#1301 | Link |
Life's clearer in 4K UHD
Are your HFYU files in a container?
#1302 | Link |
In my quick test, I exported a video to FFmpeg's Huffyuv in YUV 4:2:0 as well as 4:2:2, each with 8 bit precision, both in an AVI container (where Huffyuv video is most common). VLC 3.0.20 did not support either.
#1304 | Link |
MPC-BE 1.8.5 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
#1308 | Link | |
https://sourceforge.net/p/vdfiltermo...i/master/tree/
#1310 | Link |
An updated plugin has been posted in the VideoHelp forum, did not test yet...
#1311 | Link | |
#1312 | Link | |
new avlib-1.vdplugin + ffmpeg DLLs - 101 MB
#1313 | Link |
Works for me - when I select "Show all formats" at the bottom of the codecs list and allow color space conversion as necessary. When the option is set to "Similar to source: [CS]", some codecs may be hidden when they don't support the current color space.
The codecs are now (dynamically linked) in avcodec-61.dll and avformat-61.dll in the main directory, not in plugins64. |
#1314 | Link | |
I have a question: in the 10-bit version, shouldn't CRF have a range of 0-63 (or -12-51), instead of 0-51? (similar question for qp range) ![]() In Help of x264 CLI: Code:
Ratecontrol: -q, --qp <integer> Force constant QP (0-81, 0=lossless) -B, --bitrate <integer> Set bitrate (kbit/s) --crf <float> Quality-based VBR (-12-51)[23.0] Code:
Ratecontrol: -q, --qp <integer> Force constant QP (0-51, 0=lossless) -B, --bitrate <integer> Set bitrate (kbit/s) --crf <float> Quality-based VBR (0-51) [23.0] Last edited by blob2500; 26th July 2024 at 09:34. |
#1316 | Link |
How to concat two filter sequences?
By the time I built some filter sequences that perform special tasks.
For example contrast mask filter (a sequence of 8 filter ops). I saved them as .vdscript files. Now from time to time it happens that I need to perform two or more of these sequences. I haven't found a way to do this in VD2 GUI, but instead copy the .vdscript files into a single file. There surely must be a more elegant way for this common task? Something with jobs, projects or that strange "Save" button in filter dialog? |
#1318 | Link |
I remember some people advertising it for encoding cartoons because it can handle the smooth colour ramps between the outlines better... I can't report from own experience, though.
#1319 | Link | |
Acid fr0g
You can’t create data where there isn’t. It’s just a matter of better compression. HEVC overcame all that mess.
@turment on Telegram |
#1320 | Link |
I was just asking those who are more expert than me if the x264vdplugin-10-bit interface is correct or incomplete regarding the qp and crf range, not if it makes sense or not to use 10-bit depth with h.264
