Old 13th September 2018, 07:32   #921  |  Link
SmilingWolf
I am maddo saientisto!
SmilingWolf's Avatar
Originally Posted by Aleksoid1978 View Post
cmake output - https://pastebin.com/spXmNAJS
CMakeError.log - https://pastebin.com/aPnpqnGF
CMakeOutput.log - https://pastebin.com/JpnNx4Xm
P.S. i think some message test on russian and we can't see it in CMake logs
It's the path
The "++" in "D:/Aleksoid/C++/Source/aom/" create an invalid regular expression that makes some of the cmake tests fail. The AVX2 one just happens to be the first file tested that triggers the problem.
Just rename the path to something like CPP and all the problems should go away
Originally Posted by marcomsousa View Post
Yours two patch requests was merge in master, congrats.
Confirming that with these additions the master branch, as of commit 67645b8, compiles and works again with GCC 8.2 without adding any extra C/CXX option on the CMake command line.
Ping @LigH
EDIT:
New build, GCC 8.2 based, no extra C/CXX flags, 32/64bits, HBD/LDB, static libraries included (decoder+encoder, sorry Aleksoid1978 but this solution was simply faster than having 8 different build configs)
av1-1.0.0-566-g67645b8f5: https://mega.nz/#!BsxmTYyJ!dnoSK66uc...7QnZnFkEzEop08
Following the comments on issue 2147 I think I'll drop the CONFIG_LOWBITDEPTH=0 builds from now on
The CONFIG_LOWBITDEPTH=1 ones should work perfectly for 8/10/12 bits video and work faster for 8 bits on top, so no reason to keep the HBD-only builds around
SmilingWolf is offline   Reply With Quote
Old 13th September 2018, 08:26   #922  |  Link
Thanks, I noticed via aomedia mail notification. I assume wiiaboo will revert the MABS patch soon.
Old 13th September 2018, 08:48   #923  |  Link
GTPVHD
https://www.youtube.com/playlist?lis...eZUlNUQAVLwrZS
AV1 beta testing on Youtube.
GTPVHD is offline   Reply With Quote
Old 13th September 2018, 10:43   #924  |  Link
Pushman
It has very high bitrate now.
At time of writing, these transcodes are encoded at a very high bitrate for decoder performance testing.
Pushman is offline   Reply With Quote
Old 13th September 2018, 11:16   #925  |  Link
ChaosKing
I can't play the "halo infinite trailer" video (720p) lagfree with mpv. It seems that is uses gpu decoding? bcs cpu is only at max 5%
Old 13th September 2018, 11:42   #926  |  Link
There is no GPU decoding for AV1 anywhere yet. But maybe the decoder has a bottleneck somewhere.
Old 13th September 2018, 11:43   #927  |  Link
sneaker_ger
With mpv 2018-09-02 the 720p version of the halo trailer stutters here as well. I'm not sure it is related to shere AV1 decoding performance as LAV nightly (via MPC-HC) decodes completely smooth on i5-2500K with maybe 15% - 30% CPU. (Not that you have told us anything about your hardware ...)
Old 13th September 2018, 11:45   #928  |  Link
ChaosKing
Ryzen 1700 @3.6ghz. gpu Rx480 8GB. I testet it in Chrome 70 now and it is very smooth.
I thought of gpu decoding bcs in the task manager you can see a "GPU 3d" if you show the gpu modules column when playing in mpv.
Old 13th September 2018, 13:43   #929  |  Link
mzso
AKA, decent bitrate.
Sadly, they play nowhere near smoothly on my R5 1600, even though 6/12 cores are utilized to around 30-40%.
Old 13th September 2018, 14:52   #930  |  Link
Gravitator
Check how it will be with the disabled SMT/HT?
Gravitator is offline   Reply With Quote
Old 13th September 2018, 15:01   #931  |  Link
clsid
It seems to already use only the physical cores by default. So that won't have any effect.
Old 13th September 2018, 22:36   #932  |  Link
TD-Linux
ffmpeg bug, should be fixed in newer builds of mpv:+ffmpeg: https://git.ffmpeg.org/gitweb/ffmpeg...0015c26f4b09ba
TD-Linux is offline   Reply With Quote
Old 14th September 2018, 05:12   #933  |  Link
Clare
Still dropping many frames in 1080p with this commit.
CPU usage is around 10-13%.
Clare is offline   Reply With Quote
Old 14th September 2018, 08:23   #934  |  Link
Nintendo Maniac 64
Nintendo Maniac 64's Avatar
I just did some performance testing with the 1080p 30fps AV1 encode of the Gus Kenworthy & Tom Wallisch X Games Slopestyle GoPro Preview video in MPC-HC v1.8.1 x64 with its built-in LAVfilters; I originally tried the Halo video but I found the X Games video to be much more demanding (but also much more motion-sick inducing, especially when playing at slower than real-time).
With my 4c/8t Nehalem Xeon x3470 I was only seeing ~25% CPU utilization at maximum even though I was unable to play back the video in real-time (it was somewhere between 16fps and 20fps). Mathematically that should mean that it's only using 2 threads, but disabling SMT and setting my BIOS to only enable 2 cores resulted in noticably worse performance, yet setting the BIOS to enable 3 cores without SMT resulted in the same 16-20fps performance I was originally seeing yet at only ~67% CPU utilization.
At least with the LAVfilters bundled with MPC-HC v1.8.1 x64, it would seem that the AV1 decoder can only utilize 3 cores and no SMT, yet even then the 2 less loaded cores are only hitting around half of their according core's available utilization.
And for reference, the 720p 30fps AV1 encode of that same video played back without a hitch on my Xeon - heck it left enough headroom that I could turn on a bunch of motion interpolation which greatly helped alleviate the motion sickness I got from watching the 1080p AV1 encode playback at sub-20fps frame rates (it's times like this that I thank the devs over at Nintendo for making F-Zero X and F-Zero GX native 60fps games).
Now I'm a bit out-of-the-loop, but I couldn't help but notice that YouTube-DL was using the .MP4 extension for AV1 downloads - is that in fact correct behavior? (and no, I don't mean AVC1, otherwise my PC would have been playing back the videos easy-peasy).
Nintendo Maniac 64 is offline   Reply With Quote
Old 14th September 2018, 09:07   #935  |  Link
SmilingWolf
Originally Posted by Nintendo Maniac 64 View Post
Now I'm a bit out-of-the-loop, but I couldn't help but notice that YouTube-DL was using the .MP4 extension for AV1 downloads - is that in fact correct behavior? (and no, I don't mean AVC1, otherwise my Xeon would have been playing back the videos easy-peasy).
I can only answer to this part: the ISO-BMFF bindings for AV1 have been finalized first (just a few days ago in fact), while the Matroska/WebM ones are still WIP
So MP4-only for the time being
Also:
GCC 8.2, static builds, 32/64bits, CONFIG_LOWBITDEPTH=1
av1-1.0.0-577-g8ae39302e: https://mega.nz/#!14REmAwB!AO8Sta2C3...KVcSKPnnuyEOeI
Old 14th September 2018, 09:11   #936  |  Link
marcomsousa
I was able to play 1080p with MPC-HC v1.8.1 x64 in real time, with some hitches in middle part of the video.
CPU at 62%
Intel Core i7-8550U (Kaby Lake-R U4+2)
With ffplay.exe 20180912 I play this 1080p video, realy realy slow, but play well the 720p video.
It's correct, since webm support for av1 isn't finalized. Also youtube-dl download what youtube give, and Youtube have av1 in mp4 container with mp4 schema (av01.0.05M.08).
marcomsousa is offline   Reply With Quote
Old 14th September 2018, 10:59   #937  |  Link
SmilingWolf
ffplay 20180912 is, for whatever reason, a very poor version to test with. Don't know if it depends on the aom library revision used, on the ffmpeg revision, or something in the middle, but on my system it performs at half the perf on my own minimal ffmpeg+aom build
CPU: Intel i7-4770 @ 3.4 GHz
Zeranoe build:
# ffmpeg -threads 4 -i "Gus Kenworthy & Tom Wallisch X Games Slopestyle GoPro Preview.1080.mp4" -benchmark -f null -
ffmpeg version N-91931-gb69ea742ab Copyright (c) 2000-2018 the FFmpeg developers
  built with gcc 8.2.1 (GCC) 20180813
[libaom-av1 @ 0000000000485ac0] 1.0.0-507-g5d963cb57
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Gus Kenworthy & Tom Wallisch X Games Slopestyle GoPro Preview.1080.mp4':
frame= 1736 fps= 18 q=-0.0 Lsize=N/A time=00:00:57.92 bitrate=N/A speed=0.602x
video:909kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
bench: utime=95.473s stime=0.187s rtime=96.195s
bench: maxrss=234036kB
My own:
# ./ffmpeg -threads 4 -i "Gus Kenworthy & Tom Wallisch X Games Slopestyle GoPro Preview.1080.mp4" -benchmark -f null -
ffmpeg version N-91943-g1b98bfb932 Copyright (c) 2000-2018 the FFmpeg developers
  built with gcc 8.2.1 (GCC) 20180913
[libaom-av1 @ 0000000000338500] 1.0.0-577-g8ae39302e
frame= 1736 fps= 37 q=-0.0 Lsize=N/A time=00:00:57.92 bitrate=N/A speed=1.24x
bench: utime=98.234s stime=1.076s rtime=46.544s
bench: maxrss=272452kB
Old 14th September 2018, 12:09   #938  |  Link
Mr_Khyron
Member
Mr_Khyron's Avatar
http://download.opencontent.netflix.com/?prefix=AV1/
************** Netflix AV1 Encodes Readme **************************************
This is the readme for the Netflix AV1 Encodes.
The assets covered in this readme can be browsed on the Netflix OpenContent
bucket here:
Each asset has its license posted to its main directory in the file license.txt.
********** Downloading with AWS CLI ********************************************
You can download single files directly through your web browser on the
OpenContent page, but for large files and long frame sequence, you may wish to
use command line tools such as aws cli.
Detailled instructions are posted here:
http://download.opencontent.netflix....ets/README.txt
********** Encoding and Packaging **********************************************
The IVF files were produced using AOM aomenc (Libaom v1.0) using 2-pass, CQP,
tiles on higher resolutions, and Film Grain. Additionally, the following
parameters were used for all encodes:
--passes=2 --fpf=twopassStats --i420 --profile=0 --arnr-maxframes=7
--arnr-strength=5 --lag-in-frames=25 --aq-mode=0 --bias-pct=100
--minsection-pct=1 --maxsection-pct=10000 --end-usage=q --min-q=0 --max-q=63
--input-bit-depth=[8|10] --cpu-used=1 --auto-alt-ref=1 --max-gf-interval=12
--min-gf-interval=[4|5|6] --frame-parallel=0 --threads=8
--tile-columns=[1|2|4] --ivf
The IVF files were then packaged into (non-fragmented and non-encrypted) MP4
files conforming to https://aomediacodec.github.io/av1-isobmff/using
GPAC's MP4Box (GPAC version 0.7.2-DEV-rev654-gb6f7409ce-master) as follows:
MP4Box -add input.ivf output.mp4
Last updated: 2018 Sept 4
Copyright NETFLIX INC.
100 Winchester Circle, Los Gatos, CA 95032, USA
Mr_Khyron is offline   Reply With Quote
Old 14th September 2018, 12:34   #939  |  Link
sneaker_ger
Screenshots 8 vs 10 bit (8 bit has 40% more bitrate):
Netflix Chimera 8 bit
Netflix Chimera 10 bit
Is this an inherent problem of AV1 8 bit or just because it isn't very tuned yet (bitrate allocation, aq, psy)? Though 10 bit encode also has some problems, those "boxes" on the power lines between the two skyscrapers on the left go missing. Then again 10 bit was given much lower bitrate here ..
Old 14th September 2018, 12:43   #940  |  Link
MoSal
That's not the (only) issue. Note the decoding bottleneck in this sample five seconds in, at the scene change.
https://github.com/MoSal
MoSal is offline   Reply With Quote
