Old 13th August 2017, 23:46   #3041  |  Link
manolito
manolito's Avatar
Update the AVStoDVD helper applications
I have been meaning to compile this little list for a long time, here it is finally. I will try to keep this list current as good as I can...
Since I still use the software on an ancient machine with a non-SSE2 CPU under Windows XP I took special care to point out which updates require newer hardware or software.
Please note that if you want to upgrade you absolutely have to download and use the 32-bit versions of the applications. All 64-bit software cannot be used under AVStoDVD
Here is a list of the AVStoDVD helper applications which can be updated to newer versions. I also tested the compatibility with Win XP and with CPUs without SSE2 capabilitiy (Intel Pentium 3 and older AMD Athlons).
According to the "Requirements" section in the A2D help file an SSE2 capable CPU is required, but I found that this is not necessarily true. The only helper software which requires SSE2 at the moment is LAV Filters, and it can easily be replaced by the slightly older version 0.69.0.85.
.NET Framework 2.0 is only necessary for SubtitleCreator. For users who do not need subtitles .NET Framework is not required for using AVStoDVD.
The Java Runtime Environment (JRE) must be installed for BDSup2Sub. The program was last updated in 2013, but it works flawlessly using the current JRE Version (32-bit of course).
AviSynth:
Version 2.60 is required (the latest 2.61 Alpha also causes no problems).
AVS+ is now supported, but the user is responsible to modify the AVS script to enable multitasking. Only use the latest official version which can be found here:
https://github.com/AviSynth/AviSynthPlus/releases
To enable multithreading the command "Prefetch(n)" must be appended to the AVS script which is created by AVStoDVD (where "n" is the number of prefetch threads). Users of my FFmpeg_VBR and HCenc_Mod plugins have the option to do this automatically.
LAV Filters:
The current LAV versions require Windows Vista or higher. For a non-SSE2 CPU the nightly build 0.69.0.85 is the latest working version, under Win XP the latest working nightly is LAVFilters-0.70.2-16. So you may have to downgrade...
AVSMeter:
The latest AVStoDVD version comes with a modified AVSMeter version which does not check all the autoload plugins. This speeds up the program start considerably. The current official versions have slightly changed calling parameters, so these cannot be used with AVStoDVD.
BatchMux:
Newer versions than version 1.4.1 which is bundled with A2D are NOT compatible.
ColorMatrix:
AVStoDVD ships with the latest Tritical version 2.5. There is a newer version 2.6 from 2018 which adds support for Rec.2020 which is widely used for UHD clips. The latest build by Groucho2004 does not even require a CPU with SSE2 support. Download here:
http://www.iol.ie/~schubert/gas/ColorMatrix26.7z
If you want to upgrade please use the 32-bit version. Please note that AVStoDVD does not take any action if MediaInfo detects a source with BT.2020 color. You need to manually add ColorMatrix in the "View/Edit Title Settings -> AviSynth" tab and specity 4 for the source format and 2 for the target format.
DGIndex:
The included version 1.58 is the latest one. However there is an ICL build by Groucho2004 which is slightly faster and works well. Download the file "dgmpgdec158_ICL.7z" from here: http://www.iol.ie/~schubert/gas/dgmpgdec158_ICL.7z
Extract the files from the archive into the "DGIndex" subfolder, the file "DGDecode.dll" must be extracted into the "Lib" subfolder additionally.
FFmpeg:
The included version 2.2.3 is from 2014 and is slowly getting a little old. For the purpose of AVStoDVD it probably has everything it needs, though...
If you want to upgrade to a later version, there are a few things to keep in mind:
Starting with version 3.1.2 the FFmpeg AVS interface has changed. To work with A2D it is necessary to include the folder "...\AVStoDVD\Lib" in your "PATH" environment variable. It is also recommended to include the folder "...\AviSynth\Plugins" in the "PATH" variable.
Current FFmpeg versions do NOT work under Win XP. There are a couple of fairly recent builds by CoRoNe, rogerdpack and Sherpya which do work under Win XP, though.
The latest and highly recommended version which works under Win XP and does not require to modify the "PATH" variable is this one from July 2016 by rogerdpack:
https://sourceforge.net/projects/ffm...e.zip/download
FFMS2 (FFmpegSource):
AVStoDVD comes with the ffms2 C-plugin for AVS version 2.27 by qyot27. The latest version which works under Win XP is FFMS2 C-plugin r1315+119 version 2.30, It is available for download here:
http://www.mediafire.com/file/oi31n1...Bvsp_lastxp.7z
This version works nicely under AVStoDVD. One thing I did notice, though, is that it is less tolerant with problematic or broken source files than other ffms2 versions.
The last ffms2 version which does handle problematic sources flawlessly is FFMS2 C-plugin 1140+101 from 2016. Highly recommended. Get it here:
https://forum.doom9.org/showthread.p...12#post1783312
The current C-plugin versions need at least Windows Vista, get them here:
https://forum.doom9.org/showthread.p...61#post1829061
Good news for WinXP users (even without SSE2 capable CPUs):
CoRoNe (aka Reino) started to build XP compatible versions of the ffms2 C-Plugins, get them here:
http://rwijnsma.home.xs4all.nl/files/ffms2/
Highly recommended...
Switching from the C-plugin to the Standard-plugin version is possible, but it requires to patch the AVStoDVD executable with a hex editor. I do not see any advantages compared to the C-Plugin, but if you insist, let me know...
One note of caution:
It is NOT recommended to have a different ffms2 version in your "...\AviSynth\Plugins" folder. If you do it is much safer to copy the files ffms2.dll and ffms2.avsi from the AVStoDVD\Lib folder into the AviSynth\Plugins folder.
MediaInfo:
Works up to version 18.05. Later versions are NOT compatible with AVStoDVD..
MKVtoolNix:
The only file from the package which is actually used by AVStoDVD is "mkvextract.exe". The last version which works under Win XP is v29.0.0.
Mplex:
AVStoDVD comes with two different Mplex versions, a "normal" version and a version which requires SSE2. In my experience the SSE2 version has no advantages whatsoever, in my tests it was even slower than the normal version. I recommend to leave everything as it is.
SubtitleCreator:
AVStoDVD comes with the latest stable version 2.2. There is a newer release candidate version 2.3 available, but the author stopped working on it in 2008, so I did not test it under A2D.
All other helper applications are current. Most of them are static, i.e. there will probably be no more updates for them.
Comments and corrections welcome...
Here is the link to the current version of my plugins for AVStoDVD:
https://files.videohelp.com/u/172211...D%20Plugins.7z
The package consists of FFmpeg_VBR (adds VBR modes for the FFmpeg encoder), Wavi_Mod (offers alternative audio normalizing modes) and HCenc_Mod (users can add custom parameters to HC.ini). The FFmpeg_VBR and HCenc_Mod plugins also allow to automatically enable AVS+ Multithreading using very stable settings, a guide and some additional tools are included.
Cheers
manolito
Old 14th August 2017, 16:20   #3042  |  Link
Groucho2004
Originally Posted by manolito View Post
AVSMeter:
The current versions are NOT compatible with AVStoDVD (different log file format).
I suppose it's the video frame size formatting that has changed? I can revert this (at least in the log file), no big deal.
Old 14th August 2017, 20:43   #3043  |  Link
manolito
manolito's Avatar
Sorry I have no idea...
With AVSMeter 2.6.1 I get an error message complaining that the AVSInfo.log file could not be read. No further explanation what exactly caused the error. Using AVSMeter 2.1.3 users never get to see this log file, so there is no way to compare the two versions.
Whatever, it is not worth the trouble to fix this. For AVStoDVD the old version 2.1.3 works nicely, and since the software is small and portable users can easily keep a current version of AVSMeter in a different HDD folder.
Cheers
manolito
Old 19th August 2017, 16:40   #3044  |  Link
Groucho2004
It should work again with 2.6.2.
Old 19th August 2017, 21:49   #3045  |  Link
manolito
manolito's Avatar
Yes it does, thanks a lot...
Just one minor catch:
Older versions of AVSMeter could read the previous INI file and take over the settings to the new INI file. This does not work here. If the older INI file from 2.1.3 is still present in the AVSMeter folder then the new version 2.6.2 will crash. No big deal, I just need to tell users to clean the AVSMeter folder completely before upgrading to the latest version.
Thanks again
manolito
Old 20th August 2017, 18:24   #3046  |  Link
Groucho2004
That's a very easy fix (already done for 2.6.3).
Old 11th September 2017, 20:26   #3047  |  Link
manolito
manolito's Avatar
Confirmed...
And
Old 30th September 2017, 17:17   #3048  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
A new 2.8.7 alpha release is available to download.
Change log (cumulative from 2.8.6):
- Some bugs fixed
- Added support to WebM files (*.webm) as input files, subset of Matroska
- Added warning messages when AVC/AAC title is added and Microsoft DTV-DVD decoders are default codecs
- Added a warning message when input title has a DVD compliant audio track with delay, to force audio re-encode
- Added check of .NET Framework 2 presence in 'Preferences'/'System'/'Software Info'
- Added BDSup2Sub 5.1.2 to improve bitmap-based subs handling (resize and resync). It requires Java Runtime Environment
- Added check of Java Runtime Environment presence in 'Preferences'/'System'/'Software Info'
- Improved support of VobSub subtitles: resize and resync from BD sources is now implemented with BDSup2Sub
- Improved handling of "non-mod4" interlaced sources within the AviSynth script generation routine
- Revised video encoder smart selection rationale: no more HCenc VBR 1-pass for multicore CPUs
- LAV Filters updated to release 0.70.2
- AVSMeter updated to release 2.6.5
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 3rd October 2017, 01:21   #3049  |  Link
manolito
manolito's Avatar
Thanks for the new Alpha...
Did some short tests and found no problems. For the new addition BDSup2Sub I only checked that it runs at all on my ancient computer and that it also works using the current JRE Version 8 Update 144 (32-bit).
Cheers
manolito
Old 3rd October 2017, 13:41   #3050  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hi manolito, thanks for the feedback on the new Alpha.
I'm planning to alter a bit the routine to select the FPS conversion method, specifically for 30p/60p sources.
Currently, if Pulldown, SelectEven, PAL SpeedUp, NTSC SlowDown are not selected/feasible, then MotionProtectedFPS is used by default (with the option for the user to switch to ChangeFPS or ConvertFPS in Preferences section). MotionProtectedFPS does usually its job nicely, but we know it can introduce edge artifacts.
Nowadays many HD/FullHD sources are 30p and, when output is NTSC, probably the best approach could be to drop few frames (from 30 to 29.97) with ChangeFPS instead of applying motion compensation. Same for 60p sources: first SelectEven than ChangeFPS. Instead for PAL output the frames drop approach from 30p could provoke too much jerkiness.
What do you think? (open question to all Doom9 expert users, of course)
Bye
MrC
AVStoDVD Homepage
Old 3rd October 2017, 23:01   #3051  |  Link
manolito
manolito's Avatar
Hi MrC,
basically I believe that you are absolutely right. My thoughts so far - please keep in mind that I do not know all that much about NTSC...
The MotionProtectedFPS routine is quite deprecated these days. Using MVTools2 the results can be much better, but of course at the cost of a slower speed.
A while ago I stumbled upon a script suggestion by johnmeyer which IMO could beat everything I had seen before. I called it "jm_fps", the name did stick somehow. See here:
https://forum.doom9.org/showthread.p...39#post1800439
The script defaults work well for most sources except for anime (where you often need a higher block size of 32 and maybe a DCT value of 1). The speed is slower than for MotionProtectedFPS, but still very usable.
There is another approach by MysteryX which is based on this jm_fps script, but adds artifact masking. Still slower, sometimes very useful, sometimes not. I simplified it quite a bit and called it "mx_fps", get it here:
https://forum.doom9.org/showthread.p...50#post1805050
I also uploaded an ALL In ONE package which you can download from this page.
But still this motion interpolation approach is not for everyone, with some sources it just does not work too well. Another challenge is that today we encounter a lot more different source formats than we did earlier, and getting the best approach to convert these formats to DVD is not easy.
For a 30p source when the target format is NTSC then of course using ChangeFPS would be the preferred choice. If the target format is PAL then the users have to decide if they can live with a lot of dropped frames, or if a motion interpolated conversion is required. The same applies to 60p sources.
Recently here in Germany the switch to DVB-T2 brought some more confusion for me. The video format is now HEVC, it is always progressive at 50 fps. For film sources they just duplicate frames (looks like they first speed up 24fps sources to 25fps and then just duplicate each frame). But for video sources (news, soaps, sports) there are no duplicate frames, the captured clips have 50 unique progressive frames per second. Can we still use SelectEven() for such sources, or is it better to interpolate? And which method is best to convert such sources to 29.97fps for NTSC? Decimate (or convert) to 25p first and then apply NTSC slowdown followed by soft pulldown? Or better interpolate from 50p to 29.97p directly? I have no idea...
Cheers
manolito
Old 5th October 2017, 13:04   #3052  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hi manolito,
thanks for the link about the most recent applications of motion interpolation on FPS conversion. I have quickly tested the jm_fps routine and it is very very clean, with acceptable impact on encoding speed. Quite easy to implement into A2D too. I just would find a more "sexy" name, instead of jm_fps.... Do you confirm that fftw3.dll is actually needed only if DCT flag is set to 1? Still not tested mx_fps.
As per the 50p conversion to DVD, if the output is PAL, generally speaking I would go with SelectEven(), it should deliver the smoothest result. If the output is NTSC the decision is much more video content dependant. Will the DVB-T2 standard be @ 50fps in all countries or only in German? If the latter, NTSC output could be irrelevant...
Bye
MrC
AVStoDVD Homepage
Last edited by MrC; 5th October 2017 at 13:53. Reason: Revised comment on encoding speed of jm_fps
Old 5th October 2017, 15:48   #3053  |  Link
manolito
manolito's Avatar
For a sexier name I am open to suggestions...
It's just that a couple of other folks also have adopted this name, it might get confusing to rename the script now.
fftw3.dll is not needed when DCT is not used (DCT=0), which is the default. Usually DCT=0 works fine, but for some rare (mostly anime) sources DCT=1 gives a much better quality, but at a very very low speed.
The jm_fps script only exposes the framerate to keep it as simple as possible. Maybe I should change the interface to also expose the block size and DCT. These 2 params are the ones a user wants to play with for difficult sources. But this might be beyond the scope of A2D...
Another thing you want to think about when integrating this into A2D:
For most helper plugins there are "modernized" versions (mostly written by pinterf) which add additional features like new colorspaces, high bitdepth and MT support. All these newer versions require SSE2 so they will not work on my computer. I also find them a little unstable, they are work in progress. The AIO package for mx_fps which I linked to contains older but stable versions of these plugins.
I believe that DVB-T2 will be 50fps only in PAL countries. I really do not like the fact that each European country now uses its own flavor of the standard. Germany was very late to introduce DVB-T2 so they figured to push ahead and use HEVC video and EAC3 and/or AAC-LATM audio. It took me a long time to establish a workflow for my conversions to AVC or DVD which keeps audio in sync.
Cheers
manolito
Old 7th October 2017, 16:10   #3054  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Rename to MCJMFPS (Motion Compensation John Meyer FPS)? Not so sexier, but more "impressive"... and "expressive"...
About the need of fftw3.dll, since it was not present in my system, I did some tests, and, DCT=0 does not require it. Thus I would update the avsi info section accordingly. And maybe add the DCT flag to the MCJMFPS function. What do you think?
Another small clue when loading RemoveGrain. RemoveGrain.dll needs MSVCR71.DLL in System32/Syswow64, while the monolithic build RemoveGrainS.dll works alone.
In terms of speed, from few 1080p@60 to PAL conversions, I would say that jm_fps (DCT=0) is 1/3 than MotionProtectedFPS and 1/5 than ChangeFPS. What about mx_fps with defaults params? Even slower than jm_fps?
Bye
MrC
AVStoDVD Homepage
Old 7th October 2017, 19:35   #3055  |  Link
manolito
manolito's Avatar
Yes of course, just noticed that my previous post had it the other way around. Getting old...
I would still recommend to copy fftw3.dll into a system folder because for some sources (anime) DCT=0 causes bad artifacts. MysteryX even changed his "normal" preset from DCT=0 to DCT=4 in the latest version of his "FrameRateConverter" plugin.
If you want to have a look at this latest version, see here:
https://github.com/mysteryx93/FrameR...eases/tag/v1.2
My mx_fps version has many presets removed, all the debug code is gone, I made it compatible with older versions of MaskTools and MVTools, and the user interface exports only the most important parameters (MysteryX hates me for doing this).
And yes, mx_fps with default parameters is a little bit slower than jm_fps, simply because of the added artifact masking. In most of my tests I found that jm_fps is all I need, but this probably is different for different sources and different users.
The mx_fps version I linked to uses an additional DLL which can build a "stripe mask". This DLL needs SSE2, so I do have an alternative version which has the stripe mask feature removed. Not a big loss, this feature only helps in rare cases IMO.
Meanwhile I updated jm_fps so now it has the two additional parameters "BlkSize" and "Dct". BlkSize can only be 8, 16 or 32. For the possible Dct values see the MVTools documentation. The most useful values are 0, 1 and 4.
Cheers
manolito
Old 10th November 2017, 22:18   #3056  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 2.8.7 Alpha 171109 is out
- Added AviSynth plugin DSS2mod to replace DirectShowSource for video frame serving in 'A2DSource.avsi' script
- Added 'Smart Selection' option to 'Preferences'/'AviSynth'/'Hard FrameRate Conversion' option (see Help section for more details)
- Added AviSynth script 'MCJMFPS.avsi' for hard fps conversions (thanks to johnmeier and manolito from doom9)
- Dropped AviSynth script 'MotionProtectedFPS.avsi' for hard fps conversions, mainly due to edge artifacts
- Revised other 'Preferences'/'AviSynth'/'Hard FrameRate Conversion' option labels
- Spun off Preferred DirectShow Codecs Tool in a separate executable file 'A2DCodecs.exe'
- Removed 'Execute AVStoDVD with Elevated Privileges' option in 'Preferences'/'Misc'
Bye
MrC
MrC
AVStoDVD Homepage
Old 11th November 2017, 01:06   #3057  |  Link
manolito
manolito's Avatar
Thanks for the new build...
Did a couple of short test conversions, no problems. The only thing I found is that
this new separate A2DCodecs.exe does not (yet) use the translated strings from the language files...
Cheers
manolito
Old 12th November 2017, 11:35   #3058  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Yes, you are right, I still have to implement the language customization into the new A2DCodecs tool. In the ToDo list before going final with 2.8.7
Bye
MrC
AVStoDVD Homepage
Old 24th November 2017, 22:09   #3059  |  Link
manolito
manolito's Avatar
Oops, after a few days I did find a bug in the latest Alpha which crashes AviSynth for interlaced sources...
For "non-mod4" interlaced sources A2D adds the follwing line to the AVS script:
Video = Video.Crop(0,0,-Width % 4,-Height % 4).ConvertToYV12(interlaced=true)
Width and Height are not defined for the implicit "Last" variable at this point, so AVS crashes. The line should instead be:
Video = Video.Crop(0,0,-Video.Width % 4,-Video.Height % 4).ConvertToYV12(interlaced=true)
Cheers
manolito
Old 6th December 2017, 09:27   #3060  |  Link
manolito
manolito's Avatar
And here is another bug report for the latest Alpha...
This latest Alpha breaks BatchMux completely (at least for me). Took me a while to find it because the change log did not mention any changes to BatchMux.
The BatchMux log file says that there is no reference to the first video file. The relevant log files are here:
http://www30.zippyshare.com/v/6nkm21Zp/file.html
I then went back to the previous Alpha from 170921, and this version worked using identical settings. Something with the script creation for BatchMux must be broken.
Cheers
manolito
[IMG] code is Off
