Old 28th December 2010, 14:15   #161  |  Link
idbirch2
Ah yes, you're right, I neglected to update the guide post since the AVCHD option appeared in TSMuxer. I've fixed that now, thanks for pointing it out.
idbirch2 is offline   Reply With Quote
Old 30th December 2010, 21:58   #162  |  Link
jenko
I have downloaded the "Comgenies Awsome Filemanager" apps and found that the 10Mb file is a .pkg format that please correct me if I am wrong but this a file type suited to Mac OS or Linux? cannot open it or use it. Any comments please Deank
jenko is offline   Reply With Quote
Old 30th December 2010, 23:34   #163  |  Link
idbirch2
Not heard of that particular one but it will be one of the many file managers released for the PS3. pkg files can be installed from a usb device on a jailbroken PS3. Hit the PS3 forums for help in that regard.
Old 2nd January 2011, 05:52   #164  |  Link
jenko
Ok will have a look around the forum, below is the post from "deank"
who seems a very switched on guy, What I am attempting to to achieve is ahange AVCHD default through the PS3 so I don't have to keep detaching the external HDD to do this, apparently it can be achieved with this file manager?
A quick note for PS3 owners who jailbroke their consoles
The latest version of the "Comgenie's Awsome FileManager" application allows renaming of folders/files directly off the external USB HDD. There is no need to detach the HDD from the PS3 and plug it in the PC to do the rename now.
Dean
Old 2nd January 2011, 11:53   #165  |  Link
idbirch2
Yes, you can do that with Dean's file manager, here's a link to it:
PS3News thread
You'll need to jailbreak your PS3 first of course.
Old 4th January 2011, 06:56   #166  |  Link
jenko
I assume the plug in chip that is USB into the PS3 is what is called "jailed brake" I got mine in Thailand ?
Old 4th January 2011, 16:08   #167  |  Link
idbirch2
Yes, a jailbroken PS3 currently involves a USB device programmed with specific code, there's no way for me to tell if yours is set up correctly of if your PS3 is jailbreakable, as I keep saying, head over to some PS3 specific sites for that side of the problem, this isn't the place.
Old 8th January 2011, 06:59   #168  |  Link
alice82bill83
it is very useful! Thank you for sharing!
avchd, avchdmanager, avchdme, ps3
