12th June 2020, 01:34 | #29442 | Link |
Since force_noencode & quicker encode don't seem to work together, no matter what I fiddle with, is it possible to override the 15000 Kbs max bitrate cap for discs sized under 25GB?
I'm manually re-encoding the extras to a DVD5 and because it's under 25 minutes of content, all the extras are hitting the cap and the disc is undersized. Edit: Would this work (and is it right)? TWEAK_PASS_ONE=--vbv-bufsize 30000 --vbv-maxrate 40000 TWEAK_PASS_TWO=--vbv-bufsize 30000 --vbv-maxrate 40000 Last edited by DoctorM; 12th June 2020 at 02:01. |
12th June 2020, 13:54 | #29444 | Link | |
Elit Amans
//LD Edit: Sorry I misunderstood the first time... Ofcourse the final disc have the movie+extras, and you want to have more bitrat added to the movie? isnt it better to apply the extra bitrate to the extras if the movie already looks good? too avoid any compability issues? It will be fitted to a BD25 in the end so the DVD5 caps doesn't need to be applied. Last edited by LowDead; 12th June 2020 at 14:01. Reason: reread DoctorMs original post and understood it... |
12th June 2020, 15:19 | #29445 | Link | |
Aging Video Hobbyist
I have dreaded the work associated with building a new PC but maybe your experience will inspire me! In the Fall! |
12th June 2020, 15:23 | #29446 | Link | |
12th June 2020, 16:45 | #29447 | Link | |
Those tweaks won't work. There are some settings that BD-RB won't allow you to change (to prevent self-inflicted issues). Last edited by jdobbs; 12th June 2020 at 16:47. |
12th June 2020, 17:03 | #29448 | Link |
I know what I was doing. It's just that gonca mentioned there was an easier method a while back, and as far as doing separate processing and manually rebuilding the disc, jdobbs did mention he was planning to add a hidden opt. to allow removal the VBV restriction from the pass tweaks. He did add a maxbitrate option for UHD.
My post is 6 years old, musiclover, and 6 years later, neither of these alternatives work, it still has to be done manually. I tried gonca's method only once back when he originally posted it and I didn't aggressively try adjusting options to see if I could make it work until this week. I don't know if the original intent WAS for that method to work or not, but many updates to BDRB later, I didn't know what to expect. I'd just like to see the ability to right-click a stream and select 'don't encode'. So maybe someone doesn't want to re-encode the movie like me, or someone else might not want to re-encode a specific bonus feature that's they lover or is already bitrate starved. It sounds useful to me. Edit: Again, to be clear, this isn't an attack on anyone. It's just I haven't worked with BD-RB in a while and I'm trying to understand what changes have been made in that time. Last edited by DoctorM; 12th June 2020 at 17:25. |
12th June 2020, 19:18 | #29449 | Link |
CorrectEPData() 00006 2008
hello. i've tried to shrink the BD which i recorded again and again.
but everytime this error message is displayed and i have no choice but to abort the process. "BD Rebuilder experienced an error 2008 correctEPData() 00006 2008" i tried the latest and some old versions on Windows 7(32bit) and Windows 10(64bit). but i always got the same error message. could you tell me what i need to do to solve this problem please? ---------------------- [06/06/20] BD Rebuilder v0.61.05 [03:21:59] Source: GONZOU - Input BD size: 25.96 GB - Approximate total content: [07:36:56.756] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), CRF - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [03:22:00] PHASE ONE, Encoding - [03:22:00] Processing: VID_00000 (1 of 1) - [03:22:00] Extracting A/V streams [VID_00000] - [03:24:39] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1440x1080 - Rate/Length: 29.970fps, 821,653 frames - [03:24:39] Performing CRF Prediction... - Analyzing 17.90 [17.95] - [03:26:25] Encoding using constant rate factor. - [05:46:28] Video Encode complete - [05:46:28] Processing audio tracks - Track 4352 (und): Keeping original audio - [05:46:28] Multiplexing M2TS - [05:49:09] CorrectEPData() 00006 2008 [05:51:51]PHASE ONE aborted by user request ---------------------- [06/09/20] BD Rebuilder v0.61.05 [14:34:59] Source: BD - Input BD size: 23.82 GB - Approximate total content: [07:06:25.192] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), CRF - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:34:59] PHASE ONE, Encoding - [14:34:59] Processing: VID_00000 (1 of 1) - [14:34:59] Extracting A/V streams [VID_00000] - [14:42:46] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1440x1080 - Rate/Length: 29.970fps, 766,761 frames - [14:42:46] Performing CRF Prediction... - Analyzing 17.60 19.50 20.15 [20.15] - [14:47:50] Encoding using constant rate factor. - [16:57:44] Video Encode complete - [16:57:44] Processing audio tracks - Track 4352 (und): Keeping original audio - [16:57:44] Multiplexing M2TS - [17:00:40] CorrectEPData() 00006 2008 [17:53:55]PHASE ONE aborted by user request |
12th June 2020, 19:56 | #29450 | Link | |
Oh, Enki, indeed! I do tech stuff for family & others & 10 is not a joy. I don't "hate" but the "Blleech!" is very strong. I've installed it on my system, multiple OS installs..as you, but there isn't any way I'm going to say "Okay." to it. The GUI is my stopper. It's made for Keyboard commandos (not the PEOPLE THAT TYPE LIKE THIS ALL THE TIME). My Son at Intel really doesn't enjoy it either, and he's very much keyboard commando (as little mouse use as possible). I've heard they've finally removed a lot of bloat. Okay, well, the make it "Look cool again." so I'm not going any time soon. Besides, you're not able to pick updates; like Windows 7. Make a product and then treat customers as products - bad business idea. "Epic Fail!" as the buzz-word jargon says. Anyway, very interested to know more about how well Ryzen does with BD-RB. I'm think the cores and threads will help a lot. I'd probably not use my GPU as much then, with LAVF handling better. Hmm... I have a couple Samsung SSDs and they're not operating at near full speeds with this ASUS motherboard. So, I'm thinking that'll really be helpful with BD-RB. I don't get into heavy gaming, but sometimes it's fun. Nothing like the "gamers" of today though...many other things to do than sit for 5 to 8+ hours playing video games. Yikes, haha! So a good mix... Hmm. I'm sure the lowly wretch, Lathe, wasn't offended.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 12th June 2020 at 20:03. |
12th June 2020, 21:18 | #29451 | Link |
12th June 2020, 22:22 | #29452 | Link | |
OR one or the other, been a long time |
17th June 2020, 18:01 | #29453 | Link |
Update about 720p 59.94 videos.. I've been able to use HandBrake to convert the Secret of Skinwalker Ranch episodes to 23.96 without any filters being used. Just change it to constant framerate and force 23.97 vs 29.97, Pass AC-3 through.. When done making MKV, use MKVToolNix GUI and add SRT (and remove Substation if you don't clear subtitles)...then import into BD-RB and tsMuxer doesn't change anything. Playback of all videos and subs are smooth as can be from sources. Since there isn't an ability, yet, for BD-RB to change framerate this way, none that will complete anyway.. I thought it was a bug with BD-RB, but it's TsMuxer doing it as I downloaded newer and older versions of that to make singe BDs of each episode.
17th June 2020, 23:39 | #29454 | Link |
I've decided I'm going to buy an NVIDIA card that supports encoding so I can include NVENC support in BD-RB. I'm thinking about a GTX 1660 because it supports B-FRAMES in HEVC encoding and is in the $200~ price range. I was wondering if anyone had experience with this or other cards and could make some recommendations. Any estimates on encoding speeds for AVC and HEVC (including UHD) would be helpful. Thanks in advance.
18th June 2020, 02:32 | #29455 | Link | |
It works. Using it with FAB, set as “cuda” it is way faster than “software” mode. (When converting a Blu-ray ripped to Hard drive can be converted MKV with Fab & Cuda with CRF20 in about 15 minutes vs BD-RB as Alt-movie only CRF20 in about 45-50 min). And it’s faster than using the intel u630 with my i7-8700k. I haven’t done UHD to MKV in a while. Over the next few days I can run some tests and comparisons if you help me understand what would be the best way. |
18th June 2020, 03:36 | #29456 | Link |
Why are you dealing with 720p when 1080p23.976 is available? Especially why are you just converting the frame rate instead of doing a true IVTC? With BDRB, you can pass an AVIsynth script to do the IVTC. Me, I prefer 1080p. But that is me.
18th June 2020, 22:49 | #29458 | Link | |
i have a RTX 2070 super, if you need any tests done just ask and ill try and do them |
19th June 2020, 02:21 | #29460 | Link | ||
HandBrake won't upscale past 720p. I also don't know a script to use to force it to work. BD-RB's upscale aborts immediately after starting. I don't have a script for the AVS Filter in BD-RB. Quote:
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 19th June 2020 at 03:14. |
