Old 16th October 2018, 18:05   #27861  |  Link
Using the same test file that I sent you resulted in one of the items being fixed. The VFR->CFR resulted in 23.976 fps, but the aspect ratio was still 3:2.
If VFR is forced off, the frame rate is still 19.181.
Weird. I tested it with the source you sent me and it seemed to work fine, although it did do a VFR to CFR conversion. I actually force the aspect ratio in the VFR-CFR reencode... how could it still be 3:2???
I may have to rethink this thing for 720x480 sources with pulldown. I just imported a movie from a DVD, output it to an MKV and then tried importing the MKV. I got the same alternating timecode intervals in that one too. It must be related to the pulldown somehow -- though I can't see how the spacing would look like that???
I may have to look for that pattern, and assume pulldown. But first I need to do a little more research.
I'll let this one run and see if I can repeat the framerate issue.
Old 16th October 2018, 21:41   #27862  |  Link
MrVideo
MrVideo's Avatar
I took the VOB file, used TSMuxer to create a TS file and ran that through the latest version. I then looked at the M2TS file with Media info. I played it with VLC and yep, 3:2.
Mediainfo says that it is 2:3 pulldown. No need to look for it, since mediainfo provides that info.
Old 16th October 2018, 22:28   #27863  |  Link
Yeah... but MEDIAINFO is also telling me it is variable framerate. One doesn't necessarily exclude the other.
Old 17th October 2018, 03:50   #27864  |  Link
MrVideo
MrVideo's Avatar
From what we have seen, these two values have been working out: frame rate (23.976) and scan order (2:3 pulldown). At least for the test video when VOB converted to TS. The other is frame rate (variable), original frame rate (23.976) and scan order (2:3 pulldown). It seems that a variable frame is a false positive, even when the timecodes are all over the place. It sends one down the wrong rabbit hole.
As a side note, one of the DVDFab produced MKV files also resulted in a 3:2 aspect ratio when a VFR->CFR was done on it.
Oh, and it all comes down to what you said... DVDs can't have variable frame rate videos. It must either be 29.97 or 23.976 w/ 2:3 pulldown, because analog TVs only support 29.97 interlace video. Of course, that is moot with today's digital monitors/TVs.
IMHO, it was stupid that we kept the 29.97 frame rate when converting to digital broadcasting. I do not think there is an analog TV that wouldn't have been able to handle true 30 fps interlace video. But, that is moot too. That ship has sailed.
Old 17th October 2018, 12:54   #27865  |  Link
I figured out the 19.181 fps thing. When you mux a stream with 2:3 pulldown into the pseudo BD structure with TSMUXER the framerate has to be set to 29.97, not 23.976. If pulldown results in a 23.976 framerate, then it is assumed the underlying progressive rate must be 19.181. Duh...
Old 17th October 2018, 17:18   #27866  |  Link
Glarioo
Mediainfo: vbv-maxrate=35000 / vbv-bufsize=30000
Isn't that too low for a mkv uhd output?
TWEAK_ALTERNATE=--vbv-maxrate 50000 --vbv-bufsize 50000 in BDREBUILDER.INI has no effect, it stays at 35000/30000.
Old 17th October 2018, 19:18   #27867  |  Link
Yeah, maybe, depending on the chosen bitrate. I did most of my testing using a CRF in the low 20's -- and it was plenty for that. I'll take a look at it.
Old 17th October 2018, 19:49   #27868  |  Link
Glarioo
I did not "choose" the bitrate, BD Rebuilder did that
I chose Alternate Movie-Only output - MKV Container, HEVC, NO_RESIZE, Intact Audio. Constant Rate Factor Output (CRF) was set to 17.
Old 17th October 2018, 19:51   #27869  |  Link
MrVideo
MrVideo's Avatar
That is a good one. I did notice with the GUI that if you remove pulldown, it changes the framerate to 23.976. But if you unselect remove pulldown, it doesn't set the framerate back to 29.97. If I would have continued, I would have discovered the 19.181 thing. Nice find.
Old 18th October 2018, 00:52   #27870  |  Link
Yeah, I noticed that in TSMUXERs GUI, if you check the delete pulldown box, and then uncheck it -- it doesn't set things back, and can even cause a buffer error during it's attempt to mux.
Old 18th October 2018, 02:02   #27871  |  Link
MrVideo
MrVideo's Avatar
AIUI, work on TSMuxer is no longer being done, so that bug will never get fixed.
Old 18th October 2018, 14:59   #27872  |  Link
Yeah. Luckily I don't use the GUI, so I can set the parameters myself.
Old 18th October 2018, 18:05   #27873  |  Link
BD Rebuilder v0.60.04
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.60.04). Changes for this release:
- Corrected issues with file import of MPEG2
  sources that contain 2:3 pulldown flags.
- Added IMPORT_NO_PULLDOWN as a new hidden
  option. When set it will remove pulldown
  flags from MPEG-2 sources during import of
  files or DVDs.
- Added two new hidden options.  UHD_MAXRATE
  sets the maximum bitrate for UHD encodes
  and UHD_VBV_BUFFER sets the buffer size.
  See HIDDENOPTS.TXT for more information.
Old 18th October 2018, 18:10   #27874  |  Link
MrVideo
MrVideo's Avatar
  files or DVDs.
Great. Thanks.
Old 18th October 2018, 18:17   #27875  |  Link
Glarioo
- Other minor corrections and cosmetic fixes.[/code]
Thank you! I Will try it when I get home.
Old 18th October 2018, 18:22   #27876  |  Link
I also changed the default for UHD to 50000/50000. There are two maximums listed for a 50GB UHD M2TS, the lower of the two is a maximum of 64Mbs for all streams in a single M2TS (audio/video/graphics). So 50Mbs leaves about 14Mbs for overhead/audio/graphics.
Old 18th October 2018, 21:03   #27877  |  Link
MrVideo
MrVideo's Avatar
  files or DVDs.
Wouldn't a better description be:
removes pulldown flags during import of MPEG2/DVD, keeping the original 23.976 frame rate
The reason is that IVTC is not really being done. Doing IVTC implies that the 29.97 fps video is sent thru a filter, like AVISynth, to extract the 23.976 frames and recode those frames. Removing the 2:3 pulldown flags doesn't do any recoding, thereby keeping the original MPEG-2 quality.
Just a thought.
A side note: I started working on another project and discovered some material was marked as variable frame rate 29.97. And there was material that was marked as variable frame rate 23.976 w/ 2:3 pulldown. All on the same DVD. Can't seem to make up their minds.
Old 19th October 2018, 10:38   #27878  |  Link
MrVideo
MrVideo's Avatar
Alternate MKV is incomplete
After three DVD files were imported, I then did the backup. Only the third M2TS file was wrapped into an MKV file, the first two M2TS files were ignored. Why is that?
Old 19th October 2018, 12:14   #27879  |  Link
Sharc
Just a thought.
IVTC applies to hard-telecined material only which is different from soft-telecining based on flags.
Old 19th October 2018, 13:36   #27880  |  Link
It does one at a time. You have to choose which playlist to output to MKV.
When you import more than one at a time, do this:
1. Import multiple files. It creates a pseudo-structure with multiple menu entries. Let it finish importing.
2. From the mode menu, select the ALTERNATE method to be used (output format)
3. Go to the "Batch" tab.
3. Right-click on the queue area.
4. Select "Add multiple playlists to Queue"
5. From the list, choose the playlist(s) you want to output in the format you selected in step 2.
6. Push the "Batch Backup" button.
That way you can create multiple MKVs. I've imported as many as a hundred in a batch (multiple seasons of as series, for example).
