Old 14th December 2009, 14:03   #1081  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by 8Detonation8 View Post
Conversion with this program takes way too much time. I counted about 6 hours, while ConvertXtoDVD takes about 2-3 hours for one movie. Even giving a little sharper picture quality. Big issue which needs improvement.
Highly arguable. Default settings maximize quality and not speed. Post here your system specs and a A2D log file and I will suggest you some hints to increase speed.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 14th December 2009, 15:25   #1082  |  Link
8Detonation8
AMD Athlon 64 X2 Dual Core Processor 3800+
2,0GB Ram
NVIDIA Geforce 9800 GT
I deleted the log file, but here are the settings I used.
AVS Source Filter - DirectShowSource
AVS Resize Filter - Lanczos4Resize
Setup Video Profiles - 1. QuEnc CBR 1-pass
AC3 Audio Encoder - FFmpeg+Aften
Enable MultiThread Encoding ON
Keep DVD Compliant Video ON
Keep DVD Compliant Audio ON
hlrsnd, ConvertXtoDVD now has Two-pass encoding option, Multicore support and about 15 resize filters.
8Detonation8 is offline   Reply With Quote
Old 14th December 2009, 17:31   #1083  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
6hr encoding with 'QuEnc CBR 1-pass' profile? What kind of footage are you converting to DVD? Supposing that your footage lasts 2 hours, it means that you are going with 8-10 fps.
Hints to speed up:
- Use LinearResize
- Select 'Half-D1' or 'VCD' as video resolution
- Assuming you are still using QuEnc, toggle on 'Edit Encoder Command Parameters at runtime' and change '-hq' with '-nohq'.
Afterward, do not complain about quality...
Bye
MrC
AVStoDVD Homepage
Old 15th December 2009, 18:53   #1084  |  Link
8Detonation8
MKV, 720p, x264, Bluray rip. About 4,37GB. Movie length is about 106 min. I want the best possible quality, so, i'm not going to change any quality settings. Was just wondering about such a big conversion time gap between the two programs.
Old 16th December 2009, 12:06   #1085  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
It means that QuEnc is encoding at about 7-8 fps (6 hours enc time - 108 min footage). It is really too slow: my system (Core2 duo T8300 @2.4 Ghz) not far from yours, with same settings (720p, QuEnc CBR 1-pass, DirectShowSource, Lanczos4Resize) goes at about 30-35 fps, resulting in less than 2 hours to encode a 106 min footage.
Check the directshow filters installed. Too many can arise conflicts. I suggest to use ONLY ffdshow and haali as mp4/mkv splitter.
Bye
MrC
AVStoDVD Homepage
Old 21st December 2009, 22:20   #1086  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 2.2.5 is available to download. With a brand new (very simple indeed) homepage.
Change log:
- Some bugs fixed
- Added capability to read Chapters positions from media file that contains that info
- Added 'Use Source Chapters List' option in 'Preferences'/'Authoring Burning'
- Added automatic VOB indexing when input files is a DVD info file (ifo)
- Added possibility to demux Audio streams when processing multi Audio tracks titles
- Added 'NicAudio.dll': an AviSynth plug-in to open MPEG Audio/AC3/DTS/LPCM and other uncompressed formats (thanks to Nic/Dimzon/IanB/Tebasuna)
- Added Text (Subtitles) info reading using MediaInfo.dll
- Added possibility to demux Subtitles streams (SubRip SRT and VobSub IDX/SUB format) when processing Matroska contaneirs with Subs
- Added support to Unicode and UTF-8 text format for SubRip SRT Subtitles
- Added support to MKVExtract (if already installed - not included in AVStoDVD Installer package) to demux audio and subs from Matroska containers
- Added PgcDemux 1.2.0.5 to AVStoDVD Installer package
- Improved video and audio demuxing in 'Parse DVD' section (now using PgcDemux instead of DGIndex)
- Improved 'Title'/'Add Title' routine
- Updated 'A2DSouce.avsi' to support NicAudio's filters
- Updated AVStoDVD Homepage (migration from Googlepages to Google Sites)
- MediaInfo updated to 0.7.25
Any feedback is welcomed, as usual.
Bye
MrC
AVStoDVD Homepage
Old 22nd December 2009, 03:30   #1087  |  Link
hlrsnd
Thanks for 2.2.5.
I recently completed a project in 2.2.4, using mjpeg and DV sources from my own camera and camcorder. It took 100 minutes to complete. Any advantages/bugfixes which would make it worthwhile to redo in 2.2.5? It seems ok now.
I also tried it (2.2.4) using the latest HCEnc 0.24 from 11/27/09 and couldn't tell any difference.
hlrsnd is offline   Reply With Quote
Old 22nd December 2009, 04:53   #1088  |  Link
Richardw322
If I already have AVISYNTH installed, would I still get this plug in?
Richardw322 is offline   Reply With Quote
Old 22nd December 2009, 13:37   #1089  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@hlrsnd
No, you do not have to run your project again. There are no improvements on DV encoding with 2.2.5
@Richardw322
NicAudio is not provided with standard AviSynth installation. Anyway you have to do nothing: nicaudio.dll is located in A2D Lib folder and its use is transparent to the user or to other apps.
Bye
MrC
AVStoDVD Homepage
Old 22nd December 2009, 23:57   #1090  |  Link
Richardw322
@Richardw322
Bye
Then I don't have to copy it to the AVISynth plugin folder? Great!!
Old 30th December 2009, 07:28   #1091  |  Link
AMED
AMED's Avatar
Is there any reason why the Bias in HCenc v0.23 is set to 50 ?
http://img694.imageshack.us/img694/9661/hcenc.png
According to the pdf
*BIAS
parameter bias (range 0 – 100) type integer
Status not required
Default 0
Example *BIAS 30
This command tweaks the compression curve, 0 means full VBR (Variable BitRate), 100 tends to
CBR (Constant BitRate).
is there something wrong with the default?
A Man Eating Duck
AMED is offline   Reply With Quote
Old 30th December 2009, 13:47   #1092  |  Link
flebber
Practising Schemer
Hi
Using your program for the first time today and I have had a lot of success its simple but configurable also. I had one question and one bug report.
Can I manually add in any avisynth filters in the editor?
I have had success with file types except for flv. Should I attempt to convert to other format like d2v be using AVStoDVD?
This was the error log
<30/12/2009 11:36:47 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 16
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: Burn DVD
DVD Label: Trading basics Mod 1 & 2
DVD Menu: Static Menu
Output Folder: C:\Documents and Settings\Family\My Documents
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: A2DSource
AVS Resize Filter: Lanczos4Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6000
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliat Audio: 1
Normalize Audio: 1
DVD Audio Language: EN - English
DVD Subs Language: EN - English
Chapthers Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D: HL-DT-ST DVD-RAM GH22NP20 1.04
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: C:\Documents and Settings\Family\My Documents\My Videos\Tutorial\Investment\Beggining Trading - Informedtrades\Module 1 Technical Analysis Basics\Technical Analysis Lesson 1 - An Introduction to Technical Analysis.flv
Info: Sorenson H263 - 65 kbps - 320x240 - DAR 1.333 - 10 fps (CFR) -  - 2:54 minutes - 1742 frames
Audio: C:\Documents and Settings\Family\My Documents\My Videos\Tutorial\Investment\Beggining Trading - Informedtrades\Module 1 Technical Analysis Basics\Technical Analysis Lesson 1 - An Introduction to Technical Analysis.flv
Info: MPEG-2 Audio layer 3 - 64 kbps - CBR - 22050Hz - 1ch - 2:54 minutes
Subs:
[MediaInfoLib - v0.7.25]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Documents and Settings\Family\My Documents\My Videos\Tutorial\Investment\Beggining Trading - Informedtrades\Module 1 Technical Analysis Basics\Technical Analysis Lesson 1 - An Introduction to Technical Analysis.flv", CacheFolder = "C:\DOCUME~1\Family\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\Documents and Settings\Family\My Documents\My Videos\Tutorial\Investment\Beggining Trading - Informedtrades\Module 1 Technical Analysis Basics\Technical Analysis Lesson 1 - An Introduction to Technical Analysis.flv", CacheFolder = "C:\DOCUME~1\Family\LOCALS~1\Temp")
Video = Video.ConvertToYV12
Video = Video.ConvertFPS("pal_video")
Video = Video.Lanczos4Resize(352,288)
Video = Video.Tweak(0,1,0,1.5)
Video = Video.Sharpen(0.5,MMX=false)
Audio = Audio.SSRC(48000)
Audio = Audio.ConvertToMono
AudioDub(Video, Audio)
Encoding Profile: QuEnc CBR 1-pass
Target Video FileSize: 172.8 MB
QuEnc Parameters: -i "C:\DOCUME~1\Family\LOCALS~1\Temp\Trading basics Mod 1 & 2_0_Title_01_Technical Analysis Lesson 1 - An Introduction to Technical Analysis.avs" -o "C:\Documents and Settings\Family\My Documents\Trading basics Mod 1 & 2_0_Title_01_Technical Analysis Lesson 1 - An Introduction to Technical Analysis.m2v" -b 8329 -1 -hq -novbr -scene -trell -aspectratio 4:3 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<30/12/2009 11:37:01 PM>
PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
CHECK LOG FILE <C:\DOCUMENTS AND SETTINGS\FAMILY\MY DOCUMENTS\TRADING BASICS MOD 1 & 2_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.2.5
PS is there any reason I shouldn't use hcenc 0.24 with your program?
flebber is offline   Reply With Quote
Old 1st January 2010, 21:54   #1093  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Bias is not fixed but calculated using following formula:
Bias = Int(VideoAvgBitRate / 1000)) * 10
rationale is that if bitrate is high, the compression curve should go towards CBR (high Bias), otherwise the curve should go VBR (low Bias).
Bye
MrC
AVStoDVD Homepage
Old 1st January 2010, 22:00   #1094  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Yes, you can. Just make sure that the AVS script has consistency (check it using the Preview Clip feature).
Have you have installed flvsplitter? And a good directshow codecs suite like ffdshow?
I have not fully tested 0.24 but some users assert that there are no issues just replacing the executable.
Bye
MrC
AVStoDVD Homepage
Old 6th January 2010, 04:02   #1095  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
MrC,
Thanks for your great program, I have used it with great success in the past.
I have a few problems though.
For one, my settings are not saved from session to session using the latest version (2.2.5).
Also, in my attempt to convert my Transformers 2 Blu-ray .m2ts file, I am having a number of issues converting audio. For one, if I select the main DTS-HD track and encode using WAVI+AFTEN the encode fails.
If I use FFMPEG+AFTEN I only get the first 25 minutes of audio or so and then the rest of the movie is silent.
Also, if I try to use one of the AC3 tracks as a source, HCenc just hangs and and uses a constant ~15% CPU. And I am pretty sure that it is not using FFMpegAudioSource to index, as I don't see a .cache file created at all. Additionally, if I load the script created using one of the AC3 tracks as a source file into MPC, it also hangs and just uses ~15% of the CPU.
I'm trying to convert several of my Blu-ray's to DVD, and as this is the most feature full program available, I was hoping to use it. However, these issues are causing some serious problems that may force be to do it all manually (which I really don't want to do).
Edit: Here is the log of what I thought to be a successful encode, but it has the problem with the audio failing at ~25min:
<1/4/2010 8:41:10 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: D:\Multimedia\Output
PREFERENCES
Video Resolution: 0
AC3 Audio Encoder: 1
DVD Audio Format: 0
DVD Audio BitRate: 384
Normalize Audio: 0
DVD Burning Drive: F: HL-DT-ST BDDVDRW GGC-H20L 1.03
Save Log file: 1
Video: D:\Multimedia\temp\Transformer 2\00003.m2ts
Info: AVC - 0 kbps - 1920x1080 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:29:52 hours - 215615 frames
Audio: D:\Multimedia\temp\Transformer 2\00003.m2ts
Info: DTS-HD - 0 kbps - VBR - 48000Hz - 6ch - 2:29:53 hours - Track 0
Subs:
AVISYNTH SCRIPT
Video = A2DVideoSource("D:\Multimedia\temp\Transformer 2\00003.m2ts", CacheFolder = "C:\DOCUME~1\Merlin\LOCALS~1\Temp")
Audio = A2DAudioSource("D:\Multimedia\temp\Transformer 2\00003.m2ts", CacheFolder = "C:\DOCUME~1\Merlin\LOCALS~1\Temp")
#Using DGPulldown to upsize FPS
Video = Video.Lanczos4Resize(720,480)
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 3904.4 MB
HCenc Parameters: -ini "C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_00003.HCenc.ini"
HCenc ini file:
*INFILE C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_00003.avs
*AVSRELOAD
*OUTFILE D:\Multimedia\Output\DVD_0_00003.m2v
*LOGFILE C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_00003.HCenc.log
*MAXBITRATE 9000
*BITRATE 3642
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 40
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<1/5/2010 12:01:19 AM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: D:\Multimedia\Output\DVD_0_00003.m2v (3906.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3670 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:29:44 hours - 215401 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "D:\Multimedia\Output\DVD_0_00003.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<1/5/2010 12:08:50 AM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: D:\Multimedia\Output\DVD_0_00003.m2v (3906.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3666 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:29:53 hours - 215616 frames
<1/5/2010 12:08:51 AM>
START AUDIO ENCODING OPERATIONS
FFmpeg (WAV) Parameters: -i "C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_00003.avs" "C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_00003.wav"
Aften (AC3) Parameters: -pad 0 -b 384 "C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_00003.wav" "D:\Multimedia\Output\DVD_0_00003.ac3"
<1/5/2010 3:17:21 AM>
END AUDIO ENCODING OPERATIONS
A2DAudioSource: DirectShowSource
Created File: D:\Multimedia\Output\DVD_0_00003.ac3 (70.1 MB)
OUTPUT AUDIO INFO: AC3 - 384 kbps - CBR - 48000Hz - 6ch - 25:32 minutes
<1/5/2010 3:17:22 AM>
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_BatchMux.ini"
BatchMux ini file:
-d "D:\Multimedia\Output\DVD_0\VIDEO_TS"
-mxp "C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_MuxMan.mxp"
-l "C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "D:\Multimedia\Output\DVD_0_00003.m2v"
-vidmode LB
-a1 "D:\Multimedia\Output\DVD_0_00003.ac3"
-a1lang en
-cellfr "C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_00003_MuxMan.txt"
-progfr "C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_00003_MuxMan.txt"
-chapfr "C:\DOCUME~1\Merlin\LOCALS~1\Temp\DVD_0_00003_MuxMan.txt"
<1/5/2010 3:26:05 AM>
END DVD AUTHORING OPERATIONS
Created Folder: D:\Multimedia\Output\DVD_0 (4074.9 MB)
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline   Reply With Quote
Old 6th January 2010, 14:29   #1096  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hi Adub,
first of all thanks for the kind words and for using A2D. Let's approach the issues, as I believe they are not impossible to solve.
About save settings: do you mean Preferences? Are you sure you have saved them by checking the lower left option box? You can verify the preferences saving by looking at the following reg key:
HKLM\Software\AVStoDVD
About DTS-HD audio, I have to admit that I am not very used at BD to DVD encoding. Anyway, here you are some suggestions:
1. I'm sure you have already installed ffdshow as DTS audio decoder, haven't you?
2. Have you tried DTS to AC3 conversion with QUENC profile?
3. When you select the other AC3 sources, try do demux them instead of directly encoding using FFMpegSource
4. Use always the 'Preview Clip' function: it saves you time and if there are AviSynth errors, they are displayed.
Let me know
Bye
MrC
MrC
AVStoDVD Homepage
Old 7th January 2010, 04:34   #1097  |  Link
Adub
Adub's Avatar
Ah, just realized about the lower left hand corner "Preferences" option. Thanks for that.
Yes, I have FFDShow installed with the DTS audio decoder enabled. I realized that I have a semi old (NOV 09) build, so I'm updating to the latest to see if that helps.
The problem with this source is that the AC3 tracks are all foreign languages, so I don't really need them anyways.
I will use the Preview Clip function from now on.
I'm attempting another try with the options that you suggest + the newer FFDShow build, and I will report back.
Edit: Preview works. Both Audio and Video. Playback is choppy, but it works.
Site:Adubvideo
Old 7th January 2010, 19:38   #1098  |  Link
Adub
Adub's Avatar
Okay, a temporary report.
The DTS-HD audio encode failed using Wavi+AFTEN. I managed to take a screen shot which I will post when I get back home later today.
One thing I may try is disabling DTS in FFDShow so that A2DAudioSource uses NicDTS instead. This may or may not fix it, but I will follow any suggestions that you have after I have posted a screenshot of the error.
Site:Adubvideo
Old 7th January 2010, 21:44   #1099  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Good idea.
And do not forget to try QuEnc as audio encoder.
Bye
MrC
AVStoDVD Homepage
Old 8th January 2010, 03:46   #1100  |  Link
Adub
Adub's Avatar
Here is the error that I encountered ealier:
http://mirror.adubvideo.net/wavierror.png
Oh, and disabling the ffdshow decoder cause AVStoDVD to hang. Apparently, NicDTSSource doesn't like loading a .m2ts file as a source, which is understandable.
I'm going to try using libavcodec as the decoder and then maybe Quenc.
Site:Adubvideo
[IMG] code is Off
