Old 12th January 2019, 12:24   #6621  |  Link
If you rely on a specific setting that strongly, you should not rely on it being the default, and just specify it. Or as an alternative, not blindly update your encode pipeline without verifying that it still produces expected results.
For the record, the default was changed from 1 to 2, not the other way around.
Old 12th January 2019, 12:35   #6622  |  Link
Boulder
Pig on the wing
Boulder's Avatar
That's the reason why I have a long string of options in the command line even if most of them are the defaults of a specific preset.
Old 12th January 2019, 12:48   #6623  |  Link
Personally I like the second option. Not blindly update, but validate new versions first.
Old 12th January 2019, 12:56   #6624  |  Link
Selur
Selur's Avatar
Still waiting for them to update the documentation https://x265.readthedocs.io/en/latest/presets.html,..
Opened an issue entry for it (https://bitbucket.org/multicoreware/...-documentation) at the end of last year.
I get it that they change the defaults(/presets/tune) from time to time, but not updating the documentation do represent such fundamental changes is really annoying,...
Old 12th January 2019, 13:10   #6625  |  Link
Boulder
Pig on the wing
Boulder's Avatar
And a funny thing is that --no-rskip is supposed to be a default in --preset veryslow (and also --slower) but it's not according to the code. I reported the issue a long time ago but no one fixed it Doesn't matter to me though, I use --rskip all the time anyway.
Old 12th January 2019, 13:26   #6626  |  Link
Selur
Selur's Avatar
@Boulder: yeah, looking at https://bitbucket.org/multicoreware/...cpp?at=default rskip is only disabled in placebo,
but the documentation:
- https://x265.readthedocs.io/en/latest/presets.html reports that is is disabled starting with slower.
- https://x265.readthedocs.io/en/default/presets.html reports that is is disabled starting with very slow.
-> wrong documentation is even worse than missing documentation
(same for https://bitbucket.org/multicoreware/....cpp?at=latest)
Old 12th January 2019, 14:29   #6627  |  Link
jlpsvk
ok... can you tell me why aq mode 2 is better? i noticed rapid lower bitrate with aq-mode 2... any impact on picture quality and fine detail retention? i am encoding with crf18
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD
jlpsvk is offline   Reply With Quote
Old 12th January 2019, 14:44   #6628  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I didn't find mode 2 better than 1 in my test cases (reported earlier here in this thread) so I'm still using mode 1 with the default strength.
I think you need to find a new sweet spot for CRF since the bitrate demand is indeed quite different compared to mode 1, and I also think it depends heavily on the content.
Old 12th January 2019, 15:35   #6629  |  Link
Ma
Originally Posted by Motenai Yoda View Post
@Ma can you make results about --ctu 64 --qg-size 32 and --ctu 32 --qg-size 16 too?
maybe just for --merange 40 only
Results in attachment -- it is a bit faster encoding but quality is worse (at the same bitrate).
Old 12th January 2019, 17:57   #6630  |  Link
excellentswordfight
Lost my old account :(
Originally Posted by Ma View Post
I've made a test with --merange 12/26/40/57/74/92 for --ctu 64 --qg-size 64 vs. --ctu 32 --qg-size 32
Command line:
for %m in (12 26 40 57 74 92) do (
x265 -p7 --bitrate 500 -f3333 --psnr --ssim --qg-size 64 --merange %m ../big_buck_bunny_1080p24.y4m w64-%m.hevc
x265 -p7 --bitrate 500 -f3333 --psnr --ssim --ctu 32 --merange %m ../big_buck_bunny_1080p24.y4m w32-%m.hevc
Results (in ctu block: speed (fps), PSNR, SSIM (dB)):
					ctu
merange	|		64		|		32
12	|	6.93	39.980	12.996	|	6.44	39.565	12.742
26	|	6.69	40.303	13.599	|	6.21	39.903	13.345
40	|	6.46	40.393	13.746	|	6.07	39.999	13.499
57	|	6.13	40.404	13.757	|	5.90	40.019	13.512
74	|	5.85	40.409	13.757	|	5.67	40.024	13.515
92	|	5.58	40.413	13.760	|	5.47	40.026	13.514
When --merange grows, the quality increases regardless of the size of --ctu (it may depend on the source movie).
For CPU with only 12 logical cores (6 physical) --ctu 64 is just better in preset slower for 1080p encoding.
I see, thanks for sharing.
I think you are correct, since the biggest benefit of reducing it only appears when going above arround 8C/16T (I was testing with 12/24 and went from 7fps to 11fps cause of the less thread utilization at CTU 64, and I would say that it was definitely was worth the trade off), it does makes since to keep it as an manual setting.
I would say though that it might be worth consideration to lower the merange for those fastets presets, since it doesnt seem to benefit quality that much.
excellentswordfight is offline   Reply With Quote
Old 13th January 2019, 14:40   #6631  |  Link
I like DoVi as the short way to type it.
That might sound stupid to a German (Doofi ~ retarded kid)
a couple decades later!
I am old!
_
Some on-topic:
Support for Dolby Vision is announced, and immediately people believe that applications for decoding, possibly even encoding, for consumer PCs are available too ... which is doubtful. I wonder how "homeopathic" its additional features will be in a generic furnished living room, where average people can hardly tell the difference between DD AC3 and dts on a DVD Video, not to mention HD Audio formats.
To me, it seems that supporting such data is mainly for professional content producers. Might be a field where hobbyists can't help the developers much.
Old 13th January 2019, 14:55   #6632  |  Link
sneaker_ger
Oh, I'm sure the difference will be noticable to consumers. Simply because authors will make it so, not because it's superior. Just like in the past authors used different mixes for AC3 and DTS tracks on the same DVD. It's all about marketing.
Old 13th January 2019, 17:39   #6633  |  Link
jd17
That.
jd17 is offline   Reply With Quote
Old 15th January 2019, 00:31   #6634  |  Link
Lucius Snow
Hello all,
There's still no GPU support to speed up the encoding?
Lucius Snow is offline   Reply With Quote
Old 15th January 2019, 03:00   #6635  |  Link
No. I believe because GPU features would not speed x265 up. At least not without risking a loss of quality or losing the independence from hardware and software platforms (portability).
GPU features are not magical general speed-ups for every case of use, sometimes they just don't match the requirements.
Old 15th January 2019, 09:55   #6636  |  Link
jlpsvk
Ok. Did a test. 3840x2160 res., same x265 settings. One with aq-mode 1 crf18 and second aq-mode 2 (which is now new default) with crf16. aq-mode 2 with crf16 still gives lower bitrate. which one "should" be better in terms of detail retention?
whole CLI (HDR parameters are added automatically by RipBot264):
-preset slow --profile main10 --level-idc 5.1 --output-depth 10 --ctu 32 --aq-mode 1 --amp --no-rskip --qg-size 8 --vbv-bufsize 160000 --vbv-maxrate 160000 --bframes 8
--rc-lookahead 48 --gop-lookahead 30 --hdr --hdr-opt --repeat-headers --no-info --no-deblock --no-sao --allow-non-conformance --no-strong-intra-smoothing --high-tier --asm avx512 --crf 18
-preset slow --profile main10 --level-idc 5.1 --output-depth 10 --ctu 32 --aq-mode 2 --amp --no-rskip --qg-size 8 --vbv-bufsize 160000 --vbv-maxrate 160000 --bframes 8
--rc-lookahead 48 --gop-lookahead 30 --hdr --hdr-opt --repeat-headers --no-info --no-deblock --no-sao --allow-non-conformance --no-strong-intra-smoothing --high-tier --asm avx512 --crf 16
Old 15th January 2019, 10:10   #6637  |  Link
asarian
Having an HD Amp myself, trust me, you can hear de difference! Try listening to Blade Runner, the Final Cut, with full HD audio, or the same movie, just with DD5.1, and I guarantee you that everything below HD audio will sound crap from there on in.
Old 15th January 2019, 10:53   #6638  |  Link
jd17
That is not a very good argument against what sneaker said.
How do you know both mixes are based on the same mastering?
How do you know the DD-mix is not willingly different/worse than the HD mix?
Are you comparing identical speaker layouts (both just 5.1)?
Are you sure there is no dynamic compression in the DD-mix?
Are the volume levels identical?
Is the DD-mix limited in bitrate (384/448) or does it use the full 640kbit/s potential?
If you want a comparison of codec audio quality only, try encoding your own DD-mix from the HD-audio stream, considering all the factors above.
Even then, you cannot be sure in case of AC-3, because people claim that the original, commercial encoder is superior to those available freely...
Old 15th January 2019, 11:01   #6639  |  Link
asarian
Blade Runner is just one example. Let's not derail this thread too much, but I can assure you, that once you go HD audio, you'll never want to go back, ever. And why should that surprise anyone?! A typical DTS-MA/TrueHD track is often larger in size than an entire DVD! With bitrates around 10x higher as regular DTS, the superiority of HD audio is a no-brainer, far as I'm concerned.
Old 15th January 2019, 12:12   #6640  |  Link
excellentswordfight
Cause 48Khz 16bit audio is very much sufficient for human hearing, and if you have enough experience of audio compression you know that there is several codecs that can achive very close to transperent audio with say 64kbps per channel (and most formats are above that!). I've encoded several surround tracks form lossless to multiple formats, you be surprised how little it affects hearable fidelity.
With that said, I'm sure that the HD-track sounds better for you, but most of that doesnt come from the higher specs (sample rate, bit depth and losslessness)
