27th February 2017, 19:16 | #25722 | Link |
This is what I do, I take number 355, I select it, it does a scann and it keeps the selection, weird
Well it does not matter I succeeded to do otherwise, what derrange me the most it is the autocrop that resize me the vertical thank |
27th February 2017, 19:46 | #25723 | Link |
There are certain actions that require a reset, like changing settings or editing the INI file. If you do any of those things it will default back to what it thinks is the main feature. You just have to make sure you change the playlist as the last thing you do before running the job.
28th February 2017, 07:43 | #25727 | Link | |
thanks, I'll try |
1st March 2017, 20:03 | #25728 | Link | |
http://forum.doom9.org/showthread.ph...60#post1706160 I mention a couple of posts later that I had the same issue with The Girl with The Dragon Tattoo. http://forum.doom9.org/showpost.php?...ostcount=22118 |
2nd March 2017, 19:03 | #25729 | Link |
Hello, I am rebuilding, I have the option Automatic cropping of borders enabled, the original video made 1920x1080, bd rebuilder should release me a video of 1920x804, out it out a video of 1692x720, why Please?
thank you Last edited by thekiller; 2nd March 2017 at 19:13. |
2nd March 2017, 19:24 | #25731 | Link |
Thank you for your reply, that it filter editor please? Must convert 1920x1080 without cropping and after passing the editor? Currently nothing is centered, it has cut to the left
This happened with the cartoon brave On the other hand dvdfab me detect the correct resolution, but bd rebuilder still better quality |
2nd March 2017, 19:34 | #25732 | Link | |
Crop(0,140,1920,800) That would result in cropping a 1920x1080 source to 1920x800. |
3rd March 2017, 11:16 | #25734 | Link |
alternate output: missing forced subs
currently I'm struggling a bit with alternate output. My latest MP4s are missing the hard coded subs. I use Suptitle is ticked under settings. I examined the encoding process and saw that BDRB calls x264L-64.exe which is an indicator (AFAIK) that internal LAVF is used instead of LAVFilter + Avisynth. Therefore the AVS file is not used (which includes the subtitle line). But I do not use "Use X264's internal..." I have "Use DirectShow.." selected. If I enter an AVS filter through settings Dialog such as "Version()" I see BDRB switches to Avisynth processing. Weird... Any suggestions? Edit: Maybe I could add a dummy value as a filter which forces Avisynth and does not harm encoding Performance. ggtop Last edited by ggtop; 3rd March 2017 at 11:23. |
3rd March 2017, 11:39 | #25735 | Link | |
Hi DarWun, you are writing here: http://forum.doom9.org/showpost.php?...ostcount=22118 the movie has a short studio logo (Yellowbird). I suggest you demux that m2ts with TSMUXER and see if it has 0 (zero) KB audio tracks. Especially the track you have chosen for output. I experienced the same issue on at least one other movie. If that's the case the Audio is delayed by the length of that clip (or maybe more if there are other clips before the movie starts). These empty dts tracks get somehow truncated by TSMUXER (maybe because it violates the Standard). For that reason BDRB cannot circumvent anything. In order to fix it you can add silence to your Audio track using eac3to and remux the files with MP4Box which is shipped with BDRB. I could advise you to do so if you wish but I suggest you have a look first into your source. ggtop Last edited by ggtop; 3rd March 2017 at 11:44. |
3rd March 2017, 14:11 | #25737 | Link | |
3rd March 2017, 14:32 | #25738 | Link | |
[[Options] VERSION=0.50.0.23 ENCODER=0 MODE=3 ENCODE_QUALITY=3 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUDIO_TO_KEEP=fra;fre; SUBS_TO_KEEP=fra;fre; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AUDIO_DRC=0 DECODER=0 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=1 BDMV_CERT_ONLY=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=3000 TARGET_SIZE=47366 MOVIEONLY_TYPE=11 ALTCRF=20 ALT_TARGET=1900 ALT_CRF_TARGET=2500 ALTMETHOD=3 ALTAUTOCROP=0 AUTO_BURN=2 QUICK_EXTRAS=0 VERBOSE_STATUS=1 AVSFilter01=crop(0,136,1920,804) [Paths] SOURCE_PATH=V:\IMPORTS\BRAVE\ WORKING_PATH=V:\ Last edited by thekiller; 3rd March 2017 at 15:30. |
3rd March 2017, 15:31 | #25739 | Link |
@thekiller
No. That's not how you do it. 1. You go to the SETUP dialog (from the Settings menu). 2. Then click on "Use AVS Filters during encoding". 3. Within the editor dialog, just at the text: Crop(0,140,1920,800) 4. Save it. |
