27th May 2011, 09:15 | #3481 | Link | |
1. Media type in the tab Output. (Audio not working) 2. Download the selected filter tab Graph Builder. 3. Compulsory connection to the filter tab Connections. And yes, a developer from Russia. Therefore, the discussion forums is available only in Rousseau, unfortunately. We will be glad to see here http://www.forum.team-mediaportal.ru...ic,1939.0.html and here http://forum.ixbt.com/topic.cgi?id=10:58214-111#3692 About the use of someone else's code the developer wrote the following: Partly pieces of code from ffmpeg, other libraries, music players, splitters, codecs, razumetso present, but naturally in a highly processed form. It is normal practice, and everybody does it. From scratch software was written years since 20 years. |
27th May 2011, 09:24 | #3482 | Link | |
You can't just go around and "use" all the code you find. You have to obey to the licenses that code was released under, and if you don't, its stealing of intellectual property. Even if the code is completely free (public domain, etc), its just common courtesy to give credit to the people that did all the work for you. Just using their work and claiming it your own without comment is disrespectful and just arrogant.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 27th May 2011 at 09:33. |
27th May 2011, 12:19 | #3483 | Link |
Did some further testing regarding the CVID file from #3461 not playing with ffdShow anymore on my setup. And the breaking change is probably the minor ffmpeg update right before the release of 0.27.
As I suspected ffmpeg to be the cause, I replaced the according dlls from 0.27 one by one with those from 0.26-31 (I know it's brute force) and found out that avformat-53.dll is responsible. Now, I know that it may very well be ffdShow's fault and - of course - I will bring it up there it, if this is the case, but maybe you find the time to have another look - just in case that it is ffmpeg in LAV that is broken with this specific format... Last edited by Sven75; 27th May 2011 at 12:22. |
27th May 2011, 18:29 | #3484 | Link |
LAV Filters 0.28
LAV Splitter - Improved PGS filtering, forced subtitles should be cleared off the screen properly more often. - Improved playback of H264 in MPEG-TS with certain files (mostly from camcorders, but some Blu-rays as well) - Fixed 16-bit LPCM on DVDs - Fixed the Media Types for uncompressed video LAV Audio - Added the ability to decode DTS Express when using the ArcSoft DTS Decoder - Fixed missing audio after seeks with Ogg Vorbis DTS Express DTS Express is a special low-bandwidth format used on Blu-rays for PiP commentary tracks. It consists of only HD frames, and therefor cannot be decoded by ffmpeg. You can only decode it with the ArcSoft DTS Decoder right now. Bitstreaming it is also not supported at this time. Still, this is the first time i see it actually decoded outside of TMT itself, the standalone ArcSoft decoder crashed when i fed it to it. All other changes are more or less bugfixes. The PGS filtering should hopefully no longer keep some forced subs on the screen for way too long, but i didn't watch a full movie to confirm, just did some quick tests on known problem spots. Have fun!
27th May 2011, 20:25 | #3486 | Link |
nevcairiel, thanks for the new version!
1) 0.28 plays fine my Panasonic AVCHD files while 0.27 doesn't. 2) Re-sync issue on AVI files is fixed with (I guess) that ogg patch. 3) Zoom Player hang problem was fixed along with AVI crash issue after pre-0.26 patch. 4) LAV Splitter +ArcSoft Audio Decoder problem on M2TS with E-AC3 still persists. It appears after seek, and if you seek to a middle position in a M2TS file. Although this combination of container, audio format and decoder is not usual I think it is good to fix it because the bug may exibit is some other place (like fixed bugs 2) and 3)). Sample file M2TS + E-AC3 can be found here. Thanks again, your work is greatly appreciated! |
27th May 2011, 20:27 | #3487 | Link |
dts express support is nice, never could get it to play before (in remuxes)
27th May 2011, 21:27 | #3488 | Link | |
The sample links you posted are dead.
27th May 2011, 22:16 | #3490 | Link |
Thats the same file i already had, and it decodes just fine with the ArcSoft DD+ decoder. I get audio out of all channels, with or without seeking.
27th May 2011, 22:41 | #3491 | Link |
Another sample with E-AC3: http://stfcc.org/misc/transformers.sample.m2ts
27th May 2011, 23:05 | #3493 | Link | |
ASAudioHD.ax v1.3.3.219 26.07.2010 DdpDec71.dll v1.0.1.12 16.04.2010 |
27th May 2011, 23:07 | #3494 | Link |
I'm using 1.3.3.273 (from TMT3.190) and 1.0.1.12, and i experience no such issues.
27th May 2011, 23:51 | #3496 | Link |
I did some more testing with this, and it looks like the older versions of the TMT decoder are indeed having this problem. But i don't think there is anything i can fix.
It works with the MPC-HC splitter, because its stupid and tells the decoder that its AC3 instead of EAC3, so my guess is that its actually only decoding the normal AC3 part of the stream when using the MPC-HC splitter, but not the E-AC3 part that adds the 2 extra channels. Anyway, its fixed in the decoder from TMT3.190 - use that.
28th May 2011, 09:52 | #3498 | Link | |
The problem with ASAudioHD.ax v1.3.3.273 is that it's limited to 16/48 output. Anyway it looks like bug in ArcSoft decoder and not in LAV Splitter. Thanks for the tests and the explanation. BTW am I right that LAV Audio does not decode E-AC-3 extension to an AC-3 core in M2TS files? I read somewhere ffmpeg does not support E-AC-3 over 5.1 config. Last edited by Gleb Egorych; 28th May 2011 at 09:54. |
28th May 2011, 10:40 | #3499 | Link |
Thats right. The format is very rare, AFAIK it only exists on the Dolby Demo Blu-ray, so there is no need to invest much more time in it.
28th May 2011, 10:49 | #3500 | Link |
Not that this is your problem, but just wanted to say that with the asaudiohd.ax from .190 it's even worse for me. I get the channel wrong/silent issue even when not skipping. With .185 at least I got it correct when playing from the beginning.
