Old 6th May 2013, 13:59   #17081  |  Link
Ch3vr0n
You have an incompatible anydvd setting that may be causing issues (the remove adverts setting) disable it. Rip the disc anew and try again.
Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk
Old 6th May 2013, 16:30   #17082  |  Link
sojourner353
Thanks for the reply guys, so I fixed the AnyDVD problem as you can see in the quote bellow but still failing.
[05/07/13] BD Rebuilder v0.44.04 (beta)
[01:18:49] Source: ARTHUR_CHRISTMAS_3D_00001
- Input BD size: 22.92 GB
- Approximate total content: [01:37:32.846]
- Windows Version: 6.1 [7601]
- Mode: MKV Container, 1920x1080, 640Kbs DD5.1
- 3D conversion mode enabled
- Decoding/Frame serving: DirectShowMVC
- Resuming from previously started job.
[01:18:51] PHASE ONE, Encoding
- [01:18:51] Processing: VID_00001 (1 of 1)
- [01:18:51] Reencoding video [VID_00001]
- Encode failed. Aborting.
- BD-Rebuilder v0.44.04 (beta)
- FFDSHOW: 4422, Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[01:18:51] - Failed video encode, aborted
Done the LASTCMD.TXT and got the following screenshot
Looks like a problem with DirectshowMVCSource like you said, I'm a bit lost on how to set it up I guess, thanks.
sojourner353 is offline   Reply With Quote
Old 6th May 2013, 16:53   #17083  |  Link
Just make sure you follow the directions in DirectshowMVCSource_ReadMe.TXT. I can tell from your command line that it is definitely wrong..
Old 6th May 2013, 17:04   #17084  |  Link
@AmigaFuture
I traced down the bug you reported. Actually it had nothing to do with the 3D code, and in fact the bug has probably been there for many versions. The failure was caused by having MKV_MUXSUPS set. The zero length files were completely unrelated and harmless, but I did correct that as well, as they shouldn't even be there.
Old 6th May 2013, 17:14   #17085  |  Link
sojourner353
Cool thanks for that, just reading it I was way off, its just after 2am here so will have a go at the setup tomorrow, thanks again for the help.
Old 6th May 2013, 17:50   #17086  |  Link
AmigaFuture
AmigaFuture's Avatar
@AmigaFuture
Good to know. I felt it probably had been for a few. I was going t go back a few versions but knew testing 44.04 to be more valuable. I haven't been checking Alternative MKV for a few versions. I feel so horrible now. Not! I'm excited to check the new version with the list of tested movies from an earlier post. :-)
Old 7th May 2013, 21:02   #17087  |  Link
Sinatrafan
WELL.. I downloaded the latest version of BD Rebuilder..proceeded to back up a blu ray of DIEHARD; this is an ordinary Blu Ray..not 3d.. yet I get the "FAILURE to ENCODE" message, it says "AnyDVD Remove Annoying Adverts: Incompatible"..
I've never seen this with BD Rebuilder before; I've never had any problems with either ANYDVD or BD Rebuilder..yet with THIS latest version (44.4) of BD Rebuilder, a problem seems to exist.
Soo; I went BACK to the PREVIOUS version of BD Rebuilder, started the encode again..this time, the encode is proceeding nicely.
I see that one or two others on the forum are experiencing this problem as well.. Will this problem be FIXED in a future version of BD Rebuilder? OR should I always un check the "ANYDVD Remove annoying Adverts" before ripping a Blu Ray?
I'm really not a techie guy..but I've used BD Rebuilder ever since it was released, with no problems.. I know how to use it, but I'm afraid that I'll break something if I try to repair it with the "Fix" that Mr. Dobbs has suggested.
I can continue to use the previous version of BD Rebuilder until a new version becomes available with the problem fixed.. BUT I dunno how LONG I will be able to use this previous version until it expires. sigh..
Thank you soo much for BD Rebuilder, Mr. Dobbs; and all you've done to improve it's funtionality over the last few years.. the software IS amazing!
And, thank you for your attention, and patience with me.
Sinatrafan is offline   Reply With Quote
Old 7th May 2013, 23:07   #17088  |  Link
Ch3vr0n
undo that anydvd setting. It's incompatible with BDRB's blanking mode and may cause other issues. Bugreports with that setting can't be accepted.
Old 7th May 2013, 23:08   #17089  |  Link
setarip_old
setarip_old's Avatar
Try it and see if it resolves your problem (It should)...
Old 7th May 2013, 23:23   #17090  |  Link
Sinatrafan
Thank you for your responses.. well.. all I can say is that I've always had that setting on in ANYDVD..it's never ever caused any problem with BD Rebuilder until this version.. I'll try to rip the blu ray again..without this setting on.. and then try the latest version of BD Rebuilder again, per your recommendations..I hope this fixes the problem.. however, this also sorta kinda defeats the purpose of that setting.. to remove annoying advertisements.. heh heh..
Thanks again for your responses..
Old 7th May 2013, 23:41   #17091  |  Link
Ch3vr0n
not if you if you add enable_test=1 and enable_blanking=1 to the bdrb ini file. That way you'll get BDRB's movie & menu's mode and will be able to blank trailer crap (automatically or manually) the "proper" way.
Old 8th May 2013, 14:04   #17092  |  Link
That check for "remove annoying" message has been there for many months and many versions. It isn't anything new -- and it should NOT be set in AnyDVD while using BD Rebuilder. The fact that is may have not created a problem in something you did in the past is irrelevant -- it shouldn't be set. With that said, I doubt that it is your problem in this instance since you say it works with the last release.
Please post your log and your settings... I can't fix a problem based on "I got an error".... from your post I don't even know what phase it was in. I don't even know if it was full backup or movie-only, encoding or rebuilding, ALTERNATE or normal, BD-5 or BD-25... on-and-on.
Old 8th May 2013, 16:49   #17093  |  Link
sojourner353
Hi jdobbs, will there be an option to create Full SBS 3D (3840x1080) with untouched audio? Don't know if its possible or not, I have downloaded in the past Full SBS 3D's and they work great on my setup (HTPC to 1080p 3D Projector), thanks.
Old 8th May 2013, 23:13   #17094  |  Link
xtremevideoinc117
I got this error after i downloaded the newest version.
[18:10:17] PHASE ONE, Encoding
- [18:10:17] Processing: VID_00805 (7 of 12)
- [18:10:17] Reencoding video [VID_00805]
- Rate/Length: 23.976fps, 2,764 frames
- Bitrate: 9,305 Kbs
- [18:10:17] Reencoding: VID_00805, Pass 1 of 1
- FFDSHOW: 3882, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[18:10:18] - Failed video encode, aborted
xtremevideoinc117 is offline   Reply With Quote
Old 8th May 2013, 23:20   #17095  |  Link
Ch3vr0n
I'd be happy to be able to do FULL disc mode in Half SBS. Would free up a ton of harddrive space on my HTPC. SBS discs would be able to be shrinked to being able to convert a Real3D disc to SBS in full disc mode would be just awesome.
Old 8th May 2013, 23:37   #17096  |  Link
omegaman7
omegaman7's Avatar
- FFDSHOW: 3882, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Where's the rest of your log? It could be a bad rip... (since the current file failed so quickly)
Suggest ripping again, with a different drive, if available. Or cleaning the disc.
Old 8th May 2013, 23:51   #17097  |  Link
@xtremevideoinc117
I notice it got through several files before it crashed. You might want to check for heat related CPU instability. That's the most likely problem.
Old 8th May 2013, 23:53   #17098  |  Link
If I did this it would have to be to ALTERNATE MKV or MP4 only -- as the size would not be compliant with AVCHD or Blu-ray.
Old 8th May 2013, 23:54   #17099  |  Link
I'd have to look at that closely, mainly because I'd have to remove all the other 3D indicators in the disc. But I'll see how hard it might be.
Old 9th May 2013, 00:39   #17100  |  Link
Ch3vr0n
Well aslong as the menu's work correctly "eg: watch film in RealD > triggers SBS copy". For movies like the most recent resident evil it may be a little tricky. There's 3 versions on it. 2D, anaglyph & RealD. The 1st 2 can easily be shrinked. Afaik the anaglyph one from what i can see on my iso probably uses some kind of "anaglyph overlay" on the 2D stream as there is no seperate anaglyph stream. It's the RealD (2nd eye stream) that as you know prevents shrinking.
