Old 24th February 2017, 15:22   #3081  |  Link
AviSynth has a rather flexible syntax in this case. From the documentation shipped with AviSynth 2.60:
Continue on next or from previous line: \
Subtitle ("Test-Text")
Subtitle ( \
          "Test-Text")
Subtitle (
       \ "Test-Text")
What I mean was your quoted snippet, originally by tcope in #3067, which I saw as truncated due to the last plus:
ovText = "AviSynth Authors:"+chr(13)+
	\ "----------------------------"+chr(13)+
I assume that a few more concatenated strings would follow in the next lines.
LigH is offline
Old 24th February 2017, 18:47   #3082  |  Link
qyot27
qyot27's Avatar
I don't know which version was crashing for you, but I fixed bug earlier that could cause crash, for me it was only a garbaged error display, but it would show up as crash under other conditions.
20161222 r2347dev
- Fix: ScriptClip would show garbage text when internal exception occurs instead of the error message
Yeah, it was a personal build of r2343, so that's more than likely what was going on there.
qyot27 is online now
Old 24th February 2017, 20:02   #3083  |  Link
pinterf
Meanwhile real.finder, our script master has found a bug in Merge in 32 bit float.
pinterf is offline
Old 25th February 2017, 00:28   #3084  |  Link
qyot27
qyot27's Avatar
Output of Wine 2.2 on Ubuntu 16.10 with the winetest build:
[~:$] wine --version
wine-2.2
[~:$] wine ffplay -i Authors.avs
fixme:advapi:GetCurrentHwProfileA (0x23f770) semi-stub
fixme:heap:RtlSetHeapInformation (nil) 1 (nil) 0 stub
fixme:win:RegisterDeviceNotificationA (hwnd=0x36cb0, filter=0xd3e3c8,flags=0x00000001) returns a fake device notification handle!
fixme:module:load_library unsupported flag(s) used (flags: 0x00000800)
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
ffplay version r83188 git-bb7db37 Copyright (c) 2003-2017 the FFmpeg developers
  built on Jan 20 2017 12:33:30 with gcc 6.3.0 (GCC)
  libavutil      55. 43.100 / 55. 43.100
  libavcodec     57. 75.100 / 57. 75.100
  libavformat    57. 62.100 / 57. 62.100
  libavdevice    57.  2.100 / 57.  2.100
  libavfilter     6. 69.100 /  6. 69.100
  libavresample   3.  2.  0 /  3.  2.  0
  libswscale      4.  3.101 /  4.  3.101
  libswresample   2.  4.100 /  2.  4.100
  libpostproc    54.  2.100 / 54.  2.100
fixme:win:EnumDisplayDevicesW ((null),0,0x364f8c8,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",0,0x364f8c8,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",0,0x364f510,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",1,0x364f8c8,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x364f8c8,0x00000000), stub!
    nafixme:module:load_library unsupported flag(s) used (flags: 0x00000a00)
fixme:msvcp:_Mtx_init_in_situ unknown flags ignored: 2   0B f=0/0
fixme:msvcp:_Mtx_init_in_situ unknown flags ignored: 102
[avisynth @ 0023ca80] Exception while processing ScriptEnvironment::ThrowError().
    nan    :  0.000 fixme:msvcrt:__clean_type_info_names_internal (0x4b89b38) stub
Authors.avs: Unknown error occurred  0B f=0/0
    nan    :  0.000 fd=   0 aq=    0KB vq=    0KB sq=    0B f=0/0
[~:$] fixme:msvcrt:__clean_type_info_names_internal (0x1298c20) stub
fixme:msvcrt:__clean_type_info_names_internal (0x1528360) stub
fixme:msvcrt:__clean_type_info_names_internal (0x1687448) stub
fixme:msvcrt:__clean_type_info_names_internal (0x5a4d4600) stub
fixme:msvcrt:__clean_type_info_names_internal (0xb0f480) stub
fixme:msvcrt:__clean_type_info_names_internal (0xb307a0) stub
fixme:msvcrt:__clean_type_info_names_internal (0x35d1f0) stub
fixme:msvcrt:__clean_type_info_names_internal (0x580cb0) stub
fixme:msvcrt:__clean_type_info_names_internal (0x7f1858) stub
fixme:msvcrt:__clean_type_info_names_internal (0x94cff0) stub
fixme:msvcrt:__clean_type_info_names_internal (0x614770) stub
fixme:msvcrt:__clean_type_info_names_internal (0x5f3710) stub
fixme:msvcrt:__clean_type_info_names_internal (0x5cf760) stub
fixme:msvcrt:__clean_type_info_names_internal (0x1800045a0) stub
Or with the Wine-related messages trimmed out:
wine-2.2
    nan    :  0.000
Old 25th February 2017, 04:50   #3085  |  Link
tcope
Digital Artifact
tcope's Avatar
I hope there are syntactically correctly following terms after the last "plus". Unfortunately this is omitted in your examples.
Originally Posted by davidhorman View Post
tcope - post your full working and broken scripts in order to get an accurate diagnosis.
The Authors.avs is the file being tested. It is one of several
example test scripts avail for download from the AviSynthPlus
github repo. Here
Here is that Authors.avs script
tcope is offline
Old 25th February 2017, 05:11   #3086  |  Link
tcope
Digital Artifact
tcope's Avatar
32 bit wine
$ uname -r
3.2.0-4-amd64
$ cat /etc/os-release | grep PRETTY_NAME
PRETTY_NAME="Debian GNU/Linux 7 (wheezy)"
$ wine --version
wine-2.0
wine 'C:\FFMPEG\bin\ffmpeg.exe' -version
ffmpeg version 3.2.2 Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 5.4.0 (GCC)
configuration: --enable-gpl
--enable-zlib
libavutil      55. 34.100 / 55. 34.100
libavcodec     57. 64.101 / 57. 64.101
libavformat    57. 56.100 / 57. 56.100
libavdevice    57.  1.100 / 57.  1.100
libavfilter     6. 65.100 /  6. 65.100
libswscale      4.  2.100 /  4.  2.100
libswresample   2.  3.100 /  2.  3.100
libpostproc    54.  1.100 / 54.  1.100
 wine ~/.wine/drive_c/Program\ Files/AVSMeter/AVSMeter.exe -avsinfo
AVSMeter 2.5.0 (x86) - Copyright (c) 2012-2017, Groucho2004
fixme:file:K32GetMappedFileNameA (0xffffffff, 0x220000, 0x33d508, 260): stub
VersionString:              AviSynth+ 0.1 (r2423, MT, i386)
VersionNumber:              2.60
File version:               0.1.0.0
Interface Version:          6
Multi-threading support:    Yes
Avisynth.dll location:      C:\windows\system32\avisynth.DLL
Avisynth.dll time stamp:    2017-02-25, 03:06:06 (UTC)
PluginDir2_5 (HKLM, x86):   C:\Program Files\AvisynthRepository\AVSPLUS_x86\plugins
[CPP 2.6 / 32 Bit plugins]
C:\Program Files\AvisynthRepository\AVSPLUS_x86\plugins\ConvertStacked.dll
C:\Program Files\AvisynthRepository\AVSPLUS_x86\plugins\DirectShowSource.dll
C:\Program Files\AvisynthRepository\AVSPLUS_x86\plugins\ImageSeq.dll
C:\Program Files\AvisynthRepository\AVSPLUS_x86\plugins\Shibatch.dll
C:\Program Files\AvisynthRepository\AVSPLUS_x86\plugins\TCPDeliver.dll  [2.6.0.7]
C:\Program Files\AvisynthRepository\AVSPLUS_x86\plugins\TimeStretch.dll
C:\Program Files\AvisynthRepository\AVSPLUS_x86\plugins\VDubFilter.dll
 wine ~/.wine/drive_c/Program\ Files/AVSMeter/AVSMeter.exe -i ~/.wine/drive_c/Examples/Authors.avs
fixme:msvcrt:__clean_type_info_names_internal (0x1489b38) stub
wine 'C:\FFMPEG\bin\ffmpeg.exe' -i ~/.wine/drive_c/Examples/Authors.avs ~/example-test-output.mkv
[avisynth @ 00256260] Exception while processing ScriptEnvironment::ThrowError().
fixme:msvcrt:__clean_type_info_names_internal (0x4529b38) stub
.wine/drive_c/Examples/Authors.avs: Unknown error occurred
tcope is offline
Old 25th February 2017, 20:37   #3087  |  Link
pinterf
tcope, qyot27, thanks.
Finally installed a VirtualBox, Ubuntu 16.04, Wine stage, and of course a Midnight commander Grouchos's AVS plus installer did the dirty job and started to iterate the problematic line.
It turned out that the functions, I suspected earlier were the culprit.
Before formatting a string, we are querying the buffer size, which is returned by _vsnprintf_l when a null-length buffer size is given.
int count = _vsnprintf_l(NULL, 0, fmt, locale, args);
under Wine, this function returns -1, which is a rather unexpected number here.
Now I'm using this function instead:
int count = _vscprintf_l(fmt, locale, args2);
which works on both Wine and Windows, and the Authors.avs script with the scrolling credits is rendered fine.
You two will get a bonus build to test it.
But only after I have a little glass of wine (red)
pinterf is offline
Old 25th February 2017, 21:14   #3088  |  Link
Oh, well ... "Little Known Facts" about incompletely supported features in a compatibility layer.
Cheers.
LigH is offline
Old 26th February 2017, 00:18   #3089  |  Link
qyot27
qyot27's Avatar
Confirmed, the second winetest .dll works without issues for me.
Old 26th February 2017, 07:34   #3090  |  Link
tcope
Digital Artifact
tcope's Avatar
Woot ..! Is working here as well.
Looking forward to giving it a spin
with production workflow.
TY for working on this and finding a fix.
Cheers
tcope is offline
Old 27th February 2017, 22:11   #3091  |  Link
martin53
Hi pinterf,
forked your Github AviSynthPlus today
The README.md of the MT branch (also of the AviSynth/AviSynthPlus project, where you probably forked your project) says that the documentation is built with 'Sphinx'.
Do you know anything about that?
I'm asking because I thought I'd have a look if the doc is up do date and maybe I could be useful there...
martin53 is offline
Old 27th February 2017, 23:04   #3092  |  Link
pinterf
Originally Posted by martin53 View Post
Hi pinterf,
No, it wasn't me. But this question will soon be answered I think.
Regarding the two important bugfixes (32 bit float Merge and wine compatibility), I will try to do something in this or next week. I was bothered by having a half-done MaskTools, but now I took a big breath of relief.
pinterf is offline
Old 28th February 2017, 00:21   #3093  |  Link
qyot27
qyot27's Avatar
Hi pinterf,
What's not clear about it?
Like README.md says, install Python, use the pip tool to install Sphinx. Make the desired changes to the .rst files in distrib/docs/english/source, run the Sphinx commands from README.md to regenerate the HTML, view the HTML in your web browser.
Old 1st March 2017, 19:06   #3094  |  Link
martin53
I'd mainly like to know if the statement is still true or someone changed the HTML directly after last .rst update (the AviSynth/AviSynth+ project repeatedly became a sudden orphan until it was adopted by someone new, as it appears )
Github points most .rst files to be at least 2 years old. But definitely AviSynth+ has been extended since. So it's reasonable to ask this question, no?
martin53 is offline
Old 1st March 2017, 20:39   #3095  |  Link
qyot27
qyot27's Avatar
The simplest answer to that there's no way they could do that. The English* HTML documentation was completely removed from the AviSynth+ source tree (except for the separate FilterSDK directory, but the RST version of that is subsumed into the general documentation, and was updated at the same time as that merge from upstream), so it would be impossible for someone to change the HTML directly. In reality, all of any extant documentation regarding AviSynth+'s newer features has gone directly to the AviSynth+ wiki page on avisynth.nl, based on//copy-pasted from the descriptions contained in the thread discussion. If anyone wants to integrate those changes into the RST documentation, feel free to do so.
AviSynth+'s English* documentation (which it inherited from AviSynth 2.6) was officially ported to RST/Sphinx a couple years ago, that's why the dates for most of those files show they were updated two years ago. There was no effort at all in changing the specifics of the documentation beyond simply porting it over (apart from the occasional glaring error that had to be corrected), so the only reasons for it to change would be with post-fork changes from 2.6's docs merged in after-the-fact, or the new 'Contributing to AviSynth+' section.
*yes, only the English docs; the original plan was that the rest of the language-specific docs were going to be removed from the source tree since most of them hadn't been updated by classic AviSynth for years (prior to the fork), but if anyone wanted to port them to RST like the English docs had been, that would have been fine and we would likely have kept the newer RST version around or moved them to a separate git repository.
Old 2nd March 2017, 09:16   #3096  |  Link
pinterf
What is the normal way to add things to the Avisynth+ wiki pages? Is saw in the page history that poor Reel.Deel, practically he alone was doing additions there.
I've never edited Wiki, and I'm feeling the same when I was introduced to git last year and had fears of annihilating other's work if I'm doing something wrong like accidental reformatting, deleting content or whatever.
I'd like to have there new pages for the new or changed avs+ functions, I've already found that there is a template for this. And another one for general info, maybe a new page for filter writers.
I suppose the pages describing classic Avisynth functions and behaviour should not be changed. (And please ignore if my questions are stupid, I had very limited time to deal with this documentation topic, every hours I can spare with your hints or tutorial is welcome)
pinterf is offline
Old 2nd March 2017, 15:33   #3097  |  Link
qyot27
qyot27's Avatar
I've never edited the avisynth.nl Wiki (and the last time I did edit a Wiki of any sort was probably something on the order of 10+ years ago), so someone else will have to comment on that. But Wikis store the revision history like git does and can be reverted to a previous revision if necessary. The only big thing I can think of is to make sure that the comment box has some hint as to what the change(s) made were, so it shows up in the page history.
Old 2nd March 2017, 18:48   #3098  |  Link
martin53
I'll PM to you. A couple of years ago there was a severe problem with spam flooding the wiki, so Wilbert was forced to make changing less easy.
martin53 is offline
Old 2nd March 2017, 19:39   #3099  |  Link
martin53
I really hope I don't start a quarrel here, and 1st I must admit I'm new to using Git/Github and I'm afraid the discussion tends to get off topic.
I realized that pinterf is doing many, many valuable things these days, but I feel documentation/installer things become left behind.
So i forked pinterf's Github AviSynthPlus fork and stupid as I am I thought I might work myself into the docs and update here and there.
Now I have the new question on my mind if someone who forks a Guthub project can commit his changes back to the original project without being authorized by the original project's owner? Should I regard AviSynth/AviSynthPlus or pinterf/AviSynthPlus as the most up to date and legitimate current version of AviSynth+?
I could not spot any commits after about Aug 17,2016 to avisynth/AviSynthPlus, but the pinterf repository is much more recent.
With the ideal that everone's contribution is of most use for the community and no one stands in the other's way: where should I start?
Anyone replying: please refrain from criticising anything in the past, but if you can, give hints & explanations on how we can keep the project in good shape.
martin53 is offline
Old 2nd March 2017, 22:17   #3100  |  Link
blaze077
What is the correct syntax to use arrays? Or were they removed?
I tried the one specified in this post but it seems to give an error in AvsPMod as well as AVSMeter.
Version()
array_variable = [[1,2,3],[4,5,8],"hello"]
n = ArraySize(array_variable)
last
ERROR: Unexpected character "["
Thank you.
blaze077 is offline
