Old 27th October 2019, 17:16   #28921  |  Link
Ch3vr0n
Originally Posted by desierto300w View Post
Hay alguna solución al problema?
2 problems here.
1. This is an english only forum (use google translate if you have too)
2. Please post the FULL bdrb log, just just a fragment of it.
Old 27th October 2019, 18:48   #28922  |  Link
musiclover
Estimado
Estaba comprimiendo el recital de The Cure – 40 Live (Curaetion 25 + Anniversary) (2019), Quality: Blu-ray
Container: BDMV
Video codec: MPEG-4 AVC
Audio codec: PCM, DTS
Video: MPEG-4 AVC Video / 35986 kbps / 1080i / 29,970 fps / 16:9 / High Profile 4.1
Audio 1: English / LPCM Audio / 2.0 / 48 kHz / 2304 kbps / 24-bit
Audio 2: English / DTS-HD Master Audio / 5.1 / 48 kHz / 5152 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Size: 40.27 + 43.57 GB
He intendado dos veces pero no se puede extraer las dos pistas de audio que tienen 5.152 kbps
Los registros del BD REBUILDER SON:
- [12:17:05] Processing: VID_00001 (4 of 4)
- [12:17:05] Extracting A/V streams [VID_00001]
- Extracting video streams [VID_00001]
- Extracting audio/subtitle streams [VID_00001]
- AV frame too large (53045 bytes). Increase AV buffer.
- Extracting audio streams [VID_00001]
- Error in attempt to extract audio.
[12:23:34] - Failed to retrieve audio, aborted
This is a bad rip. Rip the bluray again
musiclover is online now   Reply With Quote
Old 28th October 2019, 23:59   #28923  |  Link
zamengo
Hey guys.
I have a strange issue...
Every time I import a 24.000 source, BDRebuilder change this to 23.976.
I don't find a hidden option to avoid this...
Can you guys help me ? This not a new issue, every time a face with this, I remux with audio track from mkv file, but this have issues when playback, some frame drop.
Mediainfo:
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 47 min 52 s
Bit rate mode : Variable
Bit rate : 4 020 kb/s
Maximum bit rate : 6 030 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.081
Stream size : 1.34 GiB (91%)
Writing library : x264 core 148 r2715 7e75228
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / stitchable=1 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=0 / intra_refresh=0 / rc_lookahead=48 / rc=2pass / mbtree=1 / bitrate=4020 / ratetol=1.0 / qcomp=0.50 / qpmin=6 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=6030 / vbv_bufsize=8040 / nal_hrd=vbr / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
When import and start encode:
[20:55:55] PHASE ONE, Encoding
- [20:55:55] Processing: VID_00000 (1 of 1)
- [20:55:55] Extracting A/V streams [VID_00000]
- [20:56:03] Reencoding video [VID_00000]
- Rate/Length: 23,976fps, 68.930 frames
- Bitrate: 35.000 Kbs
Settings:
ENCODER=0
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=1
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=1
REMOVE_OUTPUT=1
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=19500
TARGET_SIZE=23500
AUTO_BURN=0
PRIORITY_CLASS=1
zamengo is offline   Reply With Quote
Old 29th October 2019, 11:12   #28924  |  Link
Ch3vr0n
Full log please
Sent from my Pixel 3 XL using Tapatalk
Old 29th October 2019, 12:19   #28925  |  Link
zamengo
Originally Posted by Ch3vr0n View Post
Full log please
Ok.
BDRebuilder Log
[08:56:29] Importing MKV: VIDEO
- Preparing MKV for processing...
- Collecting audio/video streams from source...
- Building pseudo-BD source structure...
[08:56:51] Video import completed successfully.
[10/29/19] BD Rebuilder v0.60.27
[08:57:04] Source: VIDEO
- Input BD size: 1,58 GB
- Approximate total content: [00:47:54.955]
- Target BD size: 22,95 GB
- Windows Version: 6.2 [9200]
- Auto Quality: Very Good (Very Fast), ABR
[08:57:04] PHASE ONE, Encoding
- [08:57:04] Processing: VID_00000 (1 of 1)
- [08:57:04] Extracting A/V streams [VID_00000]
- [08:57:12] Reencoding video [VID_00000]
- [08:57:12] Reencoding: VID_00000, Pass 1 of 1
- [09:06:09] Video Encode complete
- [09:06:09] Processing audio tracks
- Track 4352 (por): Keeping original audio
- [09:06:09] Multiplexing M2TS
[09:06:30]PHASE ONE complete
[09:06:30]PHASE TWO - Rebuild Started
- [09:06:31] Rebuilding BD file Structure
[09:06:31] - Encode and Rebuild complete
[09:06:31] Writing BD structure to ISO file
- ImgBurn completed successfully
[09:07:16] JOB: VIDEO finished.
Mediainfo before:
General
Unique ID : 306470413897794769842652061988899888794 (0xE6900E02180DCDB7A7F6880663719E9A)
Complete name : C:\TEST\VIDEO.mkv
Format : Matroska
Format version : Version 4
File size : 1.47 GiB
Overall bit rate mode : Variable
Overall bit rate : 4 386 kb/s
Encoded date : UTC 2019-10-28 12:07:55
Writing application : mkvmerge v32.0.0 ('Astral Progressions') 64-bit
Writing library : libebml v1.3.7 + libmatroska v1.5.0
Video
Format : AVC
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 131 MiB (9%)
Language : Portuguese
Service kind : Complete Main
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 45 min 32 s
Bit rate : 57 b/s
Count of elements : 551
Stream size : 19.1 KiB (0%)
Title : Portugues
Default : No
Forced : No
Mediainfo after:
General
Complete name : D:\BD25\VIDEO\BDMV\STREAM\00000.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 11.6 GiB
Duration : 47 min 54 s
Overall bit rate : 34.7 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, Reference frames : 2 frames
Codec ID : 27
Bit rate : 32.9 Mb/s
Maximum bit rate : 35.0 Mb/s
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.662
Stream size : 11.0 GiB (95%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Bit rate : 384 kb/s
Stream size : 131 MiB (1%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Delay relative to video : 6 s 6 ms
Old 29th October 2019, 16:00   #28926  |  Link
AmigaFuture
AmigaFuture's Avatar
Originally Posted by zamengo View Post
Hey guys.
This should solve the problem:
IMPORT_PAL_TO_FILM=n n = 0/1 - Default=0, if set to 1, imported 25fps video file sources are converted to 23.976. Be sure that's not set to 0. Or add to config, and go another go.
Old 29th October 2019, 16:46   #28927  |  Link
I'll look at it. But in the meantime you can always set IMPORT_FORCE_FRAMERATE=24. But don't forget to delete it after the import, or your next import might have issues.
I think there was a reason why 24fps could be converted to 23.976 during import... but it was a long time ago and I can't remember why...
Old 30th October 2019, 00:15   #28928  |  Link
zamengo
Thanks!!!
Works like a charm!
I will create 2 BD Rebuilder folder, one called "BDRB24"
The video playback without stutter and finished with 24fps.
Old 30th October 2019, 02:14   #28929  |  Link
MrVideo
MrVideo's Avatar
Ok.
For future reference, don't "quote" it, "code" it.
My Total Eclipse 2017 Photos
Old 30th October 2019, 05:49   #28930  |  Link
AmigaFuture
Yeah, where'd that come from? It's not in the included archive memo I have. Man, someone needs to steal those sneakers.. Lathe??
Old 30th October 2019, 09:49   #28931  |  Link
musiclover
This opens up a lot of possibilities.
But .... Why is that not in HIDDENOPTS.TXT ?. It is not documented before in this threat either. It is really hidden.
Old 30th October 2019, 11:37   #28932  |  Link
I have many undocumented settings that were put there for testing. Most are undocumented for a reason... because they would be the source of self-inflicted bug reports that people would "fail to mention". I don't want to have to deal with that.
Old 30th October 2019, 11:42   #28933  |  Link
Just remember. It doesn't change the framerate of the imported source -- it just forces BD-RB to treat it as what you set. So, for example, if you forced a 25fps source to 24 -- it would play in (slightly) slow motion.
It really is useful only for sources that, for some reason, MEDIAINFO detects incorrectly.
Old 30th October 2019, 20:49   #28934  |  Link
Michi
Originally Posted by FilipeAmadeuO View Post
Do you have any jerky video transition between m2ts on LAST JEDI (for example) ?
I have no stuttering between m2ts of the 0800.mpls, but no FF/REW.
Michi is offline   Reply With Quote
Old 31st October 2019, 05:15   #28935  |  Link
AmigaFuture
Now you have the memo I was joking about, too.
Programmers are very mischievous and very fun..you all are demigods of sorts. I remember programming...after that I left it for other stuff.
I hope you enjoy Samhain tomorrow. You goofy coder, admin you.
Ohh! Have you checked into https://www.videohelp.com/software/P...AudioConverter ?? Seems there's a way to deal with some DTS stuff BD RB isn't currently able.
Old 1st November 2019, 22:36   #28936  |  Link
raul124
raul124's Avatar
4k
Just a quick question, I'm planning on switching to the 4k ultra HD game and I want to know how long will it take converting a 59GB to a 25GB MKV movie with BD-Rebuilder?
raul124 is offline   Reply With Quote
Old 2nd November 2019, 11:43   #28937  |  Link
Ch3vr0n
That's different for everyone. That depends heavily on the cpu used for encoding, available ram, cpu workload, storage device holding the source...
Old 2nd November 2019, 11:47   #28938  |  Link
Mike-uk
Hi question about UHD support ?? before i spend hours encoding
source is UHD , can the program make a BD-25 bluray (x264) ?? to play on a BluRay player or does it make UHD-25 (x265)??
if it does make BD-25 i guess it converts HDR to SDR ?
thanks
Mike
Mike-uk is offline   Reply With Quote
Old 2nd November 2019, 13:47   #28939  |  Link
FreaQ
Starfish
FreaQ's Avatar
How do I enable One-Pass CRF Encoding?
I already put FIXED_CRF=19 in my bdrebuilder.ini but the option ist still grayed out.
Anything else I have to consider?
FreaQ is offline   Reply With Quote
Old 2nd November 2019, 16:20   #28940  |  Link
thanks
Mike
Not positive what you are asking. But if you plan to have it stay UHD, there is no choice. The specification requires it to be HEVC (X265). If your intent is to resize it and create a 1080p BD-25... BD-RB doesn't have an option to resize UHD to HD yet.
