13th July 2010, 03:15 | #8782 | Link | |
Out of sync for me on 3 different system !!! French dd ac3 5.1 The only solution for me to resolve the problem (swapping audio track demuxed with tsmuxer by the track demuxed by eac3to) , tsmuxer cut some overlapped frame when demuxing but not eac3to. And i can hear a little echo at jonction of some files. This echo is also present on original BD. AC3 stream (track 1): overlapped frame detected at position 00:00:22,047. Remove frame. AC3 stream (track 1): overlapped frame detected at position 00:04:31,552. Remove frame. AC3 stream (track 1): overlapped frame detected at position 00:10:59,231. Remove frame. AC3 stream (track 1): overlapped frame detected at position 00:11:59,327. Remove frame. AC3 stream (track 1): overlapped frame detected at position 00:20:31,615. Remove frame. AC3 stream (track 1): overlapped frame detected at position 00:20:40,768. Remove frame. AC3 stream (track 1): overlapped frame detected at position 00:37:20,543. Remove frame. AC3 stream (track 1): overlapped frame detected at position 00:44:02,079. Remove frame. AC3 stream (track 1): overlapped frame detected at position 00:52:29,920. Remove frame. AC3 stream (track 1): overlapped frame detected at position 00:56:46,592. Remove frame. AC3 stream (track 1): overlapped frame detected at position 01:07:42,079. Remove frame. AC3 stream (track 1): overlapped frame detected at position 01:14:45,152. Remove frame. Just my personal experience...
DVD Rebuilder user Last edited by Elvis Gratton; 13th July 2010 at 03:40. |
13th July 2010, 05:38 | #8783 | Link | |
13th July 2010, 07:05 | #8784 | Link | |
13th July 2010, 09:53 | #8785 | Link |
win7 preferred codec
sorry for this noob question, but inspect.exe reports all 3 win7 preferred codecs not set correctly and I cannot for the life of me remember where you set them. Can any kind soul point me in the right direction?? many thanks Night.... Don't bother folks...found the answer the old run as admin trick Last edited by Nightlight; 13th July 2010 at 10:20. |
13th July 2010, 14:36 | #8788 | Link | |
[Edit] Whoops. Too late with the answer... |
13th July 2010, 15:52 | #8789 | Link |
Error in attempt to MKVMERGE
Trying to make BD9 version of 'Se7en Deadly Sins', this is an adult movie(xxx). I am doing a movie only backup, using Automatic Quality Settings. I believe the options are default except the encoder priority which I set to normal. MKVMERGE is failing when trying to extract the audio from VID_00013. According to the stream information window from BDR there is no audio in VID_00013. Using the preview option VID_00013 is a 14 second long disclaimer screen. I am guessing that VID_00005 would fail as well as it has no audio. Using the preview option VID_00005 is a 1 second black screen.
I searched this thread and found two resolutions to this error, neither of them worked for me. The first was to reboot. The second was low disc space. My drive a: has over 1TB of free space. This disc was ripped to the harddrive as an .iso with AnyDVDHD. Here is the log: Code:
[07:02:52] BD Rebuilder v0.34.04 (beta) - Source: SE7EN_DEADLY_SINS - Input BD size: 14.19 GB - Approximate total content: [02:05:10.703] - Target BD size: 7.84 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [07:02:58] PHASE ONE, Encoding - [07:02:58] Extracting A/V streams [VID_00001] - [07:12:16] Reencoding: VID_00001 (1 of 3) - [07:12:16] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29.970fps, 224,646 frames - Bitrate: 7,639 Kbs - [07:12:16] Reencoding: VID_00001, Pass 1 of 2 - [08:50:25] Reencoding: VID_00001, Pass 2 of 2 - [10:30:51] Video Encode complete - [10:30:51] Reencoding audio tracks (if req'd) - [10:32:18] Multiplexing M2TS - [10:34:33] Extracting A/V streams [VID_00013] - Error in attempt to MKVMERGE. [10:34:35] - Failed to retrieve audio, aborted Code:
- Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.34.0.4, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok Code:
[Options] MODE=0 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=1 TARGET_SIZE=8032 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=0 FULL_AVCHD=0 REMOVE_OUTPUT=0 USE_FILTERS=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 AUTO_BURN=2 PRIORITY_CLASS=0 [Paths] SOURCE_PATH=I:\ WORKING_PATH=A:\BD-RB WORK\ |
13th July 2010, 15:59 | #8790 | Link |
Well, I've tried FORCE_ENCODE=1 on three discs (The Green Mile, A Mighty Heart, and Starship Troopers) and though it does reencode the video now, the resulting BDMV directories, though smaller than before, are *still* too large for a BD-RE. Starship Troopers for instance was reduced to 26.64GB. Is the program just not calculating bitrates correctly for reencoding (the target size is correct)?? Should I set the target size considerably smaller than 23GiB?
13th July 2010, 18:56 | #8792 | Link | |
Of course that doesn't solve your problem. The problem isn't really in the audio extraction or reencoding. MKVMERGE is actually trying to convert the extracted video into an intermediate MKV file. It has to do that because field-based VC-1 sources fail to work in FFDSHOW/HAALI without doing so (the "**" next to the frame rate). I'm not sure why its failing, I'll have to give it some thought. Last edited by jdobbs; 13th July 2010 at 19:04. |
13th July 2010, 19:32 | #8793 | Link |
@jdobbs;
I just did another test on a previous full movie backup to BD5 that experienced the same no audio heard for the main feature, with the same results. The movie is U571, a Universal title, that structurally is identical to Scorpion King. The BD-RB backup does not hear the audio of the main title, but the re-authored / remove and add external audio version from multiAVCHD works perfectly! So going back to my backups that experience this issue, I have discovered that one common denominator is they all seem to have PiP with DTS Express secondary audio, except Batman Begins. On all of these backups, I either chose to have BD-RB disable the PiP video, or the PiP video was not an option with BD-RB way back in the beginning ( pages 4-9 of this thread, up to 12-28-2008 ). Some examples I have are: Scorpion King, U571, and Twilight. Batman Begins experienced this too, but it has DD Plus for secondary audio. If these same backups were burned to BD-RE media, there is no audio problem! |
13th July 2010, 20:16 | #8795 | Link | ||
14th July 2010, 01:19 | #8797 | Link |
Post your .INF file and results of INSPECT.EXE. The INF tells me what the target was and what the reencoded output size is. INSPECT lets me know that the helper apps are all configured right.
14th July 2010, 19:14 | #8798 | Link | |
Here's my INSPECT output: Code:
- Windows Version: 6.0 [6000] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.34.0.2, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok |
14th July 2010, 20:27 | #8799 | Link | |
I don't think it is related to .2 -- in fact you are the only person reporting this issue. Last edited by jdobbs; 14th July 2010 at 20:32. |
14th July 2010, 20:49 | #8800 | Link | |
I'll attach my encode log to show that video really was being reencoded. Again, my current INI file looks like this: Code:
[Options] MODE=0 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 TARGET_SIZE=23200 AUDIO_TO_KEEP=eng;fas; SUBS_TO_KEEP=eng; SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DEINTERLACE=1 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=1 FULL_AVCHD=0 REMOVE_OUTPUT=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 FORCE_ENCODE=1 [Paths] WORKING_PATH=\\.PSF\EXTRA\BD\TEMP\ SOURCE_PATH=W:\BD\DECRYPTED\STARTSHIP_TROOPERS_1_P1\ |
