Old 14th December 2018, 22:14   #1321  |  Link
Motenai Yoda
Motenai Yoda's Avatar
the ones that don't care about gpu capabilities and still get a display without need a discrete card
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 14th December 2018, 22:19   #1322  |  Link
Originally Posted by Nintendo Maniac 64 View Post
But lets be honest here - with AMD finally being a viable alternative again, who is really buying Intel for their graphics capabilities?
Gen11 is also supposed to be significantly faster. And Intel has among the best media capabilities today already, while AMD has the worst.
So for a small form factor media PC, there would be no competition for me.
Old 15th December 2018, 04:16   #1323  |  Link
Nintendo Maniac 64
Nintendo Maniac 64's Avatar
Uhhhh...
____HTPC____  | __Desktop PC__
2.93GHz Xeon x3470 (4c/8t Nehalem) | 4.5GHz 1.24v dual-core Haswell G3258
Radeon HD5870  | Intel iGPU
2x2GB+2x1GB DDR3-1333 | 4x4GB DDR3-1600
Nintendo Maniac 64 is offline   Reply With Quote
Old 17th December 2018, 13:43   #1324  |  Link
you are aware that amd is still missing VP9 for hardware decoding even on vega.
while AMD is very competitive in the CPU market there GPU's are currently at an all time low. vega is using a lot of power needs a huge die and is really slow if you take size into consideration and the hardware decoder is pretty much worse than the nvidia cards that are getting 4 years old.
Old 17th December 2018, 18:53   #1325  |  Link
Mr_Khyron
Member
Mr_Khyron's Avatar
https://en.wikichip.org/w/images/a/a...whitepaper.pdf
on page 14
Vega” can also decode the VP9 format at resolutions up to 3840x2160 using a hybrid approach where the video and shader engines collaborate to offload work from the CPU.
Mr_Khyron is offline   Reply With Quote
Old 17th December 2018, 19:56   #1326  |  Link
sneaker_ger
AFAIK the newer AMD ones like Ryzen 5 2500U (Raven Ridge/ Vega 8) now have VP9 10 bit ASIC decoding.
But yeah, they are late. Don't expect it to be different for AV1.
Old 17th December 2018, 21:39   #1327  |  Link
hybrid decoding has nothing todo with hardware decoding.
letting a CPU and GPU core do the work of an ASIC is simply not the same.
it would be nice if the newest APU have asic decoder but not that trust worth test i found told me the vega 11 is hybrid.
Old 18th December 2018, 08:54   #1328  |  Link
alex1399
No sense, the amd hybrid decoding of vp9 just works as the way that intel do on the hybrid decoding of hevc in their 6th generation processor skylake. They ARE hardware decode.
alex1399 is offline   Reply With Quote
Old 18th December 2018, 19:33   #1329  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Keep things on topic, please.
Old 18th December 2018, 22:31   #1330  |  Link
SmilingWolf
I am maddo saientisto!
SmilingWolf's Avatar
Status report, redux
"rav1e is doing well" edition
1st edition: http://forum.doom9.org/showthread.ph...49#post1852449
2nd edition: http://forum.doom9.org/showthread.ph...87#post1857587
Whatever paragraph I don't repeat here can be assumed to be the same as in the aforementioned posts
First of all: graphs! Click to enlarge
Y axis: chosen metric
X axis: bits per pixel
720p:
1080p:
Encoders improvement over time:
720p:
1080p:
BD rates for 720p:
Codecs ladder:              |  x264 relative:
x264 -> rav1e               |  x264 -> rav1e
        RATE (%) DSNR (dB)  |          RATE (%) DSNR (dB)
 MSSSIM -10.7345 0.541324   |   MSSSIM -10.7345 0.541324
PSNRHVS -15.3271 1.07245    |  PSNRHVS -15.3271 1.07245
  HVMAF -7.40703 2.07138    |    HVMAF -7.40703 2.07138
rav1e -> vp9                |  x264 -> vp9
 MSSSIM -15.1057 0.68453    |   MSSSIM -21.81   1.08927
PSNRHVS -11.2436 0.654976   |  PSNRHVS -22.9586 1.51188
  HVMAF -19.2883 2.57019    |    HVMAF -24.1102 3.58993
vp9 -> x265                 |  x264 -> x265
 MSSSIM -4.25723 0.169151   |   MSSSIM -25.6195 1.21115
PSNRHVS -8.19042 0.41409    |  PSNRHVS -29.8289 1.83058
  HVMAF -10.6714 0.708441   |    HVMAF -31.2046 4.45371
x265 -> av1                 |  x264 -> av1
 MSSSIM -18.9088 0.7852     |   MSSSIM -38.0511 1.97653
PSNRHVS -15.3123 0.761791   |  PSNRHVS -38.6659 2.56119
  HVMAF -18.0023 1.0489     |    HVMAF -44.0411 4.3982
BD rates for 1080p:
 MSSSIM -20.0683 1.00011      |   MSSSIM -20.0683 1.00011
PSNRHVS -21.9935 1.47903      |  PSNRHVS -21.9935 1.47903
  HVMAF -18.4773 3.96202      |    HVMAF -18.4773 3.96202
 MSSSIM -18.2653 0.729489     |   MSSSIM -31.1754 1.49143
PSNRHVS -14.922  0.755605     |  PSNRHVS -30.1275 1.87845
  HVMAF -20.1645 2.31195      |    HVMAF -32.4505 4.72978
 MSSSIM 5.13717 -0.177855     |   MSSSIM -28.9956 1.18206
PSNRHVS -0.096748 -0.0123981  |  PSNRHVS -31.474  1.63676
  HVMAF -3.78107 0.0881882    |    HVMAF -34.6185 4.22357
 MSSSIM -26.486  0.938124     |   MSSSIM -45.4959 2.12535
PSNRHVS -21.7431 0.905916     |  PSNRHVS -43.4792 2.56047
  HVMAF -22.7091 1.17861      |    HVMAF -48.0404 4.69582
Encoders:
x264 157-2935-545de2f
x265 2.9-4-471726d3a046
rav1e 0.1.0-977-64b9f501
libaom 1.0.0-908-g3a607f7b0
libvpx 1.7.0-1352-gea57f9acd
Cmdlines:
x264 --preset veryslow --tune ssim --crf 16 -o test.x264.crf16.264 orig.i420.y4m
x265 --preset veryslow --tune ssim --crf 16 -o test.x265.crf16.hevc orig.i420.y4m
rav1e --low_latency false -o test.rav1e.cq80.ivf --quantizer 80 -s 2 --tune psnr orig.i420.y4m
aomenc --frame-parallel=0 --tile-columns=3 --auto-alt-ref=1 --cpu-used=4 --tune=psnr --passes=2 --threads=2 --end-usage=q --cq-level=20 --test-decode=fatal -o test.av1.cq20.webm orig.i420.y4m
vpxenc --codec=vp9 --frame-parallel=0 --tile-columns=2 --good --cpu-used=0 --tune=psnr --passes=2 --threads=2 --end-usage=q --cq-level=20 --test-decode=fatal --ivf -o test.vp9.cq20.ivf orig.i420.y4m
Quality settings:
x264: CRF 16-24 step 1, and 24-34 step 2
x265: CRF 16-24 step 1, and 24-34 step 2
rav1e: CQ 80-160 step 16
aomenc: CQ 20-40 step 4
vpxenc: CQ 20-48 step 4
VMAF: model used: nflxall_vmafv4, pooling: harmonic_mean
Notes:
Revisiting the sequences from the previous report:
F.Y.C, x264 -> rav1e
        RATE (%) DSNR (dB)
 MSSSIM -21.8223 1.2258
PSNRHVS -28.408 2.29056
  HVMAF -18.7682 3.89782
PresageFlowerFight, x264 -> rav1e
        RATE (%) DSNR (dB)
 MSSSIM -33.8353 1.95641
PSNRHVS -33.5774 2.47118
  HVMAF -29.2079 7.17318
PresageFlowerWalk, x264 -> rav1e
        RATE (%) DSNR (dB)
 MSSSIM -6.98635 0.333085
PSNRHVS -3.78743 0.244148
  HVMAF 2.23865 -0.150589
MAJOR improvements in static/very low motion scenes thanks to adaptive keyframe selection, marginal improvements in the others.
SmilingWolf is offline   Reply With Quote
Old 19th December 2018, 00:36   #1331  |  Link
Phanton_13
SmilingWolf, can you also indicates the encoding speed, it don't need to be in fps as it can be in relation of a specific encoder, is more to see the variation in the speed of aoemc and rav1e due to optimizations or other improvements.
Phanton_13 is offline   Reply With Quote
Old 19th December 2018, 05:26   #1332  |  Link
utack
The cpu-used heuristics in libaom seems to be poorly tuned in lossless mode.
Tested with a digitally animated gif
hitting 50% size increase at 1/4 encode time saved compared to cpu-used=0, and double the size at 60% the encode time of cpu-used=0
each dot presets one cpu-used value
utack is offline   Reply With Quote
Old 19th December 2018, 07:31   #1333  |  Link
Nintendo Maniac 64
If you ever want to test higher-quality animation examples (read: not limited to 256 colors), then perhaps try an animated PNG.
Old 19th December 2018, 11:06   #1334  |  Link
SmilingWolf
I use my PC under various loads while encoding, so I can't reliably measure times, which is why I haven't included anything time specific so far.
A quick test on the F.Y.C clip however has displayed an improvement, on average, of 12% over the last month (1.0.0-1058-g8547359cf vs 1.0.0-908-g3a607f7b0).
At the same time, quality as measured by MS-SSIM and PSNR-HVS-M has gone down ~2.5%, circa to the levels of 3 months ago (1.0.0-577-g8ae39302e).
As for rav1e, the times have only grown worse because there have been many new additions but almost no early breakout (or none at all?) strategies have been implemented yet.
And as of right now, some ASM optimizations are disabled on Windows, so I guess I'm basically running on Rust code. So not much of a speedup on that front either (yet).
Old 20th December 2018, 14:52   #1335  |  Link
Phanton_13
Thanks SmilingWolf for the info.
Old 22nd December 2018, 11:31   #1336  |  Link
sneaker_ger
Simply crashes on my system even with a simple "ffmpeg" (no parameters). Windows 7 x64, i5-2500K (SSE4.2 and AVX).
Old 22nd December 2018, 17:47   #1337  |  Link
sneaker_ger
Still crashes.
Old 22nd December 2018, 18:40   #1338  |  Link
lvqcl
My CPU doesn't support SSE4.2, only 4.1, but I still tried to run it.
ffmpeg.exe crashes at shlx instruction, which is part of BMI2 (Haswell/Excavator).
Old 22nd December 2018, 19:11   #1339  |  Link
Its usually not a good idea to build such a restricted binary, nor does it really give a meaningful speed enhancement. Just use a better build.
I often intentionally restrict what I allow compilers to do, because even GCC 8 is still terrible at using advanced instruction set instructions, and it can and will cause issues left and right.
This is especially true in a large and old code base like ffmpeg, which has code that was written 15 years ago, and code that as written just now, code that was painstakingly hand-optimized, and whatnot which can result in quite varying stress on the compiler.
Old 22nd December 2018, 22:01   #1340  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
I think the crash comes from that I configured gcc to have skylake by default, forget to use the --cpu switch, will rebuild them later.
Thanks nevcairiel.
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
