Old 29th October 2011, 13:04   #1921  |  Link
whiskey
Drunken munky
Hi got movie in mkv plus separate subs in two files idx and sup (if not mistaken) I can add them in program but end result on dvd is horrible, subs wont fit on screen they appear in bottom right corner (cut off) and have blue color with white outline. Same thing happened with totally other movie that had subs in same external format, no clue what to do :S
whiskey is offline   Reply With Quote
Old 31st October 2011, 14:02   #1922  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Shablagoo and whiskey
before going forward with troubleshooting, where did you get the mkv you are trying to convert?
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 2nd November 2011, 15:34   #1923  |  Link
Marvel
@rendez2k
bug found, it is releated to the combination of PAL-SpeedUp and DTS track. Next release will fix it. Now, as workaround, go to 'Preferences'/'Audio' and toggle off 'Keep AC3/DTS/MP2 DVD Compliant Audio', save as default and restart your project.
Bye
hmm I've been having countless audio failed errors since installing and no matter how many different setting setups I try I couldn't figure it out! I use the pal speed up function and use mkvs usually with dts audio. I wonder if this has been my issue
Marvel is offline   Reply With Quote
Old 5th November 2011, 19:20   #1924  |  Link
jmac698
MrC,
Regarding the feature request for CC, I found two tools which do this and at least one has source. It seems compatible with muxman as well. I haven't tried the methods yet but I can tell you if they work; in that case you have some simple binaries you can just call from your GUI and it's done. Should be simple.
jmac698 is offline   Reply With Quote
Old 7th November 2011, 20:06   #1925  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@jmac698
ok, let me know your progresses
Bye
MrC
AVStoDVD Homepage
Old 8th November 2011, 02:44   #1926  |  Link
8ternity
8ternity's Avatar
Hi Mrc,
Can you plan in to do list to save batch process when you save the current project? I had sometimes for some reasons to reboot computer in remote and i want to save batch but doesnt supported yet.
Also, the magnetic suggestion for the batch windows ;-) *Already replied that you put in to do list*
Old 8th November 2011, 20:32   #1927  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by 8ternity View Post
Hi Mrc,
Ok, another item in the ToDo list
Bye
MrC
AVStoDVD Homepage
Old 12th November 2011, 11:12   #1928  |  Link
rippn
Having an issue when trying to create a dvd from 2 separate xvids. Here are my logs. I have tried with different xvids and different numbers of xvids with the same issue. Any help would be appreciated.
<11/12/2011 2:14:19 AM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 2
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: ISO UDF Image
DVD Label: SOA_S4_D1
DVD Menu: Motion Menu
Output Folder: D:
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 8500
Video Profile Level 2: 8500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
PAL SpeedUp: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Agency FB 16pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: F: TSSTcorp CDDVDW SH-S203N SB02
DVD Burning Speed: 8x
Auto Erase DVD RW: 1
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 1
TITLE 1 SOURCE FILES
Video: M:\!Sons of Anarchy\Season 4\401 - Out.avi
Info: XviD - 1141 kbps - 624x352 - DAR 1.773 - 23.976 fps (CFR) - Progressive - 59:04 minutes - 84992 frames
Audio 1: M:\!Sons of Anarchy\Season 4\401 - Out.avi
Info: MPEG-1 Audio layer 3 - 147 kbps - VBR - 2 ch - 48000 Hz - 59:04 minutes (0 ms delay) - Internal
[MediaInfoLib - v0.7.47]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("M:\!Sons of Anarchy\Season 4\401 - Out.avi", CacheFolder="D:\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("M:\!Sons of Anarchy\Season 4\401 - Out.avi", CacheFolder="D:\Temp")
Video = Video.ConvertToYV12
#Using DGPulldown/HCenc to upsize FPS
Video = Video.Lanczos4Resize(720,480,0,0,0,-0)
Audio = Audio.EnsureVBRMP3Sync()
AudioDub(Video, Audio)
<11/12/2011 2:14:22 AM>
TITLE 1 AVISYNTH FRAMESERVING CHECK
Check passed successfully.
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 2337.4 MB
HCenc Parameters: -ini "D:\Temp\SOA_S4_D1_0_Title_01_401 - Out.HCenc.ini"
HCenc ini file:
*INFILE D:\Temp\SOA_S4_D1_0_Title_01_401 - Out_1.avs
*AVSRELOAD
*OUTFILE D:\Temp\SOA_S4_D1_0_Title_01_401 - Out.m2v
*LOGFILE D:\Temp\SOA_S4_D1_0_Title_01_401 - Out.HCenc.log
*MAXBITRATE 9000
*BITRATE 5531
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 60
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<11/12/2011 2:39:11 AM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: D:\Temp\SOA_S4_D1_0_Title_01_401 - Out.m2v (2337.8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5571 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 59:04 minutes - 84992 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "D:\Temp\SOA_S4_D1_0_Title_01_401 - Out_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "D:\Temp\SOA_S4_D1_0_Title_01_401 - Out_1.ac3"
<11/12/2011 2:40:15 AM>
END AUDIO ENCODING OPERATIONS (Track 1)
A2DAudioSource: DirectShowSource
Created File: D:\Temp\SOA_S4_D1_0_Title_01_401 - Out_1.ac3 (81.1 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 59:04 minutes (0 ms delay)
TITLE 2 SOURCE FILES
Video: M:\!Sons of Anarchy\Season 4\402 - Booster.avi
Info: XviD - 905 kbps - 624x352 - DAR 1.773 - 23.976 fps (CFR) - Progressive - 46:52 minutes - 67435 frames
Audio 1: M:\!Sons of Anarchy\Season 4\402 - Booster.avi
Info: MPEG-1 Audio layer 3 - 128 kbps - VBR - 2 ch - 48000 Hz - 46:52 minutes (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("M:\!Sons of Anarchy\Season 4\402 - Booster.avi", CacheFolder="D:\Temp", FrameRate=23.976, VFR=false)
Audio = A2DAudioSource("M:\!Sons of Anarchy\Season 4\402 - Booster.avi", CacheFolder="D:\Temp")
<11/12/2011 2:40:18 AM>
TITLE 2 AVISYNTH FRAMESERVING CHECK
Target Video FileSize: 1854.7 MB
HCenc Parameters: -ini "D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster.HCenc.ini"
HCenc ini file:
*INFILE D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster_1.avs
*AVSRELOAD
*OUTFILE D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster.m2v
*LOGFILE D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster.HCenc.log
*MAXBITRATE 9000
*BITRATE 5531
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 60
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<11/12/2011 3:00:07 AM>
Created File: D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster.m2v (1854.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5571 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 46:52 minutes - 67433 frames
Wavi+Aften Parameters: "D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster_1.ac3"
<11/12/2011 3:00:37 AM>
Created File: D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster_1.ac3 (64.4 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 46:52 minutes (0 ms delay)
START DVD MENU BUILDING OPERATIONS
DVD Menu settings:
Style: 1
Aspect Ratio: 1
Titles Format: 1
Template: Menu in Black
Max Titles Page: 4
Enable Play All: 1
Force Play All: 0
Background Audio: 0
Max Thumbs Row: 2
Thumb Image Source: 0
Thumb Frame Position: 10%
HL Frame Format: 0
HL Selection Color: 8
HL Play Color: 3
Menu Video BitRate: 6000 kbps
Motion Menu Duration: 15 seconds
Thumb Drop Shadow: 2
Play All Shadow: 2
Arrows Shadow: 0
<11/12/2011 3:01:10 AM>
END DVD MENU BUILDING OPERATIONS
Created File (Menu Page 1): D:\Temp\SOA_S4_D1_0_MenuPage1.m2v (0 MB)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "D:\Temp\SOA_S4_D1_0_BatchMux.ini"
BatchMux ini file:
-d "D:\SOA_S4_D1_0\VIDEO_TS"
-mxp "D:\Temp\SOA_S4_D1_0_MuxMan.mxp"
-l "D:\Temp\SOA_S4_D1_0_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-palette "D:\Temp\SOA_S4_D1_0_Palette.txt"
-v "D:\Temp\SOA_S4_D1_0_Title_01_401 - Out.m2v"
-vidmode LB
-a1 "D:\Temp\SOA_S4_D1_0_Title_01_401 - Out_1.ac3"
-a1lang en
-cellfr "D:\Temp\SOA_S4_D1_0_Title_01_401 - Out_Chapters.txt"
-progfr "D:\Temp\SOA_S4_D1_0_Title_01_401 - Out_Chapters.txt"
-chapfr "D:\Temp\SOA_S4_D1_0_Title_01_401 - Out_Chapters.txt"
-SEG2v "D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster.m2v"
-SEG2vidmode LB
-SEG2a1 "D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster_1.ac3"
-SEG2a1lang en
-SEG2cellfr "D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster_Chapters.txt"
-SEG2progfr "D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster_Chapters.txt"
-SEG2chapfr "D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster_Chapters.txt"
-SEG3v "D:\Temp\SOA_S4_D1_0_MenuPage1.m2v"
-SEG3vidmode LB
-SEG3s1 "D:\Temp\SOA_S4_D1_0_Menu.sst"
-SEG3s1dmode WIDE_LB
-SEG3hlmnu "D:\Temp\SOA_S4_D1_0_MenuPage1_Buttons.mnu"
-SEG3hlcsm "D:\Temp\SOA_S4_D1_0_HighlightScheme.csm
-hcn "D:\Temp\SOA_S4_D1_0_BatchMux.hcn"
<11/12/2011 3:01:30 AM>
Process aborted during DVD AUTHORING operations!
Check following files for more details:
AVStoDVD log file <D:\SOA_S4_D1_0.log>
BatchMux log file <D:\SOA_S4_D1_0_BatchMux.log>
<11/12/2011 3:01:33 AM>
Log file created by AVStoDVD Release 2.4.1
BatchMux version                   --> 1.3
Destination Folder                 --> D:\SOA_S4_D1_0\VIDEO_TS
MuxMan Script File                 --> D:\Temp\SOA_S4_D1_0_MuxMan.mxp
MuxMan Log String                  --> -l "D:\Temp\SOA_S4_D1_0_MuxMan.log"
Folder of the MuxMan executable    --> C:\Program Files (x86)\AVStoDVD\MuxMan
Check presence of MuxMan.exe       --> PASSED
Palette File                       --> D:\Temp\SOA_S4_D1_0_Palette.txt
Default Palette                    --> SUCCESSFULLY REDEFINED
Segment #1 - Video File #1         --> D:\Temp\SOA_S4_D1_0_Title_01_401 - Out.m2v
Checking asset for importing as    --> M2V, M1V, MPV
Video Coding Mode                  --> MPEG-2
Video Resolution (Nominal)         --> (720x480)
MPEG-2 Aspect Ratio (DAR)          --> 16:9
Video Frame Rate                   --> 29,97 fps
Video Bitrate (Nominal, Kbps)      --> 8789
VBV Buffer Size (Kbyte)            --> 224
Segment #1 - Video Display Mode    --> LB
Segment #1 - Audio #1 File #1      --> D:\Temp\SOA_S4_D1_0_Title_01_401 - Out_1.ac3
Segment #1 - Audio Lang Code #1    --> en
Segment #1 - Timeframe file        --> D:\Temp\SOA_S4_D1_0_Title_01_401 - Out_Chapters.txt
Segment #1 - Total Nr of Cells     --> 12
Segment #1 - Total Nr of Programs  --> 12
Segment #1 - Total Nr of Chapters  --> 12
Segment #2 - Video File #1         --> D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster.m2v
Segment #2 - Video Display Mode    --> LB
Segment #2 - Audio #1 File #1      --> D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster_1.ac3
Segment #2 - Audio Lang Code #1    --> en
Segment #2 - Timeframe file        --> D:\Temp\SOA_S4_D1_0_Title_02_402 - Booster_Chapters.txt
Segment #2 - Total Nr of Cells     --> 10
Segment #2 - Total Nr of Programs  --> 10
Segment #2 - Total Nr of Chapters  --> 10
Segment memory resources           --> RELEASED
Local Stack memory                 --> RELEASED
File i/o structures                --> DEALLOCATED
rippn is offline   Reply With Quote
Old 13th November 2011, 22:19   #1929  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hi rippn,
there's something wrong with the DVD Menu creation:
Do you get any errors during Menu creation routine?
Bye
MrC
AVStoDVD Homepage
Old 14th November 2011, 04:25   #1930  |  Link
rippn
Hi rippn,
Bye
Do you mean when running through the wizard? Not that I'm aware of. I run the wizard, then go to the editor, change the titles and disc menu text, then exit the editor, is there a step I'm missing?
Old 14th November 2011, 07:20   #1931  |  Link
rippn
So I attempted several changes to the menu options and still getting the error. So I went and downloaded the Beta release (2.4.0 build 110422) and over wrote my AVStoDVD directory which kept all my settings. Again attempted the same DVD and this time it worked with no problem. It appears the new version is failing when "generating dvd background" then it is supposed to launch quenc, which is working properly in the beta release. Any ideas? Was a fresh install required for 2.4.1?
Old 14th November 2011, 23:19   #1932  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
See Help/FAQ/General/Q1.7:
Q1.7 When I download a new release, should I uninstall a previous installed one?
A: Yes, that's a better choice.
Bye
MrC
AVStoDVD Homepage
Old 22nd November 2011, 16:49   #1933  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 2.4.2 is available to download.
Change log:
- Some bugs fixed
- Added possibility to edit source titles media info ('Title'/'Edit Source Title Info')
- Added a consistency check on special chars to main window 'DVD Label' and 'Title Edit'/'General'/'Title Name'
- Added custom values saving in (and loading from) Windows Registry from 'Title Edit'/'AviSynth'
- Added 'Bias' and 'DC Precision' options in 'Title Edit'/'Video'/'HCenc Advanced Options'
- Improved backup Audio encoding routine (FFmpeg based)
- Improved input titles format checking routine
- Wavi updated to 1.06m
- FFmpeg updated to 32754
- MediaInfo updated to 0.7.50
Bye
MrC
AVStoDVD Homepage
Old 22nd November 2011, 21:22   #1934  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Awesome! Thanks for the update
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
Sparktank is offline   Reply With Quote
Old 23rd November 2011, 03:33   #1935  |  Link
soneca
Thanks MrC!
Old 23rd November 2011, 05:05   #1936  |  Link
8ternity
8ternity's Avatar
Thanks!!!
Did you change something in the programmation of icon's resolution. Look like more sharp.
Also, nice image in installer i verry like it!
Old 24th November 2011, 13:53   #1937  |  Link
Marvel
Thanks MrC your works appreciated here .
I was just wondering whats the best media player to have installed? I don't have windows media player 12 installed cos it messes with my music folder which I don't like!! So for music I use MusicBee and normally have vlc for my video playback but with this combo I'm having problems converting mkv to dvd (no audio or audio errors) So after reading the FAQ I installed FFDshow and this fixed the probs I was having. So I guess my question is whats the best setup Ie media players and filters? should I stick with vlc + FFDshow or go for a mediaplayer that has filters avstodvd can use? I like the cleanest sytem possible (think I have OCD).
Whats everyone else doing???
Hope its ok posting this here
Cheers M.
Old 25th November 2011, 14:15   #1938  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Marvel
I suggest Media Player Classic Home Cinema
Bye
MrC
AVStoDVD Homepage
Old 22nd December 2011, 23:45   #1939  |  Link
8ternity
8ternity's Avatar
I personnally use:
- PowerDVD 11
and also
- Media Player Classic (first version of media plassic classic home cinema).
I like powerdvd11 because we can listen everything. Also VIDEO_TS folder (drag'n'drop); m2ts HD, divx, xvid, everhing excel FLV.
Old 23rd December 2011, 17:33   #1940  |  Link
Fishman0919
FishmanMod Android Dev
Fishman0919's Avatar
Change log:
- Some bugs fixed
Bye
Thank You kind sir
"Cinderella story, out of nowhere,
former greenskeeper, now about
to become the Masters champion.
It looks like a mirac- it's in the hole!"
Fishman0919 is offline   Reply With Quote
[IMG] code is Off
