Old 5th January 2021, 15:04   #6941  |  Link
Danette
So many good little tools in this GUI!
Request for enhancement of the “AviSynth script creator”:
- Allow the “Analyse” function, under the “Filters” tab, to be selected as a default setting, so that the “Save” function will then include the results of the analysis in the AVS file.
- Provide a batch option in this tool (think: “batch” in all things, since many of us process entire TV series as opposed to only single movies).
Danette is offline   Reply With Quote
Old 5th January 2021, 18:44   #6942  |  Link
kalehrl
One Click Encoder is for batch encoding.
You can specify a folder and all files will be processed.
kalehrl is offline   Reply With Quote
Old 5th January 2021, 21:40   #6943  |  Link
Danette
Yes, I do all of my processing with One-Click. However, the Avisynth script editor function is outside of the One-Click functionality.
Old 5th January 2021, 22:33   #6944  |  Link
jlw_4049
You can setup scripts for the one click method and avisynth
Also maybe look into StaxRip
Sent from my SM-G986U1 using Tapatalk
Old 5th January 2021, 23:16   #6945  |  Link
Danette
I don't think that this has anything to do with my request. However, if you can tell me how it is relevant, I'd be interested.
Old 5th January 2021, 23:40   #6946  |  Link
jlw_4049
Batch option
Old 6th January 2021, 04:17   #6947  |  Link
Danette
Batch option
But it doesn't apply to the "AVS script creator" tool.
Old 10th January 2021, 15:50   #6948  |  Link
hello_hello
Danette,
I never use the Onelick encoder so I'm not an expert, but I'm also not sure I understand what you're requesting. The OneClick encoder has an option to automatically analyse and de-interlace, which I assume is the same as the analysis run from the Script Creator. OnceClick and the Script Creator share the same Avisynth profiles/templates. What is you're wanting to do that you can't at the moment?
Old 17th January 2021, 10:03   #6949  |  Link
kedautinh12
DGMPGDec Version 2.0.0.2 Executables
http://rationalqm.us/dgmpgdec/dgmpgdec.html
Old 17th January 2021, 10:59   #6950  |  Link
StainlessS
StainlessS's Avatar
Above kedautinh12 linked DGMPGDec also with official x64 DGDecode.dll MPeg2Source(),
previously available x64 Mpeg2Source from JoshyD version from 2010, with Upconv=1 crash bug [+ other probs].
Updated for v2.60 AVS colorspaces.
I sometimes post sober.
Old 21st January 2021, 13:57   #6951  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Which server address are to be used for updates now ?
I am on 2924, the development server brought no further changes up for months now, although these are discussed,
and stable server wants to downgrade.
Old 22nd January 2021, 17:47   #6952  |  Link
kedautinh12
Here:
http://megui.tmebi.de/test/?C=M;O=D
Old 23rd January 2021, 23:26   #6953  |  Link
Emulgator
Emulgator's Avatar
Thanks !
Old 1st February 2021, 04:22   #6954  |  Link
tp9192
Hello, whenever I modify a setting in a One Click Encoder profile, and then try to encode something, the change I made doesn't seem to take effect until I fully re-open MeGUI. Specifically, this happened when I tried to change the preset from Medium to Slow or whatever. Any reason why this is?
tp9192 is offline   Reply With Quote
Old 2nd February 2021, 10:06   #6955  |  Link
kedautinh12
Are you use x64 ver??
Old 18th February 2021, 01:47   #6956  |  Link
kedautinh12
DGMPGDec v2.0.0.3
http://rationalqm.us/dgmpgdec/dgmpgdec2003.zip
MKVToolNix v53.0.0
https://mkvtoolnix.download/windows/releases/53.0.0/
MP4Box v1.1.0-DEV-rev506-gc259a3e65
http://www.mediafire.com/file/awy9wd...GCC102.7z/file
x264 0.161.3048 b86ae3c
http://www.mediafire.com/file/l5rmui...GCC102.7z/file
Old 18th February 2021, 02:57   #6957  |  Link
videoh
Useful n00b
Originally Posted by kedautinh12 View Post
DGMPGDec v2.0.0.3
It's at 2.0.0.4 now:
http://rationalqm.us/dgmpgdec/dgmpgdec2004.zip (right click and save link as)
Old 18th February 2021, 03:47   #6958  |  Link
kedautinh12
Windows security detected virus in file DGIndex.exe. Your old ver don't meet any virus problem
Old 18th February 2021, 08:46   #6959  |  Link
Microsoft Defender is the only engine producing a false alarm.
Old 18th February 2021, 15:13   #6960  |  Link
videoh
Useful n00b
Correct, thank you. I submitted a sample but that's all I can do. I recommend making an exclusion:
Go to Start > Settings > Update & Security > Windows Security > Virus & threat protection.
Under Virus & threat protection settings, select Manage settings, and then under Exclusions, select Add or remove exclusions.
Select Add an exclusion, and then select from files, folders, file types, or process.
