Old 27th May 2010, 15:45   #3221  |  Link
rack04
Originally Posted by komisar View Post
rack04, x264_thread_pool_v2.9_r1612 patch by <MasterNobody>...
Fixed. Thank you.
rack04 is offline   Reply With Quote
Old 27th May 2010, 16:09   #3222  |  Link
ajp_anton
ajp_anton's Avatar
What happened to the Intel builds?
ajp_anton is offline   Reply With Quote
Old 27th May 2010, 16:47   #3223  |  Link
Schrade
Schrade's Avatar
rack04, x264_x86_r1613M download link links to an archive named x264_x86_r1612M.7z
Is it just a typo?
Schrade is offline   Reply With Quote
Old 27th May 2010, 16:53   #3224  |  Link
rack04
Is it just a typo?
What does --help say?
x264 core:97 r1613M 81e75e9
Old 27th May 2010, 20:41   #3225  |  Link
jpsdr
Rack04 : Big problem with your x64 1613M version. I have the program wich brutaly crash/stop without any kind of error message after encoding 30 frames of the 1rst pass (video is 1280x720 23.976fps)...
Commande line used :
@echo off
SET E_SRC=%6%1.avs
SET E_DST=%3%1.264
SET STAT_FILE=%1.stats
SET TUNING=%4
SET LOG_FILE_1=%1_log_1.txt
SET LOG_FILE_2=%1_log_2.txt
REM Set of max bitrate (ici le bitrate max)
set MAX_BR=15000
REM Set of Buffer (ici le buffer)
set BUF_BR=30000
REM 1ère passe
x264_x64.exe --profile "high" --preset "placebo" --tune %TUNING% --pass 1 --bitrate %2 --stats %STAT_FILE% --level "4.0" --qpmin 0 --vbv-maxrate %MAX_BR% --vbv-bufsize %BUF_BR% --keyint 48 --min-keyint 2 --mvrange 511 --ref 6 --bframe 3 --b-pyramid "strict" --open-gop --subme 9 --trellis 1 --me "umh" --aq-mode 2 --aud --nal-hrd "vbr" --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --videoformat "ntsc" --sar 1:1 --qpfile %5 --threads 0 --thread-input --output NUL %E_SRC% 2> %LOG_FILE_1%
REM 2ème passe
x264_x64.exe --profile "high" --preset "placebo" --tune %TUNING% --pass 2 --bitrate %2 --stats %STAT_FILE% --level "4.0" --qpmin 0 --vbv-maxrate %MAX_BR% --vbv-bufsize %BUF_BR% --keyint 48 --min-keyint 2 --mvrange 511 --ref 6 --bframe 3 --b-pyramid "strict" --open-gop --aq-mode 2 --aud --nal-hrd "vbr" --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --videoformat "ntsc" --sar 1:1 --qpfile %5 --threads 0 --thread-input --output %E_DST% %E_SRC% 2> %LOG_FILE_2%
Old 27th May 2010, 22:30   #3226  |  Link
rack04
Post a sample that can be reproduced. Do it work with unpatched build?
Old 28th May 2010, 08:37   #3227  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by burfadel View Post
Which mandatory command line are you trying to replace?
Well, replace the older command line with the newer that should use rack04 patched compile.
@turment on Telegram
Old 28th May 2010, 08:40   #3228  |  Link
jpsdr
I'll make other tests this evening. With unpatched build, the command line will be of course without open-gop.
Old 28th May 2010, 09:40   #3229  |  Link
kypec
User of free A/V tools
kypec's Avatar
Originally Posted by rack04 View Post
Fixed. Thank you.
You've only fixed _x86 part. <komisar> is still mentioned at _x64 part.
I think it would be easier for you and also for the readers to join that
descriptive links to patches. Write them just once together with compilation
settings used and post only separate download links to _x86 / _x64 builds underneath.
Same suggestion to unpatched builds applies.
It's redundant and likely error prone to write same information twice, no need for that.
kypec is offline   Reply With Quote
Old 28th May 2010, 16:01   #3230  |  Link
Wishbringer
Silent Reader
Wishbringer's Avatar
Big problem with your x64 1613M version. I have the program wich brutaly crash/stop without any kind of error message after encoding 30 frames of the 1rst pass...
Same here, tried to encode 1920x1080/24
--profile high --preset veryslow --tune film --slices 4 --level 4.0 --keyint 48 --min-keyint 2 --aq-mode 2 --b-pyramid strict --aud --nal-hrd vbr --open-gop --vbv-bufsize 31250 --vbv-maxrate 15000 --direct auto
Same encode worked with 1603, I just updated the exe to 1613M and restarted encode.
Wishbringer is offline   Reply With Quote
Old 28th May 2010, 16:16   #3231  |  Link
rack04
Have you tried without open-gop? Can you post a sample?
Old 28th May 2010, 17:03   #3232  |  Link
Wishbringer
Silent Reader
Without --open-gop it works (1st pass was ok, atm it started 2nd pass and is at 10%).
Sorry, no sample, am here at girlfriend with only 64kbit/sec upload speed.
Old 28th May 2010, 17:23   #3233  |  Link
rack04
I found the problem. Try this build. I will update the download link in the other post.
Old 28th May 2010, 17:27   #3234  |  Link
jpsdr
Was the problem specific to x64 build ?
Old 28th May 2010, 17:28   #3235  |  Link
rack04
Nope. I managed to screw up the the open-gop patch. It should be fixed now.
Old 28th May 2010, 17:43   #3236  |  Link
Wishbringer
Silent Reader
Seems to work now, 1st pass at 30%, no crash like first build at 0-1%.
Thanks rack04!
Old 28th May 2010, 17:44   #3237  |  Link
jpsdr
@Rack04Thanks for the builds and the updates. I'll test it.
@Wishbringer : Level 4.0 don't need slices (if encoding for blu-ray), so, removing will slighty improve quality.
Old 30th May 2010, 07:02   #3238  |  Link
3ngel
I continue to have the same situation with first pass truncked after some minutes with only a "encode failed" and second pass that can't find the "stat file".
I've downloaded again from the Rack04 updated post the new build (with the open gop corrected patch), but same problem.
I download the x86 without filters.
Am i missing something?
3ngel is offline   Reply With Quote
Old 30th May 2010, 09:03   #3239  |  Link
Wishbringer
Silent Reader
The 1613 build without "M" in name?
Does it even have open-gop-patch? it's not "Modified"!
Maybe your 1st pass doesn't start because it can't recognize "--open-gop" command.
Old 2nd June 2010, 17:46   #3240  |  Link
rack04
Toolchain:
  • GCC 4.4.4
  • GPAC 0.4.6
  • Pthreads 2.9.0.0
  • Yasm 1.0.1
LAVF/FFMS Builds:
x264 Builds:
System:     MINGW
asm:        yes
avs input:  yes
lavf input: yes
ffms input: yes
mp4 output: yes
pthread:    yes
debug:      no
gprof:      no
PIC:        no
shared:     no
visualize:  no
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
