29th September 2018, 20:35 | #982 | Link | |
I don't know how cut vob file. edit: I have just tried any option. If I use enhanced video renderer in mpc-hc 64 with xysubfilter 3.1.0.751, subs are displayed. If I use madvr instead of enhanced video renderer with xysubfilter 3.1.0.751, subs are not displayed. I have tried madvr 0.91.4 and the last version 0.92.17. The problem seems to occur with a strange interaction between madvr, mpc-hc64 and xysubfilter 64bits edit 2: with madvr 0.89.2 subs are displayed. evr madvr0.89.2 madvr 0.92.17 or 0.91.4 Last edited by ikarad; 29th September 2018 at 20:42. |
29th September 2018, 22:39 | #983 | Link |
@ikarad, could it have to do with LAV Decoder filter and XySubFilter fighting over the subtitle connection to madVR? It's a known problem that madVR currently only accepts one subtitle connection. And if LAV has that connection, XySubFilter can lose out. Try using a different decoder, just to verify.
30th September 2018, 05:39 | #984 | Link |
[QUOTE=ikarad;1853344]I have tried the two versions and it doesn't work.
I don't know how cut vob file. edit: I have just tried any option. If I use enhanced video renderer in mpc-hc 64 with xysubfilter 3.1.0.751, subs are displayed. If I use madvr instead of enhanced video renderer with xysubfilter 3.1.0.751, subs are not displayed. I have tried madvr 0.91.4 and the last version 0.92.17. The problem seems to occur with a strange interaction between madvr, mpc-hc64 and xysubfilter 64bits edit 2: with madvr 0.89.2 subs are displayed. I had the same issue, try disabling (not removing), lav splitter and lav splitter source under external filters in mpc-hc, subtitles are now displaying for me. forced subtitles are not loading automatically though . |
30th September 2018, 08:10 | #985 | Link |
Broadband Junkie
Try installing the latest LAVFilters-0.72.0-15.exe Nightly from https://files.1f0.de/lavf/nightly/ . It looks like nev actually changed the handling of DVD subtitles on that build compared LAVFilters-0.72.0-13.exe, maybe it is related? The commit message mentions "Disable the CC output pin for DVD playback".
If that doesn't work, ensure that you've run XySubFilter regsvr32 (as admin) and it actually succeeded, and also test MPC-BE to rule out it's not just a MPC-HC quirk. The last thing you could try is setting XySubFilter to "Always Load" under Properties->Main. Personally I've been using MPC-HC 1.7.16, madVR 90.24, LAVFilters-0.72.0-15 on Win7 and and don't remember seeing anything like that. Though thinking back, I don't think XySubFilter has ever supported rendering subtitles directly from a DVD disc(?). Isn't that usually handled by DVD Navigator and a DVD/MPEG2 decoder? Is the situation differ on OS newer than Win7? LAV Splitter never loads for DVD playback on my end, and XySubFilter never connects to the DVD subtitle pin, the subtitle pin is always taken and rendered by the video decoder. If there is some kind of weird timing conflict going on, media players should probably consider blocking XySubFilter when a DVD disc is played. Yet it is curious if it doesn't occur with older madVR builds though, so maybe it's something madshi could fix on his end? Last edited by cyberbeing; 30th September 2018 at 08:15. |
30th September 2018, 08:19 | #986 | Link | |
With DVD playback, LAV Video uses the ISubRenderConsumer interface to render DVD menus and DVD subtitles. It'll connect that pretty late, when the DShow graphs enters "Pause" mode, so long after graph building. In what order would madVR act? If the consumer slot is already taken, does it let me kick out whats in there, or does it just block the slot for the first one to get in there? The reason it doesn't happen with older madVR versions is that LAV Video checks the madVR version, and doesn't act unless its at least 0.89.10, because the interface was a bit crashy before that version. It falls back to the inefficient manual blending onto the decoded picture. But actual DVD disc playback is a bit complicated anyway. External subs would probably be hard to sync to the appropriate timing, so do people really do that?
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 30th September 2018 at 08:28. |
30th September 2018, 08:31 | #987 | Link | |
I have tried to turn off lav filter in mpc-hc. Now, Mpc use microsoft dtv-dvd video and audio decoder. Subs are not displayed. With madvr and mpc-hc32 bits and xysubfilter 32 bits, subs are displayed. Only 64 bits version have a problem. Last edited by ikarad; 30th September 2018 at 08:36. |
30th September 2018, 08:51 | #989 | Link | |
30th September 2018, 08:56 | #990 | Link | |
The problem arrive only with dvd when I use "open dvd/BD" function in mpc-hc with mad vr, mpc-hc 64bits and xysubfilter 64 bits. With 32 bits versions of mpc-hc and xysubfilter, subs are displayed Last edited by ikarad; 30th September 2018 at 09:03. |
30th September 2018, 09:28 | #991 | Link | |
Until 0.89.09, subs are displayed Since 0.89.11 subs are not displayed. I can't test 0.89.10 because when I download 0.89.10.zip on videohelp https://www.videohelp.com/software/m...sions#download , it download 0.89.11. |
30th September 2018, 13:55 | #992 | Link |
madshi, this should fix the missing sub problem:
https://github.com/mpc-hc/mpc-hc/com...3478c9895adfe0 |
30th September 2018, 14:50 | #994 | Link |
@ikarad,
can you make a debug log with the missing subtitles? Please try to keep it as short as possible, which means: Start playback, when the subtitle should occur, and it doesn't, immediately stop the media player. If possible, no funny things like reloading the DVD multiple times, switching resolutions or zooming etc. Ideally, could you also add a debug log with the 32bit build, so I can compare both? @clsid, that change seems to be related to subtitle scaling quality (replacing bilinear with bicubic). How would that change help fixing missing subtitles? |
30th September 2018, 15:19 | #997 | Link |
Broadband Junkie
Do you have a sample, and are you sure that wasn't only a VSFilter.dll issue? XySubFilter handles such thing differently than MPC-HC, so I don't think it would be affected by the same issue. Bitmaps subtitles such as VOBSUB are sent to madVR at original size, and madVR is responsible for scaling them as needed.
What ikarad & austonrush are reporting is a madVR/LavFilters specific issue related to DVD playback only, since they stated XySubFilter+EVR, XySubFilter+OldMadVR, and XySubFilter+CurrentMadVR+blockingLavSplitter were all working. It sounds like either a filter conflict, or a case of XySubFilter connecting to the madVR consumer before LAV Video (or the reverse, depending on which is actually rendering the DVD subs). Last edited by cyberbeing; 30th September 2018 at 15:28. |
30th September 2018, 15:50 | #998 | Link | |
Broadband Junkie
30th September 2018, 17:28 | #1000 | Link | |
