25th November 2013, 01:47 | #18461 | Link | |
If you remove the BD Rebuilder directory, then uninstall the programs from the first page and reset your machine. Or shut down completely. Then start it again...and install everything from the instructions. BestBuy isn't always the best at diagnosing... I've fixed programs they've created. Anyway, unless you're really good with computers...I'd not suggest a Virtual Machine to test. Most people become even more confused when attempting to do so. Try those steps before quitting. Learning is fun...just remember to breathe and relax while doing so. :-)
25th November 2013, 08:14 | #18463 | Link |
Firstly, the x264 fails the instant it tries to reencode, not a minute. And my system is not unstable. I have good RAM, I even tested it, my hard drives are non-plattered, and as for the source, I have tried to compress 11 titles and all of them seem to fail once it comes time to reencode, so as I said before, I cannot figure out what the problem is, its obvious that this software no longer works for me, so thank you all for your efforts, goodbye.
25th November 2013, 23:53 | #18464 | Link |
Aging Video Hobbyist
Today I tried 45.05 on Silver Linings Playbook in Movie and Menus (Auto Blank Extras) and Edit Mode (Manual Blanking) both selected, and managed to blank the main movie. Turns out that I'd Previewed it and instead of playing the Multi-Ch Engish DTS track, the preview mplayer used the French track that had been de-selected, which threw me off and so I accidentally blanked it w/o looking more closely.
Later I look at the mplayer header where it shows MPC_VIEW.AVS which is this: #Created by BD Rebuilder - v0.45.05 (beta) DirectshowSource("V:\BDMV\STREAM\00006.m2ts", fps=23.976, framecount=175671) BicubicResize(480,270) ConvertToYV12().AssumeFPS(24000,1001) If I open and play 00006.m2ts (in the original disc) using BD-RB's mplayer it too plays the French track when I do that. But if I use instead my Media Player Classic - Home Cinema to open the file, it plays the English track as expected (though it "can't render file" if I try to open your .AVS file). Is this maybe an issue with the old media player you're using? I don't see anything in the .avs that determines audio track so am not sure why it should play this 2nd audiotrack the way it does. BTW I am frequently confused when Previewing each of the VID_XXXXX which I always do, because when I right-click on each and select Preview This Item and the MPC_VIEW.AVS opens in Media Player Classic, the highlighting in the BD-RB window is lost until the Preview is closed and the BD-RB window is selected again. It would be nice if either the highlighting in the BD-RB window could be retained (i.e. stay blue-highlighted while mplayer is playing), or if the header of mpc player would show the VID number, so I know for sure which VID it is that I am previewing. I do typically get lost when Previewing and end-up re-playing some of the clips to be sure... Last edited by laserfan; 26th November 2013 at 00:03. |
26th November 2013, 02:00 | #18465 | Link | |
The highlighting acivity is controlled by the O/S rather than the app... And it likely is unhighlighted because it loses focus. I'll see if I can set the focus back just before making the call to MPC. Last edited by jdobbs; 26th November 2013 at 02:02. |
26th November 2013, 09:49 | #18466 | Link |
Ok, I haven't given up completely but can someone at least tell me why it will reencode all the way until it gets to the main title? It does this on every single title I have. It ALWAYS gives me the H.264 Has Stopped Working error once it gets there. Here is my log:
---------------------- [11/26/13] BD Rebuilder v0.45.05 (beta) [01:27:17] Source: SOURCE_CODE - Input BD size: 26.93 GB - Approximate total content: [01:55:14.390] - Target BD size: 23.31 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [01:27:19] PHASE ONE, Encoding - [01:27:19] Processing: VID_00001 (1 of 13) - [01:27:19] Extracting A/V streams [VID_00001] - [01:27:48] Reencoding video [VID_00001] - [01:27:48] Reencoding secondary video [TRK_02] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,235 frames - Bitrate: 22,439 Kbs - [01:27:55] Reencoding: VID_00001, Pass 1 of 1 - [01:30:33] Video Encode complete - [01:30:33] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (spa): Keeping original audio - Track 4354 (eng): Keeping original audio - Track 6656 (eng): Keeping original audio - [01:30:33] Multiplexing M2TS - [01:30:44] Remuxing DTSX/IGS stream(s) - [01:31:08] Processing: VID_00002 (2 of 13) - [01:31:08] Extracting A/V streams [VID_00002] - [01:31:23] Reencoding video [VID_00002] - [01:31:23] Reencoding secondary video [TRK_02] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 559 frames - Bitrate: 22,739 Kbs - [01:31:27] Reencoding: VID_00002, Pass 1 of 1 - [01:32:36] Video Encode complete - [01:32:36] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (spa): Keeping original audio - Track 4354 (eng): Keeping original audio - Track 6656 (eng): Keeping original audio - [01:32:36] Multiplexing M2TS - [01:32:43] Remuxing DTSX/IGS stream(s) - [01:32:54] Processing: VID_00003 (3 of 13) - [01:32:54] Extracting A/V streams [VID_00003] - [01:34:01] Reencoding video [VID_00003] - [01:34:01] Reencoding secondary video [TRK_02] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,989 frames - Bitrate: 22,827 Kbs - [01:34:29] Reencoding: VID_00003, Pass 1 of 1 - [01:45:10] Video Encode complete - [01:45:10] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (spa): Keeping original audio - Track 4354 (eng): Keeping original audio - Track 6656 (eng): Keeping original audio - [01:45:10] Multiplexing M2TS - [01:45:35] Remuxing DTSX/IGS stream(s) - [01:46:34] Processing: VID_00004 (4 of 13) - [01:46:34] Extracting A/V streams [VID_00004] - [02:19:37] Reencoding video [VID_00004] - [02:19:37] Reencoding secondary video [TRK_02] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 93,629 frames - Bitrate: 23,302 Kbs - [02:45:30] Reencoding: VID_00004, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.45.05 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 4504, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - WAVI: Ok - TSMUXER: Ok [02:47:39] - Failed video encode, aborted |
26th November 2013, 10:24 | #18467 | Link |
I can feel your frustration!
The only times I had x264 crash the way you are describing it's all about my overclocked CPU. When I lower the clock frequency just a few notches all is well. So if you havn't tried that give it a shot. |
26th November 2013, 10:34 | #18468 | Link |
It's not overclocked! I have NO idea why this is happening, my RAM is fine, nothing new has been installed on my computer other than reinstalling the three programs required, the log is correct, I know what I'm doing, I just can't understand why it's doing this to me! I have no viruses, my disks are defragmented, my computer is not lagging and is running just fine, but on every single movie it does this, so what could it be??????
26th November 2013, 14:26 | #18470 | Link | ||
Regarding previewing...
26th November 2013, 15:40 | #18471 | Link |
jdobbs, remember I mentioned about my Sony BR player not displaying the buttons on QP menus? Well, today I purchased a Samsung BD-F6500 standalone. I now have the opposite issue! The disc buttons come up, but no background. Clicking on the buttons return back to the menu and won't play anything! I've only tested one BD-R 25GB disc so far, but that works great in PDVD 13. Any thoughts or anyone else with this player who can test for me?
26th November 2013, 18:12 | #18472 | Link | |
26th November 2013, 21:23 | #18473 | Link | |
27th November 2013, 02:29 | #18474 | Link | |
27th November 2013, 04:27 | #18475 | Link |
I don't think this is the cause of problem here. Since Crocluvr92 can encode extras from video just fine and as soon as it start main movie encode it crashes and according to Crocluvr92 it is happening on all movie title he has tried.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 27th November 2013 at 04:35. |
27th November 2013, 09:09 | #18477 | Link |
I do not have other codecs, My drives are SSD's, I have tried all four versions x264 with replacing them in the Tools folder and they all fail as well. I also tried movie only and that fails too after reencode. It does this on my movies, not just one. My PC is cleaned out, I used compressed air, I even went to CompUSA today and bought some new Antec paste for my CPU and fan, I tried using my BluRay Source from the source folder from hard drive and from ISO format running on a Virtual Drive and still NOTHING works! Now do you all understand why I want to give up?
27th November 2013, 12:33 | #18479 | Link | |
Full 3D Backups with no resize
I would really appreaciate it. |
