Old 29th April 2010, 21:18   #1001  |  Link
Zathor
Originally Posted by AMED View Post
@Zathor
The log is too big to put in a single post so i have uploaded it to mediafire.
http://www.mediafire.com/?wgjz0ajayid
Thanks. I have tried to reproduce it but I failed. Can you reproduce it?
Can you please explain what you have done? I tried to index to DVDs (same VOB name), did an autoencode on both of them and then started the two workers.
Old 29th April 2010, 23:30   #1002  |  Link
AMED
AMED's Avatar
1. Make sure there is a worker 1 and worker 2 setup.
2. Index first video and make changes with avisynth editor (crop, denoise, auto deinterlace) click save.
# Set DAR in encoder to 43 : 23. The following line is for automatic signalling
global MeGUI_darx = 43
global MeGUI_dary = 23
LoadPlugin("C:\Program Files (x86)\megui\tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("E:\MainMovie\ONE_MISSED_CALL_SCN\VIDEO_TS\VTS_01_1.d2v", info=3)
LoadPlugin("C:\Program Files (x86)\megui\tools\avisynth_plugin\ColorMatrix.dll")
ColorMatrix(hints=true, interlaced=true, threads=0)
Load_Stdcall_Plugin("C:\Program Files (x86)\megui\tools\yadif\yadif.dll")
Yadif(order=1)
crop( 8, 84, -8, -80)
#resize
super = MSuper(pel=2, sharp=2)
backward_vec2 = MAnalyse(super, isb = true, delta = 2, overlap=4)
backward_vec1 = MAnalyse(super, isb = true, delta = 1, overlap=4)
forward_vec1 = MAnalyse(super, isb = false, delta = 1, overlap=4)
forward_vec2 = MAnalyse(super, isb = false, delta = 2, overlap=4)
MDegrain2(super, backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=400)
3. Click AutoEncode, click Queue.
4. Index second video and make changes with avisynth editor (crop, denoise, auto deinterlace) click save.
# Set DAR in encoder to 4 : 3. The following line is for automatic signalling
global MeGUI_dary = 3
DGDecode_mpeg2source("E:\MainMovie\THE_GHOST\VIDEO_TS\VTS_01_1.d2v", info=3)
Yadif(order=1)
crop( 8, 2, -10, -2)
Spline36Resize(704,576) # Spline36 (Neutral)
5. On the Queue tab, click start.
6. If you look at the screenshot below, it seems to mess up the audio encoding as well. both were encoded with the same nero aac settings (keep channels and vbr 0.40) but yet job 2 is 18.6MB and completely slient, job 6 is 194MB and the audio is fine. another thing i noticed was when job 2 had finished encoding it would not start the next job until job 6 had also finished.
7. Then both workers started processing job 3 at the same time.
A Man Eating Duck
AMED is offline   Reply With Quote
Old 29th April 2010, 23:31   #1003  |  Link
AMED
AMED's Avatar
and the Log
[Information] Log
-[Information] Versions
--[NoImage] MeGUI Version : 0.3.4.13
--[NoImage] OS : Windows Seven Ultimate Edition x64 (6.1.0.7600)
--[NoImage] Latest .Net Framework installed : 3.5 SP1 (3.5.30729.4926)
--[NoImage] Avisynth Version : 2.5.8.5
-[Information] Log for job1 (idx, VTS_01_1.VOB -> VTS_01_1.d2v)
--[Information] [30/04/2010 9:57:26 a.m.] Started handling job
--[Information] [30/04/2010 9:57:26 a.m.] Preprocessing
--[NoImage] Job commandline: "C:\Program Files (x86)\megui\tools\dgindex\dgindex.exe" -SD=< -AIF=<E:\MainMovie\ONE_MISSED_CALL_SCN\VIDEO_TS\VTS_01_1.VOB< -OF=<E:\MainMovie\ONE_MISSED_CALL_SCN\VIDEO_TS\VTS_01_1< -FO=0 -exit -hide -OM=1 -TN=80
--[Information] [30/04/2010 9:57:26 a.m.] Indexing started
--[NoImage] Standard output stream
--[NoImage] Standard error stream
--[Information] [30/04/2010 9:58:31 a.m.] Running auto force film
---[NoImage] Film percentage: -1
--[Information] [30/04/2010 9:58:31 a.m.] Postprocessing
---[Information] Deleting intermediate files
--[Information] [30/04/2010 9:58:31 a.m.] Job completed
-[Information] AutoEncode job generation log
--[NoImage] Split Size : null
--[Information] Eliminating duplicate filenames
---[NoImage] Video output file: E:\MainMovie\ONE_MISSED_CALL_SCN\VIDEO_TS\VTS_01_1.264
---[NoImage] Muxed output file: E:\MainMovie\ONE_MISSED_CALL_SCN\VIDEO_TS\VTS_01_1-muxed.mkv
---[NoImage] Encodable audio stream 0: E:\MainMovie\ONE_MISSED_CALL_SCN\VIDEO_TS\VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.m4a
-[Information] Log for job5 (idx, VTS_01_1.VOB -> VTS_01_1.d2v)
--[Information] [30/04/2010 10:00:06 a.m.] Started handling job
--[Information] [30/04/2010 10:00:06 a.m.] Preprocessing
--[NoImage] Job commandline: "C:\Program Files (x86)\megui\tools\dgindex\dgindex.exe" -SD=< -AIF=<E:\MainMovie\THE_GHOST\VIDEO_TS\VTS_01_1.VOB< -OF=<E:\MainMovie\THE_GHOST\VIDEO_TS\VTS_01_1< -FO=0 -exit -hide -OM=1 -TN=80
--[Information] [30/04/2010 10:00:06 a.m.] Indexing started
--[Information] [30/04/2010 10:01:06 a.m.] Running auto force film
--[Information] [30/04/2010 10:01:06 a.m.] Postprocessing
--[Information] [30/04/2010 10:01:06 a.m.] Job completed
---[NoImage] Video output file: E:\MainMovie\THE_GHOST\VIDEO_TS\VTS_01_1.264
---[NoImage] Muxed output file: E:\MainMovie\THE_GHOST\VIDEO_TS\VTS_01_1-muxed.mkv
---[NoImage] Encodable audio stream 0: E:\MainMovie\THE_GHOST\VIDEO_TS\VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.m4a
-[Information] Log for job2 (audio, VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.ac3 -> VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.m4a)
--[Information] [30/04/2010 10:05:43 a.m.] Started handling job
--[Information] [30/04/2010 10:05:43 a.m.] Preprocessing
--[NoImage] Avisynth script
---[NoImage] LoadPlugin("C:\Program Files (x86)\megui\tools\avisynth_plugin\NicAudio.dll")
---[NoImage] NicAc3Source("E:\MainMovie\ONE_MISSED_CALL_SCN\VIDEO_TS\VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.ac3", DRC=1)
---[NoImage] Normalize()
---[NoImage] return last
--[NoImage] Commandline used: -ignorelength -q 0.4 -if - -of "{0}"
--[Information] [30/04/2010 10:05:43 a.m.] Encoding started
--[Information] [30/04/2010 10:05:43 a.m.] Encode thread started
--[Information] [30/04/2010 10:05:43 a.m.] Avisynth script environment opened
--[Information] [30/04/2010 10:05:43 a.m.] Script loaded
--[Information] Output Decoder
---[NoImage] Channels: 6
---[NoImage] Bits per sample: 32
---[NoImage] Sample rate: 48000
--[NoImage] Commandline: C:\Program Files (x86)\megui\tools\neroAacEnc.exe -ignorelength -q 0.4 -if - -of "E:\MainMovie\ONE_MISSED_CALL_SCN\VIDEO_TS\VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.m4a"
--[Information] [30/04/2010 10:05:43 a.m.] Encoder process started
--[NoImage] Output from encoder via stderr
---[NoImage] *************************************************************
---[NoImage] *                                                           *
---[NoImage] *  Nero AAC Encoder                                         *
---[NoImage] *  Copyright 2009 Nero AG                                   *
---[NoImage] *  All Rights Reserved Worldwide                            *
---[NoImage] *                                                           *
---[NoImage] *  Package build date: Feb 18 2010                          *
---[NoImage] *  Package version:    1.5.4.0                              *
---[NoImage] *                                                           *
---[NoImage] *  See -help for a complete list of available parameters.   *
---[NoImage] *                                                           *
--[Information] [30/04/2010 10:14:34 a.m.] Postprocessing
--[Information] [30/04/2010 10:14:34 a.m.] Job completed
-[Information] Log for job6 (audio, VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.ac3 -> VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.m4a)
---[NoImage] NicAc3Source("E:\MainMovie\THE_GHOST\VIDEO_TS\VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.ac3", DRC=1)
--[NoImage] Commandline: C:\Program Files (x86)\megui\tools\neroAacEnc.exe -ignorelength -q 0.4 -if - -of "E:\MainMovie\THE_GHOST\VIDEO_TS\VTS_01_1 T80 3_2ch 448Kbps DELAY 0ms.m4a"
---[NoImage] *                                                           *
---[NoImage] *                                                           *
---[NoImage] *                                                           *
---[NoImage] *                                                           *
-[Information] Log for job3 (video, VTS_01_1.avs -> VTS_01_1.264)
--[Information] [30/04/2010 10:14:34 a.m.] Started handling job
--[Information] [30/04/2010 10:14:34 a.m.] Preprocessing
--[NoImage] Job commandline: "C:\Program Files (x86)\megui\tools\x264\vfw4x264.exe" --level 4 --preset slower --crf 21.0 --sar 4429:4048 --output "E:\MainMovie\ONE_MISSED_CALL_SCN\VIDEO_TS\VTS_01_1.264" "E:\MainMovie\ONE_MISSED_CALL_SCN\VIDEO_TS\VTS_01_1.avs"
--[Information] [30/04/2010 10:14:34 a.m.] Encoding started
A Man Eating Duck
Old 2nd May 2010, 23:18   #1004  |  Link
Zathor
Thanks for the detailed report. I have been able to reproduce the problem with more than one worker working on a job and fix will be in the next build.
The audio file has been ok for me.
Old 7th May 2010, 23:41   #1005  |  Link
cheer
Question regarding DGIndexNV. This is my first go-around with using MeGUI for Blu-Ray, so be patient.
I'm using DGINdexNV to create the project files. When I then go into the AVISynth Script Creator and hit Analyze, I get an error dialog that says, "Failed to create video decoder (100)" and, at this point, MeGUI becomes unresponsive. If I skip the analysis step, everything seems OK.
Is this just not supported, or have I got a problem on my system?
I'm doing a VC-1 source (Star Trek: TOS). I manually used eac3to to figure out which stream files comprise which episode, then manually use DGIndexNV to add all of the appropriate stream files and create the project.
cheer is offline   Reply With Quote
Old 8th May 2010, 08:38   #1006  |  Link
Shevek
Do you have the CUVID server running?
Shevek is offline   Reply With Quote
Old 9th May 2010, 10:34   #1007  |  Link
Knuffi
With newest Update-Server version, I cannot encode any video stream at all:
[Information] Log
--[NoImage] OS : Windows Seven x64 (6.1.0.7600)
-[Information] Log for job9 (video, AmHisX_cut.avs -> AmHisX_cut.mp4)
--[Information] [09.05.2010 11:25:12] Started handling job
--[Information] [09.05.2010 11:25:12] Preprocessing
--[NoImage] Job commandline: "C:\Program Files (x86)\megui\tools\x264\vfw4x264.exe" --crf 20.0 --trellis 0 --profile high --level 4.1 --bframes 3 --ref 4 --slices 4 --aud --nal-hrd vbr --b-pyramid strict --keyint 24 --min-keyint 2 --vbv-maxrate 14000 --vbv-bufsize 14500 --sar 1:1 --output "E:\capture\AmHisX_cut.mp4" "E:\capture\AmHisX_cut.avs"
--[Information] [09.05.2010 11:25:12] Encoding started
--[Information] [09.05.2010 11:25:12] Job completed
In the example, it's a stream i recorded with my TV-card - two weeks ago there was no problem with another stream.
Knuffi is offline   Reply With Quote
Old 10th May 2010, 07:28   #1008  |  Link
AMED
AMED's Avatar
Hi Zathor,
I've found a way to reproduce the Audio bug that i mentioned earlier.
Here are the steps
1. Download THIS 2 channel AC3 that i borrowed from MASH
2. Create 2 copies of the downloaded AC3, call one TEST1.ac3 and the other TEST2.ac3.
3. Make sure there is a worker 1 and worker 2 setup.
4. Change the Nero AAC scratchpad to this, press update and close.
5. Load TEST1.ac3 in to the audio track 1 in MeGUI and click enqueue.
6. Load TEST2.ac3 in to the audio track 1 in MeGUI and click enqueue.
7. Click on Queue tab and click start.
run these jobs multiple times and inspect the output sizes of the mp4s created,
Run 1:
TEST1.mp4 = 1.63MB, TEST2.mp4 = 1.12MB.
Run 2:
TEST1.mp4 = 1.64MB, TEST2.mp4 = 100KB.
Run 3:
TEST1.mp4 = 100KB, TEST2.mp4 = 1.19MB.
Run 4:
TEST1.mp4 = 1.63MB, TEST2.mp4 = 1.13MB.
And the LOG
EDIT: OK found the problem, it's normalize() in the AVISynth script. If you disable normalize peaks to ... in the nero AAC encoding config dialog the output files are the exact same size.
without normalize enabled.
TEST1.mp4 = 1.51MB, TEST2.mp4 = 1.51MB.
A Man Eating Duck
Old 10th May 2010, 14:33   #1009  |  Link
Zathor
But even when normalize is disabled there are sometimes glitches. I have changed it a few days ago so that only one audio job can be run at a given time:
http://megui.svn.sourceforge.net/vie...&revision=1602
Old 10th May 2010, 14:40   #1010  |  Link
eidolen
Denoise Errors
I just auto-updated a couple days ago and now anytime I try and add a denoise filter I get errors. It took me some time to see what was happening, but for some reason the AVS Script is getting corrupted somehow.
My source is mpeg2 and is indexed with DGCreator first before opening AVS Acript Creator. After that I can use any other options fine but if I add the noise filter at any level and select "Preview AVS Script", I get multiple errors.
The default AVS Script before selecting any options looks like this:
#denoiseLoadPlugin("C:\Program Files\megui\tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("C:\VIDEO CACHE\[Test Clips]\Source\I_Opening.d2v", cpu=4, info=3)
LoadPlugin("C:\Program Files\megui\tools\avisynth_plugin\ColorMatrix.dll")
ColorMatrix(hints=true, threads=0)
#deinterlace
#crop
#resize
#denoise
I can already see that something looks awry with #denoise at the very top. When I actually load a denoise filter it changes to this:
LoadPlugin("C:\Program Files\megui\tools\avisynth_plugin\FluxSmooth.dll")
FluxSmoothST(7,7) # Medium NoiseLoadPlugin("C:\Program Files\megui\tools\dgindex\DGDecode.dll")
#deinterlace
#crop
#resize
If I reformat the script by hand it seems to work ok, but I figure it's something wrong on my end as I can't find anything anywhere on anyone else having the same problem. Am I doing something wrong, or have a corrupt file somewhere? I'd really like to get this working properly again and hope I'm not missing something obvious.
The first error that appears doesn't show in the log but states:
"AviSynth script error:
Script Error: Invalid arguments to function "FluxSmoothST""
After clicking OK, the following error appears and shows up in the log:
"MeGUI encountered a fatal error and may not be able to proceed. Reason. Parameter is not valid."
Here is the relevant portion of the log:
[Error] Unhandled error
--[NoImage] Exception message: Parameter is not valid.
--[NoImage] Stacktrace
---[NoImage]    at System.Drawing.Image.get_Width()
---[NoImage]    at System.Drawing.Image.get_Size()
---[NoImage]    at System.Windows.Forms.PictureBox.ImageRectangleFromSizeMode(PictureBoxSizeMode mode)
---[NoImage]    at System.Windows.Forms.PictureBox.get_ImageRectangle()
---[NoImage]    at System.Windows.Forms.PictureBox.OnPaint(PaintEventArgs pe)
---[NoImage]    at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
---[NoImage]    at System.Windows.Forms.Control.WmPaint(Message& m)
---[NoImage]    at System.Windows.Forms.Control.WndProc(Message& m)
---[NoImage]    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
---[NoImage]    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
---[NoImage]    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
--[NoImage] Inner exception: null
Source:
Video
Format                           : MPEG Video
Format version                   : Version 2
Format profile                   : Main@Main
Format settings, Matrix          : Standard
Duration                         : 10s 0ms
Bit rate mode                    : Constant
Bit rate                         : 3 522 Kbps
Nominal bit rate                 : 8 500 Kbps
Width                            : 720 pixels
Height                           : 480 pixels
Display aspect ratio             : 16/9
Frame rate                       : 29.970 fps
Standard                         : NTSC
Colorimetry                      : 4:2:0
Scan type                        : Interlaced
Scan order                       : Top Field First
Bits/(Pixel*Frame)               : 0.821
Thanks for any help in sorting this out,
eidolen
eidolen is offline   Reply With Quote
Old 10th May 2010, 20:37   #1011  |  Link
Natsu!
Help me
I have an error when process MKV to AVI XviD, the strange thing is that the error only occurs in at 86.69% 2pass
The error is due to Xvid_encraw.exe, the problem persists, reinstall it and update the Megui, xvid_encraw.exe was downloaded, and yet the problem continues ...
Please I need your help, and not to do ... and I often use the Megui.
Here a screenshot of the error
Thank you very much
Natsu! is offline   Reply With Quote
Old 10th May 2010, 21:10   #1012  |  Link
@Natsu!
Where did you get the MKV file?
Old 10th May 2010, 21:47   #1013  |  Link
Natsu!
is a RAW chapter of an anime series...
edit:
here screenshot error...
Old 10th May 2010, 23:13   #1014  |  Link
@Natsu!
I asked where you got the file. If you don't answer, you'll get a rule 6 strike.
Old 11th May 2010, 02:12   #1015  |  Link
Natsu!
From here take the MKV...
link removed per rule 6
Old 11th May 2010, 11:12   #1016  |  Link
AlekseiV
Zathor, would it be possible to have an option for the FFMSIndex to also create the audio index? Right now I would have to index it through MeGUI (without loading files), then manually add FFAudioSource() above FFVideoSource(), then open the .avs. Doing otherwise causes two indexing passes which can take some time on large videos.
AlekseiV is offline   Reply With Quote
Old 11th May 2010, 12:56   #1017  |  Link
@Natsu!
You may not discuss downloaded material here, per forum rule 6. Please read and follow our forum rules.
http://forum.doom9.org/forum-rules.htm
Old 12th May 2010, 13:56   #1018  |  Link
eidolen
Still having the same trouble with the AVS Script creator in MeGui.
http://forum.doom9.org/showthread.ph...33#post1398733
Does anyone have any thoughts or know where else I can find some help with this problem?
Thanks,
E
Old 12th May 2010, 17:07   #1019  |  Link
Zathor
Originally Posted by eidolen View Post
Thanks,
E
I do not have this kind of problem and cannot reproduce it. Can you please install MeGUI to a different location, let it update and try it again? This way you will get a clean installation.
Old 15th May 2010, 14:20   #1020  |  Link
HertZ
HertZ's Avatar
File indexer does not work
Since the last update of mediainfo in megui, file indexing take so much time (more than 20 minutes to start the process)
HertZ is offline   Reply With Quote
