Old 15th June 2024, 22:34   #20741  |  Link
chainring
chainring's Avatar
@essential,
Easiest way is to modify your Windows power plan.
Control Panel > Hardware and Sound > Choose a power plan > Change plan settings (I use "Balanced") > Change advanced power settings > Processor power management > Maximum processor state > set to 99%.
The six machines I have participating in DE mode used to sound like a vortex, all spun up to 100%. Now, with them all at 99%, it's nice and quiet and I didn't lose any speed.
chainring is offline   Reply With Quote
Old 16th June 2024, 02:40   #20742  |  Link
essential
Originally Posted by chainring View Post
@essential,
Nice, thank you. I will try that.
essential is offline   Reply With Quote
Old 18th June 2024, 02:30   #20743  |  Link
rlev11
@essential,
Agree with this, have done this in the past and I agree, didn't notice any real encoding performance drop. maybe a few fps at most. Will really help lowering cpu temperatures
What setting it to 99% does is limit the cpu's from going into their turbo or boost modes. Will just run at the stock max frequency.
Should be able to find instructions on the web, I don't remember now anymore how I did it, but I ended up making 2 power plan desktop shortcuts, 1 for 100% and 1 for 99%. made it easy to switch back and forth just by clicking the shortcut.
rlev11 is offline   Reply With Quote
Old 19th June 2024, 07:59   #20744  |  Link
Exactly at 99% of the stock CPU clock. (on my cpu)
I wonder if the same rule applies to for example Intel 14900k where base clock is just 2GHz?
Old 30th June 2024, 12:48   #20745  |  Link
userx
userx's Avatar
issues with attachment parsing
  1. Is there a setting to switch off attachment parsing in general?
  2. Encountered issues with attached fonts and whitespaces, so MKVExtract would fail.
MKVExtract.json
  "<REMOVED>",
  "tracks",
  "1:D:\\Temp\\RipBot264temp\\job1082\\1_audio_German_DEFAULT.aac",
  "2:D:\\Temp\\RipBot264temp\\job1082\\2_audio_Japanese.aac",
  "3:D:\\Temp\\RipBot264temp\\job1082\\1_subtitles_German_DEFAULT_FORCED.ass",
  "4:D:\\Temp\\RipBot264temp\\job1082\\2_subtitles_German_DELAY4460ms.ass",
  "5:D:\\Temp\\RipBot264temp\\job1082\\3_subtitles_English_DELAY4410ms.ass",
  "chapters",
  "-s",
  "D:\\Temp\\RipBot264temp\\job1082\\chapters.txt",
  "attachments",
  "1:D:\\Temp\\RipBot264temp\\job1082\\AmazonEmber_Bd.ttf",
  "2:D:\\Temp\\RipBot264temp\\job1082\\AmazonEmber_BdIt.ttf",
  "3:D:\\Temp\\RipBot264temp\\job1082\\AmazonEmber_Rg.ttf",
  "4:D:\\Temp\\RipBot264temp\\job1082\\AmazonEmber_RgIt.ttf",
  "5:D:\\Temp\\RipBot264temp\\job1082\\Tahoma.ttf",
  "6:D:\\Temp\\RipBot264temp\\job1082\\Georgia.ttf",
  "7:D:\\Temp\\RipBot264temp\\job1082\\Times",
  "New",
  "Roman.ttf",
  "8:D:\\Temp\\RipBot264temp\\job1082\\Times",
  "New",
  "Roman",
  "Bold.ttf",
  "9:D:\\Temp\\RipBot264temp\\job1082\\Trebuchet",
  "MS.ttf"
attachments.csv
"font/ttf";"D:\Temp\RipBot264temp\job1082\AmazonEmber_Bd.ttf"
"font/ttf";"D:\Temp\RipBot264temp\job1082\AmazonEmber_BdIt.ttf"
"font/ttf";"D:\Temp\RipBot264temp\job1082\AmazonEmber_Rg.ttf"
"font/ttf";"D:\Temp\RipBot264temp\job1082\AmazonEmber_RgIt.ttf"
"font/ttf";"D:\Temp\RipBot264temp\job1082\Tahoma.ttf"
"font/ttf";"D:\Temp\RipBot264temp\job1082\Georgia.ttf"
"application/x-truetype-font";"D:\Temp\RipBot264temp\job1082\Times New Roman.ttf"
"application/x-truetype-font";"D:\Temp\RipBot264temp\job1082\Times New Roman Bold.ttf"
"application/x-truetype-font";"D:\Temp\RipBot264temp\job1082\Trebuchet MS.ttf"
userx is offline   Reply With Quote
Old 30th June 2024, 13:58   #20746  |  Link
Send me mkv sample containing those attachments for testing purposes.
Old 6th July 2024, 04:37   #20747  |  Link
FTLOY
Friend of a friend..
FTLOY's Avatar
A month on since that last update, and I am still getting random AV alerts on Encoding Server, which can be a pain when it's quarantined mid encode (like it just did).
But other than that, things are running pretty sweet, despite what some say....
RipBot264 v1.27.3 (08-06-2024)
FTLOY is offline   Reply With Quote
Old 7th July 2024, 08:08   #20748  |  Link
Can't you just add encodingserver.exe to some whitelist in your AV?
Old 8th July 2024, 12:32   #20749  |  Link
FTLOY
FTLOY's Avatar
I have Googled how to do this with Defender, and it's not as easy as it sounds.
The problem is that when you get a notification that there's a problem, you can "Allow" it, but this isn't a permanent "Allow" like most other alerts...it just likes to repeat, every day or so.
Old 8th July 2024, 13:20   #20750  |  Link
Windows Defender should support exclusions.
Old 8th July 2024, 13:36   #20751  |  Link
FTLOY
FTLOY's Avatar
Thanks LigH,
I got close to those settings, but didn't find that one...I will have to remember that.
Cheers.
Old 9th July 2024, 01:22   #20752  |  Link
rlev11
What I did was open Defender, Then Virus and threat protection, Manage settings under Virus&threat protection settings, scroll to bottom and hit Add or remove exclusions under Exclusions, +add an exclusion.
I just excluded the ripbot folder. You can exclude files of folders from there.
Old 9th July 2024, 01:33   #20753  |  Link
FTLOY
FTLOY's Avatar
Yep, that's what I ended up doing, I just wasn't 100% sure where this option was.
But we really shouldn't need to do this, it shouldn't have happened in the first place
Old 12th July 2024, 05:34   #20754  |  Link
FTLOY
FTLOY's Avatar
Hi Atak,
An interesting request (problem / dilemma)...
I have some .mov files created with DaVinci Resolve (below, MediaInfo)
I can load them into RB, but they do not encode with DE. (haven't tried them in single mode)
Not sure if it's an x265 limitation (or it needs specific commands)
x265 [FLAW]: unable to open input file <->
OR
y4m [FLAW]: bad sequence header magic
x264 [FLAW]: could not open input file `-'
But how could I retain that very high Bitrate ??
Video
Format                                   : CineForm
Codec ID                                 : CFHD
Codec ID/Info                            : CineForm High-Definition (HD) wavelet codec
Duration                                 : 1 h 20 min
Bit rate                                 : 1 110 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Frame rate                               : 60.000 FPS
Chroma subsampling                       : 4:2:2
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 2.230
Stream size                              : 621 GiB (100%)
Encoded date                             : 2024-07-11 03:50:31 UTC
Tagged date                              : 2024-07-11 03:50:31 UTC
Color primaries                          : Display P3
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.709
Old 12th July 2024, 09:41   #20755  |  Link
Not sure what "DE" means in your case...
DaVinci has a CineForm codec to export videos in CineForm HD format. But RipBot cannot use the codec which is built into DaVinci to decode that CineForm video again; you need a source filter for Avisynth which is able to decode the CineForm HD format, which may not be the case on your system. So you can probably not use the CineForm HD video format as intermediate exchange format, but a different one which is also supported by Avisynth source filters.
