Old 4th February 2014, 04:37   #19101  |  Link
worknstiff
@worknstiff
RE: Does it also fail when you try to do a 3D backup of a 3D BD, or just when attempting a SBS-> BD3D conversion?
Sorry, was out for a bit. Even after all the installs I did it still will encode a 3D SBS from 3D.
BD Rebuilder Log:
[02/03/14] BD Rebuilder v0.46.07 (beta)
[22:20:35] Source:  HUBBLE_3D_01000
  - Input BD size: 14.68 GB
  - Approximate total content: [00:44:00.637]
  - Target BD size: 23.68 GB
  - Windows Version: 6.2 [9200]
  - MOVIE-ONLY mode enabled
  - Quality: High Quality (Default), Two Pass
  - 3D conversion mode enabled
  - Decoding/Frame serving: FRIMSource
[22:20:35] PHASE ONE, Encoding
 - [22:20:35] Processing: VID_00013 (1 of 2)
 - [22:20:35] Extracting A/V streams [VID_00013]
 - [22:23:52] Reencoding video [VID_00013]
   - Rate/Length: 23.976fps, 63,288 frames
   - Converting output to Side-By-Side 3D Format
   - Bitrate: 45,000 Kbs
 - [22:23:52] Reencoding: VID_00013, Pass 1 of 2
BD Rebuilder INF
[Status]
LABEL=HUBBLE_3D
VERSION=v0.46.07 (beta)
SOURCE_SIZE=15760478208
SOURCE_VIDEO_SIZE=15760478208
TARGET_SIZE=25427968000
REDUCTION=1.6134007905352
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;spa;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;spa;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
SSIF_MODE=-1
QUICK=0
ENCODE_STEP=1.5
[00013]
AUDIO=100
PGS=111
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=25427581403
RATE=45000
SPLITS=1
Hey WOW! No wonder this Hubble 3D looks so great
BITRATE 45,000 kbs
Old 4th February 2014, 04:53   #19102  |  Link
Uh oh. I need to fix that. Side-by-side should be limited to a lower bitrate. The 45Mbs should be for BD-3D output only, not SBS.
Old 4th February 2014, 04:56   #19103  |  Link
worknstiff
RE: Even after all the installs I did it still will encode a 3D SBS from 3D. OOPS I should have paid attention to the version I downloaded and installed,
BD Rebuilder Log:
Here is the latest version and logs.
BD Rebuilder Log:
[02/03/14] BD Rebuilder v0.46.10 (beta)
[22:47:42] Source:  HUBBLE_3D_01000
[22:47:42] PHASE ONE, Encoding
 - [22:47:42] Processing: VID_00013 (1 of 2)
 - [22:47:42] Extracting A/V streams [VID_00013]
 - [22:50:58] Reencoding video [VID_00013]
 - [22:50:58] Reencoding: VID_00013, Pass 1 of 2
  - Encode failed.  Aborting.
  - BD-Rebuilder v0.46.10 (beta)
  - FFDSHOW: 4504, Ok
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - FFDSHOW AVC set to "libavcodec":  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[22:50:58] - Failed video encode, aborted
BD Rebuilder INF:
[Status]
LABEL=HUBBLE_3D
VERSION=v0.46.10 (beta)
RESIZE_1080=0
RESIZE_1440=0
KEEP_HD_AUDIO=-1
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
SSIF_MODE=-1
QUICK=0
ENCODE_STEP=1.5
[00013]
AUDIO=100
PGS=100
VIDEO2=0
V2MBRATE=0
RATE=45000
SPLITS=1
Old 4th February 2014, 05:55   #19104  |  Link
worknstiff
Well whatever it is BD Rebuilder's latest version didn't fix it. It fails IMMEDIATELY in full 3D to SBS or the 3D SBS to full 3D conversion. I will be ready to try any fix you suggest, hopefully it's not just because of the intel quick sync procedure.
Latest Logs for 3D to SBS MKV :
[23:31:31] Source:  HUBBLE_3D_01000
  - Mode: MKV Container, Full-SBS (3D), Intact Audio
[23:31:31] PHASE ONE, Encoding
 - [23:31:31] Processing: VID_00013 (1 of 2)
 - [23:31:31] Extracting A/V streams [VID_00013]
 - [23:34:46] Reencoding video [VID_00013]
   - Bitrate: 27,008 Kbs
 - [23:34:46] Reencoding: VID_00013, Pass 1 of 2
  - FFDSHOW: 4504, Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[23:34:47] - Failed video encode, aborted
BD Rebuilder INF:
Status]
LABEL=HUBBLE_3D
RESIZE_1080=0
RESIZE_1440=0
KEEP_HD_AUDIO=-1
BACKUP_MODE=1
MOVIEONLY_TYPE=32
USE_LAVF=0
INSTANCES=1
DGDECNV=0
SSIF_MODE=-1
QUICK=0
ENCODE_STEP=1.5
[00013]
AUDIO=100
PGS=000
VIDEO2=0
V2MBRATE=0
SPLITS=1
BD Rebuilder 3D SBS to full 3D ISO Logs
[23:37:50] Importing MKV: PJSOFMNSTERS3D_(SBS)
- Collecting audio/video streams from source...
- Building pseudo-BD source structure...
[23:39:52] Video import completed successfully.
[23:39:57] Source: PJSOFMNSTERS3D_(SBS)_00000
- Input BD size: 3.88 GB
- Approximate total content: [01:46:09.029]
- Converting SBS source to 3D-BD format
- Quality: High Quality (Default), ABR
- MVC 3D Output Mode enabled
[23:40:00] - Aborted per user request
[23:40:16] Source:  PJSOFMNSTERS3D_(SBS)_00000
[23:40:17] PHASE ONE, Encoding
 - [23:40:17] Processing: VID_00000 (1 of 1)
 - [23:40:17] Extracting A/V streams [VID_00000]
 - [23:42:13] Reencoding video [VID_00000]
   - Rate/Length: 23.976fps, 152,704 frames
   - Bitrate: 28,997 Kbs
   - Using FRIMEncoder for MVC reencoding
 - [23:42:13] Reencoding: VID_00000, Pass 1 of 1
[23:42:14] - Failed video encode, aborted
BD Rebuilder INF:
[Status]
LABEL=PJSOFMNSTERS3D_(SBS)
SOURCE_SIZE=4166344704
SOURCE_VIDEO_SIZE=4166344704
REDUCTION=6.10318391936876
RESIZE_1080=0
RESIZE_1440=0
KEEP_HD_AUDIO=-1
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=1.5
[00000]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=25427968000
RATE=28997
Old 4th February 2014, 15:22   #19105  |  Link
Blurayhd
Jdobs Thanks for your dedication on it. Only one thing, when i try to remove languages ​​and subtitles i do not want, simply click and give them listed as an x.
All good to this point. The problem is when i see the end result, and play the movie (obviously the languages ​​and subtitles were marked out) but... (the text) still there, are displayed. Any chance to remove them and not listed there?
Thanks jdobs!
Sorry my English, because i speask Spanish
Old 4th February 2014, 16:43   #19106  |  Link
dfsooner
Mr
I personally don't think BD-5/9 is a good choice for 3D. There are twice as many frames, so you're creating the equivalent of 4 hrs video for a 2 hr film. While it's not exactly 2x required bandwidth -- it's using the currently available tools. Add to that all the enhancements that X264 provides (that aren't available with FRIMEncode) and a BD-5/9 is really pushing the limit.
I'm not saying you can't create a presentable BD-5/9 -- but I wouldn't expect quality comparible to the original. I personally do all my 3D backups to BD-25 (except possibly imported half-SBS sources that have already lost a significant portion of their true resolution before the conversion).
Good news. Re-ran using BD-25 and all the artifacts are gone.
Looking at the parameter list options for FRIM, I assume it was designed to work with hardware encode/decode. However, running MVCENCODE.BAT produces a message that the parameters are invalid for Quicksync processors. I'm curious whether FRIM provides those parameters or BDRB. Is there no way to get that working with Quicksync? (Bet you knew you were going to get that question.)
dfsooner is offline   Reply With Quote
Old 4th February 2014, 16:55   #19107  |  Link
inge70
cool, you have "inspect.exe" integrated into BD_rebuilder Help button. SUPER work Jdobbs
Thank you for your great work ..
inge70 is offline   Reply With Quote
Old 4th February 2014, 17:15   #19108  |  Link
If they are invalid, how did you complete the BD-25 job? I'm running on an AMD processor, so I wouldn't see anything related to Quicksync. What does it say exactly?
Old 4th February 2014, 17:57   #19109  |  Link
dfsooner
I only get the failure when trying to use hardware encode.
I posted the messages when you asked for them a couple of days ago. Guess you missed the post. Here it is again:
MVCENCODE.BAT output:
ERROR: Cannot initiate Intel Media Encoder - invalid parameters.
ERROR: invalid video parameters (-15), src\pipeline_encode.cpp (961)
ERROR: undefined behavior (-16), src\pipeline_decode.cpp (1113)
ERROR: the previous asynchronous operation is in execution (1), src\main_frim_decode.cpp (129)
Old 4th February 2014, 18:03   #19110  |  Link
Ok. I got the impression you were getting errors without the hardware settings as well. Yeah, that's why I set the default to software decoding/encoding on my latest release. If people can get errors, I don't want it happening with the default settings.
Old 4th February 2014, 18:17   #19111  |  Link
dfsooner
I understand that. The question was, can it be made to do Quicksync encode/decode? Running FRIMEncode or FRIMDecode without any parameters displays a list of all the possible options one of which is -sw:hw. The fact that there is a "hw" option implies that hardware encode/decode is supported. If the parameter is not specified, autodetection is used and for my processors it tries to use -hw but the "invalid parameters" message results. I don't know what parameters it is passed that are invalid or how they get passed and wondered whether you did. Maybe it supports only CUDA, but not Quicksync. Not sure how to find out or how it could be made to work with Quicksync.
Sure would be nice to speed things up.
Old 4th February 2014, 18:22   #19112  |  Link
This might be a question for the FRIMEncode thread. But my guess would be it has to do with your specific computer's configuration.
Old 4th February 2014, 18:33   #19113  |  Link
soneca
Jdobbs, today I tried these two conversions but failed.
[02/04/14] BD Rebuilder v0.46.10 (beta)
[09:15:52] Source:  49775_DEEPSEA_3D_WB_00001
  - Input BD size: 15,49 GB
  - Approximate total content: [00:40:49.405]
  - Target BD size: 4,38 GB
  - Windows Version: 6.1 [7601]
  - Quality: Better (Faster), Two Pass
  - Output folder: E:\VIDEOS\
  - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=448
[09:15:52] PHASE ONE, Encoding
 - [09:15:52] Processing: VID_00002 (1 of 1)
 - [09:15:52] Extracting A/V streams [VID_00002]
 - [09:19:33] Reencoding video [VID_00002]
   - Rate/Length: 23,976fps, 58.727 frames
   - Bitrate: 13.394 Kbs
 - [09:19:33] Reencoding: VID_00002, Pass 1 of 2
  - FFDSHOW: 4515, Ok
  - WIN7 preferred AVC CODEC:  Ok
  - WIN7 preferred VC-1 CODEC:  Ok
  - WIN7 preferred MPEG2 CODEC:  Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[09:21:10] - Failed video encode, aborted
[15:06:08] Source:  UNDER_THE_SEA_BD_3D_00004
  - Input BD size: 15,01 GB
  - Approximate total content: [00:40:49.321]
  - Mode: MKV Container, 1920x1080, Intact Audio
[15:06:17] PHASE ONE, Encoding
 - [15:06:17] Processing: VID_00002 (1 of 1)
 - [15:06:17] Extracting A/V streams [VID_00002]
 - [15:10:23] Reencoding video [VID_00002]
   - Rate/Length: 23,976fps, 58.725 frames
 - [15:10:23] Reencoding: VID_00002, Pass 1 of 1
  - FFDSHOW: 4515, Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[15:11:59] - Failed video encode, aborted
Old 4th February 2014, 18:35   #19114  |  Link
HWK
HWK's Avatar
No, Frim encode at this moment can't do Intel quick sync and unless videofan3d can modify Intel media SDK library or Intel themselves, I don't see it as a option.
-hw option is only supported on 4th Generation on Intel Core processors
Old 4th February 2014, 20:29   #19115  |  Link
@soneca
Thanks for the report. I think I might see what's going on, it looks like a change I made may be causing the SBS output from BD-3D to have issues.
[Edit] Ughh... this was a really silly error. I've fixed it and will post an update.
Old 4th February 2014, 21:34   #19116  |  Link
Blurayhd
Hi @Jdobbs
Can you help me? http://forum.doom9.org/showpost.php?...ostcount=19106
Old 4th February 2014, 21:41   #19117  |  Link
soneca
@soneca
Ok, If you need more information just let me know.
Go rest a bit to not get stressed!
Old 4th February 2014, 23:08   #19118  |  Link
BD Rebuilder v0.46.11 (beta)
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.46.11). Changes for this release:
- Fixed an issue introduced in v0.46.10 in
  which a BD-3D source that is targeted for
  SBS output (BD or ALTERNATE) will fail
  during the encode phase.
- Corrected maximum bitrate for output in SBS
  mode from 3D sources.
- Changed process so that DGIndexNV does not
  run when a FRIMSource() is in effect (when
  creating SBS from a BD-3D source).
Old 5th February 2014, 00:01   #19119  |  Link
mparade
Is it possible with the current BD-RB to process a 3D BD disk as 2D in Full backup mode or just in movie-only mode?
I have a few disks just in 3D version.
Old 5th February 2014, 00:29   #19120  |  Link
soneca
Thank you!
Yeah, MVC encoding is anything but fast. But I notice on my system that my processor time is nowhere near 100%. I need to find a way to multiprocess when using FRIMEncode. On my system I think I could probably double the speed.
The multiprocess is really useful!
