrating for such a brilliant program, with which I have had NO Problems until now.
Scorpio1 is offline   Reply With Quote
Old 16th May 2012, 13:00   #15104  |  Link
RobertM
Pretty unlikely that this has anything to do with BDRB. A serious programming bug will crash an application, a worse bug will cause a BSOD (blue screen). But when your system just suddenly turns off this is almost always caused by overheating. Your processor is protecting itself from being permanently damaged by too high a temperature.
A BD-Rebuild will start out using moderate resources (during the stream extraction), but once it calls X264 to do the actual video re-encoding the temps will quickly rise, with the second pass (of a 2-pass encode) being the most intense.
I would suggest running a temp monitoring program (something like RealTemp) while you do an encode, and see what the temps get to. Anything below 60c is great, below 80c is fine, 90c is pushing it, and at 100c (depending on your processor) your system will suddenly turn off.
Now clean you heat sink, make sure that all your fans are working, and repeat the process to see if this reduces temps.
Old 16th May 2012, 15:29   #15105  |  Link
I agree with RobertM. If your system is turning itself off it is highly unlikely it has anything to do with BD-RB. It could be overheating (as he mentioned), or it could be some other concurrent app calling for system shutdown. As for the report that it works if you go back a couple version... not sure how that could happen unless there has been a change in settings (e.g. setting multiprocessing could make your system run hotter). There has also been an update to X264 -- but if there were issues there I would expect to hear a lot of reports, as the i7 is a very popular processor.
As for turning off expirations... not yet. If I do that I'd have to keep saying "that was fixed 6 versions ago" for all the outdated reports. That's just more of a headache than I want to endure -- especially when it's under my control. I specifically added the timeout because of my problems with that exact scenario when developing DVD Rebuilder.
I do think the software has gotten to a fairly stable state, though, so I expect I'll be turning the expiration off and releasing v1.00 reasonably soon.
Old 16th May 2012, 15:38   #15106  |  Link
@Audiophile1178
I'll check out one of the Mummy movies and test the 480i/p report. As for it not playing back sound... there is still an issue with DTS Express -- that's the reason I have it supported only via hidden option. I've done a lot of analysis and haven't been able to put my finger on where the issue is... some players accept it and play back fine -- others don't. I'm certain I'm missing something in the remux or update, but I just haven't been able to find what that "something" is.
Old 16th May 2012, 17:12   #15107  |  Link
varekai
varekai's Avatar
Some time ago I had some issues with BD-RB 0.40.09 and H.264 (MPEG-4 AVC) crashing.
The odd thing is BD-RB 0.40.08 worked OK.
Did some troubleshooting and ended up with lowering the overclocking of
my i7 2600K from 4.5Ghz to 4.4Ghz and voilą!
No more H.264 crash! BD-RB 0.40.09 works like a charm!
Old 17th May 2012, 02:20   #15108  |  Link
Scorpio1
Temps not the problem
First of all thanks to all who replied saying that temperature was probably the reason that my PC suddenly shuts down without warning.
4 problems with this theory.:-
1) It's watercooled and never goes above 38 c even under full load.
2) If I install XP instead of 7 it doesn't crash at all, works a charm. Put Win 7 on it and I am back to the turning off about 20 minutes in. BUT ONLY if I install WIN XP using fat32, ntfs creates the same behaviour.
3) I can play games that will push the CPU and GPU to their limits and the PC will behave impeccably, sometimes for many hours at a time.
4) The PC didn't exhibit this behaviour with v 3907 installed. I am fairly certain if I was able to go back to 3907, the problem would disappear.
Oh and I am NOT overclocking the CPU and memory are stock timings and voltage and at the moment the ONLY programs installed are BdRebuilder, Haali. AVI Synth and Matroska.
Very frustrating, PC is monitored and logged and temp never goes above 38 c, but this bizzare behaviour continues, it did not happen with 3907 though. The only way to be sure is to go back to 3907, which is why I asked if it was possible to stop 3907 telling me it has been superceeded.
Old 17th May 2012, 03:55   #15109  |  Link
RobertM
Well, temps probably aren't the issue then.
But remember that x264 encoding is more demanding than just about anything else you can do, including gaming. Have you taken a look at the CPU usage to see if it spikes right before the 20 min crash?
Regarding BDRB 3907, can you fool it into working by just setting your clock back?
Also, you could try replacing the version of x264 that comes with 4009 with the one that came with 3907, to eliminate one more variable.
Old 17th May 2012, 10:40   #15110  |  Link
varekai
varekai's Avatar
The x264 version (2184) that came with BD-RB 0.40.09 was probably causing the issue I had.
Never had any heat problems, temp always around 50-55°C on 100% load for hours.
Old 17th May 2012, 14:06   #15111  |  Link
Cela
Confused with audio results and Audio checkboxes under SETUP
I use BD-RB v0.40.09 (beta) and Output Options>Custom Target Size (7700MB). In BD-RB Setup>Audio Encoding Options>'Do not reencode AC3 (Blu-Ray only)' is the only option checked. (The option 'Do not convert DTS to AC3 (Blu-Ray only)' is unchecked.)
But I get some audio results which, IMHO, do not correspond to what I should get according to what I read in the FAQ explanation of the 'Audio checkboxes under SETUP' ( BD Rebuilder (BD-RB) Frequently Asked Questions ).
1. From my Audio Encoding Options settings I expected that this DTS would be converted to AC3 640 kbps! Am I wrong?
- [06:26:08] Processing audio tracks
- Track 4352 (eng): Keeping original audio <---
where this track is:
Audio
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : 130
Duration : 11mn 5s
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
The FAQ states 'Important note: Choosing to keep DTS on AVCHD output violates the AVCHD standard and can result in a disc that will not play on some players.' I have checked 'Strict AVCHD for BD-5/9 Movie Only'. I am doing a full backup and my Custom Target Size (7700MB) is well within BD-5/9 size, isn't it? Doesn't the FAQ statement 'choosing to keep DTS on AVCHD output violates the AVCHD standard' also hold for full backups. Anyway, I did not choose to keep DTS.
2. My LPCM 2.0 audio is converted to 192KBs!
From my Audio Encoding Options settings I expected that 'LPCM is always converted to AC3' (FAQ) 224Kbs for 2.0. Why do I get 192Kbs for 2.0?
Why is there no option to select 448Kbs or the default 640Kbs for LPCM 2.0 to AC3 2.0 conversion?
IMHO, even with the FAQ, the Audio checkboxes under SETUP are a little confusing.
3. Wouldn't it be easier for the user to choose from a more explicit audio option selection table?
Example:
Keep HD audio? > Yes / NO
Convert DTS to AC3? > 640Kbs / 448Kbs / 224KBs / 192KBs / NO
Convert LPCM to AC3? > 640Kbs / 448Kbs / 224KBs / 192KBs / NO
Higher bitrates than 192 KBs for LPCM to AC3 conversion are especially needed for those concert/opera BDs which only have LPCM audio.
4. Audio/Video Bitrate Calculation _before_ video processing:
I would prefer if the audio/video bitrate calculations and/or the audio part were processed _before_ the time consuming video encoding. Then the audio processing could be checked and corrected immediately. Now, many hours of video encodings have to be redone if the audio choices need correction.
Please make the audio processing choices more unambiguous, easier to understand and predictable for the common user. I am convinced, in the long run, it will pay back by less user errors and less users, like me, calling for support and help.
Please remember, I very much appreciate your great work and program!
Cela is offline   Reply With Quote
Old 18th May 2012, 01:06   #15112  |  Link
pichu69
Reencoding secondary video [TRK_02] - Encode failed. Aborting
this happens when the bluray contains different videos in the same M2TS (1080 and 420)
[05/17/12] BD Rebuilder v0.40.09 (beta)
[22:56:40] Source: BDRA
- Input BD size: 39.14 GB
- Approximate total content: [03:51:20.165]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
- Quality: High-Speed Option (BD-25), ABR
[22:56:40] PHASE ONE, Encoding
- [22:56:40] Processing: VID_00312 (1 of 52)
- [22:56:40] Extracting A/V streams [VID_00312]
- [22:56:53] Reencoding video [VID_00312]
- Source Video: MPEG-2, 720x480
- Rate/Length: 29.970fps, 10,935 frames
- Bitrate: 2,526 Kbs
- [22:56:53] Reencoding: VID_00312, Pass 1 of 1
- [22:57:49] Video Encode complete
- [22:57:49] Processing audio tracks
- [22:57:49] Multiplexing M2TS
- [22:58:01] Processing: VID_00313 (2 of 52)
- [22:58:01] Extracting A/V streams [VID_00313]
- [22:58:13] Reencoding video [VID_00313]
- Rate/Length: 29.970fps, 8,170 frames
- Bitrate: 2,863 Kbs
- [22:58:14] Reencoding: VID_00313, Pass 1 of 1
- [22:58:54] Video Encode complete
- [22:58:54] Processing audio tracks
- [22:58:54] Multiplexing M2TS
- [22:59:00] Processing: VID_00314 (3 of 52)
- [22:59:00] Extracting A/V streams [VID_00314]
- [22:59:20] Reencoding video [VID_00314]
- Rate/Length: 29.970fps, 11,785 frames
- Bitrate: 2,858 Kbs
- [22:59:20] Reencoding: VID_00314, Pass 1 of 1
- [23:00:17] Video Encode complete
- [23:00:17] Processing audio tracks
- [23:00:17] Multiplexing M2TS
- [23:00:26] Processing: VID_00315 (4 of 52)
- [23:00:26] Extracting A/V streams [VID_00315]
- [23:00:48] Reencoding video [VID_00315]
- Rate/Length: 29.970fps, 17,425 frames
- Bitrate: 2,846 Kbs
- [23:00:48] Reencoding: VID_00315, Pass 1 of 1
- [23:02:13] Video Encode complete
- [23:02:13] Processing audio tracks
- [23:02:13] Multiplexing M2TS
- [23:02:26] Processing: VID_00316 (5 of 52)
- [23:02:26] Extracting A/V streams [VID_00316]
- [23:02:37] Reencoding video [VID_00316]
- Rate/Length: 29.970fps, 7,040 frames
- Bitrate: 2,551 Kbs
- [23:02:37] Reencoding: VID_00316, Pass 1 of 1
- [23:03:14] Video Encode complete
- [23:03:14] Processing audio tracks
- [23:03:14] Multiplexing M2TS
- [23:03:21] Processing: VID_00317 (6 of 52)
- [23:03:21] Extracting A/V streams [VID_00317]
- [23:03:34] Reencoding video [VID_00317]
- Rate/Length: 29.970fps, 4,028 frames
- Bitrate: 6,945 Kbs
- [23:03:34] Reencoding: VID_00317, Pass 1 of 1
- [23:03:53] Video Encode complete
- [23:03:53] Processing audio tracks
- [23:03:53] Multiplexing M2TS
- [23:04:01] Processing: VID_00321 (7 of 52)
- [23:04:01] Extracting A/V streams [VID_00321]
- [23:04:51] Reencoding video [VID_00321]
- Rate/Length: 29.970fps, 14,410 frames
- Bitrate: 4,784 Kbs
- [23:04:51] Reencoding: VID_00321, Pass 1 of 1
- [23:06:07] Video Encode complete
- [23:06:07] Processing audio tracks
- [23:06:07] Multiplexing M2TS
- [23:06:25] Processing: VID_00323 (8 of 52)
- [23:06:25] Extracting A/V streams [VID_00323]
- [23:06:35] Reencoding video [VID_00323]
- Rate/Length: 29.970fps, 7,400 frames
- Bitrate: 2,573 Kbs
- [23:06:35] Reencoding: VID_00323, Pass 1 of 1
- [23:07:11] Video Encode complete
- [23:07:11] Processing audio tracks
- [23:07:11] Multiplexing M2TS
- [23:07:17] Processing: VID_00324 (9 of 52)
- [23:07:17] Extracting A/V streams [VID_00324]
- [23:08:38] Reencoding video [VID_00324]
- Rate/Length: 29.970fps, 35,815 frames
- Bitrate: 4,704 Kbs
- [23:08:38] Reencoding: VID_00324, Pass 1 of 1
- [23:11:56] Video Encode complete
- [23:11:56] Processing audio tracks
- [23:11:56] Multiplexing M2TS
- [23:12:31] Processing: VID_00325 (10 of 52)
- [23:12:31] Extracting A/V streams [VID_00325]
- [23:12:45] Reencoding video [VID_00325]
- Rate/Length: 29.970fps, 5,615 frames
- Bitrate: 2,605 Kbs
- [23:12:45] Reencoding: VID_00325, Pass 1 of 1
- [23:13:14] Video Encode complete
- [23:13:14] Processing audio tracks
- [23:13:14] Multiplexing M2TS
- [23:13:19] Processing: VID_00328 (11 of 52)
- [23:13:19] Extracting A/V streams [VID_00328]
- [23:13:29] Reencoding video [VID_00328]
- Rate/Length: 23.976fps, 7,200 frames
- Bitrate: 3,010 Kbs
- [23:13:29] Reencoding: VID_00328, Pass 1 of 1
- [23:15:31] Video Encode complete
- [23:15:31] Processing audio tracks
- [23:15:31] Multiplexing M2TS
- [23:15:38] Processing: VID_00333 (12 of 52)
- [23:15:38] Extracting A/V streams [VID_00333]
- [23:35:18] Reencoding video [VID_00333]
- [23:35:18] Reencoding secondary video [TRK_02]
- Encode failed. Aborting.
- BD-Rebuilder v0.40.09 (beta)
- FFDSHOW: 3882, Ok
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[23:35:28] - Failed video encode, aborted
BD info that M2TS fails
VIDEO:
Codec Bitrate Description
VC-1 Video 0 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video 0 kbps 480p / 23.976 fps / 4:3 / Advanced Profile 2
VC-1 Video 0 kbps 480p / 23.976 fps / 16:9 / Advanced Profile 2
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio English 0 kbps 5.1 / 48 kHz / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio French 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio German 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio Italian 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio Japanese 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio Spanish 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio Chinese 384 kbps 5.1 / 48 kHz / 384 kbps
Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / Dolby Surround
DTS Express English 192 kbps 2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
Presentation Graphics English 0.000 kbps
Presentation Graphics Chinese 0.000 kbps
Presentation Graphics Danish 0.000 kbps
Presentation Graphics Dutch 0.000 kbps
Presentation Graphics Finnish 0.000 kbps
Presentation Graphics French 0.000 kbps
Presentation Graphics German 0.000 kbps
Presentation Graphics Greek 0.000 kbps
Presentation Graphics Italian 0.000 kbps
Presentation Graphics Japanese 0.000 kbps
Presentation Graphics Korean 0.000 kbps
Presentation Graphics Norwegian 0.000 kbps
Presentation Graphics Portuguese 0.000 kbps
Presentation Graphics Spanish 0.000 kbps
Presentation Graphics Swedish 0.000 kbps
FILES:
Name Time In Length Size Total Bitrate
00333.M2TS 0:00:00.000 1:59:02.552 0 0
pichu69 is offline   Reply With Quote
Old 18th May 2012, 02:35   #15113  |  Link
Capsbackup
You should try it on the original Blu-ray and not a pre-processed one with multiAVCHD.
Old 18th May 2012, 15:02   #15114  |  Link
pichu69
Bluray is the same, the former was prosecuted MultyAVCH changing the order of the videos to see if that solved the error
[05/18/12] BD Rebuilder v0.40.09 (beta)
[05:08:12] Source: JOSS.WHEDON.-.[SERENITY].2005.BLU-RAY.1080P.VC-1.DTS-HDMA.-GEORGE.C
- Approximate total content: [04:00:58.976]
[05:08:12] PHASE ONE, Encoding
- [05:08:12] Processing: VID_00312 (1 of 52)
- [05:08:12] Extracting A/V streams [VID_00312]
- [05:08:22] Reencoding video [VID_00312]
- [05:08:22] Reencoding: VID_00312, Pass 1 of 1
- [05:09:11] Video Encode complete
- [05:09:11] Processing audio tracks
- [05:09:11] Multiplexing M2TS
- [05:09:16] Processing: VID_00313 (2 of 52)
- [05:09:16] Extracting A/V streams [VID_00313]
- [05:10:08] Reencoding video [VID_00313]
- [05:10:08] Reencoding: VID_00313, Pass 1 of 1
- [05:10:43] Video Encode complete
- [05:10:43] Processing audio tracks
- [05:10:43] Multiplexing M2TS
- [05:10:51] Processing: VID_00314 (3 of 52)
- [05:10:51] Extracting A/V streams [VID_00314]
- [05:12:48] Reencoding video [VID_00314]
- [05:12:48] Reencoding: VID_00314, Pass 1 of 1
- [05:13:46] Video Encode complete
- [05:13:46] Processing audio tracks
- [05:13:46] Multiplexing M2TS
- [05:13:53] Processing: VID_00315 (4 of 52)
- [05:13:53] Extracting A/V streams [VID_00315]
- [05:16:04] Reencoding video [VID_00315]
- [05:16:04] Reencoding: VID_00315, Pass 1 of 1
- [05:17:27] Video Encode complete
- [05:17:27] Processing audio tracks
- [05:17:27] Multiplexing M2TS
- [05:17:44] Processing: VID_00316 (5 of 52)
- [05:17:44] Extracting A/V streams [VID_00316]
- [05:18:23] Reencoding video [VID_00316]
- [05:18:23] Reencoding: VID_00316, Pass 1 of 1
- [05:19:01] Video Encode complete
- [05:19:01] Processing audio tracks
- [05:19:01] Multiplexing M2TS
- [05:19:08] Processing: VID_00317 (6 of 52)
- [05:19:08] Extracting A/V streams [VID_00317]
- [05:19:58] Reencoding video [VID_00317]
- Rate/Length: 29.970fps, 12,125 frames
- Bitrate: 2,307 Kbs
- [05:19:58] Reencoding: VID_00317, Pass 1 of 1
- [05:20:51] Video Encode complete
- [05:20:51] Processing audio tracks
- [05:20:51] Multiplexing M2TS
- [05:21:05] Processing: VID_00321 (7 of 52)
- [05:21:05] Extracting A/V streams [VID_00321]
- [05:23:46] Reencoding video [VID_00321]
- [05:23:46] Reencoding: VID_00321, Pass 1 of 1
- [05:25:01] Video Encode complete
- [05:25:01] Processing audio tracks
- [05:25:01] Multiplexing M2TS
- [05:25:26] Processing: VID_00323 (8 of 52)
- [05:25:27] Extracting A/V streams [VID_00323]
- [05:26:22] Reencoding video [VID_00323]
- [05:26:22] Reencoding: VID_00323, Pass 1 of 1
- [05:27:07] Video Encode complete
- [05:27:07] Processing audio tracks
- [05:27:07] Multiplexing M2TS
- [05:27:16] Processing: VID_00324 (9 of 52)
- [05:27:16] Extracting A/V streams [VID_00324]
- [05:37:07] Reencoding video [VID_00324]
- [05:37:07] Reencoding: VID_00324, Pass 1 of 1
- [05:40:20] Video Encode complete
- [05:40:20] Processing audio tracks
- [05:40:20] Multiplexing M2TS
- [05:41:10] Processing: VID_00325 (10 of 52)
- [05:41:10] Extracting A/V streams [VID_00325]
- [05:42:19] Reencoding video [VID_00325]
- [05:42:20] Reencoding: VID_00325, Pass 1 of 1
- [05:42:54] Video Encode complete
- [05:42:54] Processing audio tracks
- [05:42:54] Multiplexing M2TS
- [05:43:03] Processing: VID_00328 (11 of 52)
- [05:43:03] Extracting A/V streams [VID_00328]
- [05:43:10] Reencoding video [VID_00328]
- [05:43:10] Reencoding: VID_00328, Pass 1 of 1
- [05:45:01] Video Encode complete
- [05:45:01] Processing audio tracks
- [05:45:01] Multiplexing M2TS
- [05:45:09] Processing: VID_00333 (12 of 52)
- [05:45:09] Extracting A/V streams [VID_00333]
- [06:09:19] Reencoding video [VID_00333]
- [06:09:19] Reencoding secondary video [TRK_02]
- FFDSHOW: 3882, Ok
- X264: Wrong version found
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[06:09:46] - Failed video encode, aborted
Disc Title: Joss.Whedon.-.[Serenity].2005.Blu-Ray.1080P.VC-1.DTS-HDMA.-george.c
Disc Size: 42,031,350,297 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.1
VIDEO:
AUDIO:
SUBTITLES:
FILES:
Old 18th May 2012, 16:13   #15115  |  Link
Capsbackup
Original purchased Blu-ray!
Sorry, cannot help.
Old 19th May 2012, 13:53   #15116  |  Link
@Cela
The only time you have to worry about violating the AVCHD standard is when you are backing up to DVD+-R. Usually that means you are doing a movie-only backup.
Old 19th May 2012, 14:43   #15117  |  Link
Capsbackup
@Cela
I quite often do full backups to BD5/9 for playback on my Sony S360 standalone. I always let BD-RB reencode the audio to 640 DD AC3, since this always works and plays back correctly.
I know some users are making backups for PC based playback, and thus the AVCHD standard may not be as important to them. Seems software players will play back almost anything.
What is important is for the user to consider the ultimate playback device and the potential compatibility of the backup for future use. Then the decision for the type of audio to keep will have more relevance!
Old 19th May 2012, 15:50   #15118  |  Link
You're absolutely right. A full backup to DVD+-R is a little different. It depends on the player. If the source uses no BD-J, then (for the most part) the output can become AVCHD compliant. In that case it's almost always better to convert to AC3. Frankly I believe you should always do it anyway, since it is more efficient and the difference can't be detected anyway (at 640Kbs).
Old 20th May 2012, 16:50   #15119  |  Link
dfsooner
- Bitrate: -24,691 Kbs
[05/20/12] BD Rebuilder v0.40.09 (beta)
[00:16:07] Source:  SOPRANOS_S1D5
  - Input BD size: 20.63 GB
  - Approximate total content: [02:32:13.632]
  - Target BD size: 7.84 GB
  - Quality: High Quality (Default), Two Pass
[00:16:07] PHASE ONE, Encoding
 - [00:16:07] Processing: VID_00000 (1 of 12)
 - [00:16:07] Extracting A/V streams [VID_00000]
 - [00:23:11] Reencoding video [VID_00000]
   - Rate/Length: 23.976fps, 87,011 frames
   - Bitrate: 11,701 Kbs
 - [00:23:12] Reencoding: VID_00000, Pass 1 of 2
 - [01:02:53] Reencoding: VID_00000, Pass 2 of 2
 - [02:13:53] Video Encode complete
 - [02:13:54] Processing audio tracks
 - [02:13:54] Multiplexing M2TS
 - [02:15:46] Processing: VID_00001 (2 of 12)
 - [02:15:46] Extracting A/V streams [VID_00001]
 - [02:15:56] Reencoding video [VID_00001]
   - Rate/Length: 29.970fps, 6,361 frames
   - Bitrate: 2,195 Kbs
 - [02:15:56] Reencoding: VID_00001, Pass 1 of 2
 - [02:16:20] Reencoding: VID_00001, Pass 2 of 2
 - [02:17:04] Video Encode complete
 - [02:17:04] Processing audio tracks
 - [02:17:04] Multiplexing M2TS
 - [02:17:09] Processing: VID_00002 (3 of 12)
 - [02:17:09] Extracting A/V streams [VID_00002]
 - [02:17:20] Reencoding video [VID_00002]
   - Rate/Length: 29.970fps, 7,547 frames
   - Bitrate: 2,481 Kbs
 - [02:17:20] Reencoding: VID_00002, Pass 1 of 2
 - [02:17:49] Reencoding: VID_00002, Pass 2 of 2
 - [02:18:42] Video Encode complete
 - [02:18:42] Processing audio tracks
 - [02:18:42] Multiplexing M2TS
 - [02:18:48] Processing: VID_00003 (4 of 12)
 - [02:18:48] Extracting A/V streams [VID_00003]
 - [02:18:52] Reencoding video [VID_00003]
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 29.970fps, 270 frames
   - Bitrate: 3,722 Kbs
 - [02:18:52] Reencoding: VID_00003, Pass 1 of 2
 - [02:18:55] Reencoding: VID_00003, Pass 2 of 2
 - [02:18:58] Video Encode complete
 - [02:18:58] Processing audio tracks
 - [02:18:58] Multiplexing M2TS
 - [02:19:01] Processing: VID_00004 (5 of 12)
 - [02:19:01] Extracting A/V streams [VID_00004]
 - [02:19:06] Reencoding video [VID_00004]
   - Rate/Length: 23.976fps, 313 frames
   - Bitrate: 10,253 Kbs
 - [02:19:06] Reencoding: VID_00004, Pass 1 of 2
 - [02:19:14] Reencoding: VID_00004, Pass 2 of 2
 - [02:19:30] Video Encode complete
 - [02:19:30] Processing audio tracks
 - [02:19:30] Multiplexing M2TS
 - [02:19:34] Processing: VID_00007 (6 of 12)
 - [02:19:34] Extracting A/V streams [VID_00007]
 - [02:19:42] Reencoding video [VID_00007]
   - Rate/Length: 23.976fps, 1,032 frames
   - Bitrate: 8,750 Kbs
 - [02:19:43] Reencoding: VID_00007, Pass 1 of 2
 - [02:20:04] Reencoding: VID_00007, Pass 2 of 2
 - [02:20:37] Video Encode complete
 - [02:20:37] Processing audio tracks
   - Track 4353 (spa): Keeping original audio
   - Track 4354 (fra): Keeping original audio
   - Track 4355 (deu): Keeping original audio
   - Track 4356 (spa): Keeping original audio
   - Track 4357 (eng): Keeping original audio
 - [02:20:37] Multiplexing M2TS
 - [02:20:45] Processing: VID_00008 (7 of 12)
 - [02:20:45] Extracting A/V streams [VID_00008]
 - [02:20:52] Reencoding video [VID_00008]
   - Rate/Length: 23.976fps, 711 frames
   - Bitrate: 9,326 Kbs
 - [02:20:52] Reencoding: VID_00008, Pass 1 of 2
 - [02:21:06] Reencoding: VID_00008, Pass 2 of 2
 - [02:21:30] Video Encode complete
 - [02:21:30] Processing audio tracks
 - [02:21:30] Multiplexing M2TS
 - [02:21:34] Processing: VID_00009 (8 of 12)
 - [02:21:34] Extracting A/V streams [VID_00009]
 - [02:21:42] Reencoding video [VID_00009]
   - Rate/Length: 29.970fps, 210 frames
 - [02:21:42] Reencoding: VID_00009, Pass 1 of 2
 - [02:21:49] Reencoding: VID_00009, Pass 2 of 2
  - FFDSHOW: 3882, Ok
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
[02:21:52] - Failed video encode, aborted
[02:21:52] END - BATCH SEQUENCE
dfsooner is offline   Reply With Quote
Old 20th May 2012, 23:03   #15120  |  Link
AmigaFuture
AmigaFuture's Avatar
The program multiAVCHD (4.1) is good for combining or making playable disks from your backups but there are bugs when processing Blu-ray directories (still). I've carefully processed several of my originals. I like to remove those warnings and more, not just trailers, (from any part of the structure) like DVDReMakePro and PGCEdit do for DVDs but until one is made (Any suggestions anyone?), BD-RB doesn't "play well" with multiAVCHD. Which is why Processed (or produced) Bugs (hehe) aren't supported here. Though, BD-RB's EDIT mode does function ~very well~ where it's at.
