20th January 2019, 04:50 | #6042 | Link |
Show statistic(Ctrl+J), show filters list when playback.
If LAV also don't work - something with your system. Maybe it's have more then 1 video adapter and mpc-be assign on different ??
20th January 2019, 04:51 | #6043 | Link | |
22nd January 2019, 07:39 | #6044 | Link |
When trying to open about 300 media files at once using the option 'only add to playlist', only about 180 were actually added and the name of the last one was cut off and therefore dysfunctional. Is this a known problem?
22nd January 2019, 08:48 | #6045 | Link |
It's possible. Limitation on buffer for store file names - or limitation of WM_COPYDATA message.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 22nd January 2019 at 08:54. |
22nd January 2019, 09:54 | #6046 | Link |
How do you open files - from dialog in player or from explorer ?? If from dialog - i think i know what's happened and can fix.
22nd January 2019, 11:09 | #6047 | Link | |
22nd January 2019, 12:12 | #6048 | Link | ||
22nd January 2019, 18:26 | #6049 | Link |
Updated german translation based on r4344 "Playlist"
23rd January 2019, 05:19 | #6050 | Link |
@Klaus1189
Current "trunk" code - https://sourceforge.net/p/mpcbe/code/HEAD/tree/trunk/ Current "trunk" log - https://sourceforge.net/p/mpcbe/code...g/?path=/trunk Translation files - https://sourceforge.net/p/mpcbe/code...esources/text/ This code is used to release nightly builds. "Playlist" branch code - https://sourceforge.net/p/mpcbe/code...ches/Playlist/ "Playlist" branch log - https://sourceforge.net/p/mpcbe/code...nches/Playlist Please do not do the translations for branches.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 24th January 2019 at 13:48. |
27th January 2019, 10:52 | #6051 | Link |
Is it possible to lock the player's window from moving?
I mostly move it by accident when I'm trying to jump quickly between a video's scenes using the mouse cursor. Thanks a lot for your effort! Last edited by salam2009; 27th January 2019 at 11:10. |
27th January 2019, 10:53 | #6052 | Link |
No - it's not possible.
27th January 2019, 12:14 | #6054 | Link |
Would it be possible to play the subtitle specified via the /sub command line switch with an external filter (such as XySubFilter)?
It works fine using the internal subtitle renderer but not when using an external one and it looks like the player isn't sending to the filter the required information to do so. |
27th January 2019, 13:31 | #6055 | Link | |
27th January 2019, 15:22 | #6056 | Link |
Nope, it still doesn't work.
I don't know anything about DirectShow so I might be wrong, but I built xysubfilter with logging enabled and it looks like it's not connecting to any Subtitle Pin. To be clear: it works fine when the subtitle is embedded inside the file or outside with the same name but it doesn't work if I try to load a subtitle from another folder via the command line. |
29th January 2019, 17:46 | #6057 | Link |
I experience strange behaviour from MediaInfo included in MPC-BE; standalone MediaInfo is fine. The problem affects Matroska files where the cues are located in front of the clusters and not at the end. The issue is twofold:
1. For files that show this behaviour the output of the integrated MediaInfo is Code:
General Unique ID : 7900589881153944875766578117805679678 (0x5F19927C44F2C17F663489B8631243E) Complete name : I:\sample4.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 16.5 KiB Duration : 21 s 160 ms Overall bit rate : 6 402 b/s Writing application : Lavf58.23.102 Writing library : Lavf58.23.102 ErrorDetectionType : Per level 1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 21 s 160 ms Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant / Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive / Progressive Writing library : x264 core 148 r2762 90a61ec Encoding settings : cabac=1 / ref=3 / ... [omitted for brevity] Language : English Default : Yes Forced : No 2. But the more important of the two issues is that MediaInfo reads the whole file before returning its report. Especially annoying for multi-GB files. As has been said: The standalone MediaInfo is not affected by this; and MPC-HC is also no longer affected by it. It used to be affected just like MPC-BE, but it isn't any more since 1.7.14. This is the first version that uses an external mediainfo.dll and looking at the commits. MPC-HC 1.7.13.112 is still affected by this bug. I know of two ways to create such files: The first is by using mkclean and the second by using ffmpeg with the "reserve_index_space" option: ffmpeg -i <InputFile> -c copy -f matroska -reserve_index_space <Number> <OutputFile>. Here is a sample. |
29th January 2019, 17:54 | #6058 | Link |
updated german translation based on r4379
Is it possible to edit the close button of the new Playlist window, because it is cut off when using 200% scaling, see here. |
30th January 2019, 00:10 | #6059 | Link | |
Aleksoid / Volt can you please let MPC-BE show all the mpls in descending order of the duration, there's no point in hiding some of the mpls as long as MPC-BE can't chose, or even show as it seems, the correct main movie's mpls for sure, without a directshow Bluray disc navigator filter ? P.S. I will not send another sample cause the fix seems very easy to me: let MPC-BE show all the mpls in descending order of the duration
Intel UHD Graphics 750; Win 10 22H2 |
30th January 2019, 01:49 | #6060 | Link | |
1) duration > 3 min 2) mpls don't contain duplicate .m2ts files entry.
