8th November 2013, 07:30 | #641 | Link |
Why TsMuxer not recognizing this video file:
Hope it will be fixed in next build. Code:
Format : MPEG-TS File size : 135 MiB Duration : 1mn 21s Overall bit rate mode : Variable Overall bit rate : 13.8 Mbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : Main@High Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=15 Codec ID : 2 Duration : 1mn 21s Bit rate mode : Variable Bit rate : 12.7 Mbps Maximum bit rate : 20.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.204 Time code of first frame : 00:00:00;00 Time code source : Group of pictures header Stream size : 124 MiB (92%) Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : E-AC-3 Format/Info : Audio Coding 3 Format settings, Endianness : Big Codec ID : 129 Duration : 1mn 21s Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 4.36 MiB (3%) |
8th November 2013, 17:09 | #643 | Link | |||
I have provided correct file example Quote:
8th November 2013, 22:26 | #647 | Link | |
if I use the videostreams (AVC/MVC) from the original BD or an un-tagged mkv video stream then it works... so tsmuxer should look out for mkv tags and/or covers and remove them before muxing... |
9th November 2013, 14:08 | #648 | Link |
Compatible?
tsMuxer 2.1.6(b) seems no longer to accept "old" .meta, like
MUXOPT --no-pcr-on-video-pid --new-audio-pes --avchd --vbr --custom-chapters=00:00:00.000;00:12:13.333;00:23:37.375;00:33:41.208;00:52:01.583;00:59:13.583;01:11:16.916;01:21:51.708;01:31:41.875;01:44:23.083;01:55:19.833;02:10:40.375;02:16:23.125;02:20:13.166 --vbv-len=500 V_MPEG4/ISO/AVC, "C:\TEMP\VID_00007.AVS.264", fps=24, insertSEI, contSPS, track=4113 A_AC3, "C:\TEMP\AUD_00007_4352.AC3", lang=deu A_AC3, "C:\TEMP\AUD_00007_4353.AC3", lang=eng S_HDMV/PGS, "C:\TEMP\00007.track_4608.SUP",fps=24,lang=deu |
9th November 2013, 16:44 | #650 | Link |
Are these normal subtitle with sup extension and audio files. I would give it a try as well and see what happens. Just to make we are on same page you first combine mvc + h.264 files and then import inside tsmuxer to add audio and subtitle to it.
9th November 2013, 17:15 | #651 | Link | |
I have muxed the video stream from the mkv with transcoded audio and pgs streams...all streams are in the iso , but the video stream is not mentioned in the mpls... Last edited by arrgh; 9th November 2013 at 17:19. |
9th November 2013, 23:18 | #652 | Link |
froggy1
Looks like font doesn't contains symbols which present in a srt track. Please, check it. Sharc Unfortunatly, I lost latest version of source file for DVD subtitles decodig (SUP extension). I just disabled SUP support for a while (in all versions since 10.11.x) arrgh Is source mkv was detected as AVC + MVC tracks? Or two AVC tracks? It can't be muxed to ISO correctly If second option. Last edited by physic; 9th November 2013 at 23:20. |
10th November 2013, 01:28 | #654 | Link |
Speaking of super old bugs, could we get a fix for compressed headers that cause this bug, please? This has been plaguing the community for years now:
"Matroska parse error: invalid H264 NAL unit size. NAL unit truncated." I could eliminate a bunch of automation with this one minor detail. I'm begging. Literally. |
10th November 2013, 12:08 | #655 | Link |
@HWK
You can combine both mvc and .264 inside tsmuxer but here the problem is if we combine and later on we want this 3dm2ts files to be joined together than there is error as the file will not play properly from where it is joined and also i had found out that if both the files is out of tsmuxer combined and is 3dm2ts we can join it easily and will play fine but if u r going to change its audio and add subtitles than the file will play again with errors. |
10th November 2013, 14:06 | #656 | Link |
tsMuxeR 2.1.8(b) is ready:
windows 32 bit: tsMuxeR_2.1.8(b).zip linux 32 bit: tsMuxeR_2.1.8(b).tar.gz MacOS 10.8 (64 bit): tsMuxeR_2.1.8(b).dmg version 2.1.8(b) - Fixed join files problem with True-HD track - introduce MAC build |
