Old 24th March 2019, 15:24   #501  |  Link
Budtz
And Youtube-dl dosnt support HTTP? It says on the site it supports appletrailers i think
Any way to make mpchc just as robust as the kodiplayer in this regard?
http://hometheatersettings.com - how to setup htpc and more
Budtz is offline   Reply With Quote
Old 24th March 2019, 18:07   #502  |  Link
clsid
Apple trailers works fine here, so something is wrong at your end.
Use latest MPC-HC and youtube-dl.exe
Don't disable the internal HTTP(s) source filter.
Old 25th March 2019, 13:23   #503  |  Link
ashlar42
Originally Posted by clsid View Post
First it takes too long, then you say I should wait a week. It is never good, always someone who complains. I just release when I am in the mood for it. You can also just wait before updating. One of the two fixed VP9 bugs has been present in LAV nightlies for over 6 weeks now, and nobody reported it. Nobody has bothered to report an issue with 1.8.5 either.
I almost never write here but reading this made me sad.
clsid I'm pretty sure there's tons of people that appreciate your hard work and you simply don't see them because they're simply happy and satisfied. So, thank you.
Old 25th March 2019, 20:19   #504  |  Link
VBB
VBB's Avatar
Especially when replacing the LAV filters is so simple:
1. Download and install latest nightly from here http://files.1f0.de/lavf/nightly/.
2. Go to \Program Files (x86)\LAV Filters\ and copy the contents of either the 64-bit or 32-bit folder to the \MPC-HC\LAVFilters64 or \MPC-HC\LAVFilters32 folder.
You can also replace the MediaInfo.dll whenever a new version of that is released.
Thanks @clsid for keeping MPC-HC alive!
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex
VBB is offline   Reply With Quote
Old 26th March 2019, 13:40   #505  |  Link
Duccat
I thought the current LAV filters + player supported .usm files? I tried to play an .usm video with mpc-hc and it just says "cannot render the file". I know they are not corrupted or any such because they are scenes from a computer game that are inside the game's folder and they play fine when they are viewed in gameplay.
Duccat is offline   Reply With Quote
Old 26th March 2019, 16:38   #506  |  Link
clsid
Provide a sample file.
Not everything that is supported by FFmpeg is automatically supported by LAV Filters. The video decoder needs to define which formats it can handle.
Old 26th March 2019, 20:12   #507  |  Link
Budtz
I am. How are u opening the trailers? i use kodi+add-on that then opens mpchc but that dosnt work. maybe its that?
I am using lav external and tried both with internal HTTP(s) source filter inabled and disabled with no succes. maybe its becouse I use external filters?
Old 27th March 2019, 15:52   #508  |  Link
clsid
I copy/paste the webpage URL from browser.
Your addon probably tries to extract video url by itself. ProcessExplorer can show the command line that was used to open MPC-HC. That contains the URL that Kodi used.
Old 28th March 2019, 23:17   #509  |  Link
Budtz
I Think its that then. I Can open Them from copying a link but not from Kodi.
Old 29th March 2019, 00:51   #510  |  Link
djsolidsnake86
any way to set multiple keyboard key for commands?
djsolidsnake86 is offline   Reply With Quote
Old 29th March 2019, 10:22   #511  |  Link
A combination of several shift keys with a letter or function key is possible as far as the "virtual key" constants of Windows permit.
First click in the "Keys" table selects the line; second click in the "Key" column in this table enables a key input field.
Or do you mean: Several alternative key combinations for the same command? Doesn't look like this would be possible, it's a 1:1 table.
Old 29th March 2019, 17:18   #512  |  Link
djsolidsnake86
for example i want use keys A & P for stop movie
is possible?
Old 29th March 2019, 17:31   #513  |  Link
clsid
No. Each command has only one keycombo.
But there are separate Pause/Stop/Close/Exit commands.
Old 30th March 2019, 12:44   #514  |  Link
Duccat
This is the smallest file at 2MB.
It is just the Sega logo that plays when the game boots up.
https://ufile.io/z0zd8
In case that is not adequate enough, here is the smallest file of a scene from the game. It is 34MB.
https://ufile.io/2l3vs
Old 31st March 2019, 15:56   #515  |  Link
MPC-hc has a problem in loading iso directly in some cases.
samples: https://kodi.wiki/view/Samples
the #4 sample doesn't work it works fine in mpc-be.
i personally can see anything that's related to this and i guess the iso is just virtual mount and the open "open DVD/BD..." is used on it which works fine if you do these steps by hand.
Old 1st April 2019, 15:19   #516  |  Link
clsid
USM files are not yet supported by FFmpeg, and thus also not by MPC-HC.
Direct playback of ISO files is also not supported.
Old 1st April 2019, 19:26   #517  |  Link
but still kind interesting that direct iso playback works "most" of the time by accident.
Old 2nd April 2019, 14:52   #518  |  Link
clsid
It works only partially. LAV Splitter may be able to find the contents of the first file in the ISO and play that. But it doesn't do more than that.
Old 6th April 2019, 15:34   #519  |  Link
clsid
Someone made a patch for an optional dark theme. It's not perfect yet. Currently only the main UI is dark, all other dialogs, like playlist and options, are still light as they are now.
Test build for those who want to try:
https://www.sendspace.com/file/vuda6t
(menu > view > dark theme)
Other known issues atm: Menu separators are not visible, statusbar border is still light, menubar is light again after changing language.
Old 9th April 2019, 22:39   #520  |  Link
Nintendo Maniac 64
Nintendo Maniac 64's Avatar
Did YouTube change something? Some recently uploaded 60fps videos are giving me 30fps versions when opened directly in MPC-HC via the built-in youtube-dl functionality.
Here's a couple example 60fps videos that are exhibiting this aforementioned behavior:
https://www.youtube.com/watch?v=Gkb87gjLyPg
https://www.youtube.com/watch?v=PTF0ZvWraMA
Yet other recent videos do not exhibit this behavior and do in fact play at 60fps in MPC-HC, such as the following:
https://www.youtube.com/watch?v=mVnWPvufIuo
Heck this video only gives me 720p 30fps even though 1080p 60fps is available via stand-alone youtube-dl:
https://www.youtube.com/watch?v=4qxhwFrjK4A
____HTPC____  | __Desktop PC__
2.93GHz Xeon x3470 (4c/8t Nehalem) | 4.5GHz 1.24v dual-core Haswell G3258
Radeon HD5870  | Intel iGPU
2x2GB+2x1GB DDR3-1333 | 4x4GB DDR3-1600
Nintendo Maniac 64 is offline   Reply With Quote
