#18101 | Link | |
#18102 | Link | |
[EDIT] Oops,... I should probably have addressed this to ghasting... [/EDIT]
For instance, could you run the process again, and after it completes the first task (Processing: VID_00274 (1 of 12)) look to see if "00274.track_4113.264" actually exists in the Workfiles folder. If it DOES exist at that point, keep looking in the Workfiles folder while the rest of the tasks are completed to see at what point it gets deleted. Some extra detail like this might help narrow down what the cause might be. |
#18104 | Link |
I did Monsters University 2D a couple of days ago and had no problems. I just used Sly and did file copy to HD and then full BD25 backup while removing the previews and then replacing the Coming soon to Theaters & Coming soon to Blu-ray banner .m2ts with a couple of the 24kb dummy place holders from the BD Rebuilder files. It plays great and still had like a 14,000 bitrate. Thanks jdobb's for the latest release, I have been doing a lot of MKV's with HD audio and the forced subtitles are really working great.
#18105 | Link |
h.264 encoder has stopped working error
Hello, on nearly all of my reencodes, I keep getting this error that says " h.264 encoder has stopped working " and it will not rebuild. This happens after extraction on all file and once it goes to start the encode, I get this error and have to shut down and it says reencode failed. I have over 2 TB free for the working folder and I have made sure my Inspect with BD Rebuilder is correct, I have uninstalled and reinstalled Haali Media Splitter, x264 Encoder, ffdshow and AviSynth and reinstalled all of them again per the versions need for the new beta of BD Rebuilder which is as of writing this is 0.44.17 and I even made the sure Uncompressed Audio is set for all supported and made sure wmv9 is used for VC-1 and MPEG2 is enabled and I even tried using libavcodec for VC-1 as well but to no avail, it always fails on movie I try to compress in any mode
#18106 | Link |
Here is the log of F&F 6 : Code:
---------------------- [11/05/13] BD Rebuilder v0.44.17 (beta) [12:51:45] Source: FAST_AND_FURIOUS_6_G51_00800 - Input BD size: 32,17 GB - Approximate total content: [02:10:06.673] - Target BD size: 22,95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - SHUTDOWN at completion enabled - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Subtitle [16] is defaulted ON. - Audio [3] set to default. [12:51:45] PHASE ONE, Encoding - [12:51:45] Processing: VID_00023 (1 of 22) - [12:51:45] Extracting A/V streams [VID_00023] - [12:57:36] Reencoding video [VID_00023] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 16*421 frames - Bitrate: 21*913 Kbs - [12:57:36] Reencoding: VID_00023, Pass 1 of 2 - [13:03:01] Reencoding: VID_00023, Pass 2 of 2 - [13:27:01] Video Encode complete - [13:27:01] Processing audio tracks - Track 4354 (fra): Keeping original audio - [13:27:01] Processing: VID_50407 (2 of 22) - [13:27:01] Extracting A/V streams [VID_50407] - [13:27:07] Reencoding video [VID_50407] - [13:27:07] Keeping original video (no reencode) - [13:27:07] Processing: VID_50403 (3 of 22) - [13:27:07] Extracting A/V streams [VID_50403] - [13:28:24] Reencoding video [VID_50403] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 39*375 frames - Bitrate: 22*203 Kbs - [13:28:24] Reencoding: VID_50403, Pass 1 of 2 - [13:40:32] Reencoding: VID_50403, Pass 2 of 2 - [14:39:59] Video Encode complete - [14:39:59] Processing: VID_50408 (4 of 22) - [14:39:59] Extracting A/V streams [VID_50408] - [14:40:05] Reencoding video [VID_50408] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 519 frames - Bitrate: 21*731 Kbs - [14:40:05] Reencoding: VID_50408, Pass 1 of 2 - [14:40:15] Reencoding: VID_50408, Pass 2 of 2 - [14:40:49] Video Encode complete - [14:40:49] Processing: VID_50359 (5 of 22) - [14:40:49] Extracting A/V streams [VID_50359] - [14:41:08] Reencoding video [VID_50359] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 6*451 frames - Bitrate: 21*748 Kbs - [14:41:08] Reencoding: VID_50359, Pass 1 of 2 - [14:43:08] Reencoding: VID_50359, Pass 2 of 2 - [14:51:39] Video Encode complete - [14:51:39] Processing: VID_50409 (6 of 22) - [14:51:39] Extracting A/V streams [VID_50409] - [14:51:45] Reencoding video [VID_50409] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*346 frames - Bitrate: 21*704 Kbs - [14:51:45] Reencoding: VID_50409, Pass 1 of 2 - [14:52:11] Reencoding: VID_50409, Pass 2 of 2 - [14:53:50] Video Encode complete - [14:53:50] Processing: VID_50406 (7 of 22) - [14:53:50] Extracting A/V streams [VID_50406] - [14:54:02] Reencoding video [VID_50406] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 6*433 frames - Bitrate: 22*691 Kbs - [14:54:02] Reencoding: VID_50406, Pass 1 of 2 - [14:56:03] Reencoding: VID_50406, Pass 2 of 2 - [15:07:16] Video Encode complete - [15:07:16] Processing: VID_50410 (8 of 22) - [15:07:16] Extracting A/V streams [VID_50410] - [15:07:22] Reencoding video [VID_50410] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 482 frames - Bitrate: 22*712 Kbs - [15:07:22] Reencoding: VID_50410, Pass 1 of 2 - [15:07:31] Reencoding: VID_50410, Pass 2 of 2 - [15:08:19] Video Encode complete - [15:08:19] Processing: VID_50360 (9 of 22) - [15:08:19] Extracting A/V streams [VID_50360] - [15:08:40] Reencoding video [VID_50360] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 8*126 frames - Bitrate: 21*664 Kbs - [15:08:40] Reencoding: VID_50360, Pass 1 of 2 - [15:11:08] Reencoding: VID_50360, Pass 2 of 2 - [15:22:23] Video Encode complete - [15:22:23] Processing: VID_50411 (10 of 22) - [15:22:23] Extracting A/V streams [VID_50411] - [15:22:28] Reencoding video [VID_50411] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 664 frames - Bitrate: 21*472 Kbs - [15:22:28] Reencoding: VID_50411, Pass 1 of 2 - [15:22:40] Reencoding: VID_50411, Pass 2 of 2 - [15:23:36] Video Encode complete - [15:23:36] Processing: VID_50361 (11 of 22) - [15:23:36] Extracting A/V streams [VID_50361] - [15:23:48] Reencoding video [VID_50361] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 4*651 frames - Bitrate: 21*918 Kbs - [15:23:48] Reencoding: VID_50361, Pass 1 of 2 - [15:25:13] Reencoding: VID_50361, Pass 2 of 2 - [15:31:52] Video Encode complete - [15:31:53] Processing: VID_50412 (12 of 22) - [15:31:53] Extracting A/V streams [VID_50412] - [15:31:58] Reencoding video [VID_50412] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 635 frames - Bitrate: 21*352 Kbs - [15:31:58] Reencoding: VID_50412, Pass 1 of 2 - [15:32:10] Reencoding: VID_50412, Pass 2 of 2 - [15:32:56] Video Encode complete - [15:32:56] Processing: VID_50362 (13 of 22) - [15:32:56] Extracting A/V streams [VID_50362] - [15:33:09] Reencoding video [VID_50362] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 4*939 frames - Bitrate: 21*847 Kbs - [15:33:09] Reencoding: VID_50362, Pass 1 of 2 - [15:34:36] Reencoding: VID_50362, Pass 2 of 2 - [15:42:18] Video Encode complete - [15:42:18] Processing: VID_50379 (14 of 22) - [15:42:18] Extracting A/V streams [VID_50379] - [15:42:25] Reencoding video [VID_50379] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*445 frames - Bitrate: 22*353 Kbs - [15:42:25] Reencoding: VID_50379, Pass 1 of 2 - [15:42:52] Reencoding: VID_50379, Pass 2 of 2 - [15:45:24] Video Encode complete - [15:45:24] Processing: VID_50363 (15 of 22) - [15:45:24] Extracting A/V streams [VID_50363] - [15:46:47] Reencoding video [VID_50363] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 61*710 frames - Bitrate: 22*281 Kbs - [15:46:47] Reencoding: VID_50363, Pass 1 of 2 - [16:05:02] Reencoding: VID_50363, Pass 2 of 2 - [17:47:06] Video Encode complete - [17:47:06] Processing: VID_50413 (16 of 22) - [17:47:06] Extracting A/V streams [VID_50413] - [17:47:12] Reencoding video [VID_50413] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 477 frames - Bitrate: 22*862 Kbs - [17:47:12] Reencoding: VID_50413, Pass 1 of 2 - [17:47:21] Reencoding: VID_50413, Pass 2 of 2 - [17:48:13] Video Encode complete - [17:48:13] Processing: VID_50368 (17 of 22) - [17:48:13] Extracting A/V streams [VID_50368] - [17:48:20] Reencoding video [VID_50368] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*325 frames - Bitrate: 23*062 Kbs - [17:48:20] Reencoding: VID_50368, Pass 1 of 2 - [17:48:45] Reencoding: VID_50368, Pass 2 of 2 - [17:51:19] Video Encode complete - [17:51:19] Processing: VID_50381 (18 of 22) - [17:51:19] Extracting A/V streams [VID_50381] - [17:51:25] Reencoding video [VID_50381] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*020 frames - Bitrate: 22*803 Kbs - [17:51:25] Reencoding: VID_50381, Pass 1 of 2 - [17:51:44] Reencoding: VID_50381, Pass 2 of 2 - [17:53:37] Video Encode complete - [17:53:37] Processing: VID_50404 (19 of 22) - [17:53:37] Extracting A/V streams [VID_50404] - [17:53:44] Reencoding video [VID_50404] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*572 frames - Bitrate: 22*813 Kbs - [17:53:44] Reencoding: VID_50404, Pass 1 of 2 - [17:54:13] Reencoding: VID_50404, Pass 2 of 2 - [17:57:13] Video Encode complete - [17:57:13] Processing: VID_50382 (20 of 22) - [17:57:13] Extracting A/V streams [VID_50382] - [17:57:18] Reencoding video [VID_50382] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 601 frames - Bitrate: 22*746 Kbs - [17:57:18] Reencoding: VID_50382, Pass 1 of 2 - [17:57:29] Reencoding: VID_50382, Pass 2 of 2 - [17:58:38] Video Encode complete - [17:58:38] Processing: VID_50405 (21 of 22) - [17:58:38] Extracting A/V streams [VID_50405] - [17:59:07] Reencoding video [VID_50405] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 15*645 frames - Bitrate: 22*228 Kbs - [17:59:07] Reencoding: VID_50405, Pass 1 of 2 - [18:03:58] Reencoding: VID_50405, Pass 2 of 2 - [18:28:46] Video Encode complete - [18:28:46] Processing: VID_50414 (22 of 22) - [18:28:46] Extracting A/V streams [VID_50414] - [18:29:08] Reencoding video [VID_50414] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 12*570 frames - Bitrate: 22*231 Kbs - [18:29:08] Reencoding: VID_50414, Pass 1 of 2 - [18:32:49] Reencoding: VID_50414, Pass 2 of 2 - [18:51:50] Video Encode complete [18:51:50]PHASE ONE complete [18:51:50]PHASE TWO - Rebuild Started - [18:51:50] Rebuilding BD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Can't open file: F:\RIPS\WORKFILES\00023.track_4113.264 [18:51:53] - Failed to REBUILD Last edited by jdobbs; 6th November 2013 at 14:08. |
#18108 | Link |
Same problem I had with Breaking Dawn Part 2:
http://forum.doom9.org/showthread.php?p=1645331#post1645331 - [15:08:36] Rebuilding BD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Can't open file: G:\TBD2 ABORT\WORKFILES\00504.track_4113.264 [15:08:40] - Failed to REBUILD File 00504.track_4113.264 did exist but disappeared later. |
#18110 | Link | |
![]() Join Date: Oct 2001
#18111 | Link |
I do somewhere in the neighborhood of 3-5 encodes a day, every day, and I've never seen this happen. I need an exact set of repeatable circumstances and your BD-RB settings (the INI file) or I'll never be able to fix it.
#18112 | Link |
I tried Monsters U again by ripping the movie as files to the hard drive. Then I used BDRB to encode movie only (25BD). I got the exact same error with the same missing file. Here are the last few lines of the log file...
[21:39:30]PHASE TWO - Rebuild Started - [21:39:30] Rebuilding BD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Can't open file: D:\TEMP\WORKFILES\00875.track_4113.264 [21:39:33] - Failed to REBUILD |
#18113 | Link | |
Are you doing a full backup or movie-only? Any odd settings? It's hard to help with only pieces of the log... Last edited by jdobbs; 6th November 2013 at 17:00. |
#18114 | Link | |
I am doing movie only. No odd settings I'm aware of. I will post the log in multiple parts (this site won't let me list the whole thing). I will try again without antivirus running. Log part 1: Code:
[11/05/13] BD Rebuilder v0.44.17 (beta) [20:19:44] Source: MONSTERS_UNIVERSITY_00800 - Input BD size: 25.17 GB - Approximate total content: [01:43:47.720] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [20:19:44] PHASE ONE, Encoding - [20:19:44] Processing: VID_00875 (1 of 132) - [20:19:44] Extracting A/V streams [VID_00875] - Extracting A/V to M2TS [VID_00875] - Extracting A/V from M2TS [VID_00875] - [20:47:25] Reencoding video [VID_00875] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,176 frames - Bitrate: 27,331 Kbs - [20:47:25] Reencoding: VID_00875, Pass 1 of 1 - [20:48:09] Video Encode complete - [20:48:09] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:48:09] Processing: VID_00876 (2 of 132) - [20:48:09] Extracting A/V streams [VID_00876] - [20:48:14] Reencoding video [VID_00876] - [20:48:14] Keeping original video (no reencode) - [20:48:14] Processing: VID_00879 (3 of 132) - [20:48:14] Extracting A/V streams [VID_00879] - [20:48:26] Reencoding video [VID_00879] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,972 frames - Bitrate: 29,410 Kbs - [20:48:26] Reencoding: VID_00879, Pass 1 of 1 - [20:48:55] Video Encode complete - [20:48:55] Processing: VID_00880 (4 of 132) - [20:48:55] Extracting A/V streams [VID_00880] - [20:49:00] Reencoding video [VID_00880] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 340 frames - Bitrate: 27,446 Kbs - [20:49:00] Reencoding: VID_00880, Pass 1 of 1 - [20:49:04] Video Encode complete - [20:49:04] Processing: VID_00882 (5 of 132) - [20:49:04] Extracting A/V streams [VID_00882] - [20:49:21] Reencoding video [VID_00882] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,389 frames - Bitrate: 28,510 Kbs - [20:49:21] Reencoding: VID_00882, Pass 1 of 1 - [20:50:08] Video Encode complete - [20:50:08] Processing: VID_00883 (6 of 132) - [20:50:08] Extracting A/V streams [VID_00883] - [20:50:17] Reencoding video [VID_00883] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,154 frames - Bitrate: 28,635 Kbs - [20:50:17] Reencoding: VID_00883, Pass 1 of 1 - [20:50:31] Video Encode complete - [20:50:31] Processing: VID_00886 (7 of 132) - [20:50:31] Extracting A/V streams [VID_00886] - [20:50:38] Reencoding video [VID_00886] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 701 frames - Bitrate: 27,381 Kbs - [20:50:38] Reencoding: VID_00886, Pass 1 of 1 - [20:50:48] Video Encode complete - [20:50:48] Processing: VID_00887 (8 of 132) - [20:50:48] Extracting A/V streams [VID_00887] - [20:50:53] Reencoding video [VID_00887] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 518 frames - Bitrate: 28,193 Kbs - [20:50:54] Reencoding: VID_00887, Pass 1 of 1 - [20:51:01] Video Encode complete - [20:51:01] Processing: VID_00890 (9 of 132) - [20:51:01] Extracting A/V streams [VID_00890] - [20:51:08] Reencoding video [VID_00890] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 846 frames - Bitrate: 30,225 Kbs - [20:51:08] Reencoding: VID_00890, Pass 1 of 1 - [20:51:21] Video Encode complete - [20:51:21] Processing: VID_00891 (10 of 132) - [20:51:21] Extracting A/V streams [VID_00891] - [20:51:28] Reencoding video [VID_00891] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 791 frames - Bitrate: 27,398 Kbs - [20:51:28] Reencoding: VID_00891, Pass 1 of 1 - [20:51:39] Video Encode complete - [20:51:39] Processing: VID_00894 (11 of 132) - [20:51:39] Extracting A/V streams [VID_00894] - [20:51:47] Reencoding video [VID_00894] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,153 frames - Bitrate: 28,153 Kbs - [20:51:47] Reencoding: VID_00894, Pass 1 of 1 - [20:52:04] Video Encode complete - [20:52:04] Processing: VID_00895 (12 of 132) - [20:52:04] Extracting A/V streams [VID_00895] - [20:52:13] Reencoding video [VID_00895] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,294 frames - Bitrate: 27,461 Kbs - [20:52:13] Reencoding: VID_00895, Pass 1 of 1 - [20:52:31] Video Encode complete - [20:52:31] Processing: VID_00898 (13 of 132) - [20:52:31] Extracting A/V streams [VID_00898] - [20:52:40] Reencoding video [VID_00898] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,256 frames - Bitrate: 27,378 Kbs - [20:52:40] Reencoding: VID_00898, Pass 1 of 1 - [20:52:57] Video Encode complete - [20:52:57] Processing: VID_00899 (14 of 132) - [20:52:57] Extracting A/V streams [VID_00899] - [20:53:02] Reencoding video [VID_00899] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 353 frames - Bitrate: 27,466 Kbs - [20:53:02] Reencoding: VID_00899, Pass 1 of 1 - [20:53:07] Video Encode complete - [20:53:07] Processing: VID_00902 (15 of 132) - [20:53:07] Extracting A/V streams [VID_00902] - [20:53:12] Reencoding video [VID_00902] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 215 frames - Bitrate: 29,964 Kbs - [20:53:12] Reencoding: VID_00902, Pass 1 of 1 - [20:53:15] Video Encode complete - [20:53:15] Processing: VID_00903 (16 of 132) - [20:53:15] Extracting A/V streams [VID_00903] - [20:53:20] Reencoding video [VID_00903] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 339 frames - Bitrate: 32,558 Kbs - [20:53:20] Reencoding: VID_00903, Pass 1 of 1 - [20:53:25] Video Encode complete - [20:53:25] Processing: VID_00906 (17 of 132) - [20:53:25] Extracting A/V streams [VID_00906] - [20:53:30] Reencoding video [VID_00906] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 508 frames - Bitrate: 27,210 Kbs - [20:53:31] Reencoding: VID_00906, Pass 1 of 1 - [20:53:37] Video Encode complete - [20:53:37] Processing: VID_00907 (18 of 132) - [20:53:37] Extracting A/V streams [VID_00907] - [20:53:42] Reencoding video [VID_00907] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 355 frames - Bitrate: 29,735 Kbs - [20:53:42] Reencoding: VID_00907, Pass 1 of 1 - [20:53:48] Video Encode complete - [20:53:48] Processing: VID_00910 (19 of 132) - [20:53:48] Extracting A/V streams [VID_00910] - [20:53:53] Reencoding video [VID_00910] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 495 frames - Bitrate: 27,449 Kbs - [20:53:53] Reencoding: VID_00910, Pass 1 of 1 - [20:54:00] Video Encode complete - [20:54:00] Processing: VID_00911 (20 of 132) - [20:54:00] Extracting A/V streams [VID_00911] - [20:54:05] Reencoding video [VID_00911] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 339 frames - Bitrate: 27,272 Kbs - [20:54:05] Reencoding: VID_00911, Pass 1 of 1 - [20:54:10] Video Encode complete - [20:54:10] Processing: VID_00914 (21 of 132) - [20:54:10] Extracting A/V streams [VID_00914] - [20:54:18] Reencoding video [VID_00914] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 784 frames - Bitrate: 30,535 Kbs - [20:54:18] Reencoding: VID_00914, Pass 1 of 1 - [20:54:29] Video Encode complete - [20:54:29] Processing: VID_00915 (22 of 132) - [20:54:29] Extracting A/V streams [VID_00915] - [20:54:35] Reencoding video [VID_00915] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 365 frames - Bitrate: 34,143 Kbs - [20:54:35] Reencoding: VID_00915, Pass 1 of 1 - [20:54:41] Video Encode complete - [20:54:41] Processing: VID_00918 (23 of 132) - [20:54:41] Extracting A/V streams [VID_00918] - [20:54:47] Reencoding video [VID_00918] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 670 frames - Bitrate: 31,473 Kbs - [20:54:47] Reencoding: VID_00918, Pass 1 of 1 - [20:54:57] Video Encode complete - [20:54:57] Processing: VID_00919 (24 of 132) - [20:54:57] Extracting A/V streams [VID_00919] - [20:55:03] Reencoding video [VID_00919] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 395 frames - Bitrate: 34,141 Kbs - [20:55:03] Reencoding: VID_00919, Pass 1 of 1 - [20:55:09] Video Encode complete - [20:55:09] Processing: VID_00922 (25 of 132) - [20:55:09] Extracting A/V streams [VID_00922] - [20:55:15] Reencoding video [VID_00922] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 532 frames - Bitrate: 29,829 Kbs - [20:55:15] Reencoding: VID_00922, Pass 1 of 1 - [20:55:23] Video Encode complete - [20:55:23] Processing: VID_00923 (26 of 132) - [20:55:23] Extracting A/V streams [VID_00923] - [20:55:30] Reencoding video [VID_00923] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 975 frames - Bitrate: 28,864 Kbs - [20:55:30] Reencoding: VID_00923, Pass 1 of 1 - [20:55:44] Video Encode complete - [20:55:44] Processing: VID_00926 (27 of 132) - [20:55:44] Extracting A/V streams [VID_00926] - [20:55:48] Reencoding video [VID_00926] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 133 frames - Bitrate: 27,557 Kbs - [20:55:48] Reencoding: VID_00926, Pass 1 of 1 - [20:55:50] Video Encode complete - [20:55:50] Processing: VID_00927 (28 of 132) - [20:55:50] Extracting A/V streams [VID_00927] - [20:55:55] Reencoding video [VID_00927] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 372 frames - Bitrate: 27,436 Kbs - [20:55:55] Reencoding: VID_00927, Pass 1 of 1 - [20:56:01] Video Encode complete - [20:56:01] Processing: VID_00929 (29 of 132) - [20:56:01] Extracting A/V streams [VID_00929] - [20:56:07] Reencoding video [VID_00929] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 742 frames - Bitrate: 26,999 Kbs - [20:56:07] Reencoding: VID_00929, Pass 1 of 1 - [20:56:18] Video Encode complete - [20:56:18] Processing: VID_00930 (30 of 132) - [20:56:18] Extracting A/V streams [VID_00930] - [20:56:23] Reencoding video [VID_00930] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 435 frames - Bitrate: 27,280 Kbs - [20:56:23] Reencoding: VID_00930, Pass 1 of 1 - [20:56:29] Video Encode complete - [20:56:29] Processing: VID_00933 (31 of 132) - [20:56:29] Extracting A/V streams [VID_00933] - [20:56:39] Reencoding video [VID_00933] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,779 frames - Bitrate: 27,792 Kbs - [20:56:39] Reencoding: VID_00933, Pass 1 of 1 - [20:57:03] Video Encode complete - [20:57:03] Processing: VID_00934 (32 of 132) - [20:57:03] Extracting A/V streams [VID_00934] - [20:57:10] Reencoding video [VID_00934] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 602 frames - Bitrate: 28,475 Kbs - [20:57:10] Reencoding: VID_00934, Pass 1 of 1 - [20:57:19] Video Encode complete - [20:57:19] Processing: VID_00936 (33 of 132) - [20:57:19] Extracting A/V streams [VID_00936] - [20:57:29] Reencoding video [VID_00936] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,770 frames - Bitrate: 28,167 Kbs - [20:57:29] Reencoding: VID_00936, Pass 1 of 1 - [20:57:55] Video Encode complete - [20:57:55] Processing: VID_00937 (34 of 132) - [20:57:55] Extracting A/V streams [VID_00937] - [20:58:00] Reencoding video [VID_00937] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 338 frames - Bitrate: 28,141 Kbs - [20:58:00] Reencoding: VID_00937, Pass 1 of 1 - [20:58:05] Video Encode complete - [20:58:05] Processing: VID_00939 (35 of 132) - [20:58:05] Extracting A/V streams [VID_00939] - [20:58:12] Reencoding video [VID_00939] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 893 frames - Bitrate: 27,540 Kbs - [20:58:12] Reencoding: VID_00939, Pass 1 of 1 - [20:58:25] Video Encode complete - [20:58:25] Processing: VID_00940 (36 of 132) - [20:58:25] Extracting A/V streams [VID_00940] - [20:58:30] Reencoding video [VID_00940] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 357 frames - Bitrate: 28,664 Kbs - [20:58:30] Reencoding: VID_00940, Pass 1 of 1 - [20:58:35] Video Encode complete - [20:58:35] Processing: VID_00943 (37 of 132) - [20:58:35] Extracting A/V streams [VID_00943] - [20:58:47] Reencoding video [VID_00943] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,211 frames - Bitrate: 28,165 Kbs - [20:58:47] Reencoding: VID_00943, Pass 1 of 1 - [20:59:19] Video Encode complete - [20:59:19] Processing: VID_00944 (38 of 132) - [20:59:19] Extracting A/V streams [VID_00944] - [20:59:24] Reencoding video [VID_00944] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 317 frames - Bitrate: 27,529 Kbs Last edited by jdobbs; 6th November 2013 at 18:28. |
#18115 | Link |
Part 2:
- [20:59:24] Reencoding: VID_00944, Pass 1 of 1 - [20:59:29] Video Encode complete - [20:59:29] Processing: VID_00946 (39 of 132) - [20:59:29] Extracting A/V streams [VID_00946] - [20:59:34] Reencoding video [VID_00946] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 336 frames - Bitrate: 27,643 Kbs - [20:59:34] Reencoding: VID_00946, Pass 1 of 1 - [20:59:39] Video Encode complete - [20:59:39] Processing: VID_00949 (40 of 132) - [20:59:39] Extracting A/V streams [VID_00949] - [20:59:44] Reencoding video [VID_00949] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 386 frames - Bitrate: 27,263 Kbs - [20:59:44] Reencoding: VID_00949, Pass 1 of 1 - [20:59:50] Video Encode complete - [20:59:50] Processing: VID_00950 (41 of 132) - [20:59:50] Extracting A/V streams [VID_00950] - [20:59:55] Reencoding video [VID_00950] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 352 frames - Bitrate: 27,360 Kbs - [20:59:55] Reencoding: VID_00950, Pass 1 of 1 - [21:00:00] Video Encode complete - [21:00:00] Processing: VID_00952 (42 of 132) - [21:00:00] Extracting A/V streams [VID_00952] - [21:00:08] Reencoding video [VID_00952] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 912 frames - Bitrate: 27,676 Kbs - [21:00:08] Reencoding: VID_00952, Pass 1 of 1 - [21:00:20] Video Encode complete - [21:00:20] Processing: VID_00953 (43 of 132) - [21:00:20] Extracting A/V streams [VID_00953] - [21:00:25] Reencoding video [VID_00953] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 370 frames - Bitrate: 26,750 Kbs - [21:00:25] Reencoding: VID_00953, Pass 1 of 1 - [21:00:31] Video Encode complete - [21:00:31] Processing: VID_00956 (44 of 132) - [21:00:31] Extracting A/V streams [VID_00956] - [21:00:36] Reencoding video [VID_00956] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 291 frames - Bitrate: 27,543 Kbs - [21:00:36] Reencoding: VID_00956, Pass 1 of 1 - [21:00:39] Video Encode complete - [21:00:39] Processing: VID_00957 (45 of 132) - [21:00:39] Extracting A/V streams [VID_00957] - [21:00:44] Reencoding video [VID_00957] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 304 frames - Bitrate: 28,343 Kbs - [21:00:44] Reencoding: VID_00957, Pass 1 of 1 - [21:00:49] Video Encode complete - [21:00:49] Processing: VID_00959 (46 of 132) - [21:00:49] Extracting A/V streams [VID_00959] - [21:01:20] Reencoding video [VID_00959] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,039 frames - Bitrate: 28,633 Kbs - [21:01:20] Reencoding: VID_00959, Pass 1 of 1 - [21:02:57] Video Encode complete - [21:02:57] Processing: VID_00961 (47 of 132) - [21:02:57] Extracting A/V streams [VID_00961] - [21:03:04] Reencoding video [VID_00961] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 908 frames - Bitrate: 27,536 Kbs - [21:03:04] Reencoding: VID_00961, Pass 1 of 1 - [21:03:16] Video Encode complete - [21:03:16] Processing: VID_00969 (48 of 132) - [21:03:16] Extracting A/V streams [VID_00969] - [21:03:23] Reencoding video [VID_00969] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 625 frames - Bitrate: 28,101 Kbs - [21:03:23] Reencoding: VID_00969, Pass 1 of 1 - [21:03:32] Video Encode complete - [21:03:32] Processing: VID_00971 (49 of 132) - [21:03:32] Extracting A/V streams [VID_00971] - [21:03:37] Reencoding video [VID_00971] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 366 frames - Bitrate: 27,566 Kbs - [21:03:37] Reencoding: VID_00971, Pass 1 of 1 - [21:03:42] Video Encode complete - [21:03:42] Processing: VID_00972 (50 of 132) - [21:03:42] Extracting A/V streams [VID_00972] - [21:03:48] Reencoding video [VID_00972] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 673 frames - Bitrate: 28,086 Kbs - [21:03:48] Reencoding: VID_00972, Pass 1 of 1 - [21:03:58] Video Encode complete - [21:03:58] Processing: VID_00974 (51 of 132) - [21:03:58] Extracting A/V streams [VID_00974] - [21:04:02] Reencoding video [VID_00974] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 124 frames - Bitrate: 27,490 Kbs - [21:04:02] Reencoding: VID_00974, Pass 1 of 1 - [21:04:04] Video Encode complete - [21:04:04] Processing: VID_00975 (52 of 132) - [21:04:04] Extracting A/V streams [VID_00975] - [21:04:10] Reencoding video [VID_00975] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 590 frames - Bitrate: 27,595 Kbs - [21:04:10] Reencoding: VID_00975, Pass 1 of 1 - [21:04:18] Video Encode complete - [21:04:18] Processing: VID_00977 (53 of 132) - [21:04:18] Extracting A/V streams [VID_00977] - [21:04:26] Reencoding video [VID_00977] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,110 frames - Bitrate: 27,350 Kbs - [21:04:26] Reencoding: VID_00977, Pass 1 of 1 - [21:04:41] Video Encode complete - [21:04:41] Processing: VID_00978 (54 of 132) - [21:04:41] Extracting A/V streams [VID_00978] - [21:04:46] Reencoding video [VID_00978] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 301 frames - Bitrate: 28,353 Kbs - [21:04:46] Reencoding: VID_00978, Pass 1 of 1 - [21:04:50] Video Encode complete - [21:04:51] Processing: VID_00980 (55 of 132) - [21:04:51] Extracting A/V streams [VID_00980] - [21:04:55] Reencoding video [VID_00980] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 164 frames - Bitrate: 28,000 Kbs - [21:04:55] Reencoding: VID_00980, Pass 1 of 1 - [21:04:57] Video Encode complete - [21:04:57] Processing: VID_00981 (56 of 132) - [21:04:57] Extracting A/V streams [VID_00981] - [21:05:02] Reencoding video [VID_00981] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 276 frames - Bitrate: 28,578 Kbs - [21:05:02] Reencoding: VID_00981, Pass 1 of 1 - [21:05:06] Video Encode complete - [21:05:06] Processing: VID_00983 (57 of 132) - [21:05:06] Extracting A/V streams [VID_00983] - [21:05:14] Reencoding video [VID_00983] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,007 frames - Bitrate: 27,266 Kbs - [21:05:14] Reencoding: VID_00983, Pass 1 of 1 - [21:05:27] Video Encode complete - [21:05:27] Processing: VID_00984 (58 of 132) - [21:05:27] Extracting A/V streams [VID_00984] - [21:05:33] Reencoding video [VID_00984] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 456 frames - Bitrate: 27,275 Kbs - [21:05:33] Reencoding: VID_00984, Pass 1 of 1 - [21:05:38] Video Encode complete - [21:05:38] Processing: VID_00987 (59 of 132) - [21:05:39] Extracting A/V streams [VID_00987] - [21:06:03] Reencoding video [VID_00987] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,493 frames - Bitrate: 27,294 Kbs - [21:06:03] Reencoding: VID_00987, Pass 1 of 1 - [21:07:29] Video Encode complete - [21:07:29] Processing: VID_00988 (60 of 132) - [21:07:29] Extracting A/V streams [VID_00988] - [21:07:34] Reencoding video [VID_00988] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 303 frames - Bitrate: 27,003 Kbs - [21:07:34] Reencoding: VID_00988, Pass 1 of 1 - [21:07:38] Video Encode complete - [21:07:38] Processing: VID_00990 (61 of 132) - [21:07:38] Extracting A/V streams [VID_00990] - [21:07:43] Reencoding video [VID_00990] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 280 frames - Bitrate: 27,339 Kbs - [21:07:43] Reencoding: VID_00990, Pass 1 of 1 - [21:07:48] Video Encode complete - [21:07:48] Processing: VID_00991 (62 of 132) - [21:07:48] Extracting A/V streams [VID_00991] - [21:07:53] Reencoding video [VID_00991] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 438 frames - Bitrate: 28,285 Kbs - [21:07:53] Reencoding: VID_00991, Pass 1 of 1 - [21:08:00] Video Encode complete - [21:08:00] Processing: VID_00994 (63 of 132) - [21:08:00] Extracting A/V streams [VID_00994] - [21:08:04] Reencoding video [VID_00994] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 170 frames - Bitrate: 28,060 Kbs - [21:08:04] Reencoding: VID_00994, Pass 1 of 1 - [21:08:07] Video Encode complete - [21:08:07] Processing: VID_00995 (64 of 132) - [21:08:07] Extracting A/V streams [VID_00995] - [21:08:12] Reencoding video [VID_00995] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 332 frames - Bitrate: 27,608 Kbs - [21:08:12] Reencoding: VID_00995, Pass 1 of 1 - [21:08:17] Video Encode complete - [21:08:17] Processing: VID_00998 (65 of 132) - [21:08:17] Extracting A/V streams [VID_00998] - [21:08:22] Reencoding video [VID_00998] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 313 frames - Bitrate: 27,315 Kbs - [21:08:22] Reencoding: VID_00998, Pass 1 of 1 - [21:08:26] Video Encode complete - [21:08:26] Processing: VID_01000 (66 of 132) - [21:08:26] Extracting A/V streams [VID_01000] - [21:08:30] Reencoding video [VID_01000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 101 frames - Bitrate: 27,421 Kbs - [21:08:30] Reencoding: VID_01000, Pass 1 of 1 - [21:08:32] Video Encode complete - [21:08:32] Processing: VID_01001 (67 of 132) - [21:08:32] Extracting A/V streams [VID_01001] - [21:08:38] Reencoding video [VID_01001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 490 frames - Bitrate: 27,481 Kbs - [21:08:38] Reencoding: VID_01001, Pass 1 of 1 - [21:08:45] Video Encode complete - [21:08:45] Processing: VID_01005 (68 of 132) - [21:08:45] Extracting A/V streams [VID_01005] - [21:08:50] Reencoding video [VID_01005] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 370 frames - Bitrate: 27,731 Kbs - [21:08:50] Reencoding: VID_01005, Pass 1 of 1 - [21:08:56] Video Encode complete - [21:08:56] Processing: VID_01007 (69 of 132) - [21:08:56] Extracting A/V streams [VID_01007] - [21:09:12] Reencoding video [VID_01007] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,679 frames - Bitrate: 27,828 Kbs - [21:09:12] Reencoding: VID_01007, Pass 1 of 1 - [21:10:04] Video Encode complete - [21:10:04] Processing: VID_01008 (70 of 132) - [21:10:04] Extracting A/V streams [VID_01008] - [21:10:10] Reencoding video [VID_01008] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 328 frames - Bitrate: 28,224 Kbs - [21:10:10] Reencoding: VID_01008, Pass 1 of 1 - [21:10:14] Video Encode complete - [21:10:14] Processing: VID_01010 (71 of 132) - [21:10:14] Extracting A/V streams [VID_01010] - [21:10:19] Reencoding video [VID_01010] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 123 frames - Bitrate: 29,913 Kbs - [21:10:19] Reencoding: VID_01010, Pass 1 of 1 - [21:10:21] Video Encode complete - [21:10:21] Processing: VID_01011 (72 of 132) - [21:10:21] Extracting A/V streams [VID_01011] - [21:10:26] Reencoding video [VID_01011] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 268 frames - Bitrate: 31,123 Kbs - [21:10:26] Reencoding: VID_01011, Pass 1 of 1 - [21:10:30] Video Encode complete - [21:10:30] Processing: VID_01013 (73 of 132) - [21:10:30] Extracting A/V streams [VID_01013] - [21:10:35] Reencoding video [VID_01013] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 247 frames - Bitrate: 34,155 Kbs - [21:10:35] Reencoding: VID_01013, Pass 1 of 1 - [21:10:39] Video Encode complete - [21:10:39] Processing: VID_01014 (74 of 132) - [21:10:39] Extracting A/V streams [VID_01014] - [21:10:44] Reencoding video [VID_01014] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 280 frames - Bitrate: 30,391 Kbs - [21:10:44] Reencoding: VID_01014, Pass 1 of 1 - [21:10:49] Video Encode complete - [21:10:49] Processing: VID_01016 (75 of 132) - [21:10:49] Extracting A/V streams [VID_01016] - [21:10:53] Reencoding video [VID_01016] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 85 frames - Bitrate: 33,894 Kbs - [21:10:53] Reencoding: VID_01016, Pass 1 of 1 - [21:10:54] Video Encode complete - [21:10:54] Processing: VID_01017 (76 of 132) - [21:10:55] Extracting A/V streams [VID_01017] - [21:11:02] Reencoding video [VID_01017] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 893 frames - Bitrate: 29,380 Kbs - [21:11:02] Reencoding: VID_01017, Pass 1 of 1 - [21:11:15] Video Encode complete - [21:11:15] Processing: VID_01022 (77 of 132) - [21:11:15] Extracting A/V streams [VID_01022] - [21:11:34] Reencoding video [VID_01022] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,320 frames - Bitrate: 27,685 Kbs - [21:11:34] Reencoding: VID_01022, Pass 1 of 1 - [21:12:34] Video Encode complete - [21:12:34] Processing: VID_01024 (78 of 132) - [21:12:34] Extracting A/V streams [VID_01024] - [21:12:39] Reencoding video [VID_01024] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 271 frames - Bitrate: 28,813 Kbs - [21:12:39] Reencoding: VID_01024, Pass 1 of 1 - [21:12:43] Video Encode complete - [21:12:43] Processing: VID_01027 (79 of 132) - [21:12:43] Extracting A/V streams [VID_01027] - [21:13:00] Reencoding video [VID_01027] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,556 frames - Bitrate: 27,646 Kbs - [21:13:00] Reencoding: VID_01027, Pass 1 of 1 - [21:13:51] Video Encode complete - [21:13:52] Processing: VID_01028 (80 of 132) - [21:13:52] Extracting A/V streams [VID_01028] - [21:13:56] Reencoding video [VID_01028] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 319 frames - Bitrate: 29,125 Kbs - [21:13:57] Reencoding: VID_01028, Pass 1 of 1 - [21:14:01] Video Encode complete - [21:14:01] Processing: VID_01031 (81 of 132) - [21:14:01] Extracting A/V streams [VID_01031] - [21:14:19] Reencoding video [VID_01031] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,536 frames - Bitrate: 30,929 Kbs - [21:14:19] Reencoding: VID_01031, Pass 1 of 1 - [21:15:13] Video Encode complete - [21:15:13] Processing: VID_01032 (82 of 132) - [21:15:13] Extracting A/V streams [VID_01032] - [21:15:29] Reencoding video [VID_01032] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,064 frames - Bitrate: 28,892 Kbs - [21:15:29] Reencoding: VID_01032, Pass 1 of 1 - [21:16:12] Video Encode complete - [21:16:12] Processing: VID_01043 (83 of 132) - [21:16:12] Extracting A/V streams [VID_01043] - [21:16:17] Reencoding video [VID_01043] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 152 frames - Bitrate: 27,234 Kbs - [21:16:17] Reencoding: VID_01043, Pass 1 of 1 - [21:16:19] Video Encode complete - [21:16:19] Processing: VID_01044 (84 of 132) - [21:16:19] Extracting A/V streams [VID_01044] - [21:16:27] Reencoding video [VID_01044] Last edited by jdobbs; 6th November 2013 at 18:28. |
#18116 | Link |
Part 3:
- Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,009 frames - Bitrate: 27,426 Kbs - [21:16:27] Reencoding: VID_01044, Pass 1 of 1 - [21:16:41] Video Encode complete - [21:16:41] Processing: VID_01047 (85 of 132) - [21:16:41] Extracting A/V streams [VID_01047] - [21:16:48] Reencoding video [VID_01047] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 772 frames - Bitrate: 27,516 Kbs - [21:16:48] Reencoding: VID_01047, Pass 1 of 1 - [21:16:58] Video Encode complete - [21:16:58] Processing: VID_01048 (86 of 132) - [21:16:58] Extracting A/V streams [VID_01048] - [21:17:03] Reencoding video [VID_01048] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 229 frames - Bitrate: 27,246 Kbs - [21:17:03] Reencoding: VID_01048, Pass 1 of 1 - [21:17:06] Video Encode complete - [21:17:06] Processing: VID_01051 (87 of 132) - [21:17:06] Extracting A/V streams [VID_01051] - [21:17:14] Reencoding video [VID_01051] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 948 frames - Bitrate: 28,655 Kbs - [21:17:14] Reencoding: VID_01051, Pass 1 of 1 - [21:17:27] Video Encode complete - [21:17:27] Processing: VID_01052 (88 of 132) - [21:17:27] Extracting A/V streams [VID_01052] - [21:17:49] Reencoding video [VID_01052] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,541 frames - Bitrate: 29,357 Kbs - [21:17:49] Reencoding: VID_01052, Pass 1 of 1 - [21:18:54] Video Encode complete - [21:18:54] Processing: VID_01055 (89 of 132) - [21:18:54] Extracting A/V streams [VID_01055] - [21:18:59] Reencoding video [VID_01055] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 249 frames - Bitrate: 28,068 Kbs - [21:18:59] Reencoding: VID_01055, Pass 1 of 1 - [21:19:03] Video Encode complete - [21:19:03] Processing: VID_01058 (90 of 132) - [21:19:03] Extracting A/V streams [VID_01058] - [21:19:14] Reencoding video [VID_01058] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,965 frames - Bitrate: 27,887 Kbs - [21:19:14] Reencoding: VID_01058, Pass 1 of 1 - [21:19:42] Video Encode complete - [21:19:42] Processing: VID_01059 (91 of 132) - [21:19:42] Extracting A/V streams [VID_01059] - [21:19:47] Reencoding video [VID_01059] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 295 frames - Bitrate: 28,578 Kbs - [21:19:47] Reencoding: VID_01059, Pass 1 of 1 - [21:19:52] Video Encode complete - [21:19:52] Processing: VID_01062 (92 of 132) - [21:19:52] Extracting A/V streams [VID_01062] - [21:20:02] Reencoding video [VID_01062] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,847 frames - Bitrate: 28,612 Kbs - [21:20:02] Reencoding: VID_01062, Pass 1 of 1 - [21:20:28] Video Encode complete - [21:20:28] Processing: VID_01063 (93 of 132) - [21:20:28] Extracting A/V streams [VID_01063] - [21:20:33] Reencoding video [VID_01063] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 268 frames - Bitrate: 28,514 Kbs - [21:20:33] Reencoding: VID_01063, Pass 1 of 1 - [21:20:37] Video Encode complete - [21:20:37] Processing: VID_01066 (94 of 132) - [21:20:37] Extracting A/V streams [VID_01066] - [21:20:44] Reencoding video [VID_01066] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 680 frames - Bitrate: 28,361 Kbs - [21:20:44] Reencoding: VID_01066, Pass 1 of 1 - [21:20:54] Video Encode complete - [21:20:54] Processing: VID_01067 (95 of 132) - [21:20:54] Extracting A/V streams [VID_01067] - [21:20:59] Reencoding video [VID_01067] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 427 frames - Bitrate: 27,492 Kbs - [21:20:59] Reencoding: VID_01067, Pass 1 of 1 - [21:21:06] Video Encode complete - [21:21:06] Processing: VID_01069 (96 of 132) - [21:21:06] Extracting A/V streams [VID_01069] - [21:21:12] Reencoding video [VID_01069] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 705 frames - Bitrate: 27,338 Kbs - [21:21:12] Reencoding: VID_01069, Pass 1 of 1 - [21:21:22] Video Encode complete - [21:21:22] Processing: VID_01070 (97 of 132) - [21:21:22] Extracting A/V streams [VID_01070] - [21:21:27] Reencoding video [VID_01070] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 239 frames - Bitrate: 27,314 Kbs - [21:21:27] Reencoding: VID_01070, Pass 1 of 1 - [21:21:30] Video Encode complete - [21:21:30] Processing: VID_01072 (98 of 132) - [21:21:30] Extracting A/V streams [VID_01072] - [21:21:35] Reencoding video [VID_01072] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 299 frames - Bitrate: 27,342 Kbs - [21:21:35] Reencoding: VID_01072, Pass 1 of 1 - [21:21:39] Video Encode complete - [21:21:39] Processing: VID_01073 (99 of 132) - [21:21:39] Extracting A/V streams [VID_01073] - [21:21:45] Reencoding video [VID_01073] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 548 frames - Bitrate: 27,171 Kbs - [21:21:45] Reencoding: VID_01073, Pass 1 of 1 - [21:21:53] Video Encode complete - [21:21:53] Processing: VID_01075 (100 of 132) - [21:21:53] Extracting A/V streams [VID_01075] - [21:22:06] Reencoding video [VID_01075] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,263 frames - Bitrate: 29,402 Kbs - [21:22:06] Reencoding: VID_01075, Pass 1 of 1 - [21:22:37] Video Encode complete - [21:22:38] Processing: VID_01076 (101 of 132) - [21:22:38] Extracting A/V streams [VID_01076] - [21:22:44] Reencoding video [VID_01076] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 607 frames - Bitrate: 30,228 Kbs - [21:22:44] Reencoding: VID_01076, Pass 1 of 1 - [21:22:53] Video Encode complete - [21:22:53] Processing: VID_01078 (102 of 132) - [21:22:53] Extracting A/V streams [VID_01078] - [21:23:00] Reencoding video [VID_01078] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 800 frames - Bitrate: 27,527 Kbs - [21:23:00] Reencoding: VID_01078, Pass 1 of 1 - [21:23:11] Video Encode complete - [21:23:11] Processing: VID_01079 (103 of 132) - [21:23:11] Extracting A/V streams [VID_01079] - [21:23:16] Reencoding video [VID_01079] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 333 frames - Bitrate: 29,339 Kbs - [21:23:16] Reencoding: VID_01079, Pass 1 of 1 - [21:23:21] Video Encode complete - [21:23:21] Processing: VID_01081 (104 of 132) - [21:23:21] Extracting A/V streams [VID_01081] - [21:23:27] Reencoding video [VID_01081] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 352 frames - Bitrate: 31,761 Kbs - [21:23:27] Reencoding: VID_01081, Pass 1 of 1 - [21:23:33] Video Encode complete - [21:23:33] Processing: VID_01084 (105 of 132) - [21:23:33] Extracting A/V streams [VID_01084] - [21:23:40] Reencoding video [VID_01084] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 927 frames - Bitrate: 31,100 Kbs - [21:23:40] Reencoding: VID_01084, Pass 1 of 1 - [21:23:54] Video Encode complete - [21:23:54] Processing: VID_01085 (106 of 132) - [21:23:54] Extracting A/V streams [VID_01085] - [21:24:00] Reencoding video [VID_01085] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 315 frames - Bitrate: 29,216 Kbs - [21:24:00] Reencoding: VID_01085, Pass 1 of 1 - [21:24:04] Video Encode complete - [21:24:04] Processing: VID_01087 (107 of 132) - [21:24:04] Extracting A/V streams [VID_01087] - [21:24:09] Reencoding video [VID_01087] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 160 frames - Bitrate: 35,000 Kbs - [21:24:09] Reencoding: VID_01087, Pass 1 of 1 - [21:24:12] Video Encode complete - [21:24:12] Processing: VID_01088 (108 of 132) - [21:24:12] Extracting A/V streams [VID_01088] - [21:24:18] Reencoding video [VID_01088] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 452 frames - Bitrate: 30,335 Kbs - [21:24:18] Reencoding: VID_01088, Pass 1 of 1 - [21:24:25] Video Encode complete - [21:24:25] Processing: VID_01090 (109 of 132) - [21:24:25] Extracting A/V streams [VID_01090] - [21:24:30] Reencoding video [VID_01090] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 274 frames - Bitrate: 34,739 Kbs - [21:24:30] Reencoding: VID_01090, Pass 1 of 1 - [21:24:35] Video Encode complete - [21:24:35] Processing: VID_01091 (110 of 132) - [21:24:35] Extracting A/V streams [VID_01091] - [21:24:40] Reencoding video [VID_01091] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 367 frames - Bitrate: 31,195 Kbs - [21:24:40] Reencoding: VID_01091, Pass 1 of 1 - [21:24:46] Video Encode complete - [21:24:46] Processing: VID_01093 (111 of 132) - [21:24:46] Extracting A/V streams [VID_01093] - [21:24:51] Reencoding video [VID_01093] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 343 frames - Bitrate: 30,931 Kbs - [21:24:52] Reencoding: VID_01093, Pass 1 of 1 - [21:24:57] Video Encode complete - [21:24:57] Processing: VID_01096 (112 of 132) - [21:24:57] Extracting A/V streams [VID_01096] - [21:25:03] Reencoding video [VID_01096] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 571 frames - Bitrate: 31,419 Kbs - [21:25:03] Reencoding: VID_01096, Pass 1 of 1 - [21:25:12] Video Encode complete - [21:25:12] Processing: VID_01097 (113 of 132) - [21:25:13] Extracting A/V streams [VID_01097] - [21:25:18] Reencoding video [VID_01097] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 457 frames - Bitrate: 27,255 Kbs - [21:25:18] Reencoding: VID_01097, Pass 1 of 1 - [21:25:25] Video Encode complete - [21:25:25] Processing: VID_01099 (114 of 132) - [21:25:25] Extracting A/V streams [VID_01099] - [21:25:34] Reencoding video [VID_01099] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,370 frames - Bitrate: 29,350 Kbs - [21:25:34] Reencoding: VID_01099, Pass 1 of 1 - [21:25:54] Video Encode complete - [21:25:54] Processing: VID_01100 (115 of 132) - [21:25:54] Extracting A/V streams [VID_01100] - [21:25:59] Reencoding video [VID_01100] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 326 frames - Bitrate: 29,882 Kbs Last edited by jdobbs; 6th November 2013 at 18:29. |
#18117 | Link |
Part 4:
- [21:25:59] Reencoding: VID_01100, Pass 1 of 1 - [21:26:04] Video Encode complete - [21:26:04] Processing: VID_01102 (116 of 132) - [21:26:04] Extracting A/V streams [VID_01102] - [21:26:09] Reencoding video [VID_01102] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 338 frames - Bitrate: 28,161 Kbs - [21:26:09] Reencoding: VID_01102, Pass 1 of 1 - [21:26:14] Video Encode complete - [21:26:14] Processing: VID_01103 (117 of 132) - [21:26:14] Extracting A/V streams [VID_01103] - [21:26:20] Reencoding video [VID_01103] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 335 frames - Bitrate: 29,815 Kbs - [21:26:20] Reencoding: VID_01103, Pass 1 of 1 - [21:26:25] Video Encode complete - [21:26:25] Processing: VID_01105 (118 of 132) - [21:26:25] Extracting A/V streams [VID_01105] - [21:26:38] Reencoding video [VID_01105] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,408 frames - Bitrate: 28,680 Kbs - [21:26:38] Reencoding: VID_01105, Pass 1 of 1 - [21:27:12] Video Encode complete - [21:27:12] Processing: VID_01106 (119 of 132) - [21:27:12] Extracting A/V streams [VID_01106] - [21:27:17] Reencoding video [VID_01106] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 352 frames - Bitrate: 27,864 Kbs - [21:27:17] Reencoding: VID_01106, Pass 1 of 1 - [21:27:22] Video Encode complete - [21:27:22] Processing: VID_01109 (120 of 132) - [21:27:22] Extracting A/V streams [VID_01109] - [21:27:34] Reencoding video [VID_01109] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,102 frames - Bitrate: 27,161 Kbs - [21:27:34] Reencoding: VID_01109, Pass 1 of 1 - [21:28:03] Video Encode complete - [21:28:03] Processing: VID_01112 (121 of 132) - [21:28:03] Extracting A/V streams [VID_01112] - [21:28:21] Reencoding video [VID_01112] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,939 frames - Bitrate: 27,876 Kbs - [21:28:21] Reencoding: VID_01112, Pass 1 of 1 - [21:29:16] Video Encode complete - [21:29:16] Processing: VID_01113 (122 of 132) - [21:29:16] Extracting A/V streams [VID_01113] - [21:29:21] Reencoding video [VID_01113] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 336 frames - Bitrate: 27,444 Kbs - [21:29:21] Reencoding: VID_01113, Pass 1 of 1 - [21:29:26] Video Encode complete - [21:29:26] Processing: VID_01116 (123 of 132) - [21:29:26] Extracting A/V streams [VID_01116] - [21:30:18] Reencoding video [VID_01116] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 12,967 frames - Bitrate: 28,214 Kbs - [21:30:18] Reencoding: VID_01116, Pass 1 of 1 - [21:33:17] Video Encode complete - [21:33:17] Processing: VID_01118 (124 of 132) - [21:33:17] Extracting A/V streams [VID_01118] - [21:33:22] Reencoding video [VID_01118] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 447 frames - Bitrate: 27,243 Kbs - [21:33:22] Reencoding: VID_01118, Pass 1 of 1 - [21:33:29] Video Encode complete - [21:33:29] Processing: VID_01121 (125 of 132) - [21:33:29] Extracting A/V streams [VID_01121] - [21:33:34] Reencoding video [VID_01121] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 290 frames - Bitrate: 27,313 Kbs - [21:33:34] Reencoding: VID_01121, Pass 1 of 1 - [21:33:38] Video Encode complete - [21:33:38] Processing: VID_01122 (126 of 132) - [21:33:38] Extracting A/V streams [VID_01122] - [21:33:48] Reencoding video [VID_01122] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,654 frames - Bitrate: 27,851 Kbs - [21:33:48] Reencoding: VID_01122, Pass 1 of 1 - [21:34:10] Video Encode complete - [21:34:10] Processing: VID_01133 (127 of 132) - [21:34:10] Extracting A/V streams [VID_01133] - [21:34:21] Reencoding video [VID_01133] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,743 frames - Bitrate: 27,345 Kbs - [21:34:21] Reencoding: VID_01133, Pass 1 of 1 - [21:34:44] Video Encode complete - [21:34:45] Processing: VID_01134 (128 of 132) - [21:34:45] Extracting A/V streams [VID_01134] - [21:34:52] Reencoding video [VID_01134] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,012 frames - Bitrate: 26,360 Kbs - [21:34:52] Reencoding: VID_01134, Pass 1 of 1 - [21:35:05] Video Encode complete - [21:35:05] Processing: VID_01137 (129 of 132) - [21:35:05] Extracting A/V streams [VID_01137] - [21:35:10] Reencoding video [VID_01137] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 98 frames - Bitrate: 33,695 Kbs - [21:35:10] Reencoding: VID_01137, Pass 1 of 1 - [21:35:11] Video Encode complete - [21:35:11] Processing: VID_01138 (130 of 132) - [21:35:11] Extracting A/V streams [VID_01138] - [21:36:02] Reencoding video [VID_01138] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 14,717 frames - Bitrate: 25,371 Kbs - [21:36:02] Reencoding: VID_01138, Pass 1 of 1 - [21:38:57] Video Encode complete - [21:38:57] Processing: VID_01150 (131 of 132) - [21:38:57] Extracting A/V streams [VID_01150] - [21:39:03] Reencoding video [VID_01150] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 745 frames - Bitrate: 24,058 Kbs - [21:39:03] Reencoding: VID_01150, Pass 1 of 1 - [21:39:12] Video Encode complete - [21:39:12] Processing: VID_01153 (132 of 132) - [21:39:13] Extracting A/V streams [VID_01153] - [21:39:19] Reencoding video [VID_01153] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 635 frames - Bitrate: 32,820 Kbs - [21:39:20] Reencoding: VID_01153, Pass 1 of 1 - [21:39:30] Video Encode complete [21:39:30]PHASE ONE complete [21:39:30]PHASE TWO - Rebuild Started - [21:39:30] Rebuilding BD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Can't open file: D:\TEMP\WORKFILES\00875.track_4113.264 [21:39:33] - Failed to REBUILD Last edited by jdobbs; 6th November 2013 at 18:29. |
#18118 | Link |
@Darth_Emma
Do you have FORCE_ENCODE on? On my system all 132 parts of the movie add up to only 18.6GB -- and no encode is required. [Edit] I think I see... you're keeping the HD audio, which must put it over the target output size. Can you post your config/INI file contents so I can make sure I'm using the same settings? Last edited by jdobbs; 6th November 2013 at 18:35. |
#18119 | Link | |
Can you tell me where the config.ini file is? I can't seem to locate it on my system. (Sorry to sound like such a noob.) What audio setting should I select rather than the HD audio? I'd be happy to use another audio setting to get around this issue. I really appreciate your help. |
#18120 | Link | |
