Old 27th December 2019, 11:31   #1061  |  Link
StainlessS
StainlessS's Avatar
FranceBB, just consider the plugin dead.
I sometimes post sober.
Old 4th January 2020, 09:33   #1062  |  Link
kedautinh12
Originally Posted by krmit View Post
i see in last releases, function Automation > Apply Karaoke Template was errored
Old 9th January 2020, 20:20   #1063  |  Link
zerowalker
How do the VS and XY differ, and how do they compare to MPC-HC internal?
In my simple tests the VS seems unstable for some reason and can crash, but it seems to work when XY messes up,
in one case XY shows the wrong subtitle when you jump in the video, it will show the previous (i think) for one subtitle, then when the next one comes it's in sync again.
MPC-HC has issue when jumping where it sometimes doesn't show any subtitles for awhile (i think it's in combination with madvr).
zerowalker is offline   Reply With Quote
Old 10th January 2020, 20:20   #1064  |  Link
xy VSfilter renders the subs on the video so the quality can only be as good as the resolution of the video and they are usually sub sampled.
XY subfilter uses a custom API created by madshi these subtitles can be moved independent from the video be rendered at any resolution or color correct you name it.
the ISR in mpc-hc is vs filter based it is rendered on an extra surface just like xy subfilter but missed much of the features if you are using a 3D LUT for color correction it is not applied to the subtitles. it pretty similar to xy VSfilter still slower but not much.
Old 15th January 2020, 14:01   #1065  |  Link
Shark007
Shark007's Avatar
The following archive contains updated and mostly stable versions of XyVSFilter and XySubFilter in both 32 and 64bit iterations.
Filters
Shark007 is offline   Reply With Quote
Old 17th January 2020, 04:58   #1066  |  Link
zerowalker
Ah, odd but mpc-hc seemed faster for me than xy-subfilter in heavy cases, i got framedrops with the latter and took awhile to figure out why.
I haven't touched any settings that i know of either when it comes to the subfilters.
Old 18th January 2020, 03:44   #1067  |  Link
it's supposed to be faster and i even multiply time reported cases where the ISR couldn't compete.
Old 21st January 2020, 01:04   #1068  |  Link
kedautinh12
Filters
can you share me link offical updated of it?
Old 21st January 2020, 11:38   #1069  |  Link
Shark007
Shark007's Avatar
No, I cannot share anything official. I just downloaded them from a publicly available distribution.
I can tell you that the author is a regular reader here and is aware that I posted these filters.
If he wants to share the patches that were applied, thats up to him.
Old 23rd January 2020, 03:39   #1070  |  Link
kedautinh12
I found it, it in folder of k-lite codec pack 😂😂😂😂😂
Old 23rd January 2020, 05:08   #1071  |  Link
Shark007 and the K-lite codec pack? Ya don't say..
