17th May 2020, 20:12 | #2161 | Link |
DXVA Checker 4.3.0 has been updated to add support for AV1.
Changelog: Added the following alternative names of Decoder Device AV1_VLD_Profile0 AV1_VLD_Profile1 AV1_VLD_Profile2 AV1_VLD_12bit_Profile2 AV1_VLD_12bit_Profile2_420 Minor fix |
18th May 2020, 08:17 | #2162 | Link | |
The other typical structures to convey codec information to the hardware are still suspiciously absent however, so it may not be fully finalized.
19th May 2020, 10:37 | #2166 | Link |
Libaom v2.0.0 "Applejack" has been released: https://aomedia.googlesource.com/aom/+/refs/tags/v2.0.0
First official release of libaom. This release includes new real-time mode and SVC support. - Upgrading: AOM_SET_POSTPROC, AOM_CODEC_CAP_POSTPROC and AOM_CODEC_USE_POSTPROC are removed. AOM_SET_DBG_* is removed. Multi-resolution encoding is removed. put_frame and put_slice callbacks are removed. - Enhancements: Full-sweep document update for codec controls. Last edited by hajj_3; 19th May 2020 at 10:50. |
19th May 2020, 11:01 | #2167 | Link |
Sorry for the delay: A bug in shaderc blocked the suite until I disabled mpv temporarily... / VPx is here.
The media-autobuild suite did not yet build an aomenc binary that reports itself as v2.0.0, maybe a merge to master is missing? New uploads: (MSYS2; MinGW32 / MinGW64: GCC 10.1.0) AOM v1.0.0-errata1-avif-893-g9c38f3b0f rav1e 0.3.0 (02018bf / 2020-05-19) dav1d 0.7.0 (cbe05cf / 2020-05-19) |
19th May 2020, 20:25 | #2168 | Link |
I generated one time build for libaom v2.0.0 stable branch.
https://ci.appveyor.com/project/marc...7143/artifacts |
20th May 2020, 08:42 | #2169 | Link | |
Has this encoder something like a github repo? It seems there is absolutely no version information provided by the encoder.
20th May 2020, 08:56 | #2170 | Link |
If you use the media-autobuild suite:
In the media-suite_compile.sh you can read that it is downloaded from https://aomedia.googlesource.com/aom by a helper function do_vcs() in media-suite_helper.sh which handles a variety of methods. Apparently there is a git repo behind this URL, which appears as website with an own design in a browser. There are branches (MABS uses the "master" branch usually) and tags. Their relation is not very obvious, though. I am not sure but I believe there was an additional shell script which collects required information to store the version information as "tag+updatecount" in a header file... Last edited by LigH; 20th May 2020 at 09:00. |
20th May 2020, 09:55 | #2171 | Link |
Thanks for the info LigH, so no issue tracker. Maybe a developer reads here and bookmarks this post as feature request, I would like to suggest providing version info, examples:
Desktop> x265 --help x265 [info]: HEVC encoder version 3.3+27-g4780a8d99 x265 [info]: build info [Windows][GCC 11.0.0][64 bit] 8bit+10bit+12bit Syntax: x265 [options] infile [-o] outfile infile can be YUV or Y4M outfile is raw HEVC bitstream Executable Options: -h/--help Show this help text and exit --fullhelp Show all options and exit -V/--version Show version info and exit Code:
Desktop> nvencc64 --help NVEncC (x64) 5.01 (r1507) by rigaya, May 7 2020 12:04:16 (VC 1916/Win/avx2) [NVENC API v9.1, CUDA 10.1] reader: raw, y4m, avi, avs, vpy, avsw, avhw [H.264/AVC, H.265/HEVC, MPEG2, VP8, VP9, VC-1, MPEG1, MPEG4] Usage: NVEncC.exe [Options] -i <input file> -o <output file> Input can be avi, avs, raw YUV, YUV4MPEG2(y4m). When Input is in raw format, fps, input-res is required. Ouput format will be in raw H.264/AVC or H.265/HEVC ES. Example: NVEncC -i "<avsfilename>" -o "<outfilename>" avs2pipemod -y4mp "<avsfile>" | NVEncC --y4m -i - -o "<outfilename>" Information Options: -h,-? --help print help -v,--version print version info
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 20th May 2020 at 09:58. |
20th May 2020, 10:30 | #2172 | Link | |||
Build script for vs2019 git repo: https://github.com/marcomsousa/build_aom In every libaom commit (in master branch) a build is automatically generated: https://ci.appveyor.com/project/marc...ld-aom/history Now it goes with v2.0.0-255-ge0be17e7f The version you can see if you perform: Quote:
20th May 2020, 10:33 | #2173 | Link |
is this it ?
https://bugs.chromium.org/p/aomedia/issues/list google look at and respond in it, eg by addressing a couple of very trivial things I may have raised. Last edited by hydra3333; 20th May 2020 at 10:38. |
20th May 2020, 15:17 | #2174 | Link |
There must have been a merge in the meantime.
AOM v2.0.0-255-ge0be17e7f And yes, the bug tracker should match. Last edited by LigH; 20th May 2020 at 15:19. |
21st May 2020, 22:35 | #2175 | Link | |
22nd May 2020, 16:04 | #2176 | Link |
Artem S. Tashkinov
Looks like Tiger Lake will be the first x86 uArch to support AV1 HW decoding:
https://pbs.twimg.com/media/EYn7NM0V...=png&name=orig https://pbs.twimg.com/media/EYn7f9BU...=png&name=orig https://pbs.twimg.com/media/EYn72cxU...=png&name=orig https://pbs.twimg.com/media/EYn8WKXU...=png&name=orig I do hope NVIDIA will support it as well in Ampere. Last edited by birdie; 22nd May 2020 at 16:07. |
22nd May 2020, 18:32 | #2179 | Link |
Momomo_us posted this: https://twitter.com/momomo_us/status...18639423074304
He didn't reveal the original source. |
22nd May 2020, 18:56 | #2180 | Link | |
I note they don't list bit depths for AV1. Does that imply 8-bit only? They don't list it for AVC either, does Intel support >8-bit AVC decode, or only with more advanced codecs. |
