1st October 2009, 14:39 | #401 | Link |
HDConvertToX author
1) you usually the langer the better
2) green squares ? post the mplayer.log and automen.log in automen folder 3) make sure you use latest beta 4) i know. but most probably will not implemented BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
21st October 2009, 16:48 | #402 | Link |
Sorry, I'm very late...
However 1)green squares are "artifacts" when starting to play movie, they are not IN the movie.. something like buggy video driver or something else... 2) progress % stays always to 0% ... 3) selecting language looking for their codes in the dos window is possibile, but not "easy".. however, this can be done :-) 4) a strange thing that has happened me is that I selected 1500MB and had a output file of 860mb.. 5) Is it possible to select more than one audio track? another nice thing would be visual crop, like hdc. But I can imagine this is "the little brother", it cannot have ALL features :-) keep up the good work |
2nd November 2009, 10:59 | #403 | Link |
Thanks for the automen
buzzqw's AutoMen encoder is so far the best x264 encoder that my laptop can use. it uses less resources compared to handbrake.
i just encountered a audio problem. i used the x264 format, 2 pass with my desired file size and ar. it resulted with no audio but when i used the 1 pass setting it had an audio. now the question is, why is this happening? thanks. |
2nd November 2009, 11:11 | #404 | Link |
HDConvertToX author
Hi Tukmol
i need the "queue" bat for understanding the problem please add your work to queue and post here thanks! BHH
3rd November 2009, 23:44 | #405 | Link |
unfortunately i erased all data about the project. i just went back to using the1 pass x264 setting. THANKS for replying though. but btw i'm a noob in this.. wher can i get the queue bat anyway just in case next time i'll encounter this i'll let you know.
6th November 2009, 23:45 | #406 | Link |
EphMan
Not Encoding Entire Movie
I ripped a dvd disc to my hard drive to one single VOB file for conversion to XviD format.
AutoMen detected the movie at 90+ minutes, but when the encode finished, the resulting XviD file was only 16 min. in length. Anyone else experiencing this? I am using the latest beta (downloaded and installed today). |
7th November 2009, 08:56 | #407 | Link |
HDConvertToX author
post the batch file
automen should be able to concatenate all vobs... BHH
7th November 2009, 18:30 | #408 | Link | |
EphMan
Also, maybe something is wrong on my end? Because every single GUI I've tried from the forums is failing me. AutoMKV only encoded a few min. like AutoMen did. ASXGui failed at 50%, etc etc. I'm only on an XP SP3 install with not much software installed besides Office and freeware video programs. I'm at a loss. As for posting a batch file, I'm trying to re-create the encode issue, but now AutoMen won't even encode. When I hit "encode" the screen flashes and nothing happens. Going to reboot and try again. Last edited by EpheMeroN; 7th November 2009 at 18:39. |
7th November 2009, 22:51 | #409 | Link |
HDConvertToX author
corrupt vob ?
try demuxing and remuxing with rejig BHH
8th November 2009, 18:22 | #410 | Link |
EphMan
Okay. I did what you suggested. This time it encoded but only 40+ minutes worth. I used the default 1 pass XviD Balanced preset. I'm at a loss here.
Here's that batch log you requested: Code:
"C:\Documents and Settings\User1\Desktop\AutoMen6_beta\mencoder.exe" -demuxer lavf -vf harddup,scale=624:352,hqdn3d=1:1:1 -sid 1001 -o "D:\ONE_WEEK\VIDEO_TS\automen_VTS_02_1.avi" -ovc xvid -xvidencopts bitrate=4316:max_bframes=2:bquant_ratio=162:bquant_offset=100:vhq=2:me_quality=6:chroma_me:chroma_opt:hq_ac:trellis:lumi_mask:autoaspect:bvhq=1 -aid 1 -af volnorm=1 -oac mp3lame -lameopts abr:br=128 -channels 2 -lavdopts threads=3 -lavcopts threads=3 "D:\ONE_WEEK\VIDEO_TS\VTS_02_1.VOB" "D:\ONE_WEEK\VIDEO_TS\VTS_02_2.VOB" "D:\ONE_WEEK\VIDEO_TS\VTS_02_3.VOB" "D:\ONE_WEEK\VIDEO_TS\VTS_02_4.VOB" 2>"C:\Documents and Settings\User1\Desktop\AutoMen6_beta\automen.log" |
8th November 2009, 20:30 | #411 | Link |
HDConvertToX author
just some information:
can you confirm that there are only 4 vobs ? "D:\ONE_WEEK\VIDEO_TS\VTS_02_1.VOB" "D:\ONE_WEEK\VIDEO_TS\VTS_02_2.VOB" "D:\ONE_WEEK\VIDEO_TS\VTS_02_3.VOB" "D:\ONE_WEEK\VIDEO_TS\VTS_02_4.VOB" and all there vobs are correct and accessible ? could you post the "C:\Documents and Settings\User1\Desktop\AutoMen6_beta\automen.log" ? thanks! BHH
8th November 2009, 21:32 | #412 | Link | |
EphMan
The AutoMen log was too large to fit in a post here so I uploaded it to PasteBin. Hope that'll suffice. The log is here: http://pastebin.com/m5009c369 |
8th November 2009, 22:06 | #413 | Link |
HDConvertToX author
try builing only 1 file
also.. there are too much duplicate frames maybe is to apply decimate ? (film pattern) BHH
8th November 2009, 22:16 | #414 | Link |
EphMan
AutoMen doesn't do auto-IVTC?
I had an original single VOB file that DVD Decrypter outputted. I just tested my original single VOB rip using the latest AutoGK and it encoded the entire movie. However, it was only 380mb in size when I specified 800mb. I'm going to go the manual route with an AviSynth script, and manual 2-pass setup in VDub and see what happens... Last edited by EpheMeroN; 9th November 2009 at 01:02. |
9th November 2009, 08:09 | #415 | Link |
HDConvertToX author
automen don't auto deinterlace
just select on deinterlacer list the FILM preset BHH
9th November 2009, 09:23 | #416 | Link |
HDConvertToX author
update automen beta
try to auto detecting FILM pattern some minor and cosmetic fixes BHH
9th November 2009, 11:46 | #417 | Link |
Contradiction: bitrate vs. final size
When I open AutoMen v6.63 to (re-) encode a movie then on the "Summary" tab there are (among others) two values (resp. entry fields):
- Video bitrate and - ....keep in .... MB So the user can enter both values at the same time. From my point of view this is nonsense: The user can either determine the bitrate. Then the final size is open or the user can fix the desired final size then it is up to the encoder to chose the appropriate bitrate. So how can AutoMen handle both key values at the same time? Or in other words: If the user enters values in both entry fields: Which one has priority? Mike |
9th November 2009, 11:57 | #418 | Link |
HDConvertToX author
Video Bitrate has always priority
also .. when you edit the final size, the bitrate is re-computed, WHILE if you edit manually the bitrate the final size will not change in this way users can simply specify the final size.. and power users can specify bitrate BHH
10th November 2009, 07:45 | #419 | Link |
Hi I recently tried to convert a BRrip movie of 600 Mb MKV Movie to 700 Mb AVI Movie. But the conversion wont start. I dont know whats wrong but it wont start. I get the following :
Automen (Notepad) : o audio encoder (-oac) selected. Select one (see -oac help) or use -nosound. Mplayer (Notepad) : Creating config file: D:/AutoMen6_beta/mplayer/config MPlayer Sherpya-SVN-r29319-4.5.0 (C) 2000-2009 MPlayer Team Playing F:\Video\Movies\Harry Potter & The Half Blood Prince.mkv. ID_SUBTITLE_ID=0 ID_SID_0_LANG=eng [mkv] Track ID 1: subtitles (S_TEXT/UTF8), -sid 0, -slang eng ID_SUBTITLE_ID=1 ID_SID_1_LANG=dut [mkv] Track ID 2: subtitles (S_TEXT/UTF8), -sid 1, -slang dut ID_SUBTITLE_ID=2 ID_SID_2_LANG=pol [mkv] Track ID 3: subtitles (S_TEXT/UTF8), -sid 2, -slang pol ID_SUBTITLE_ID=3 ID_SID_3_LANG=rum [mkv] Track ID 4: subtitles (S_TEXT/UTF8), -sid 3, -slang rum ID_SUBTITLE_ID=4 ID_SID_4_LANG=tur [mkv] Track ID 5: subtitles (S_TEXT/UTF8), -sid 4, -slang tur ID_VIDEO_ID=0 [mkv] Track ID 6: video (V_MPEG4/ISO/AVC), -vid 0 ID_AUDIO_ID=0 ID_AID_0_LANG=und [mkv] Track ID 7: audio (A_AAC), -aid 0, -alang und [mkv] Will play video track 6. Matroska file format detected. VIDEO: [avc1] 1280x534 24bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s) ID_FILENAME=F:\Video\Movies\Harry Potter & The Half Blood Prince.mkv ID_DEMUXER=mkv ID_VIDEO_FORMAT=avc1 ID_VIDEO_BITRATE=0 ID_VIDEO_WIDTH=1280 ID_VIDEO_HEIGHT=534 ID_VIDEO_FPS=23.976 ID_VIDEO_ASPECT=2.3970 ID_AUDIO_FORMAT=MP4A ID_AUDIO_BITRATE=0 ID_AUDIO_RATE=24000 ID_AUDIO_NCH=2 ID_LENGTH=9211.01 ID_SEEKABLE=1 ID_CHAPTERS=2 ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264) ========================================================================== ID_VIDEO_CODEC=ffh264 ========================================================================== Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding) AUDIO: 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000) ID_AUDIO_BITRATE=128000 ID_AUDIO_RATE=48000 ID_AUDIO_NCH=2 Selected audio codec: [faad] afm: faad (FAAD AAC (MPEG-2/MPEG-4 Audio)) ========================================================================== AO: [dsound] 48000Hz 2ch s16le (2 bytes per sample) ID_AUDIO_CODEC=faad Starting playback... VDec: vo config request - 1280 x 534 (preferred colorspace: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 2.40:1 - prescaling to correct movie aspect. ID_VIDEO_ASPECT=2.3970 VO: [null] 1280x534 => 1280x534 Planar YV12 A: 0.1 V: 0.0 A-V: 0.064 ct: 0.000 0/ 0 ??% ??% ??,?% 0 0 Exiting... (End of file) ID_EXIT=EOF Please rectify me and tell me where the problem is. |
10th November 2009, 08:21 | #420 | Link |
HDConvertToX author
post the make report (in program path panel)
also try updating mplayer/mencoder -> http://sourceforge.net/projects/mpla...vision%2029851 BHH
automen, ffmpeg, handbrake, mencoder, x264 |
