#17065 | Link |
I'm also using now using my MacBook Pro Networked to my main computer. I rarely use Windows on it for anything other than some video editing, BD-RB, and Firefox, so I updated BD-RB to newest. I'm having BD-RB use the same settings/config as Gonca and I are using for Paul Unrated. I'll report soon.
Edit: I thought it was producing the 0 files during the MKV event..I missed that it did it during the extraction.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 6th May 2013 at 02:25. |
#17067 | Link |
BD-RB is almost done with Sherlock Holmes (2009) and it has 1 audio track. No 0 files at the moment.
[18:47:50] Building ALTERNATE OUTPUT Structure Part 1: No 0 files. Part 2: No 0 files. As that process changes, and just before MVKMERGE process starts 2 .SUP blank files are created. As well as 2 filename's representing what would be the compressed counterparts are made. Then "[18:49:53] - Failed to REBUILD".
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 6th May 2013 at 02:54. |
#17069 | Link |
@Jdobbs, AmigaFuture
I think I know where the problem manifests itself. 3 audio tracks are kept DTS-HD, and 2 AC3 at 192K. The DTS-HS appears to be processed correctly, however the 2 AC3 tracks are converted from 192k to 192k and the 0 byte tracks are the resulting AC3 tracks. Last edited by gonca; 6th May 2013 at 02:48. Reason: typing boo-boo |
#17070 | Link | |
![]() Join Date: Oct 2001
#17071 | Link |
jdobbs, I want to let you know if you are doing 3d and choose alternate movie output and then select "Automatically crop black border" option, encoder simply crashes.
Un-check "Automatically crop black border" causes encoder to continue. May be add some sort of logic if 3d is enabled then do not allow crop black border or simply ignore. BTW, Happy birthday and donation is on it's way for all the hard work you put into bd-rebuilder. Last edited by HWK; 6th May 2013 at 03:09. |
#17072 | Link |
I don't support hard work, but I do support passion and integrity. I hope you enjoy the donation. Be good to Yourself....and have some Fun!
Will test the next release when you're ready.
#17073 | Link |
Not able to 'Blank' items in new version...
Basically, I just upgraded to the new version (V0.44.04) and although I have added 'enable_blanking=1' in the config file, the blanking choices are still grayed out.
Any suggestions please? Thank you!!! Last edited by Lathe; 6th May 2013 at 04:57. |
#17076 | Link |
Look closer at "ENABLE_TEST".
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 6th May 2013 at 07:39. |
#17077 | Link |
@Jdobbs, Happy Birthday and I hope its less stressfull than the previous few hours. Downloaded the latest version and will test with Life of Pi 3D again and let you know the result.
Thanks for the effort you are making to get this all sorted out. Edit: Finished another encode of Life of Pi 3D with BD-rebuilder v0.44.04. Completed successfully. Last edited by richardrpg; 6th May 2013 at 10:01. |
#17079 | Link | |
Hi all,
First of all happy birthday jdobbs and thanks for BD-RB. Ok second I just cannot get BD-RB 3D MKV working and it fails whatever 3D I throw at it (multiple & single) but all 2D still works fine. Bellow is logs from a couple of movies I have been trying to do and as you can see same result on all, bit lost on what I'm doing wrong but if you can see just from looking at the log please let me know. Thanks in advance for any help. Quote:
#17080 | Link | |
Well the first thing I see is:
Another possibility (probability) is that you don't have the DirectshowMVCSource folder set up correctly. I would recommend you go to the BD Rebuilder folder, right after a failure, and copy the contents of LASTCMD.TXT to the clipboard. Then open a DOS window and paste it/run. That way you will see the specific error that X264 is encountering. Last edited by jdobbs; 6th May 2013 at 13:57. |
