Old 15th June 2024, 09:57   #31721  |  Link
MrVideo
MrVideo's Avatar
You may want to look at some of the options available directly via NVENCC (using ENC_CUSTOM=) at this link -- there are quite a few things you can do directly that AVISYNTH does for you. One thing to look at, though is the order of any preprocessing (--vpp) options. For example, one annoying thing I found is that the output resizing happens before padding. So if you wanted to change a 4:3 source into a 16:9 1080p output, for example, you would have to do this:
--output-res 1440x1080 --vpp-pad 240,0,240,0
Thanks for the update. I will certainly dig into this.
Old 16th June 2024, 03:25   #31722  |  Link
MrVideo
MrVideo's Avatar
I'm not sure what I am doing wrong, but when I do
ENC_CUSTOM=--output-res 2880x2160 --vpp-pad 480,0,480,0
or
ENC_CUSTOM=--vpp-pad 480,0,480,0
The resulting video in both cases is 2880x2160. The padding was never added.
UPDATE: I just looked at the NV last command file and the --vpp-pad is nowhere to be found. The 2nd example above was what I used in this case.
Old 16th June 2024, 05:59   #31723  |  Link
iambryanknowles
For IMPORT_PAL_TO_FILM=1, it seems that the video frame rate changes, but that the audio doesn't reencode to match. Is that handled by another option, or is that something that can be implemented in the new release?
Edit: Tested this with PCM afterwards and that worked, so I think it's at odds with "don't reencode ac3".
When importing a Pal to Film file, the chapters don't seem to be adjusted.
Also, when PAL is imported as film this way, it is automatically resized in avisynth, regardless of Scale SD to 720/1080. Is there a chance you could allow that scaling directly from the PAL frame size?
iambryanknowles is offline   Reply With Quote
Old 16th June 2024, 13:19   #31724  |  Link
or
You can't put two ENC_CUSTOM lines. When you do, the first one is the only one that is applied. But the first line looks like it should work. Look through our INI and make sure there isn't more than one.
Old 16th June 2024, 13:23   #31725  |  Link
If the frame rate is changed, then the audio definitely has to be adjusted too -- so the AC3 has to be reencoded. I thought I'd made the code force the reencode, but I'll look at it and see.
Old 16th June 2024, 13:58   #31726  |  Link
MrVideo
MrVideo's Avatar
Thanks for the tip about the ENC_CUSTOM. It is the first one in the file. All of the others are commented out anyway. I put it back to the single line and ran it again. Still no joy, but:
"C:\BD_Rebuilder-0.61.25\tools\nvenc\nvencc.exe" --avhw --output-res 2880x2160
--vpp-pad 480,0,480,0 --interlace auto --vpp-deinterlace normal -i "E:\Doctor_Who-test.mkv"
--codec h265 --preset default --profile main10 --output-depth 10 --chromaloc auto --colorprim auto
--transfer auto --colormatrix auto --master-display copy --max-cll copy --qp-min 0 --multipass 2pass-full
--vbr 4000 --aq --aq-temporal --aud --pic-struct --vbv-bufsize 45000 --max-bitrate 48000 --lookahead 24
--no-b-adapt --gop-len 24 --audio-copy 1 --sub-copy --chapter-copy
-o "E:\BD-REBUILDER\WORK\Doctor_Who-test.mkv"
Notice how the pad is there. I use it all the time to add letterbox black to videos, so I know it can work.
UPDATE: I did some more digging. I took the output from the run and placed it into VideoReDo. The 4:3 image was squished horizontally. It makes no difference if the pad was before, or after, the res value. What I discovered makes perfect sense. And what was that? The output res doesn't have the padding added to it to make it 3840. The output res is what it actually puts out. So, what it does is take the output res and subtract any padding and upsizes that value. In this case 2880. Within an AVISynth script, you add padding to the original file and then upres it to the final size. I've never tried upressing to a 4:3 size and then adding padding.
So, one has to remember that the output res must be the final result and you figure out what the padding needs to be to get to that final size.
Learn something new every day.
Old 16th June 2024, 23:45   #31727  |  Link
Lathe
Lathe's Avatar
I'm wondering if BDRB does this or if actually ANYTHING does this...
I have a nice MKV file of a full movie, all encoded to be Blu-ray compliant. It has 4 audio tracks, the main audio and 3 commentary tracks. Now, with MKVMerge, you can see every track, nicely labeled for what it is. Main audio, director's commentary, 2nd commentary with so and so, and 3rd commentary with that person. AND, all the subs are taken from 3 different sources and I think go with all the commentary tracks as well as the main audio.
But, here's the catch... As soon as I use TSMuxer to mux it into BDMV folder form to burn to Blu-ray, WHAM! all the nice titles of each track are totally lost and after muxing it merely says 'Track 1', 'Track 2', etc...
IS there ANY way at all with BDRB or otherwise to preserve all the excellent titles of each stream when you mux the MKV file into a Blu-ray folder? I have not found a way to do that which really sux because it sure would be NICE to then play the resulting Blu-ray and see all the tracks and their names so you know which is which.
Any suggestions? Thanks!
***EDIT
Here is what I'm seeing when the file is in its MKV form. This is ALL LOST, any way to keep it?
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Duration : 1 h 38 min
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 449 MiB (2%)
Title : Main
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Dialog Normalization : -31 dB
dialnorm_Average : -31 dB
dialnorm_Minimum : -31 dB
dialnorm_Maximum : -31 dB
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 1 h 34 min
Bit rate : 192 kb/s
Stream size : 130 MiB (1%)
Title : Commentary by director John Dahl, writer Rick Dahl and editor Scott Chestnut
Language : English
Default : No
Forced : No
compr : -7.50 dB
dynrng : -7.50 dB
ltrtcmixlev : -3.0 dB
ltrtsurmixlev : -3.0 dB
lorocmixlev : -3.0 dB
lorosurmixlev : -3.0 dB
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Stream size : 135 MiB (1%)
Title : Commentary by historian Alain Silver and filmmaker Christopher Coppola
Language : English
Default : No
Forced : No
compr : -0.28 dB
Audio #4
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Stream size : 304 MiB (2%)
Title : Commentary by Mondo Digital's Nathaniel Thompson
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 30 min
Bit rate : 40 b/s
Frame rate : 0.183 FPS
Count of elements : 993
Stream size : 26.5 KiB (0%)
Title : US / Vinegar Syndrome
Language : English (US)
Default : No
Forced : No
Text #2
Format : UTF-8
Bit rate : 39 b/s
Frame rate : 0.145 FPS
Count of elements : 787
Stream size : 25.9 KiB (0%)
Title : UK / Plan B Entertainment
Language : English (GB)
Default : No
Forced : No
Text #3
Format : UTF-8
Duration : 1 h 37 min
Bit rate : 46 b/s
Frame rate : 0.220 FPS
Count of elements : 1291
Stream size : 33.5 KiB (0%)
Title : SDH / US / Vinegar Syndrome
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 44 b/s
Frame rate : 0.212 FPS
Count of elements : 1249
Stream size : 31.8 KiB (0%)
Title : SDH / US / Umbrella Entertainment
Default : No
Forced : No
Text #5
Format : UTF-8
Duration : 1 h 32 min
Bit rate : 39 b/s
Frame rate : 0.147 FPS
Count of elements : 814
Stream size : 26.6 KiB (0%)
Title : SDH / UK / Plan B Entertainment
Default : No
Forced : No
***EDIT 2
Okay, here is the metadata shown in TSMuxer. Is there a way to add the titles to this so that it will show when the resulting Blu-ray is burned to disc?
MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500
V_MPEG4/ISO/AVC, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv", insertSEI, contSPS, track=1, lang=eng
A_AC3, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv", track=2, lang=eng
A_AC3, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv", track=3, lang=eng
A_AC3, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv", track=4, lang=eng
A_AC3, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv", track=5, lang=eng
S_TEXT/UTF8, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv",font-name="Arial",font-size=65,font-color=0xffffffff,bottom-offset=24,font-border=5,text-align=center,video-width=1920,video-height=1038,fps=23.976, track=6, lang=eng
S_TEXT/UTF8, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv",font-name="Arial",font-size=65,font-color=0xffffffff,bottom-offset=24,font-border=5,text-align=center,video-width=1920,video-height=1038,fps=23.976, track=7, lang=eng
S_TEXT/UTF8, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv",font-name="Arial",font-size=65,font-color=0xffffffff,bottom-offset=24,font-border=5,text-align=center,video-width=1920,video-height=1038,fps=23.976, track=8, lang=eng
S_TEXT/UTF8, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv",font-name="Arial",font-size=65,font-color=0xffffffff,bottom-offset=24,font-border=5,text-align=center,video-width=1920,video-height=1038,fps=23.976, track=9, lang=eng
S_TEXT/UTF8, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv",font-name="Arial",font-size=65,font-color=0xffffffff,bottom-offset=24,font-border=5,text-align=center,video-width=1920,video-height=1038,fps=23.976, track=10, lang=eng
S_TEXT/UTF8, "D:\__MKVMerge\Red.Rock.West.1993.1080p.BluRay.FLAC.2.0.x264-c0kE.mkv",font-name="Arial",font-size=65,font-color=0xffffffff,bottom-offset=24,font-border=5,text-align=center,video-width=1920,video-height=1038,fps=23.976, track=11, lang=vie
I guess not...
Old 17th June 2024, 21:56   #31728  |  Link
I guess not...
I can tell you I don't know how. I'll look around and see if I can find anything.
Old 18th June 2024, 03:52   #31729  |  Link
Lathe
Lathe's Avatar
Oh, thanks man! Didn't expect a reply from The Man himself!
Old 18th June 2024, 13:09   #31730  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
I think there is no provision in .m2ts to have property <title>
It might be able to shoehorn something in somewhere, but which application shall read that ?
Old 19th June 2024, 00:44   #31731  |  Link
Lathe
Lathe's Avatar
Appreciate the input. Just seems to me like something that would be very basic. Now, when playing commercial Blu-rays, I THINK they show titles to the tracks. Might hafta start ripping everything to MKV so I can display the track titles (nah...)
Old 20th June 2024, 02:34   #31732  |  Link
MrVideo
MrVideo's Avatar
Does anyone know how to repair subtitle tracks that do not have the dts in sequential order? The NV encoder bitches about the subtitle being wrong and aborts. Funny thing is is that the program that created the MKV file in the first place didn't bitch about it. Using a later tsmuxer beta to rewrap to m2ts doesn't fix it (it was a long shot).
At the moment I'm running the program without saving the subtitle streams. Personally I do not really care about them.
Old 22nd June 2024, 21:32   #31733  |  Link
New Release of BD-Rebuilder (v0.62.01)
I have updated the first post of this thread with a link to the latest release (v0.62.01) of BD Rebuilder. Changes for this release:
- Added support for GPU encoding using Intel
  GPUs (Quick Sync).  Note that your GPU must
  be advanced enough, must have support enabled
  and drivers installed. This feature is still
  in the experimental stages and needs testing.
  If you would like to test it, you can enable
  it by adding "QSYNC_TEST=1" to the "Options"
  area of BDREBUILDER.INI. Please report your
  findings on the DOOM9 BD Rebuilder Bug
  Reporting site.
- Replaced NVENCCRE with GPUENCCRE so that it
  supports both NVIDIA and INTEL GPUs.
- Set GPUENCCRE to remux MKV output via
  MKVMERGE by default to low the probability
  of errors in muxing.  It can be changed
  via the OUTPUT/SPECIAL PROCESSING menu.
- Corrected NVENCCRE error (now GPUENCCRE)
  that caused subtitles to not be handled
  properly when using "Keep Original Video
  (Intact)" mode.
- Fixed an error when importing files that
  include Dolby E-AC3/ATMOS or TRUEHD that
  could result in stereo or mono output.
- Added a text clarifier when imports fail
  due to illegal character(s) in the path or
  filename.
- Fixed an issue in which converting DVD/BD
  to SRT was failing due to changes in the
  newer version of MKVEXTRACT.
- Fixed an issue in import resizing of
  certain input file that use slight off size
  widths.
Old 22nd June 2024, 22:58   #31734  |  Link
Lowpro
  Reporting site.
  (Intact)" mode.
  filename.
  widths.
Very nice. Very nice, indeed. Thanks!
Lowpro is offline   Reply With Quote
Old 23rd June 2024, 16:00   #31735  |  Link
musiclover
The release of the new GPUENCC doesn't work with Nvencc for me. I keep getting the message "- ERROR -- Encode failed. Job aborted." right at the start of each job. While NVENCCRE handles these jobs OK.
Is GPUENCC supposed to work at once or does it need changes in the GPUENCC.INI file?
[06.23.24] GPU Reencoder v0.01.12
[16:50:06]Start Job [1 of 1]
- Reencoding "The Analogues at Pinkpop 2024.mp4"
-- Collecting input file information...
-- Input : AVC, 1920x1080, 25fps
-- Output: H264 (AVC), No Resize, Keep fps, CQ 23
[06.23.24] NVENCC Reencoder v0.10.15
[16:52:00]Start Job [1 of 1]
[16:58:14]Job Completed [1 of 1]
Old 23rd June 2024, 20:13   #31736  |  Link
Hmmm... I thought I'd left that code untouched -- but I just tried a job and got the same result. I'll find out what I did and post a new version today.
Old 23rd June 2024, 20:41   #31737  |  Link
It was a dumbass mistake (I'm known for those). I've fixed it and will post a new version in a few minutes.
Old 23rd June 2024, 20:51   #31738  |  Link
New Release of BD Rebuilder (v0.62.02)
I have updated the first post of this thread with a link to the latest release of BD Rebuilder (v0.62.02). Changes for this release (and v0.62.01):
June 23rd, 2024 - v0.62.02
- Fixed an error that caused GPUENCCRE to fail
  when attempting to use NVIDIA. (v0.62.02)
  Reporting site.
  (Intact)" mode.
  filename.
  widths.
Old 23rd June 2024, 21:18   #31739  |  Link
musiclover
Thank you for the quick fix.
I used the fixed version to do the same job twice. First using NVIDIA Encoding GPU and the second time using INTEL Encoding GPU.
[06.23.24] GPU Reencoder v0.01.13
[22.03.55]Start Job [1 of 1]
- Reencoding "Doctor Who 2023 S01E08 Empire of Death 720p DSNP WEB-DL DD 5 1 H 264-playWEB.mkv"
-- Input : AVC, 1280x720, 25fps
-- Remuxing output with MKVMERGE
[22.06.45]Job Completed [1 of 1]
[22.07.19]Start Job [1 of 1]
[22.10.07]Job Completed [1 of 1]
Both GPU's were equally quick doing the job. And the results were identical in size.
Alas the log does not indicate which GPU is used.
Old 23rd June 2024, 21:24   #31740  |  Link
Lathe
Lathe's Avatar
'THE MAN' does not make dumbass mistakes...
Our Faith will not be shaken Sir...
